Windows 7 BSOD with various messages
spark
Hi all,
I've recently experience many BSODs, and the messages are changed each time.
For e.g. "IRQ_NOT_LESS_OR_EQUAL", "MEMORY_MANAGEMENT" and so on.
I must say this started once I put the computer to sleep mode.
However, no new hardware has been installed recently
I'm attaching the 3 recent DMP files made in the last few hours...
I appreciate your help... I'm posting it quick before the next BSOD...
Thanks.
  • 070712-34554-01.dmp
  • 070712-37237-01.dmp
  • 070712-35677-01.dmp
I am not the expert in the forum on reading dump files, but you have an older driver, RimSerial_AMD64.sys, which probably belongs to a blackberry. You might check for a newer version to see if it would help.
If you go to the BSOD forum, you might check the stickys to see if anything could help. But your memory is partially indicated in the problem, so you might try running the memtest for a while to see if anything there shows up. Some folks run the tool for an extended period of time instead of just the quick check.
Diagnosing memory problems on your computer
Top Bottom
