BSOD Win 7 64bit 3b and 1e
biggyk
Well-Known Member
Lately I have been having mad bsod show up after I play games. Its fine will im playing but then 10 mins or so after I close down the game it will crash. I have made sure I have updated video and audio drivers but it doesnt seem to help it. It may be a heat issue but i dont see my temp go up past 50 if that. Here is the dump files below for you to see. I feel lucky being able to post this without crashing.
TIA
Biggyk
usbfilter usbfilter.sys Fri Apr 03 07:39:51 2009
Update your above AMD USB filter driver by updating to the latest chipset drivers from your motherboard's website.
biggyk
Well-Known Member
K, il download it now and check back the next time I play a game. Thanks
Btw Im running GTX460 not onboard video.
Right, usbfilter.sys is AMD USB Filter Driver residing in your system. It is not a microsoft driver. Therefore, you should update it:
AMD.com | Support & Downloads
You may also want to check for the latest versions:
xusb21.sys Sat Feb 17 04:43:15 2007
XBox USB wireless controller
Software Download
Update or uninstall if not using it.
dc3d.sys Wed Nov 04 04:55:41 2009
Microsoft Hardware Wireless Mouse and Keyboard Device
AtiPcie.sys Tue May 05 18:00:22 2009
ATI PCIE Driver for ATI PCIE chipset
Global Provider of Innovative Graphics, Processors and Media Solutions | AMD
sptd.sys Sun Oct 11 23:55:14 2009
Daemon Tools/Alcohol
DuplexSecure - Downloads
092210-22276-01.dmp
BugCheck 3B, {c0000005, fffff96000162bf4, fffff880081e30d0, 0}
Probably caused by : win32k.sys ( win32k!TimersProc+c8 )
SYSTEM_SERVICE_EXCEPTION (3b)
FAILURE_BUCKET_ID: X64_0x3B_win32k!TimersProc+c8
092210-16208-01.dmp, 92210-15740-01.dmp
092210-16224-01.dmp
KMODE_EXCEPTION_NOT_HANDLED (1e)
FAILURE_BUCKET_ID: X64_0x1E_nt!KiKernelCalloutExceptionHandler+e
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [F:\a\Minidump\092210-16224-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (3 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`03066000 PsLoadedModuleList = 0xfffff800`032a3e50
System Uptime: 0 days 14:25:16.950
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 1E, {0, 0, 0, 0}
Probably caused by : ntkrnlmp.exe ( nt!KiKernelCalloutExceptionHandler+e )
Followup: MachineOwner
1: kd> !analyze -v
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: 0000000000000000, The exception code that was not handled
Arg2: 0000000000000000, The address that the exception occurred at
Debugging Details:
EXCEPTION_CODE: (Win32) 0 (0) -                           .
FAULTING_IP:
+0
00000000`00000000 ??              ???
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  0000000000000000
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x1E
PROCESS_NAME:  System
CURRENT_IRQL:  2
EXCEPTION_RECORD:  fffff8800311b338 -- (.exr 0xfffff8800311b338)
ExceptionAddress: fffff800030e229b (nt!KiProcessTimerDpcTable+0x0000000000000063)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
TRAP_FRAME:  fffff8800311b3e0 -- (.trap 0xfffff8800311b3e0)
rax=0000000000000000 rbx=0000000000000000 rcx=0000000000010000
rdx=0005000400030002 rsi=0000000000000000 rdi=0000000000000000
rip=fffff800030e229b rsp=fffff8800311b570 rbp=0000000000000001
 r8=00000000169f8c63  r9=0000000001cb5a6e r10=fffff80003066000
r11=fffff8800311b5b0 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl zr na po nc
nt!KiProcessTimerDpcTable+0x63:
fffff800`030e229b ff5308          call    qword ptr [rbx+8] ds:a48c:00000000`00000008=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff800030ce46e to fffff800030d6710
STACK_TEXT:
fffff880`0311a428 fffff800`030ce46e : 00000000`00000000 00000000`00000000 fffff880`0311aba0 fffff800`03103668 : nt!KeBugCheck
fffff880`0311a430 fffff800`030fc40d : fffff800`032e4b7c fffff800`0321ee84 fffff800`03066000 fffff880`0311b338 : nt!KiKernelCalloutExceptionHandler+0xe
fffff880`0311a460 fffff800`03103a90 : fffff800`03225b14 fffff880`0311a4d8 fffff880`0311b338 fffff800`03066000 : nt!RtlpExecuteHandlerForException+0xd
fffff880`0311a490 fffff800`031109ef : fffff880`0311b338 fffff880`0311aba0 fffff880`00000000 00000000`00000000 : nt!RtlDispatchException+0x410
fffff880`0311ab70 fffff800`030d5d82 : fffff880`0311b338 fffff880`0311b600 fffff880`0311b3e0 00000000`00000000 : nt!KiDispatchException+0x16f
fffff880`0311b200 fffff800`030d468a : fffff880`009e8180 fffff800`030e2de0 ffffffff`feced300 fffff880`009e8180 : nt!KiExceptionDispatch+0xc2
fffff880`0311b3e0 fffff800`030e229b : 00000000`00000000 fffffa80`05fc8d80 00000000`009eca00 00000000`00000003 : nt!KiGeneralProtectionFault+0x10a
fffff880`0311b570 fffff800`030e1dd6 : fffff880`09bbead0 fffff880`09bbead0 00000000`00000000 00000000`00000000 : nt!KiProcessTimerDpcTable+0x63
fffff880`0311b5e0 fffff800`030e24be : 00000078`e0e9f4b7 fffff880`0311bc58 00000000`0032c7f4 fffff880`009ec408 : nt!KiProcessExpiredTimerList+0xc6
fffff880`0311bc30 fffff800`030e1cb7 : 00000024`ccb6dfc1 00000024`0032c7f4 00000024`ccb6df8e 00000000`000000f4 : nt!KiTimerExpiration+0x1be
fffff880`0311bcd0 fffff800`030deeea : fffff880`009e8180 fffff880`009f2f80 00000000`00000000 fffff880`14091bdc : nt!KiRetireDpcList+0x277
fffff880`0311bd80 00000000`00000000 : fffff880`0311c000 fffff880`03116000 fffff880`0311bd40 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`030ce46e 90              nop
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt!KiKernelCalloutExceptionHandler+e
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4c1c44a9
fffff800`00ba7000 fffff800`00bb1000   kdcom    kdcom.dll    Tue Jul 14 04:31:07 2009 (4A5BDFDB)
fffff800`0301d000 fffff800`03066000   hal      hal.dll      Tue Jul 14 04:27:36 2009 (4A5BDF08)
fffff800`03066000 fffff800`03642000   nt       ntkrnlmp.exe Sat Jun 19 07:16:41 2010 (4C1C44A9)
fffff880`00c29000 fffff880`00c36000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Tue Jul 14 04:29:09 2009 (4A5BDF65)
fffff880`00c36000 fffff880`00c4a000   PSHED    PSHED.dll    Tue Jul 14 04:32:23 2009 (4A5BE027)
fffff880`00c4a000 fffff880`00ca8000   CLFS     CLFS.SYS     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00ca8000 fffff880`00d68000   CI       CI.dll       Tue Jul 14 04:32:13 2009 (4A5BE01D)
fffff880`00d68000 fffff880`00db4000   fltmgr   fltmgr.sys   Tue Jul 14 02:19:59 2009 (4A5BC11F)
fffff880`00db4000 fffff880`00df9000   a2gy7z8f a2gy7z8f.SYS Wed Jul 15 00:12:55 2009 (4A5CF4D7)
fffff880`00e00000 fffff880`00e5c000   volmgrx  volmgrx.sys  Tue Jul 14 02:20:33 2009 (4A5BC141)
fffff880`00e5c000 fffff880`00e63000   pciide   pciide.sys   Tue Jul 14 02:19:49 2009 (4A5BC115)
fffff880`00e63000 fffff880`00e73000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`00e73000 fffff880`00e8d000   mountmgr mountmgr.sys Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00e8d000 fffff880`00e96000   atapi    atapi.sys    Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`00e96000 fffff880`00ec0000   ataport  ataport.SYS  Tue Jul 14 02:19:52 2009 (4A5BC118)
fffff880`00ec0000 fffff880`00ecb000   amdxata  amdxata.sys  Tue May 19 20:56:59 2009 (4A12F2EB)
fffff880`00ecb000 fffff880`00edf000   fileinfo fileinfo.sys Tue Jul 14 02:34:25 2009 (4A5BC481)
fffff880`00ee2000 fffff880`00f86000   Wdf01000 Wdf01000.sys Tue Jul 14 02:22:07 2009 (4A5BC19F)
fffff880`00f86000 fffff880`00f95000   WDFLDR   WDFLDR.SYS   Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00f95000 fffff880`00fc8000   pci      pci.sys      Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00fc8000 fffff880`00fdd000   volmgr   volmgr.sys   Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`01000000 fffff880`01057000   ACPI     ACPI.sys     Tue Jul 14 02:19:34 2009 (4A5BC106)
fffff880`01057000 fffff880`01061000   msisadrv msisadrv.sys Tue Jul 14 02:19:26 2009 (4A5BC0FE)
fffff880`01061000 fffff880`0106e000   vdrvroot vdrvroot.sys Tue Jul 14 03:01:31 2009 (4A5BCADB)
fffff880`0106e000 fffff880`01083000   partmgr  partmgr.sys  Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`01083000 fffff880`0108c000   compbatt compbatt.sys Tue Jul 14 02:31:02 2009 (4A5BC3B6)
fffff880`01091000 fffff880`011b7000   sptd     sptd.sys     Sun Oct 11 23:55:14 2009 (4AD24632)
fffff880`011b7000 fffff880`011c0000   WMILIB   WMILIB.SYS   Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`011c0000 fffff880`011ef000   SCSIPORT SCSIPORT.SYS Tue Jul 14 03:01:04 2009 (4A5BCAC0)
fffff880`011ef000 fffff880`011fb000   BATTC    BATTC.SYS    Tue Jul 14 02:31:01 2009 (4A5BC3B5)
fffff880`01200000 fffff880`01224000   rasl2tp  rasl2tp.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`0122c000 fffff880`013cf000   Ntfs     Ntfs.sys     Tue Jul 14 02:20:47 2009 (4A5BC14F)
fffff880`013cf000 fffff880`013df000   CompositeBus CompositeBus.sys Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`013df000 fffff880`013f5000   AgileVpn AgileVpn.sys Tue Jul 14 03:10:24 2009 (4A5BCCF0)
fffff880`01400000 fffff880`0144c000   volsnap  volsnap.sys  Tue Jul 14 02:20:08 2009 (4A5BC128)
fffff880`0144c000 fffff880`01469000   sbp2port sbp2port.sys Tue Jul 14 02:19:53 2009 (4A5BC119)
fffff880`01469000 fffff880`014a3000   rdyboost rdyboost.sys Tue Jul 14 02:34:34 2009 (4A5BC48A)
fffff880`014a3000 fffff880`014b0000   MDPMGRNT MDPMGRNT.SYS Wed Sep 23 22:23:04 2009 (4ABA7598)
fffff880`014b5000 fffff880`01513000   msrpc    msrpc.sys    Tue Jul 14 02:21:32 2009 (4A5BC17C)
fffff880`01513000 fffff880`0152d000   ksecdd   ksecdd.sys   Tue Jul 14 02:20:54 2009 (4A5BC156)
fffff880`0152d000 fffff880`015a0000   cng      cng.sys      Tue Jul 14 02:49:40 2009 (4A5BC814)
fffff880`015a0000 fffff880`015b1000   pcw      pcw.sys      Tue Jul 14 02:19:27 2009 (4A5BC0FF)
fffff880`015b1000 fffff880`015bb000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 02:19:45 2009 (4A5BC111)
fffff880`015bb000 fffff880`015f9000   1394ohci 1394ohci.sys Tue Jul 14 03:07:12 2009 (4A5BCC30)
fffff880`01600000 fffff880`01660000   NETIO    NETIO.SYS    Tue Jul 14 02:21:46 2009 (4A5BC18A)
fffff880`01660000 fffff880`0168b000   ksecpkg  ksecpkg.sys  Fri Dec 11 08:03:32 2009 (4B21E0B4)
fffff880`0168b000 fffff880`016d5000   fwpkclnt fwpkclnt.sys Tue Jul 14 02:21:08 2009 (4A5BC164)
fffff880`016d5000 fffff880`016e5000   vmstorfl vmstorfl.sys Tue Jul 14 02:42:54 2009 (4A5BC67E)
fffff880`016e5000 fffff880`016ed000   spldr    spldr.sys    Mon May 11 19:56:27 2009 (4A0858BB)
fffff880`016f9000 fffff880`017eb000   ndis     ndis.sys     Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`017eb000 fffff880`017fd000   mup      mup.sys      Tue Jul 14 02:23:45 2009 (4A5BC201)
fffff880`01802000 fffff880`019ff000   tcpip    tcpip.sys    Mon Jun 14 06:39:04 2010 (4C15A458)
fffff880`01a00000 fffff880`01a0d000   TDI      TDI.SYS      Tue Jul 14 02:21:18 2009 (4A5BC16E)
fffff880`01a0d000 fffff880`01a60000   MDFSYSNT MDFSYSNT.sys Thu Feb 04 17:14:15 2010 (4B6AE447)
fffff880`01a60000 fffff880`01a69000   hwpolicy hwpolicy.sys Tue Jul 14 02:19:22 2009 (4A5BC0FA)
fffff880`01a69000 fffff880`01aa3000   fvevol   fvevol.sys   Sat Sep 26 05:34:26 2009 (4ABD7DB2)
fffff880`01aa3000 fffff880`01ab9000   disk     disk.sys     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`01ab9000 fffff880`01ae9000   CLASSPNP CLASSPNP.SYS Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`01ae9000 fffff880`01af1000   AtiPcie  AtiPcie.sys  Tue May 05 18:00:22 2009 (4A005486)
fffff880`01b27000 fffff880`01b51000   cdrom    cdrom.sys    Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`01b51000 fffff880`01b5a000   Null     Null.SYS     Tue Jul 14 02:19:37 2009 (4A5BC109)
fffff880`01b5a000 fffff880`01b61000   Beep     Beep.SYS     Tue Jul 14 03:00:13 2009 (4A5BCA8D)
fffff880`01b61000 fffff880`01b6f000   vga      vga.sys      Tue Jul 14 02:38:47 2009 (4A5BC587)
fffff880`01b6f000 fffff880`01b94000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 02:38:51 2009 (4A5BC58B)
fffff880`01b94000 fffff880`01ba4000   watchdog watchdog.sys Tue Jul 14 02:37:35 2009 (4A5BC53F)
fffff880`01ba4000 fffff880`01bad000   RDPCDD   RDPCDD.sys   Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`01bad000 fffff880`01bb6000   rdpencdd rdpencdd.sys Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`01bb6000 fffff880`01bbf000   rdprefmp rdprefmp.sys Tue Jul 14 03:16:35 2009 (4A5BCE63)
fffff880`01bbf000 fffff880`01bca000   Msfs     Msfs.SYS     Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`01bca000 fffff880`01bdb000   Npfs     Npfs.SYS     Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`01bdb000 fffff880`01bf9000   tdx      tdx.sys      Tue Jul 14 02:21:15 2009 (4A5BC16B)
fffff880`02e00000 fffff880`02e1d000   parport  parport.sys  Tue Jul 14 03:00:40 2009 (4A5BCAA8)
fffff880`02e28000 fffff880`02eb2000   afd      afd.sys      Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`02eb2000 fffff880`02ef7000   netbt    netbt.sys    Tue Jul 14 02:21:28 2009 (4A5BC178)
fffff880`02ef7000 fffff880`02f00000   wfplwf   wfplwf.sys   Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`02f00000 fffff880`02f26000   pacer    pacer.sys    Tue Jul 14 03:09:41 2009 (4A5BCCC5)
fffff880`02f26000 fffff880`02f35000   netbios  netbios.sys  Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`02f35000 fffff880`02f52000   serial   serial.sys   Tue Jul 14 03:00:40 2009 (4A5BCAA8)
fffff880`02f52000 fffff880`02f6d000   wanarp   wanarp.sys   Tue Jul 14 03:10:21 2009 (4A5BCCED)
fffff880`02f6d000 fffff880`02f81000   termdd   termdd.sys   Tue Jul 14 03:16:36 2009 (4A5BCE64)
fffff880`02f81000 fffff880`02fd2000   rdbss    rdbss.sys    Tue Jul 14 02:24:09 2009 (4A5BC219)
fffff880`02fd2000 fffff880`02fde000   nsiproxy nsiproxy.sys Tue Jul 14 02:21:02 2009 (4A5BC15E)
fffff880`02fde000 fffff880`02fe9000   mssmbios mssmbios.sys Tue Jul 14 02:31:10 2009 (4A5BC3BE)
fffff880`02fe9000 fffff880`02ff8000   discache discache.sys Tue Jul 14 02:37:18 2009 (4A5BC52E)
fffff880`03800000 fffff880`03809000   wmiacpi  wmiacpi.sys  Tue Jul 14 02:31:02 2009 (4A5BC3B6)
fffff880`03809000 fffff880`038fd000   dxgkrnl  dxgkrnl.sys  Fri Oct 02 04:00:14 2009 (4AC5509E)
fffff880`038ff000 fffff880`03982000   csc      csc.sys      Tue Jul 14 02:24:26 2009 (4A5BC22A)
fffff880`03982000 fffff880`039a0000   dfsc     dfsc.sys     Tue Jul 14 02:23:44 2009 (4A5BC200)
fffff880`039a0000 fffff880`039b4000   CBDisk   CBDisk.sys   Wed Jan 13 11:15:47 2010 (4B4D8F43)
fffff880`039b4000 fffff880`039c5000   blbdrive blbdrive.sys Tue Jul 14 02:35:59 2009 (4A5BC4DF)
fffff880`039c5000 fffff880`039eb000   tunnel   tunnel.sys   Tue Jul 14 03:09:37 2009 (4A5BCCC1)
fffff880`039eb000 fffff880`03a00000   amdppm   amdppm.sys   Tue Jul 14 02:19:25 2009 (4A5BC0FD)
fffff880`04233000 fffff880`04262000   ndiswan  ndiswan.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`04262000 fffff880`0427d000   raspppoe raspppoe.sys Tue Jul 14 03:10:17 2009 (4A5BCCE9)
fffff880`0427d000 fffff880`0429e000   raspptp  raspptp.sys  Tue Jul 14 03:10:18 2009 (4A5BCCEA)
fffff880`0429e000 fffff880`042b8000   rassstp  rassstp.sys  Tue Jul 14 03:10:25 2009 (4A5BCCF1)
fffff880`042b8000 fffff880`042c3000   rdpbus   rdpbus.sys   Tue Jul 14 03:17:46 2009 (4A5BCEAA)
fffff880`042c3000 fffff880`042d2000   kbdclass kbdclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`042d2000 fffff880`042e1000   mouclass mouclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`042e1000 fffff880`042e2480   swenum   swenum.sys   Tue Jul 14 03:00:18 2009 (4A5BCA92)
fffff880`042e3000 fffff880`04326000   ks       ks.sys       Tue Jul 14 03:00:31 2009 (4A5BCA9F)
fffff880`04326000 fffff880`04338000   umbus    umbus.sys    Tue Jul 14 03:06:56 2009 (4A5BCC20)
fffff880`04338000 fffff880`04392000   usbhub   usbhub.sys   Tue Jul 14 03:07:09 2009 (4A5BCC2D)
fffff880`04392000 fffff880`0439d000   flpydisk flpydisk.sys Tue Jul 14 03:00:54 2009 (4A5BCAB6)
fffff880`0439d000 fffff880`043b2000   NDProxy  NDProxy.SYS  Tue Jul 14 03:10:05 2009 (4A5BCCDD)
fffff880`043b2000 fffff880`043c7000   lltdio   lltdio.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`043c7000 fffff880`043df000   rspndr   rspndr.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`05200000 fffff880`05223000   luafv    luafv.sys    Tue Jul 14 02:26:13 2009 (4A5BC295)
fffff880`05223000 fffff880`05244000   WudfPf   WudfPf.sys   Tue Jul 14 03:05:37 2009 (4A5BCBD1)
fffff880`05257000 fffff880`054aa700   RTKVHD64 RTKVHD64.sys Wed Jul 28 13:01:36 2010 (4C500000)
fffff880`054ab000 fffff880`054e8000   portcls  portcls.sys  Tue Jul 14 03:06:27 2009 (4A5BCC03)
fffff880`054e8000 fffff880`0550a000   drmk     drmk.sys     Tue Jul 14 04:01:25 2009 (4A5BD8E5)
fffff880`0550a000 fffff880`0550f200   ksthunk  ksthunk.sys  Tue Jul 14 03:00:19 2009 (4A5BCA93)
fffff880`05510000 fffff880`0551c000   Dxapi    Dxapi.sys    Tue Jul 14 02:38:28 2009 (4A5BC574)
fffff880`0551c000 fffff880`0552a000   monitor  monitor.sys  Tue Jul 14 02:38:52 2009 (4A5BC58C)
fffff880`0552a000 fffff880`0553e480   xusb21   xusb21.sys   Sat Feb 17 04:43:15 2007 (45D66BC3)
fffff880`0553f000 fffff880`0555c000   usbccgp  usbccgp.sys  Tue Jul 14 03:06:45 2009 (4A5BCC15)
fffff880`0555c000 fffff880`0555df00   USBD     USBD.SYS     Tue Jul 14 03:06:23 2009 (4A5BCBFF)
fffff880`0555e000 fffff880`0556a000   dc3d     dc3d.sys     Wed Nov 04 04:55:41 2009 (4AF0ED2D)
fffff880`0556a000 fffff880`05572080   HIDPARSE HIDPARSE.SYS Tue Jul 14 03:06:17 2009 (4A5BCBF9)
fffff880`05573000 fffff880`05581000   hidusb   hidusb.sys   Tue Jul 14 03:06:22 2009 (4A5BCBFE)
fffff880`05581000 fffff880`0559a000   HIDCLASS HIDCLASS.SYS Tue Jul 14 03:06:21 2009 (4A5BCBFD)
fffff880`0559a000 fffff880`055a7000   mouhid   mouhid.sys   Tue Jul 14 03:00:20 2009 (4A5BCA94)
fffff880`055a7000 fffff880`055b5000   kbdhid   kbdhid.sys   Tue Jul 14 03:00:20 2009 (4A5BCA94)
fffff880`055b5000 fffff880`055c1000   NuidFltr NuidFltr.sys Tue Jun 29 11:54:32 2010 (4C29B4C8)
fffff880`055c1000 fffff880`055cf000   crashdmp crashdmp.sys Tue Jul 14 03:01:01 2009 (4A5BCABD)
fffff880`055cf000 fffff880`055db000   dump_dumpata dump_dumpata.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`055db000 fffff880`055e4000   dump_atapi dump_atapi.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`055e4000 fffff880`055f7000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 02:21:51 2009 (4A5BC18F)
fffff880`05a00000 fffff880`05a4e000   mrxsmb10 mrxsmb10.sys Sat Feb 27 09:52:28 2010 (4B88CF3C)
fffff880`05a4e000 fffff880`05a71000   mrxsmb20 mrxsmb20.sys Sat Feb 27 09:52:26 2010 (4B88CF3A)
fffff880`05a71000 fffff880`05a9f000   rdpdr    rdpdr.sys    Tue Jul 14 03:18:02 2009 (4A5BCEBA)
fffff880`05aa7000 fffff880`05b6f000   HTTP     HTTP.sys     Tue Jul 14 02:22:16 2009 (4A5BC1A8)
fffff880`05b6f000 fffff880`05b8d000   bowser   bowser.sys   Tue Jul 14 02:23:50 2009 (4A5BC206)
fffff880`05b8d000 fffff880`05ba5000   mpsdrv   mpsdrv.sys   Tue Jul 14 03:08:25 2009 (4A5BCC79)
fffff880`05ba5000 fffff880`05bd2000   mrxsmb   mrxsmb.sys   Sat Feb 27 09:52:19 2010 (4B88CF33)
fffff880`06000000 fffff880`06096000   srv      srv.sys      Tue Jun 22 06:21:11 2010 (4C202C27)
fffff880`0609e000 fffff880`06144000   peauth   peauth.sys   Tue Jul 14 04:01:19 2009 (4A5BD8DF)
fffff880`06144000 fffff880`0614f000   secdrv   secdrv.SYS   Wed Sep 13 16:18:38 2006 (4508052E)
fffff880`0614f000 fffff880`0617c000   srvnet   srvnet.sys   Tue Jun 22 06:20:32 2010 (4C202C00)
fffff880`0617c000 fffff880`0618e000   tcpipreg tcpipreg.sys Tue Jul 14 03:09:49 2009 (4A5BCCCD)
fffff880`0618e000 fffff880`061f6000   srv2     srv2.sys     Tue Jun 22 06:20:47 2010 (4C202C0F)
fffff880`0687c000 fffff880`068b2000   fastfat  fastfat.SYS  Tue Jul 14 02:23:28 2009 (4A5BC1F0)
fffff880`068b2000 fffff880`068bd000   tdtcp    tdtcp.sys    Tue Jul 14 03:16:32 2009 (4A5BCE60)
fffff880`068bd000 fffff880`068cc000   tssecsrv tssecsrv.sys Tue Jul 14 03:16:41 2009 (4A5BCE69)
fffff880`068cc000 fffff880`06904000   RDPWD    RDPWD.SYS    Tue Jul 14 03:16:47 2009 (4A5BCE6F)
fffff880`14000000 fffff880`14056000   USBPORT  USBPORT.SYS  Tue Jul 14 03:06:31 2009 (4A5BCC07)
fffff880`14056000 fffff880`14062000   usbfilter usbfilter.sys Fri Apr 03 14:39:51 2009 (49D5F587)
fffff880`14062000 fffff880`14073000   usbehci  usbehci.sys  Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`1407b000 fffff880`14d0ce00   nvlddmkm nvlddmkm.sys Sat Jul 10 00:15:58 2010 (4C37918E)
fffff880`14d0d000 fffff880`14d0e180   nvBridge nvBridge.kmd Sat Jul 10 00:07:54 2010 (4C378FAA)
fffff880`14d0f000 fffff880`14d55000   dxgmms1  dxgmms1.sys  Tue Jul 14 02:38:32 2009 (4A5BC578)
fffff880`14d55000 fffff880`14d79000   HDAudBus HDAudBus.sys Tue Jul 14 03:06:13 2009 (4A5BCBF5)
fffff880`14d79000 fffff880`14dd0000   Rt64win7 Rt64win7.sys Mon Mar 22 11:57:14 2010 (4BA73EFA)
fffff880`14dd0000 fffff880`14ddb000   usbohci  usbohci.sys  Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`14ddb000 fffff880`14de8000   fdc      fdc.sys      Tue Jul 14 03:00:54 2009 (4A5BCAB6)
fffff880`14de8000 fffff880`14df4000   serenum  serenum.sys  Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`14df4000 fffff880`14e00000   ndistapi ndistapi.sys Tue Jul 14 03:10:00 2009 (4A5BCCD8)
fffff960`000e0000 fffff960`003ef000   win32k   win32k.sys   unavailable (00000000)
fffff960`00520000 fffff960`0052a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff960`00720000 fffff960`00747000   cdd      cdd.dll      unavailable (00000000)
Unloaded modules:
fffff880`05bd2000 fffff880`05bdd000   tdtcp.sys
    Checksum:  00000000
fffff880`05bdd000 fffff880`05bec000   tssecsrv.sys
    Checksum:  00000000
fffff880`06844000 fffff880`0687c000   RDPWD.SYS
    Checksum:  00000000
fffff880`01af1000 fffff880`01aff000   crashdmp.sys
    Checksum:  00000000
fffff880`01aff000 fffff880`01b0b000   dump_ataport
    Checksum:  00000000
fffff880`01b0b000 fffff880`01b14000   dump_atapi.s
    Checksum:  00000000
fffff880`01b14000 fffff880`01b27000   dump_dumpfve
    Checksum:  00000000
biggyk
Well-Known Member
Just downloaded latest xbox adapter software.
I also downloaded and instaled the chipset drivers from gigabytes website.
Things are going well now I hope and presume? :)
biggyk
Well-Known Member
#8
So far so good. I think when I installed 7, I forgot to download the chipset drivers to begin with. If anything changes I will chime back in. Thanks guys for your input.
#9
Good to hear the problem seems to be gone; however, a couple of days is not enough to be sure. If you don't get a single bsod over 2-3 weeks, it would be a more sound evidence. If you get more bsod's, attach them, we'll try to help.
biggyk
Well-Known Member
#10
Well I played a game for 2 hours today no problems. Quit the game and 2 mins later, boom blue screen.
#11
Uninstall Daemon Tools in the normal method. Then use this installer/uninstaller to remove sptd.sys. Be careful to use it to uninstall as opposed to update:
If you want drive emulation still, install PowerISO. The emulation part of the software is free forever and it will never crash Windows:
PowerISO - Create, Edit, Compress, Encrypt, Split, Mount, Extract ISO file, ISO/BIN converter, Virtual Drive
#12
You have not updated this driver, please update:
Daemon Tools
092410-16738-01.dmp
Probably caused by : ntkrnlmp.exe ( nt!KiSystemServiceHandler+7c )
Stack: nt!
FAILURE_BUCKET_ID: X64_0x3B_nt!KiSystemServiceHandler+7c
Loading Dump File [F:\a\Minidump\092410-16738-01.dmp]
Mini Kernel Dump does not have process information
Machine Name:
Kernel base = 0xfffff800`03059000 PsLoadedModuleList = 0xfffff800`03296e50
System Uptime: 0 days 5:25:31.362
.....................................................Unable to load image Unknown_Module_00000000`00000000, Win32 error 0n2
*** WARNING: Unable to verify timestamp for Unknown_Module_00000000`00000000
Unable to add module at 00000000`00000000
....Missing image name, possible paged-out or corrupt data.
BugCheck 3B, {c0000005, fffff800030ce80c, fffff880073e6a60, 0}
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff800030ce80c, Address of the exception record for the exception that caused the bugcheck
Arg3: fffff880073e6a60, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - <Unable to get error code text>
FAULTING_IP:
nt!ObfDereferenceObject+2c
fffff800`030ce80c f0480fc11f      lock xadd qword ptr [rdi],rbx
CONTEXT:  fffff880073e6a60 -- (.cxr 0xfffff880073e6a60)
rax=0000000000000003 rbx=ffffffffffffffff rcx=fff7fa800665f790
rdx=00000000000007ff rsi=fff7fa800665f790 rdi=fff7fa800665f760
rip=fffff800030ce80c rsp=fffff880073e7430 rbp=fffff880073e7ca0
 r8=fffffa8006544bb8  r9=0000000000000000 r10=fffffffffffffffe
r11=fffffa80045e4700 r12=0000000000000000 r13=fffff8a0017a6b40
r14=0000000000000003 r15=0000000000000003
iopl=0         nv up ei ng nz na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010286
nt!ObfDereferenceObject+0x2c:
fffff800`030ce80c f0480fc11f      lock xadd qword ptr [rdi],rbx ds:002b:fff7fa80`0665f760=????????????????
BUGCHECK_STR:  0x3B
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 0000000000000000 to fffff800030ce80c
STACK_TEXT:
fffff880`073e6198 fffff800`030c8ca9 : 00000000`0000003b 00000000`c0000005 fff7f800`030ce80c fffff880`073e6a60 : nt!KeBugCheckEx
fffff880`073e61a0 fffff800`030c85fc : fffff880`073e71f8 fffff880`073e6a60 00000000`00000000 fffff800`030f7c90 : nt!KiBugCheckDispatch+0x69
fffff880`073e62e0 fffff800`030ef40d : fffff800`032ec510 00000000`00000000 fffff800`03059000 fffff880`073e71f8 : nt!KiSystemServiceHandler+0x7c
fffff880`073e6320 fffff800`030f6a90 : fffff800`032191a0 fffff880`073e6398 fffff880`073e71f8 fffff800`03059000 : nt!RtlpExecuteHandlerForException+0xd
fffff880`073e6350 fffff800`031039ef : fffff880`073e71f8 fffff880`073e6a60 fffff880`00000000 fff7fa80`0665f760 : nt!RtlDispatchException+0x410
fffff880`073e6a30 fffff800`030c8d82 : fffff880`073e71f8 ffffffff`ffffffff fffff880`073e72a0 fff7fa80`0665f790 : nt!KiDispatchException+0x16f
fffff880`073e70c0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiExceptionDispatch+0xc2
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`030c85fc b801000000      mov     eax,1
SYMBOL_STACK_INDEX:  2
SYMBOL_NAME:  nt!KiSystemServiceHandler+7c
MODULE_NAME: nt
fffff800`00bb4000 fffff800`00bbe000   kdcom    kdcom.dll    Tue Jul 14 04:31:07 2009 (4A5BDFDB)
fffff800`03010000 fffff800`03059000   hal      hal.dll      Tue Jul 14 04:27:36 2009 (4A5BDF08)
fffff800`03059000 fffff800`03635000   nt       ntkrnlmp.exe Sat Jun 19 07:16:41 2010 (4C1C44A9)
fffff880`00c00000 fffff880`00c4c000   fltmgr   fltmgr.sys   Tue Jul 14 02:19:59 2009 (4A5BC11F)
fffff880`00c4c000 fffff880`00c7c000   CLASSPNP CLASSPNP.SYS Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`00ca2000 fffff880`00caf000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Tue Jul 14 04:29:09 2009 (4A5BDF65)
fffff880`00caf000 fffff880`00cc3000   PSHED    PSHED.dll    Tue Jul 14 04:32:23 2009 (4A5BE027)
fffff880`00cc3000 fffff880`00d21000   CLFS     CLFS.SYS     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00d21000 fffff880`00de1000   CI       CI.dll       Tue Jul 14 04:32:13 2009 (4A5BE01D)
fffff880`00e00000 fffff880`00e0b000   amdxata  amdxata.sys  Tue May 19 20:56:59 2009 (4A12F2EB)
fffff880`00e0b000 fffff880`00e1f000   fileinfo fileinfo.sys Tue Jul 14 02:34:25 2009 (4A5BC481)
fffff880`00e1f000 fffff880`00e35000   disk     disk.sys     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00e45000 fffff880`00ee9000   Wdf01000 Wdf01000.sys Tue Jul 14 02:22:07 2009 (4A5BC19F)
fffff880`00ee9000 fffff880`00ef8000   WDFLDR   WDFLDR.SYS   Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00ef8000 fffff880`00f2b000   pci      pci.sys      Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00f2b000 fffff880`00f40000   volmgr   volmgr.sys   Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00f40000 fffff880`00f9c000   volmgrx  volmgrx.sys  Tue Jul 14 02:20:33 2009 (4A5BC141)
fffff880`00f9c000 fffff880`00fa3000   pciide   pciide.sys   Tue Jul 14 02:19:49 2009 (4A5BC115)
fffff880`00fa3000 fffff880`00fb3000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`00fb3000 fffff880`00fcd000   mountmgr mountmgr.sys Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00fcd000 fffff880`00fd6000   atapi    atapi.sys    Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`00fd6000 fffff880`01000000   ataport  ataport.SYS  Tue Jul 14 02:19:52 2009 (4A5BC118)
fffff880`01000000 fffff880`0100d000   vdrvroot vdrvroot.sys Tue Jul 14 03:01:31 2009 (4A5BCADB)
fffff880`0100d000 fffff880`01022000   partmgr  partmgr.sys  Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`01022000 fffff880`0102b000   compbatt compbatt.sys Tue Jul 14 02:31:02 2009 (4A5BC3B6)
fffff880`0102b000 fffff880`01037000   BATTC    BATTC.SYS    Tue Jul 14 02:31:01 2009 (4A5BC3B5)
fffff880`0103d000 fffff880`01163000   sptd     sptd.sys     Sun Oct 11 23:55:14 2009 (4AD24632)
fffff880`01163000 fffff880`0116c000   WMILIB   WMILIB.SYS   Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`0116c000 fffff880`0119b000   SCSIPORT SCSIPORT.SYS Tue Jul 14 03:01:04 2009 (4A5BCAC0)
fffff880`0119b000 fffff880`011f2000   ACPI     ACPI.sys     Tue Jul 14 02:19:34 2009 (4A5BC106)
fffff880`011f2000 fffff880`011fc000   msisadrv msisadrv.sys Tue Jul 14 02:19:26 2009 (4A5BC0FE)
fffff880`01202000 fffff880`013a5000   Ntfs     Ntfs.sys     Tue Jul 14 02:20:47 2009 (4A5BC14F)
fffff880`013a5000 fffff880`013f8000   MDFSYSNT MDFSYSNT.sys Thu Feb 04 17:14:15 2010 (4B6AE447)
fffff880`01400000 fffff880`0140d000   MDPMGRNT MDPMGRNT.SYS Wed Sep 23 22:23:04 2009 (4ABA7598)
fffff880`0140d000 fffff880`01447000   fvevol   fvevol.sys   Sat Sep 26 05:34:26 2009 (4ABD7DB2)
fffff880`0144b000 fffff880`014a9000   msrpc    msrpc.sys    Tue Jul 14 02:21:32 2009 (4A5BC17C)
fffff880`014a9000 fffff880`014c3000   ksecdd   ksecdd.sys   Tue Jul 14 02:20:54 2009 (4A5BC156)
fffff880`014c3000 fffff880`01536000   cng      cng.sys      Tue Jul 14 02:49:40 2009 (4A5BC814)
fffff880`01536000 fffff880`01547000   pcw      pcw.sys      Tue Jul 14 02:19:27 2009 (4A5BC0FF)
fffff880`01547000 fffff880`01551000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 02:19:45 2009 (4A5BC111)
fffff880`01551000 fffff880`0159d000   volsnap  volsnap.sys  Tue Jul 14 02:20:08 2009 (4A5BC128)
fffff880`0159d000 fffff880`015ba000   sbp2port sbp2port.sys Tue Jul 14 02:19:53 2009 (4A5BC119)
fffff880`015ba000 fffff880`015f4000   rdyboost rdyboost.sys Tue Jul 14 02:34:34 2009 (4A5BC48A)
fffff880`015f4000 fffff880`015fc000   AtiPcie  AtiPcie.sys  Tue May 05 18:00:22 2009 (4A005486)
fffff880`01600000 fffff880`01609000   hwpolicy hwpolicy.sys Tue Jul 14 02:19:22 2009 (4A5BC0FA)
fffff880`0160a000 fffff880`016fc000   ndis     ndis.sys     Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`016fc000 fffff880`0175c000   NETIO    NETIO.SYS    Tue Jul 14 02:21:46 2009 (4A5BC18A)
fffff880`0175c000 fffff880`01787000   ksecpkg  ksecpkg.sys  Fri Dec 11 08:03:32 2009 (4B21E0B4)
fffff880`01787000 fffff880`017d1000   fwpkclnt fwpkclnt.sys Tue Jul 14 02:21:08 2009 (4A5BC164)
fffff880`017d1000 fffff880`017e1000   vmstorfl vmstorfl.sys Tue Jul 14 02:42:54 2009 (4A5BC67E)
fffff880`017e1000 fffff880`017e9000   spldr    spldr.sys    Mon May 11 19:56:27 2009 (4A0858BB)
fffff880`017e9000 fffff880`017fb000   mup      mup.sys      Tue Jul 14 02:23:45 2009 (4A5BC201)
fffff880`01800000 fffff880`019fd000   tcpip    tcpip.sys    Mon Jun 14 06:39:04 2010 (4C15A458)
Unloaded modules:
c1ff7a81`1024548b c1ff7a82`0f092400   Unknown_Module_c1ff7a81`1024548b
    Checksum:  00000000
0c2c2d02`5c0903e9 0c2c2d03`0f3c0441   Unknown_Module_0c2c2d02`5c0903e9
    Checksum:  00000000
8b094075`41b80000 8b094075`c1ff7881   Unknown_Module_8b094075`41b80000
    Checksum:  00000000
5b0987e9`ffe0b70c 5b0987ea`24551502   Unknown_Module_5b0987e9`ffe0b70c
    Checksum:  00000000
09e219b9`00000000 09e219b9`00000000   Unknown_Module_09e219b9`00000000
    Checksum:  00000000
biggyk
Well-Known Member
#13
Haha I figured It was daemon tools and I reinstalled it today and never thought twice about it when I got the bsod. Screw that Daemon tools thats for sure. Il try power ISo.
#14
PowerISO is great. So is Daemon Tools if you want it, just make sure to keep them up to date.
biggyk
Well-Known Member
#15
I installed PowerIso and everything was going great today then this evening 2 different bsod. I was playing a game for at least an hour before this happened and I quit the game to desktop no problems. So its doesn't happen in the game. I once bluescreened loading into safe mode.
#16
Likely faulty RAM then.
Otherwise, update your NEC USB 3.0 driver from motherboard manufacturer's site. This particular exact one caused issues for another user, definitely without doubt:
nusb3xhc nusb3xhc.sys Thu Apr 22 21:34:36 2010
And also update your AMD chipset drivers to latest, to update this oldie:
biggyk
Well-Known Member
#17
I already upgraded the chipset and usb drivers two days ago and this computer is only a month old, I just built it.
#18
Just building it means absolutely nothing. The driver dates do. They haven't been updated yet.
Both the NEC 3.0 USB and AMD chipset drivers still need updating. Perhaps you have downloaded/installed incorrect AMD chipset drivers. That would be the only reason why the AMD USB driver is still old.
Which motherboard?
biggyk
Well-Known Member
#19
Its the gigbabyte 770t-usb 3
I went right to the website to get the drivers and installed these drivers.
GA-770T-USB3 (rev. 1.3) - GIGABYTE and I choose win7 64bit
I reinstalled the usb3 driver and this time I had a utility app show up in my start menu so thats correctly installed and the amd chipset I must have installed twice.
I also ran memtest and everything is fine, no problems.
Im wondering if it could be a heat issue and I need another fan. I have one outtake in the back, one small intake on the case door and of course the cpu fan. The video card (gtx460) had two fans. The front 120mm fan on the front broke so nothing in the front pulling air in. Im going to keep my eye on the temps and see what I come up with.
I'm on the page now and see a very nice update to 7/22/2010 for the NEC USB 3.0
Old one from crash dumps, which is a known problem causer:
I have done a little research and have found the VMPlayer or VMWare installs a file of the same name of usbfilter.sys. Highlly suggest to uninstall any software of this type as it is too old for Windows. Then check C:\Windows\System32\drivers and delete usbfilter.sys if it is still there. (It is not part of the chipset driver package for your motherboard.) Reboot.
Heat and/or a video card error can not produce the crash dump/stop error types you have.
