BSOD with new AMD system
my newly built AMD system with 64bit Windows7 keep getting BOSD randomly, with errors like System Serice Exception, IRQL not less or Equal, enexpected kernel mode trap , page fault in nonpaged area, and DTFS file system....
Somehow i can't upload the dmp file here please use the link below to download thanks
dmp.rar - Windows Live
please help BSOD on my new AMD system
i have problem attaching file here please download the dmp file at the following link..
thanks.
Re: please help BSOD on my new AMD system
IRQL_NOT_LESS_OR_EQUAL (a)
SYSTEM_SERVICE_EXCEPTION (3b)
Probably caused by : hardware
1. Update drivers:
L1C62x64.sys Wed Apr 01 01:09:17 2009
Atheros L1c PCI-E Gigabit Ethernet Controller
LVUSBS64.sys Fri May 11 20:01:20 2007
Logitech QuickCam - update or disable the cam abd uninstall its software
2. Remove Daemon Tools, reboot, and remove its driver using this tool:
DuplexSecure - FAQ
3. Run memtest overnight as described here:
RAM - Test with Memtest86+ - Windows 7 Forums
Loading Dump File [F:\a\Minidump\D M P\112910-21262-01.dmp]
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Debug session time: Mon Nov 29 10:13:01.398 2010 (UTC - 5:00)
BugCheck A, {1, c, 0, fffff80002ff2402}
Probably caused by : hardware ( nt!KiPageFault+260 )
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 0000000000000001, memory referenced
Arg2: 000000000000000c, IRQL
Arg3: 0000000000000000, bitfield :
Arg4: fffff80002ff2402, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002cab0e0
 0000000000000001
CURRENT_IRQL:  c
FAULTING_IP:
hal!HalpRequestIpiSpecifyVector+21
fffff800`02ff2402 c9              leave
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xA
PROCESS_NAME:  chrome.exe
TRAP_FRAME:  fffff88004796fd0 -- (.trap 0xfffff88004796fd0)
rax=0000000000000004 rbx=0000000000000000 rcx=0000000000000000
rdx=fffff880047971c0 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002ff2402 rsp=fffff88004797168 rbp=0000000000000001
 r8=0000000000000000  r9=0000000000000004 r10=0000000000000000
r11=fffff88002f64180 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl nz na po nc
hal!HalpRequestIpiSpecifyVector+0x21:
Resetting default scope
MISALIGNED_IP:
LAST_CONTROL_TRANSFER:  from fffff80002a72ca9 to fffff80002a73740
STACK_TEXT:
fffff880`04796e88 fffff800`02a72ca9 : 00000000`0000000a 00000000`00000001 00000000`0000000c 00000000`00000000 : nt!KeBugCheckEx
fffff880`04796e90 fffff800`02a71920 : 00000000`00000000 fffff880`02fd5180 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff880`04796fd0 fffff800`02ff2402 : fffff800`02a819fd fffff880`009ea180 fffff800`02a781fa fffffa80`04557000 : nt!KiPageFault+0x260
fffff880`04797168 fffff6fd`00000002 : 00000000`00040004 00000000`00000004 00000000`00000000 00000000`00000000 : hal!HalpRequestIpiSpecifyVector+0x21
fffff880`04797198 00000000`00040004 : 00000000`00000004 00000000`00000000 00000000`00000000 00000000`00000000 : 0xfffff6fd`00000002
fffff880`047971a0 00000000`00000004 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00040001 : 0x40004
fffff880`047971a8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00040001 00000000`00000004 : 0x4
STACK_COMMAND:  kb
FOLLOWUP_IP:
nt!KiPageFault+260
fffff800`02a71920 440f20c0        mov     rax,cr8
SYMBOL_STACK_INDEX:  2
SYMBOL_NAME:  nt!KiPageFault+260
FOLLOWUP_NAME:  MachineOwner
IMAGE_NAME:  hardware
DEBUG_FLR_IMAGE_TIMESTAMP:  0
MODULE_NAME: hardware
FAILURE_BUCKET_ID:  X64_IP_MISALIGNED
Followup: MachineOwner
Loading Dump File [F:\a\Minidump\D M P\120210-18954-01.dmp]
Debug session time: Thu Dec  2 09:42:06.160 2010 (UTC - 5:00)
BugCheck 3B, {c0000005, fffff80002ad19eb, fffff880094a0250, 0}
Probably caused by : hardware ( nt!KiSystemServiceExit+50 )
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff80002ad19eb, Address of the instruction which caused the bugcheck
Arg3: fffff880094a0250, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - <Unable to get error code text>
FAULTING_IP:
fffff800`02ad19eb 00745748        add     byte ptr [rdi+rdx*2+48h],dh
CONTEXT:  fffff880094a0250 -- (.cxr 0xfffff880094a0250)
rax=0000000000000000 rbx=0000000000000000 rcx=fffffa80068c4b60
rdx=0000000000000000 rsi=00000000000001f4 rdi=0000000000000000
rip=fffff80002ad19eb rsp=fffff880094a0c20 rbp=fffff880094a0ca0
 r8=fffffa8005b62338  r9=0000000000000000 r10=fffffffffffffffb
r11=fffffa80068c4b60 r12=00000000fff9a000 r13=00000000066efd20
r14=00000000066ef170 r15=0000000072e82450
iopl=0         nv up di pl zr na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010046
nt!KiSystemServiceExit+0x50:
fffff800`02ad19eb 00745748        add     byte ptr [rdi+rdx*2+48h],dh ds:002b:00000000`00000048=??
BUGCHECK_STR:  0x3B
PROCESS_NAME:  SC2.exe
CURRENT_IRQL:  0
MISALIGNED_IP:
LAST_CONTROL_TRANSFER:  from 0000000072e82dd9 to fffff80002ad19eb
STACK_TEXT:
fffff880`094a0c20 00000000`72e82dd9 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExit+0x50
00000000`066ef0f8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x72e82dd9
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!KiSystemServiceExit+50
STACK_COMMAND:  .cxr 0xfffff880094a0250 ; kb
fffff880`04217000 fffff880`0425c000   a1ww8vq0 a1ww8vq0.SYS Tue Jul 14 17:12:55 2009 (4A5CF4D7)
fffff880`010b0000 fffff880`01107000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02d26000 fffff880`02db0000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04275000 fffff880`0428b000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`03fb5000 fffff880`03fca000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`0104d000 fffff880`01058000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`0101a000 fffff880`01023000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`01023000 fffff880`0104d000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`050d8000 fffff880`050f8000   AtihdW76 AtihdW76.sys Mon Aug 16 06:41:02 2010 (4C6915BE)
fffff880`0480f000 fffff880`04fe5000   atikmdag atikmdag.sys Tue Sep 28 21:41:26 2010 (4CA29946)
fffff880`03e00000 fffff880`03e4b000   atikmpag atikmpag.sys Tue Sep 28 21:14:49 2010 (4CA29309)
fffff880`015e4000 fffff880`015ec000   AtiPcie  AtiPcie.sys  Tue May 05 11:00:22 2009 (4A005486)
fffff880`0143a000 fffff880`01441000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`03f7e000 fffff880`03f8f000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`060cd000 fffff880`060eb000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00750000 fffff960`00777000   cdd      cdd.dll      Wed May 19 15:48:26 2010 (4BF4408A)
fffff880`00fbf000 fffff880`00fe9000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00d28000 fffff880`00de8000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01200000 fffff880`01230000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00cca000 fffff880`00d28000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`014ba000 fffff880`0152d000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`04265000 fffff880`04275000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`03bd5000 fffff880`03be3000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`03edd000 fffff880`03f60000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`03f60000 fffff880`03f7e000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`03ece000 fffff880`03edd000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`015ce000 fffff880`015e4000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`05135000 fffff880`05157000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`03bef000 fffff880`03bf8000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`03be3000 fffff880`03bef000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`05fe5000 fffff880`05ff8000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`05038000 fffff880`05044000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`040fb000 fffff880`041ef000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`04000000 fffff880`04046000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`00fab000 fffff880`00fbf000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`01058000 fffff880`010a4000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`0153e000 fffff880`01548000   Fs_Rec   Fs_Rec.sys   unavailable (00000000)
fffff880`01400000 fffff880`0143a000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`01600000 fffff880`0164a000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`0407c000 fffff880`04089000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`02a19000 fffff800`02a62000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`04046000 fffff880`0406a000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`0516a000 fffff880`051c6000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`051d4000 fffff880`051ed000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`051ed000 fffff880`051f5080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`051c6000 fffff880`051d4000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`06005000 fffff880`060cd000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`017f4000 fffff880`017fd000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`0434b000 fffff880`0435a000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`0502a000 fffff880`05038000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bbc000 fffff800`00bc6000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`0436b000 fffff880`043ae000   ks       ks.sys       Mon Jul 13 20:00:31 2009 (4A5BCA9F)
fffff880`014a0000 fffff880`014ba000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`017b7000 fffff880`017e2000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`05157000 fffff880`0515c200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`0406a000 fffff880`0407c000   L1C62x64 L1C62x64.sys Wed Apr 01 01:09:17 2009 (49D2F6FD)
fffff880`05c44000 fffff880`05c59000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`05c00000 fffff880`05c23000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`03a61000 fffff880`03babd00   lvpopf64 lvpopf64.sys Fri May 11 19:56:21 2007 (464502A5)
fffff880`05044000 fffff880`0504e900   LVUSBS64 LVUSBS64.sys Fri May 11 20:01:20 2007 (464503D0)
fffff880`05c74000 fffff880`05fe4500   lvuvc64  lvuvc64.sys  Fri May 11 19:59:12 2007 (46450350)
fffff880`00ca9000 fffff880`00cb6000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`03bc7000 fffff880`03bd5000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`0435a000 fffff880`04369000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`05000000 fffff880`0500d000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`01000000 fffff880`0101a000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00e00000 fffff880`00e2d000   MpFilter MpFilter.sys Sat Mar 20 01:58:08 2010 (4BA463F0)
fffff880`07200000 fffff880`07210000   MpNWMon  MpNWMon.sys  Sat Mar 20 01:58:00 2010 (4BA463E8)
fffff880`060eb000 fffff880`06103000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`06103000 fffff880`06130000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`06130000 fffff880`0617e000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`0617e000 fffff880`061a1000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`02cdf000 fffff880`02cea000   Msfs     Msfs.SYS     unavailable (00000000)
fffff880`01107000 fffff880`01111000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01442000 fffff880`014a0000   msrpc    msrpc.sys    unavailable (00000000)
fffff880`03ec3000 fffff880`03ece000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`017e2000 fffff880`017f4000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01665000 fffff880`01757000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`042af000 fffff880`042bb000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`042bb000 fffff880`042ea000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`050b6000 fffff880`050cb000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02c26000 fffff880`02c35000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02db0000 fffff880`02df5000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01757000 fffff880`017b7000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`02cea000 fffff880`02cfb000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03eb7000 fffff880`03ec3000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02a62000 fffff800`0303e000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`01245000 fffff880`013e8000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`010a4000 fffff880`010ad000   Null     Null.SYS     unavailable (00000000)
fffff880`02c00000 fffff880`02c26000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`01151000 fffff880`01166000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`0111e000 fffff880`01151000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`011d7000 fffff880`011de000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`011de000 fffff880`011ee000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0152d000 fffff880`0153e000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`070c1000 fffff880`07167000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`050f8000 fffff880`05135000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00cb6000 fffff880`00cca000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`0428b000 fffff880`042af000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`042ea000 fffff880`04305000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`04305000 fffff880`04326000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`04326000 fffff880`04340000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`03e66000 fffff880`03eb7000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`04340000 fffff880`0434b000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`02cc4000 fffff880`02ccd000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02ccd000 fffff880`02cd6000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02cd6000 fffff880`02cdf000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01594000 fffff880`015ce000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`05c59000 fffff880`05c71000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`00f7c000 fffff880`00fab000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
fffff880`07167000 fffff880`07172000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`04fe5000 fffff880`04ff1000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`02c35000 fffff880`02c52000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`0165a000 fffff880`01662000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`00e4d000 fffff880`00f73000   sptd     sptd.sys     Sun Oct 11 16:55:14 2009 (4AD24632)
fffff880`072f7000 fffff880`0738d000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`07000000 fffff880`07067000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`07172000 fffff880`0719f000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`04369000 fffff880`0436a480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01801000 fffff880`019fe000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`0719f000 fffff880`071b1000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`02d19000 fffff880`02d26000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`02cfb000 fffff880`02d19000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02c6d000 fffff880`02c81000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00540000 fffff960`0054a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`03f8f000 fffff880`03fb5000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`03a00000 fffff880`03a54000   udfs     udfs.sys     Mon Jul 13 19:23:37 2009 (4A5BC1F9)
fffff880`043ae000 fffff880`043c0000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`03bac000 fffff880`03bc6c00   usbaudio usbaudio.sys Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`0500d000 fffff880`0502a000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`051f6000 fffff880`051f7f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`041ef000 fffff880`04200000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`040ea000 fffff880`040f7000   usbfilter usbfilter.sys Tue Dec 22 03:26:22 2009 (4B3082AE)
fffff880`0505c000 fffff880`050b6000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04089000 fffff880`04094000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04094000 fffff880`040ea000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`01111000 fffff880`0111e000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`011ee000 fffff880`011fc000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`02c8f000 fffff880`02cb4000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`0164a000 fffff880`0165a000   vmstorfl vmstorfl.sys unavailable (00000000)
fffff880`01166000 fffff880`0117b000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0117b000 fffff880`011d7000   volmgrx  volmgrx.sys  unavailable (00000000)
fffff880`01548000 fffff880`01594000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`02c52000 fffff880`02c6d000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`02cb4000 fffff880`02cc4000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00c00000 fffff880`00ca4000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00de8000 fffff880`00df7000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02df5000 fffff880`02dfe000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00010000 fffff960`0031f000   win32k   win32k.sys   Tue Aug 31 22:58:04 2010 (4C7DC13C)
fffff880`0425c000 fffff880`04265000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f73000 fffff880`00f7c000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`05c23000 fffff880`05c44000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`07241000 fffff880`072b2000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`0738d000 fffff880`073fe000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`07210000 fffff880`07241000   AODDriver2.s
    Checksum:  00000000
    ImageSize:  00031000
fffff880`015ec000 fffff880`015fa000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01230000 fffff880`0123c000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0123c000 fffff880`01245000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`013e8000 fffff880`013fb000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`05168000 fffff880`0516a000   USBD.SYS
    Checksum:  00000000
    ImageSize:  00002000
fffff880`0515d000 fffff880`05168000   LVUSBS64.sys
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`050d6000 fffff880`050d8000   USBD.SYS
    Checksum:  00000000
    ImageSize:  00002000
fffff880`050cb000 fffff880`050d6000   LVUSBS64.sys
    Checksum:  00000000
    ImageSize:  0000B000
Please help ~
Updated Atheros driver, remove and cleaned demon tool, unplugged logitech webcam, did an overnight memory scan with no error , but the system crashed again today.
New dmp files at the link below
dmp2.rar - Windows Live
thanks
Uninstall AMD Overdrive.
Update Logitech QuickCam software. If there is no update, remove the camera from the system and uninstall the software.
Uninstalled AMD Overdrive.
Look everywhere can't find QuickCam software to unintall, don't think i had installed any before.
Attached is files extracted by SF Diagnostic Tool.
Please help million thanks.
#7
@Joe, thank you for taking the time and effort to perfectly follow our instructions. You've done the software part and your drivers are in excellent state now. But you're still getting Stop 0x124 which means it's up to your hardware - a physical defect or wrong settings in the bios. Memory is an often cause. Of course there should be no overclocking no overheating.
Stop 0x124 - what it means and what to try - Windows 7 Forums
EDIT:
121110-19624-01.dmp
Loading Dump File [F:\a\Minidump\D M P\121110-19624-01.dmp]
Executable search path is:
Machine Name:
Kernel base = 0xfffff800`02a0b000 PsLoadedModuleList = 0xfffff800`02c48e50
Debug session time: Sat Dec 11 04:24:45.654 2010 (UTC - 5:00)
System Uptime: 0 days 0:30:33.495
Loading Kernel Symbols
Press ctrl-c (cdb, kd, ntsd) or ctrl-break (windbg) to abort symbol loads that take too long.
Run !sym noisy before .reload to track down problems loading symbols.
Loading User Symbols
Loading unloaded module list
BugCheck 3B, {c0000005, fffff80002a7a9eb, fffff880086d51e0, 0}
0: kd> !analyze -v
Arguments:
Arg2: fffff80002a7a9eb, Address of the instruction which caused the bugcheck
Arg3: fffff880086d51e0, Address of the context record for the exception that caused the bugcheck
Debugging Details:
FAULTING_IP:
fffff800`02a7a9eb 00745748        add     byte ptr [rdi+rdx*2+48h],dh
CONTEXT:  fffff880086d51e0 -- (.cxr 0xfffff880086d51e0)
rax=0000000000000002 rbx=000000000279f980 rcx=fffffa8003c68760
rdx=00000000000007ff rsi=0000000000000000 rdi=0000000000000003
rip=fffff80002a7a9eb rsp=fffff880086d5bb0 rbp=fffff880086d5ca0
 r8=fffffa8004e040e8  r9=0000000000000000 r10=fffffffffffffffe
r11=fffffa8003c68760 r12=0000000000000000 r13=000000000279f8f0
iopl=0         nv up di ng nz na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010086
fffff800`02a7a9eb 00745748        add     byte ptr [rdi+rdx*2+48h],dh ds:002b:00000000`00001049=??
BUGCHECK_STR:  0x3B
PROCESS_NAME:  audiodg.exe
CURRENT_IRQL:  0
MISALIGNED_IP:
LAST_CONTROL_TRANSFER:  from 000000007738030a to fffff80002a7a9eb
STACK_TEXT:
fffff880`086d5bb0 00000000`7738030a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExit+0x50
00000000`0279f848 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7738030a
FOLLOWUP_IP:
STACK_COMMAND:  .cxr 0xfffff880086d51e0 ; kb
DRIVERS
fffff880`00f94000 fffff880`00feb000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02a00000 fffff880`02a8a000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04140000 fffff880`04156000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`03dd5000 fffff880`03dea000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`00de6000 fffff880`00df1000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`00db3000 fffff880`00dbc000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00dbc000 fffff880`00de6000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`0513b000 fffff880`0515b000   AtihdW76 AtihdW76.sys Fri Sep 24 01:44:48 2010 (4C9C3AD0)
fffff880`0460b000 fffff880`04e00000   atikmdag atikmdag.sys Tue Oct 26 22:29:53 2010 (4CC78EA1)
fffff880`03e89000 fffff880`03ed4000   atikmpag atikmpag.sys Tue Oct 26 22:14:23 2010 (4CC78AFF)
fffff880`015f8000 fffff880`01600000   AtiPcie  AtiPcie.sys  Tue May 05 11:00:22 2009 (4A005486)
fffff880`02b53000 fffff880`02b5a000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`03d9e000 fffff880`03daf000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`053c2000 fffff880`053e0000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`007a0000 fffff960`007c7000   cdd      cdd.dll      unavailable (00000000)
fffff880`05000000 fffff880`0501d000   cdfs     cdfs.sys     Mon Jul 13 19:19:46 2009 (4A5BC112)
fffff880`02af3000 fffff880`02b1d000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00cd9000 fffff880`00d99000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`011cb000 fffff880`011fb000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c7b000 fffff880`00cd9000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01158000 fffff880`011cb000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`04130000 fffff880`04140000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`0501d000 fffff880`0502b000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`03c00000 fffff880`03c83000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`03c83000 fffff880`03ca1000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`03d8f000 fffff880`03d9e000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01247000 fffff880`0125d000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`05198000 fffff880`051ba000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`05037000 fffff880`05040000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0502b000 fffff880`05037000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`05040000 fffff880`05053000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`05053000 fffff880`0505f000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`03ed4000 fffff880`03fc8000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`03e00000 fffff880`03e46000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`010e6000 fffff880`010fa000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`00c00000 fffff880`00c4c000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`0122b000 fffff880`01235000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01086000 fffff880`010c0000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`0158d000 fffff880`015d7000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`03fc8000 fffff880`03fd5000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`02fe7000 fffff800`03030000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`03e46000 fffff880`03e6a000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`05bd7000 fffff880`05bf0000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`05bf0000 fffff880`05bf8080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`05bc9000 fffff880`05bd7000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`052fa000 fffff880`053c2000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`015ef000 fffff880`015f8000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`04025000 fffff880`04034000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`051ea000 fffff880`051f8000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bad000 fffff800`00bb7000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`04045000 fffff880`04088000   ks       ks.sys       Mon Jul 13 20:00:31 2009 (4A5BCA9F)
fffff880`01200000 fffff880`0121a000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01562000 fffff880`0158d000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`051ba000 fffff880`051bf200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`03e6a000 fffff880`03e7f000   L1C62x64 L1C62x64.sys Mon Sep 27 02:36:23 2010 (4CA03B67)
fffff880`03fd5000 fffff880`03fea000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0506d000 fffff880`05090000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c5a000 fffff880`00c67000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`0505f000 fffff880`0506d000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`04034000 fffff880`04043000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`05a00000 fffff880`05a0d000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00d99000 fffff880`00db3000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02b1d000 fffff880`02b4a000   MpFilter MpFilter.sys Sat Mar 20 01:58:08 2010 (4BA463F0)
fffff880`0529e000 fffff880`052ae000   MpNWMon  MpNWMon.sys  Sat Mar 20 01:58:00 2010 (4BA463E8)
fffff880`053e0000 fffff880`053f8000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`05200000 fffff880`0522d000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`0522d000 fffff880`0527b000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`0527b000 fffff880`0529e000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`02bb8000 fffff880`02bc3000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00ff4000 fffff880`00ffe000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`010fa000 fffff880`01158000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`03d84000 fffff880`03d8f000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01235000 fffff880`01247000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01410000 fffff880`01502000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`0417a000 fffff880`04186000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`04186000 fffff880`041b5000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`05119000 fffff880`0512e000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`03ccc000 fffff880`03cdb000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02a8a000 fffff880`02acf000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01502000 fffff880`01562000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`02bc3000 fffff880`02bd4000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03d78000 fffff880`03d84000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02a0b000 fffff800`02fe7000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`0125d000 fffff880`01400000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`02b4a000 fffff880`02b53000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`03ca6000 fffff880`03ccc000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00e40000 fffff880`00e55000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00e0d000 fffff880`00e40000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00ec6000 fffff880`00ecd000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00ecd000 fffff880`00edd000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0121a000 fffff880`0122b000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`06c41000 fffff880`06ce7000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`0515b000 fffff880`05198000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c67000 fffff880`00c7b000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`04156000 fffff880`0417a000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`041b5000 fffff880`041d0000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`041d0000 fffff880`041f1000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`04000000 fffff880`0401a000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`03d27000 fffff880`03d78000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`0401a000 fffff880`04025000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`02b9d000 fffff880`02ba6000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02ba6000 fffff880`02baf000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02baf000 fffff880`02bb8000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`0104c000 fffff880`01086000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`02ad8000 fffff880`02af0000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`06ce7000 fffff880`06cf2000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`0411b000 fffff880`04127000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`03cdb000 fffff880`03cf8000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`015e7000 fffff880`015ef000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`080bd000 fffff880`08153000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`08056000 fffff880`080bd000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`06cf2000 fffff880`06d1f000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`04043000 fffff880`04044480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01602000 fffff880`017ff000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`06d90000 fffff880`06da2000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`02bf2000 fffff880`02bff000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`02bd4000 fffff880`02bf2000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`03d13000 fffff880`03d27000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`004c0000 fffff960`004ca000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`03daf000 fffff880`03dd5000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`04088000 fffff880`0409a000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`051cd000 fffff880`051ea000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`05bf9000 fffff880`05bfaf00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`0410a000 fffff880`0411b000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`040fd000 fffff880`0410a000   usbfilter usbfilter.sys Tue Dec 22 03:26:22 2009 (4B3082AE)
fffff880`050bf000 fffff880`05119000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04600000 fffff880`0460b000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`040a7000 fffff880`040fd000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`00e00000 fffff880`00e0d000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`02b5a000 fffff880`02b68000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`05a12000 fffff880`05bc9000   viahduaa viahduaa.sys Sat May 15 06:22:39 2010 (4BEE75EF)
fffff880`02b68000 fffff880`02b8d000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`015d7000 fffff880`015e7000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00e55000 fffff880`00e6a000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00e6a000 fffff880`00ec6000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01000000 fffff880`0104c000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`03cf8000 fffff880`03d13000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`02b8d000 fffff880`02b9d000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00ee1000 fffff880`00f85000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f85000 fffff880`00f94000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02acf000 fffff880`02ad8000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`000a0000 fffff960`003af000   win32k   win32k.sys   Tue Aug 31 22:58:04 2010 (4C7DC13C)
fffff880`04127000 fffff880`04130000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00feb000 fffff880`00ff4000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`05090000 fffff880`050b1000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`06d1f000 fffff880`06d90000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01400000 fffff880`0140e000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`010c0000 fffff880`010cc000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`010cc000 fffff880`010d5000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`02ae0000 fffff880`02af3000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`051cb000 fffff880`051cd000   USBD.SYS
    Checksum:  00000000
    ImageSize:  00002000
fffff880`051c0000 fffff880`051cb000   LVUSBS64.sys
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`05139000 fffff880`0513b000   USBD.SYS
    Checksum:  00000000
    ImageSize:  00002000
fffff880`0512e000 fffff880`05139000   LVUSBS64.sys
    Checksum:  00000000
    ImageSize:  0000B000
