Bsods again
As some of you know, I am back with my bsod problems. I was asked to provide pictures or what not the next time I crashed, but I have no idea how to, thus I send you the minidumps again, in hope that you will help me.
Your blue screens are caused by hardware:
042911-22417-01.dmp
BugCheck 124, {0, fffffa8004ad6038, b2000040, 800}
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred.
CURRENT_IRQL: f
Stack nt hal
FAILURE_BUCKET_ID: X64_0x124_GenuineIntel_PROCESSOR_BUS
Probably caused by : hardware
042911-20295-01.dmp
BugCheck 3B, {c0000005, fffff880048ca5f6, fffff88008ba6f10, 0}
SYSTEM_SERVICE_EXCEPTION (3b)
FAULTING_IP:
dxgkrnl!DXGFASTMUTEX::Release+12
fffff880`048ca5f6 483901 cmp qword ptr [rcx],rax
Probably caused by : dxgkrnl.sys ( dxgkrnl!DXGFASTMUTEX::Release+12 )
1. Load bios defaults, such as fail-safe/ooptimized/setup defaults -- to ensure your hardware is set right.
2. 10 passes of Memtest86+ - Advanced Memory Diagnostic Tool
3. http://windows7forums.com/blue-scre...mportant-every-thread-starter-please-see.html
CRASH DUMPS
Loading Dump File [F:\DMP\042911-22417-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x64
Built by: 7600.16695.amd64fre.win7_gdr.101026-1503
Machine Name:
Kernel base = 0xfffff800`02a59000 PsLoadedModuleList = 0xfffff800`02c96e50
Debug session time: Fri Apr 29 10:00:21.089 2011 (UTC - 4:00)
System Uptime: 0 days 6:10:02.430
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Followup: MachineOwner
1: kd> !analyze -v
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa8004ad6038, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000b2000040, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000000800, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR:  0x124_GenuineIntel
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  fsav32.exe
CURRENT_IRQL:  f
STACK_TEXT:
fffff880`009ee9d8 fffff800`02a22903 : 00000000`00000124 00000000`00000000 fffffa80`04ad6038 00000000`b2000040 : nt!KeBugCheckEx
fffff880`009ee9e0 fffff800`02bdf5a3 : 00000000`00000001 fffffa80`0475edd0 00000000`00000000 fffffa80`0475ee20 : hal!HalBugCheckSystem+0x1e3
fffff880`009eea20 fffff800`02a225c8 : 00000000`00000728 fffffa80`0475edd0 fffff880`009eedb0 fffff880`009eed00 : nt!WheaReportHwError+0x263
fffff880`009eea80 fffff800`02a21f1a : fffffa80`0475edd0 fffff880`009eedb0 fffffa80`0475edd0 00000000`00000000 : hal!HalpMcaReportError+0x4c
fffff880`009eebd0 fffff800`02a21dd5 : 00000000`00000002 00000000`00000001 fffff880`009eee30 00000000`00000000 : hal!HalpMceHandler+0x9e
fffff880`009eec10 fffff800`02a15e88 : 00000000`5d699278 00000000`00000002 00000000`00000000 00000000`00000000 : hal!HalpMceHandlerWithRendezvous+0x55
fffff880`009eec40 fffff800`02ac7fec : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x40
fffff880`009eec70 fffff800`02ac7e53 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x6c
fffff880`009eedb0 fffff800`02afedab : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x153
fffff880`0a2bf070 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxFlushEntireTb+0x83
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: hardware
IMAGE_NAME:  hardware
DEBUG_FLR_IMAGE_TIMESTAMP:  0
Loading Dump File [F:\DMP\042911-20295-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02a19000 PsLoadedModuleList = 0xfffff800`02c56e50
Debug session time: Fri Apr 29 10:18:58.769 2011 (UTC - 4:00)
System Uptime: 0 days 0:17:22.094
0: kd> !analyze -v
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff880048ca5f6, Address of the instruction which caused the bugcheck
Arg3: fffff88008ba6f10, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
FAULTING_IP:
CONTEXT:  fffff88008ba6f10 -- (.cxr 0xfffff88008ba6f10)
rax=fffffa8005a40b60 rbx=fffffa8004179c10 rcx=fffffa8004179c10
rdx=fffffa8005a40b60 rsi=0000000000000002 rdi=0000000000000000
rip=fffff880048ca5f6 rsp=fffff88008ba78e0 rbp=fffff88008ba7c60
 r8=0000000000000000  r9=0000000000000000 r10=0000000000000001
r11=fffff88008ba72a0 r12=0000000000020000 r13=000000000ce4fd20
r14=0000000000000000 r15=0000000073f62450
iopl=0         nv up ei ng nz na pe nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010282
dxgkrnl!DXGFASTMUTEX::Release+0x12:
fffff880`048ca5f6 483901          cmp     qword ptr [rcx],rax ds:002b:fffffa80`04179c10=????????????????
Resetting default scope
BUGCHECK_STR:  0x3B
PROCESS_NAME:  RedOrchestra.e
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 0000000000000000 to fffff880048ca5f6
STACK_TEXT:
fffff880`08ba78e0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : dxgkrnl!DXGFASTMUTEX::Release+0x12
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  dxgkrnl!DXGFASTMUTEX::Release+12
MODULE_NAME: dxgkrnl
IMAGE_NAME:  dxgkrnl.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4d3fa1a0
STACK_COMMAND:  .cxr 0xfffff88008ba6f10 ; kb
FAILURE_BUCKET_ID:  X64_0x3B_dxgkrnl!DXGFASTMUTEX::Release+12
DRIVERS
fffff880`0117e000 fffff880`011d5000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02c56000 fffff880`02ce0000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`049ca000 fffff880`049e0000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`00e3e000 fffff880`00e49000   amdxata  amdxata.sys  Fri Mar 19 12:18:18 2010 (4BA3A3CA)
fffff880`061e7000 fffff880`061f2000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00e00000 fffff880`00e09000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00e09000 fffff880`00e33000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`04b65000 fffff880`04b85000   AtihdW76 AtihdW76.sys Wed Nov 17 07:02:04 2010 (4CE3C43C)
fffff880`03c64000 fffff880`04560000   atikmdag atikmdag.sys Wed Jan 26 17:48:28 2011 (4D40A4BC)
fffff880`03b17000 fffff880`03b65000   atikmpag atikmpag.sys Wed Jan 26 17:13:33 2011 (4D409C8D)
fffff880`05b96000 fffff880`05be5000   atksgt   atksgt.sys   Sun May 17 09:36:34 2009 (4A1012E2)
fffff880`045b6000 fffff880`045fb000   azwq3nle azwq3nle.SYS Tue Jul 14 17:12:55 2009 (4A5CF4D7)
fffff880`00e66000 fffff880`00e6d000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`03aca000 fffff880`03adb000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`05ac2000 fffff880`05ae0000   bowser   bowser.sys   Wed Feb 23 00:15:06 2011 (4D6497DA)
fffff960`006d0000 fffff960`006f7000   cdd      cdd.dll      Wed Jan 26 01:31:34 2011 (4D3FBFC6)
fffff880`01200000 fffff880`0122a000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00cb9000 fffff880`00d79000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`013cc000 fffff880`013fc000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c5b000 fffff880`00cb9000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`014b2000 fffff880`01525000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`048b1000 fffff880`048c1000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`04be4000 fffff880`04bf2000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`03aac000 fffff880`03aca000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`03a9d000 fffff880`03aac000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`017e8000 fffff880`017fe000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`04bc2000 fffff880`04be4000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`04a00000 fffff880`04a09000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`04bf2000 fffff880`04bfe000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`049ec000 fffff880`049ff000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`04a09000 fffff880`04a15000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`048c8000 fffff880`049bc000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`04800000 fffff880`04846000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`00e49000 fffff880`00e5d000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`00d79000 fffff880`00dc5000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01536000 fffff880`01540000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`03a70000 fffff880`03a85380   fsdfw    fsdfw.sys    Mon Jun 14 07:04:05 2010 (4C160CA5)
fffff880`03a86000 fffff880`03a8f3a0   fses     fses.sys     Tue Mar 09 06:37:48 2010 (4B96330C)
fffff880`0613f000 fffff880`06173000   fsgk     fsgk.sys     Tue Sep 21 06:51:16 2010 (4C988E24)
fffff880`03a90000 fffff880`03a9cf60   fshs     fshs.sys     Fri Jun 04 04:39:19 2010 (4C08BBB7)
fffff880`03a68000 fffff880`03a70000   fsvista  fsvista.sys  Wed Jun 23 07:59:23 2010 (4C21F71B)
fffff880`01400000 fffff880`0143a000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`01540000 fffff880`0158a000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`02ff6000 fffff800`0303f000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`04a53000 fffff880`04a5e000   hamachi  hamachi.sys  Thu Feb 19 05:36:41 2009 (499D3639)
fffff880`04846000 fffff880`0486a000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`04a7c000 fffff880`04ad8000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`026db000 fffff880`026f4000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`026f4000 fffff880`026fc080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`0163a000 fffff880`01648000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`02600000 fffff880`026c8000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`017df000 fffff880`017e8000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`03b01000 fffff880`03b17000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`04a5e000 fffff880`04a6d000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`02733000 fffff880`02741000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bbe000 fffff800`00bc8000   kdcom    kdcom.dll    Sat Feb 05 07:21:45 2011 (4D4D40D9)
fffff880`03c00000 fffff880`03c43000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`01498000 fffff880`014b2000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`0179a000 fffff880`017c5000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`049c4000 fffff880`049c9200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`04ae0000 fffff880`04ae3d80   LGBusEnum LGBusEnum.sys Mon Nov 23 20:36:48 2009 (4B0B38B0)
fffff880`06173000 fffff880`06175480   LGVirHid LGVirHid.sys Mon Nov 23 20:36:48 2009 (4B0B38B0)
fffff880`026fd000 fffff880`02712000   LHidFilt LHidFilt.Sys Tue Aug 24 13:21:36 2010 (4C73FFA0)
fffff880`05be5000 fffff880`05bf2000   lirsgt   lirsgt.sys   Sun May 17 09:06:57 2009 (4A100BF1)
fffff880`027c4000 fffff880`027d9000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0271f000 fffff880`02733000   LMouFilt LMouFilt.Sys Tue Aug 24 13:21:43 2010 (4C73FFA7)
fffff880`0274f000 fffff880`02772000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c03000 fffff880`00c47000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`02741000 fffff880`0274f000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`04a6d000 fffff880`04a7c000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`02712000 fffff880`0271f000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00fe3000 fffff880`00ffd000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`05ae0000 fffff880`05af8000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`05af8000 fffff880`05b25000   mrxsmb   mrxsmb.sys   Wed Feb 23 00:15:23 2011 (4D6497EB)
fffff880`05b25000 fffff880`05b73000   mrxsmb10 mrxsmb10.sys Wed Feb 23 00:15:14 2011 (4D6497E2)
fffff880`05b73000 fffff880`05b96000   mrxsmb20 mrxsmb20.sys Wed Feb 23 00:15:13 2011 (4D6497E1)
fffff880`00e33000 fffff880`00e3e000   msahci   msahci.sys   Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`02c0f000 fffff880`02c1a000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`011d5000 fffff880`011df000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`0143a000 fffff880`01498000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`03a5d000 fffff880`03a68000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`017cd000 fffff880`017df000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01648000 fffff880`0173a000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`049e0000 fffff880`049ec000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`02dc9000 fffff880`02df8000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`04b50000 fffff880`04b65000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02d54000 fffff880`02d63000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02ce0000 fffff880`02d25000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`0173a000 fffff880`0179a000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`02c1a000 fffff880`02c2b000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03a51000 fffff880`03a5d000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02a19000 fffff800`02ff6000   nt       ntkrnlmp.exe Tue Oct 26 22:43:09 2010 (4CC791BD)
fffff880`0122a000 fffff880`013cc000   Ntfs     Ntfs.sys     Thu Mar 10 22:39:25 2011 (4D79996D)
fffff880`00e5d000 fffff880`00e66000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`02d2e000 fffff880`02d54000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`04894000 fffff880`048b1000   parport  parport.sys  Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`01000000 fffff880`01015000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f3f000 fffff880`00f72000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`01015000 fffff880`0101c000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`011ec000 fffff880`011fc000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01525000 fffff880`01536000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`05a00000 fffff880`05aa6000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`04b85000 fffff880`04bc2000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c47000 fffff880`00c5b000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`03bd5000 fffff880`03bf9000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`03c43000 fffff880`03c5e000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`04a18000 fffff880`04a39000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`04a39000 fffff880`04a53000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`03a00000 fffff880`03a51000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`00dea000 fffff880`00df3000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`00df3000 fffff880`00dfc000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02c06000 fffff880`02c0f000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01600000 fffff880`0163a000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`027d9000 fffff880`027f1000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`03b65000 fffff880`03bd5000   Rt64win7 Rt64win7.sys Mon Mar 21 09:20:32 2011 (4D8750A0)
fffff880`02daf000 fffff880`02dc9000   SCDEmu   SCDEmu.SYS   Mon Apr 12 04:52:25 2010 (4BC2DF49)
fffff880`0114f000 fffff880`0117e000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
fffff880`05aa6000 fffff880`05ab1000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`04888000 fffff880`04894000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`02d63000 fffff880`02d80000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`049bc000 fffff880`049c4000   serscan  serscan.sys  Mon Jul 13 20:35:32 2009 (4A5BD2D4)
fffff880`017c5000 fffff880`017cd000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`01020000 fffff880`01146000   sptd     sptd.sys     Sun Oct 11 16:55:14 2009 (4AD24632)
fffff880`060aa000 fffff880`0613f000   srv      srv.sys      Wed Feb 23 00:16:24 2011 (4D649828)
fffff880`06043000 fffff880`060aa000   srv2     srv2.sys     Wed Feb 23 00:15:59 2011 (4D64980F)
fffff880`06004000 fffff880`06031000   srvnet   srvnet.sys   Wed Feb 23 00:15:49 2011 (4D649805)
fffff880`04ade000 fffff880`04adf480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01802000 fffff880`019ff000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`06031000 fffff880`06043000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`02c49000 fffff880`02c56000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`02c2b000 fffff880`02c49000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02d9b000 fffff880`02daf000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00580000 fffff960`0058a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`03adb000 fffff880`03b01000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`04ae4000 fffff880`04af6000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`015d6000 fffff880`015f3000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`04a15000 fffff880`04a16f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`04877000 fffff880`04888000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04af6000 fffff880`04b50000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04560000 fffff880`045b6000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`0486a000 fffff880`04877000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`011df000 fffff880`011ec000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`00e6d000 fffff880`00e7b000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`00dc5000 fffff880`00dea000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00f72000 fffff880`00f87000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00f87000 fffff880`00fe3000   volmgrx  volmgrx.sys  unavailable (00000000)
fffff880`0158a000 fffff880`015d6000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`02d80000 fffff880`02d9b000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`00e7b000 fffff880`00e8b000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e8c000 fffff880`00f30000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f30000 fffff880`00f3f000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02d25000 fffff880`02d2e000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`000b0000 fffff960`003c2000   win32k   win32k.sys   Wed Mar 02 22:58:01 2011 (4D6F11C9)
fffff880`01146000 fffff880`0114f000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`02772000 fffff880`02793000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`02793000 fffff880`027c4000   WUDFRd   WUDFRd.sys   Mon Jul 13 20:06:06 2009 (4A5BCBEE)
Unloaded modules:
fffff880`06176000 fffff880`061e7000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`0163a000 fffff880`01648000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`015d6000 fffff880`015e2000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`015e2000 fffff880`015eb000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`015eb000 fffff880`015fe000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`04aad000 fffff880`04ade000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`04a7c000 fffff880`04aad000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
Okay, here are the memory and SPD screens if that would help any, and, ummm, how do I load bios? It has to be done when the computer is booting and my keyboard doesn't work until it is fully on(G510).
1. Set your memory 800Mhz 5-5-5-16 1.80v.
Right now you have it wrong 667 5-5-5-15.
2. Attach CPU-Z CPU tab
3. Passmark RAMMon HTML.zip
4. BIOS settings -- it's not the same for al bioses.
How to enter bios setup? Press "Del" on boot.
I don't know how to set my memory. How do I do that? What's rammon and how do I passmark it? And I told you that my keyboard doesn't work when the computer is booting, it works only when the windows is already logged in. Even the buttons do not do anything, thus I have to wait those extra 30 secs between bsods, so, eh. And here you go, the CPU!
PS. I know I am probably getting on your nerves or something, but yeah, I am not really technical. Sorry.
#7
Oh the frequency has fallen to 2000, it rose up to 3000, most likely, because I have had a youtube vid and a megavideo vid loading at the same time.
And what about EIST and I ask you again, what do I do with the memory? How can I change all this data? And here you go with the rammon thing (it's in text because it didn't let me upload in the HTML format):
Eh, I feel like my bsods are never going to be fixed. :/
#8
No they won't, your RAM sticks are poorly matched:
Slot #1 DDR2-800 Patriot
Slot #2 DDR-667 Kingmax
Slot #3 DDR2-800 Patriot
That's why you are getting stop 0x124 and 3B with memory acccess violation.
How to fix:
1. Physically remove Kingmax from Slot #2
2. Set the Patriot RAM this way, 800 Mhz 5-5-5-16 1.80v
3. EIST must be on, good if it is.
Now, exactly where are these settings located in your bios ?
- I don't know, usually Advanced Dram Configuration & Chipset.
#9
Hm, so I need to get my patriot ram and my EIST in order by going into bios, make my computer into a skeleton, take out kingmax ram and that's it? Will it be written which ones iare the patriot RAM things? Should I change one or both? Oh and what do I do about the kingmax thing? Do I insert it back after removing it or what?
Not quite, basically you need:
a) well matched sticks with the same rates (DDR667 + DDR800 = BSOD)
b) hardware set at stock as recommended by the manufacturer
Otherwise you'll have to enjoy those nasty blue screens.
#11
Hmmm. Speaking like a human to a human, not an alien to a farmer, I will need to call a technician, won't I...?
#12
If you don't know how to open up your PC case to take out the Kingmax stick from slot #2, and if you don't know how to load default settings for your bios, then call PC technician for sure. Or send your PC to the repair's shop.
#13
Well, at least thanks for trying. I'll fix it soon enough. Well, so long, until I have more problems with my Win7 which is doubtful.
#14
DDR667 in combination with DDR800 gives you blue screens. Remove the DDR667 stick, then load setup defaults in your bios, save, reboot, and enjoy.
Good luck.
042911-22417-01.dmp
CURRENT_IRQL: f
Stack nt hal
042911-20295-01.dmp
FAULTING_IP:
