BSOD's, AGAIN- please help
Hi everyone,
About 7-8 months ago I posted here because I had huge problems with getting BSODS all the time. I did everything you told me then (thanks for that), and have had it working for quite a while. Now however I'm back to having problems.
I had 3-4 BSODS so far today, here are the logs for it:
I would post more information if I had the time, but I almost instantly get BSOD when I start my computer. Would be very appreciated if anyone could find the solution to this.
Thanks!
If you need any extra information I can try and get them, but I get very fast BSODS as stated.
Anyone? Thanks. Here's my system: Intel i5 775 ATI Radeon 5770 Gigabyte P55A-UD4 Corsair 1600MHz 4GB 80GB SSD Intel med operativsystem installerat Windows 7 Ultimate
Elmer
Hi Errien
STOP 0x0000001A: MEMORY_MANAGEMENT
Usual causes:
Device driver, memory, kernel
STOP 0x000000F4: CRITICAL_OBJECT_TERMINATION
Usual causes:
The CRITICAL_OBJECT_TERMINATION bug check has a value of 0x000000F4. This indicates that a process or thread crucial to system operation has unexpectedly exited or been terminated.
STOP 0x0000007E: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
Usual causes:
Insufficient disk space, Device driver, Video card, BIOS, Breakpoint with no debugger attached, Hardware incompatibility, Faulty system service, Memory, 3rd party remote control,
Can you boot to and run OK in Safe Mode? Although you have a few "old" drivers there are no real horror stories in there.
As a Priority:
Razerlow.sys Mon Nov 07 06:33:11 2005 Razer Diamondback driver (Win7 has issues with older drivers)
Drivers with Updates:
atikmdag.sys Wed Sep 29 02:41:26 2010
atikmpag.sys Wed Sep 29 02:14:49 2010
Download the latest Catalyst SetUp.
Download and install Driver Sweeper.
Boot to Safe Mode
Run Driver Sweeper to uninstall your current Catalyst SetUp..
Reboot to Normal Mode.
Install your new Catalyst SetUp.
GEARAspiWDM.sys Mon May 18 13:17:04 2009 Gear Software CD-ROM Class Filter Driver v4.015.1 (Feb 2010). Also comes with iTunes
jraid.sys Tue Sep 07 03:37:00 2010 JMicron Raid Driver
nusb3hub.sys Fri Apr 23 02:34:35 2010
nusb3xhc.sys Fri Apr 23 02:34:36 2010
Go to your Motherboard Mfr. Support website and update your USB 3.0 drivers.
Rt64win7.sys Mon Sep 20 08:38:09 2010 Realtek PCIe GBE Family Controller v7.046
RTKVHD64.sys Tue Oct 05 10:58:40 2010 Realtek HD Audio R2.63
Elmer
Eeek!! Double post! How's that happen?
Did what you wrote in your previous post- and it's working so far- I'll make a post if anything would occur
Thanks a lot for your help!
Elmer
Thanks for the feedback. Give it about a week and then you can safely put the hammer away! :)
#7
Hi again!
I've had this working for about a month now, but today I've got the bluescreens back sadly. Have had about 6 or 7 in an hour, and they pop up as soon as I start the comp and open an application. Here are logs:
Any help, please!
zigzag3143
Honorable Member
Microsoft MVP
#8
Hi again!
Any help, please!
Still memory management probably caused by a driver. please run these two tests
1-Memtest.
*Download a copy of Memtest86 and burn the ISO to a CD using Iso Recorder or another ISO burning program.
*Boot from the CD, and leave it running for at least 5 or 6 passes.
Just remember, any time Memtest reports errors, it can be either bad RAM or a bad motherboard slot.
Test the sticks individually, and if you find a good one, test it in all slots.
RAM - Test with Memtest86+ - Windows 7 Forums
2-Driver verifier
I'd suggest that you first backup your data and then make sure you've got access to another computer so you can contact us if problems arise. Then make a System Restore point (so you can restore the system using the Vista/Win7 Startup Repair feature).
In Windows 7 you can make a Startup Repair disk by going to Start....All Programs...Maintenance...Create a System Repair Disc - with Windows Vista you'll have to use your installation disk or the "Repair your computer" option at the top of the Safe Mode menu .
Then, here's the procedure:
- Go to Start and type in "verifier" (without the quotes) and press Enter
- Select "Create custom settings (for code developers)" and click "Next"
- Select "Select individual settings from a full list" and click "Next"
- Select everything EXCEPT FOR "Low Resource Simulation" and click "Next"
- Select "Select driver names from a list" and click "Next"
Then select all drivers NOT provided by Microsoft and click "Next"
- Select "Finish" on the next page.
Reboot the system and wait for it to crash to the Blue Screen. Continue to use your system normally, and if you know what causes the crash, do that repeatedly. The objective here is to get the system to crash because Driver Verifier is stressing the drivers out. If it doesn't crash for you, then let it run for at least 36 hours of continuous operation (an estimate on my part).
If you can't get into Windows because it crashes too soon, try it in Safe Mode.
If you can't get into Safe Mode, try using System Restore from your installation DVD to set the system back to the previous restore point that you created.
Driver Verifier - Enable and Disable - Windows 7 Forums
