BSODs while playing battlefield 3, randomly and idle
I've been getting many BSOD's recently, theyre occuring randomly, when PC is idle or lots of them when playing battlefield 3 (those have been reduced significantly by increasing GPU fan speed to manual 70%).
I've tried:
Cleaning up registry
Cleaning up HDD
Reinstalling GPU drivers with driver sweeper
Swapping out RAM and cleaning it up
Run Furmark stress test - 15 minutes max perf. whole test, no errors
Used win memory check tool - no errors
My Rig:
CPU: AMD Athlon II X4 630 2.8 GHz
GPU: Radeon HD 5850 1 GB
RAM: 4 GB RAM DDR3 (4 modules)
MB: M4A78-EM
PSU: Arctic Cooling Fusion 550
OS: Win 7 Ultimate x64
My PC is cca 2 years old, its currently running on defaults clocks (everything)
Most of my BSOD's are SYSTEM_SERVICE_EXCEPTION but I've had many others such as:
BSOD REFERENCE_BY_POINTER
BSOD BAD_POOL_HEADER
BSOD BAD_POOL_CALLER
BSOD irql_not_less_or_equal
BSOD page_fault_in_nonpaged_area
BSOD driver irql_not_less_or_equal
BSOD MEMORY MANAGEMENT
Also, this is what I am getting after win restarts after BSOD (this one is most recent, previous ones looks very similiar)...
Problem signature:
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1029
Additional information about the problem:
BCCode: 1a
BCP1: 0000000000005003
BCP2: FFFFF781C0000000
BCP3: 000000000000982B
BCP4: 00009CDB00003056
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\071912-18252-01.dmp
C:\Users\Aerin\AppData\Local\Temp\WER-41667-0.sysdata.xml
I am also including BSOD Dump & System File Collection and System Health Report
Any ideas what can be causing this?
any help appreciated
Regards
I've tried:
Cleaning up HDD
My Rig:
MB: M4A78-EM
Problem signature:
Locale ID: 1029
BCCode: 1a
Service Pack: 1_0
Product: 256_1
View attachment bsod reports.zip
Regards
Windows Forum Admin
Please do not double post. Your posts have been merged to save confusion.
I checked your dmp files and you need to update drivers particularly Realtek HD and Realtek Network driver as they are very old. You also need to check your RAM using the app found here: Memtest86+ - Advanced Memory Diagnostic Tool. Only test one stick at a time and allow for 7/8 passes.
I know you said you'd already tested using the windows version but I'm afraid it just doesn't do the job...
