Windows 7 BSOD's on startup
jhutch
I received my first crash a few days ago while playing a game. Since then I have been crashing during the startup process nearly every time. I was able to salvage the minidumps. I've tried startup recovery, system recovery and memory testing.
Thanks for any help!
I believe I ended up solving this. It looks to have been a hardware issue. I changed my gfx card pci-e port and all seems to be working now. It looks like the other one was having issues. Asus mobos *sigh*.
Please provide this info for a more complete analysis: Link Removed
Daemon Tools (and Alcohol % software) are known to cause BSOD's on some Win7 systems (mostly due to the sptd.sys driver, although I have seen dtsoftbus01.sys blamed on several occasions).
Please un-install the program, then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration): [DEL] Link Removed [/DEL] Link broken as of 21 Jul 2012
New link (15 Aug 2012): Link Removed (pick the appropriate version for your system and select "Un-install" when you run it).
Alternate link: Disc-Tools.com
Manual procedure here: Registry and SPTD problems | DAEMON Pro Help
UsbFltr.sys Wed Apr 11 04:23:46 2007 (461C9B12)
Ortek USB Keypad Driver by Waytech Development (may be a part of Razer Tarantula drivers also)
adfs.SYS Thu Jun 26 16:52:37 2008 (48640195)
Adobe File System Driver
mcdbus.sys Tue Feb 24 05:34:07 2009 (49A3CD1F)
MagicISO SCSI Host Controller driver
LHidFilt.Sys Wed Jun 17 12:49:39 2009 (4A391EA3)
Logitech SetPoint HID Filter Driver
LMouFilt.Sys Wed Jun 17 12:49:43 2009 (4A391EA7)
nusb3hub.sys Thu Jan 21 22:22:18 2010 (4B5919EA)
NEC Electronics USB 3.0 Host Controller Driver (previous BSOD issues with 2010 version)
nusb3xhc.sys Thu Jan 21 22:22:21 2010 (4B5919ED)
dtsoftbus01.sys Fri Jan 13 08:45:46 2012 (4F10358A)
Daemon Tools driver [br] Possible BSOD issues in Win7
sptd.sys Sat Mar 3 11:45:52 2012 (4F524AC0)
SCSI Pass Through Direct Host - Daemon Tools (known BSOD issues with Win7)
Analysis:
The following is for informational purposes only.
[FONT=lucida console]**************************Mon Nov 19 00:28:25.034 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111812-41184-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Built by: [B]7601[/B].17944.amd64fre.win7sp1_gdr.120830-0333
System Uptime:[B]0 days 0:03:25.048[/B]
BugCheck Code: [B]BugCheck A, {dc, 2, 1, fffff80002ec80c5}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KeStackAttachProcess+115 )[/B]
BugCheck Info: [B]IRQL_NOT_LESS_OR_EQUAL (a)[/B]
Arguments:
Arg1: 00000000000000dc, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
Arg4: fffff80002ec80c5, address which referenced memory
BUGCHECK_STR:  0xA
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]X64_0xA_nt!KeStackAttachProcess+115[/B]
CPUID:        "Intel(R) Core(TM) i7 CPU         930  @ 2.80GHz"
MaxSpeed:     2800
CurrentSpeed: [B]2806[/B]
  BIOS Version                  0108
  BIOS Release Date             03/23/2010
**************************Sun Nov 18 23:33:53.676 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111812-33930-01.dmp]
System Uptime:[B]0 days 0:00:27.580[/B]
BugCheck Code: [B]BugCheck C9, {23e, fffffa800bb932c0, fffff98007da4e10, 0}[/B]
*** WARNING: Unable to verify timestamp for PxHlpa64.sys
*** ERROR: Module load completed but symbols could not be loaded for PxHlpa64.sys
Probably caused by :[B]PxHlpa64.sys ( PxHlpa64+34d5 )[/B]
BugCheck Info: [B]DRIVER_VERIFIER_IOMANAGER_VIOLATION (c9)[/B]
Arguments:
Arg1: 000000000000023e, A driver has marked an IRP pending but didn't return STATUS_PENDING.
Arg2: fffffa800bb932c0, The address in the driver's code where the error was detected.
Arg3: fffff98007da4e10, IRP address.
Arg4: 0000000000000000, Status code.
BUGCHECK_STR:  0xc9_23e
DEFAULT_BUCKET_ID: [B]VERIFIER_ENABLED_VISTA_MINIDUMP[/B]
FAILURE_BUCKET_ID: [B]X64_0xc9_23e_VRF_PxHlpa64+34d5[/B]
MaxSpeed:     2800
  BIOS Version                  0108
**************************Sun Nov 18 19:57:47.941 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111812-51464-01.dmp]
System Uptime:[B]0 days 1:12:12.956[/B]
BugCheck Code: [B]BugCheck 1E, {ffffffffc0000096, fffff80002eaf16a, 0, 0}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KeStackAttachProcess+1ba )[/B]
BugCheck Info: [B]KMODE_EXCEPTION_NOT_HANDLED (1e)[/B]
Arguments:
Arg1: ffffffffc0000096, The exception code that was not handled
Arg2: fffff80002eaf16a, The address that the exception occurred at
BUGCHECK_STR:  0x1E_c0000096
FAILURE_BUCKET_ID: [B]X64_0x1E_c0000096_nt!KeStackAttachProcess+1ba[/B]
MaxSpeed:     2800
  BIOS Version                  0108
**************************Sun Nov 18 18:13:17.995 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111812-38111-01.dmp]
System Uptime:[B]0 days 0:02:57.899[/B]
BugCheck Code: [B]BugCheck 1E, {ffffffffc0000005, fffffa800b8d0bb0, 0, 7efa8000}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+487ad )[/B]
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffffa800b8d0bb0, The address that the exception occurred at
Arg4: 000000007efa8000, Parameter 1 of the exception
BUGCHECK_STR:  0x1E_c0000005_R
PROCESS_NAME: [B]MMLoadDrv.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x1E_c0000005_R_nt!_??_::FNODOBFM::_string_+487ad[/B]
MaxSpeed:     2800
  BIOS Version                  0108
**************************Sun Nov 18 20:56:28.347 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111812-35474-01.dmp]
System Uptime:[B]0 days 0:03:54.361[/B]
BugCheck Code: [B]BugCheck 3B, {c0000005, fffff800031cf786, fffff88007b5af50, 0}[/B]
Probably caused by :[B]memory_corruption ( nt!MmCreateSection+4c6 )[/B]
BugCheck Info: [B]SYSTEM_SERVICE_EXCEPTION (3b)[/B]
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff800031cf786, Address of the instruction which caused the bugcheck
Arg3: fffff88007b5af50, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
BUGCHECK_STR:  0x3B
PROCESS_NAME: [B]chrome.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x3B_nt!MmCreateSection+4c6[/B]
MaxSpeed:     2800
  BIOS Version                  0108
**************************Sun Nov 18 18:09:27.929 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111812-32151-01.dmp]
System Uptime:[B]0 days 0:02:17.944[/B]
BugCheck Code: [B]BugCheck 1E, {ffffffffc0000005, fffffa800b887bb0, 0, 7efa8000}[/B]
Arguments:
Arg2: fffffa800b887bb0, The address that the exception occurred at
MaxSpeed:     2800
  BIOS Version                  0108
**************************Sat Nov 17 16:55:57.171 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111712-44631-01.dmp]
System Uptime:[B]0 days 0:04:08.186[/B]
BugCheck Code: [B]BugCheck 1E, {ffffffffc0000005, fffffa800b8e8bb0, 0, 7efa8000}[/B]
Arguments:
Arg2: fffffa800b8e8bb0, The address that the exception occurred at
MaxSpeed:     2800
  BIOS Version                  0108
**************************Sat Nov 17 16:50:12.153 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111712-39390-01.dmp]
System Uptime:[B]0 days 0:02:47.168[/B]
BugCheck Code: [B]BugCheck 1E, {ffffffffc0000005, fffff80002e6f66b, 0, 7efa0000}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!RtlImageNtHeaderEx+3f )[/B]
Arguments:
Arg2: fffff80002e6f66b, The address that the exception occurred at
Arg4: 000000007efa0000, Parameter 1 of the exception
FAILURE_BUCKET_ID: [B]X64_0x1E_c0000005_R_nt!RtlImageNtHeaderEx+3f[/B]
MaxSpeed:     2800
  BIOS Version                  0108
[/FONT]
3rd Party Drivers:
[B]UsbFltr.sys                   Wed Apr 11 04:23:46 2007 (461C9B12)[/B]
[B]adfs.SYS                      Thu Jun 26 16:52:37 2008 (48640195)[/B]
[B]mcdbus.sys                    Tue Feb 24 05:34:07 2009 (49A3CD1F)[/B]
[B]LHidFilt.Sys                  Wed Jun 17 12:49:39 2009 (4A391EA3)[/B]
[B]LMouFilt.Sys                  Wed Jun 17 12:49:43 2009 (4A391EA7)[/B]
intelppm.sys                  Mon Jul 13 19:19:25 2009 (4A5BC0FD)
ASACPI.sys                    Wed Jul 15 23:31:29 2009 (4A5E9F11)
RTL8192su.sys                 Wed Aug 19 23:00:10 2009 (4A8CBC3A)
yk62x64.sys                   Mon Sep 28 04:19:31 2009 (4AC07193)
PxHlpa64.sys                  Tue Oct 20 14:08:42 2009 (4ADDFCAA)
[B]nusb3hub.sys                  Thu Jan 21 22:22:18 2010 (4B5919EA)[/B]
[B]nusb3xhc.sys                  Thu Jan 21 22:22:21 2010 (4B5919ED)[/B]
amdxata.sys                   Fri Mar 19 12:18:18 2010 (4BA3A3CA)
avgidsdrivera.sys             Fri Dec 23 07:05:21 2011 (4EF46E81)
avgidsfiltera.sys             Fri Dec 23 07:05:40 2011 (4EF46E94)
avgmfx64.sys                  Fri Dec 23 07:08:12 2011 (4EF46F2C)
agm422r2.SYS                  Tue Dec 27 17:30:45 2011 (4EFA4715)
avgrkx64.sys                  Mon Jan 30 22:11:41 2012 (4F275BED)
[B]sptd.sys                      Sat Mar  3 11:45:52 2012 (4F524AC0)[/B]
avgidsha.sys                  Wed Apr 18 22:19:15 2012 (4F8F7623)
GEARAspiWDM.sys               Thu May  3 15:56:17 2012 (4FA2E2E1)
AtihdW76.sys                  Fri May 11 04:25:40 2012 (4FACCD04)
mcaudrv_x64.sys               Tue Jun 26 11:33:54 2012 (4FE9D662)
mcvidrv_x64.sys               Thu Jun 28 01:29:29 2012 (4FEBEBB9)
avgldx64.sys                  Wed Jul 25 20:56:48 2012 (501095D0)
avgtdia.sys                   Fri Aug 24 09:20:13 2012 (50377F8D)
atikmpag.sys                  Thu Sep 27 21:12:52 2012 (5064F994)
atikmdag.sys                  Thu Sep 27 22:14:57 2012 (50650821)
RTKVHD64.sys                  Fri Jan 29 01:48:35 2010 (4B6284C3)
a4141cj3.SYS                  Tue Dec 27 17:30:45 2011 (4EFA4715)
[B]dtsoftbus01.sys               Fri Jan 13 08:45:46 2012 (4F10358A)[/B]
a8twd9ce.SYS                  Tue Dec 27 17:30:45 2011 (4EFA4715)
ac73duv1.SYS                  Tue Dec 27 17:30:45 2011 (4EFA4715)
TuneUpUtilitiesDriver64.sys   Fri May 25 06:28:19 2012 (4FBF5EC3)
ahkn1gsm.SYS                  Tue Dec 27 17:30:45 2011 (4EFA4715)
azunghub.SYS                  Tue Dec 27 17:30:45 2011 (4EFA4715)
assk865f.SYS                  Tue Dec 27 17:30:45 2011 (4EFA4715)
ar5obyk6.SYS                  Tue Dec 27 17:30:45 2011 (4EFA4715)
[/FONT]
agm422r2.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
a4141cj3.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
a8twd9ce.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
ac73duv1.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
ahkn1gsm.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
azunghub.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
assk865f.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
ar5obyk6.SYS - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
