BUGCODE_USB_DRIVER BSOD
Greetings all, I have attached my minidump file View attachment Minidump.rar . I have been having problems over several months. You will see in the minidump file, there is 1 dump file from January and then nothing until August. That is because my minidump files were overwriting for a while, so that is why there is a gap there, but there was still BSOD's that occurred during that time frame. Most of which were USB_DRIVER errors if I recall correctly.
My computer is an ASUS N61JV
-The mobo is an i5 that supports USB 2.0 and 3.0
-I have an interated webcam and mic that may use a USB protocol.
-ASUS also put "optimus" on this computer, so I have 2 graphics cards. An integrated and a dedicated graphics card. The Dedicated graphics card is an NVIDIA GT 325M CUDA w/ 1GB dedicated ram
-System RAM is DDR3 don't remember the specs on it, but I can find it if you need it.
-64bit Win7
-500GB regular harddrive
-I am using Microsoft Security Essentials
I've tried many things to fix the problem, but I must have missed something at some point, or installed a bad driver or else this wouldn't be happening. I've even rolled back to default many drivers, but to no avail. Let me know what you think. Thanks for your help!
kaos
Hi , to be honest i would rather prefer an upto date DMP , things might have changed since janurary. if u delete the old one and then any new ones please upload, i just prefer workign with fresh data
(plus things change over the months i.e drivers etc)
Oh, they are all in the .rar file. If you don't want to look at the one from January, then you may just disregard it. There is 4 in there from the last 2 months. :)
They are named by the date they occurred: MMDDYY-XXXXXX-XX
kaos
ANALYSIS
BugCheck FE, {8, 6, 5, fffffa8007ba2b20}
Probably caused by : usbhub.sys ( usbhub!UsbhHubProcessChangeWorker+ec )
Followup: MachineOwner
0: kd> !analyze -v
BUGCODE_USB_DRIVER (fe)
USB Driver bugcheck, first parameter is USB bugcheck code.
Arguments:
Arg1: 0000000000000008, USBBUGCODE_RESERVED_USBHUB
Arg2: 0000000000000006, USBHUB_TRAP_FATAL_TIMEOUT
Arg3: 0000000000000005, TimeoutCode: Timeout_PCE_Suspend_Action3 - PortData->PortSuspendEvent
Arg4: fffffa8007ba2b20, TimeoutContext - PortData
Debugging Details:
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xFE
PROCESS_NAME:  System
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff88004131a60 to fffff80003097c40
STACK_TEXT:
fffff880`033b6c18 fffff880`04131a60 : 00000000`000000fe 00000000`00000008 00000000`00000006 00000000`00000005 : nt!KeBugCheckEx
fffff880`033b6c20 fffff800`0338e9e3 : fffffa80`07b9e050 00000000`00000001 ffffffff`dc3a58a0 fffff800`032382b8 : usbhub!UsbhHubProcessChangeWorker+0xec
fffff880`033b6c80 fffff800`030a2001 : fffff800`03238200 fffff800`0338e901 fffffa80`03b68000 fffffa80`07891840 : nt!IopProcessWorkItem+0x23
fffff880`033b6cb0 fffff800`03332fee : ffffdfff`ffffffff fffffa80`03b68040 00000000`00000080 fffffa80`03b4f740 : nt!ExpWorkerThread+0x111
fffff880`033b6d40 fffff800`030895e6 : fffff880`031d3180 fffffa80`03b68040 fffff880`031ddfc0 00000000`00000000 : nt!PspSystemThreadStartup+0x5a
fffff880`033b6d80 00000000`00000000 : fffff880`033b7000 fffff880`033b1000 fffff880`033b6970 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff880`04131a60 cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  usbhub!UsbhHubProcessChangeWorker+ec
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: usbhub
IMAGE_NAME:  usbhub.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4d8c0c15
FAILURE_BUCKET_ID:  X64_0xFE_usbhub!UsbhHubProcessChangeWorker+ec
BugCheck D1, {14a0, 2, 0, fffff8800590a1c5}
Unable to load image athrx.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for athrx.sys
*** ERROR: Module load completed but symbols could not be loaded for athrx.sys
Probably caused by : athrx.sys ( athrx+bb1c5 )
2: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 00000000000014a0, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff8800590a1c5, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800032c8100
 00000000000014a0
CURRENT_IRQL:  2
FAULTING_IP:
athrx+bb1c5
fffff880`0590a1c5 48833800        cmp     qword ptr [rax],0
BUGCHECK_STR:  0xD1
PROCESS_NAME:  firefox.exe
TRAP_FRAME:  fffff88003191fd0 -- (.trap 0xfffff88003191fd0)
rax=00000000000014a0 rbx=0000000000000000 rcx=fffffa8007af1e58
rdx=0000000000000cee rsi=0000000000000000 rdi=0000000000000000
rip=fffff8800590a1c5 rsp=fffff88003192160 rbp=0000000000000000
 r8=0000000000000000  r9=0000000000000000 r10=fffff880059b92a0
r11=00000000000000ff r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl nz na po nc
athrx+0xbb1c5:
fffff880`0590a1c5 48833800        cmp     qword ptr [rax],0 ds:0001:00000000`000014a0=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff800030951e9 to fffff80003095c40
STACK_TEXT:
fffff880`03191e88 fffff800`030951e9 : 00000000`0000000a 00000000`000014a0 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`03191e90 fffff800`03093e60 : fffff880`031920d0 00000000`058b001c fffffa80`07334650 fffffa80`071701a0 : nt!KiBugCheckDispatch+0x69
fffff880`03191fd0 fffff880`0590a1c5 : 00000000`00000000 fffffa80`00000001 fffff880`03192430 fffffa80`071701a0 : nt!KiPageFault+0x260
fffff880`03192160 00000000`00000000 : fffffa80`00000001 fffff880`03192430 fffffa80`071701a0 fffffa80`04441140 : athrx+0xbb1c5
STACK_COMMAND:  kb
FOLLOWUP_IP:
athrx+bb1c5
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  athrx+bb1c5
MODULE_NAME: athrx
IMAGE_NAME:  athrx.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4aca1ff5
FAILURE_BUCKET_ID:  X64_0xD1_athrx+bb1c5
DRIVERS
fffff800`00bae000 fffff800`00bb8000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff800`0301b000 fffff800`03604000   nt       ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff800`03604000 fffff800`0364d000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`00cc0000 fffff880`00cd0000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`00ce4000 fffff880`00d33000   mcupdate mcupdate.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`00d33000 fffff880`00d47000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`00d47000 fffff880`00da5000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00da5000 fffff880`00dbf000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`00e00000 fffff880`00e5c000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`00e5c000 fffff880`00f00000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f00000 fffff880`00f0f000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00f0f000 fffff880`00f66000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`00f66000 fffff880`00f6f000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00f6f000 fffff880`00f79000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`00f79000 fffff880`00fac000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00fac000 fffff880`00fb9000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`00fb9000 fffff880`00fce000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00fce000 fffff880`00fd7000   compbatt compbatt.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00fd7000 fffff880`00fe3000   BATTC    BATTC.SYS    Tue Jul 14 00:31:01 2009 (4A5BC3B5)
fffff880`00fe3000 fffff880`00ff8000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00ff8000 fffff880`00fff000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`01000000 fffff880`01072000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`010ac000 fffff880`012b4000   iaStor   iaStor.sys   Thu Dec 17 18:41:59 2009 (4B2A7B77)
fffff880`012b4000 fffff880`012bd000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`012bd000 fffff880`012e7000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`012e7000 fffff880`012f2000   msahci   msahci.sys   Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`012f2000 fffff880`012fd000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`012fd000 fffff880`01349000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`01349000 fffff880`0135d000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`0135d000 fffff880`01366000   lullaby  lullaby.sys  Thu Jun 18 03:45:32 2009 (4A39AA4C)
fffff880`01366000 fffff880`013c4000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`01401000 fffff880`015a4000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`015a4000 fffff880`015bf000   ksecdd   ksecdd.sys   Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`015bf000 fffff880`015d0000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`015d0000 fffff880`015da000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01632000 fffff880`01725000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`01725000 fffff880`01785000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`01785000 fffff880`017b0000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`017b0000 fffff880`017cb000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`017cb000 fffff880`017df000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff880`01800000 fffff880`01816000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01816000 fffff880`01846000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`01854000 fffff880`01899000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`01899000 fffff880`018af000   vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`018c2000 fffff880`01ac6000   tcpip    tcpip.sys    Tue Jun 21 04:33:55 2011 (4E001123)
fffff880`01ac6000 fffff880`01b10000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff880`01b10000 fffff880`01b5c000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`01b5c000 fffff880`01b64000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`01b64000 fffff880`01b9e000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`01b9e000 fffff880`01ba8000   nvpciflt nvpciflt.sys Wed Aug 03 10:09:24 2011 (4E391044)
fffff880`01ba8000 fffff880`01bba000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`01bba000 fffff880`01bc3000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`01bc3000 fffff880`01bfd000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`02200000 fffff880`023b7800   snp2uvc  snp2uvc.sys  Thu Aug 20 03:41:36 2009 (4A8CB7E0)
fffff880`023f4000 fffff880`023fc080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`04000000 fffff880`04036000   fastfat  fastfat.SYS  Tue Jul 14 00:23:28 2009 (4A5BC1F0)
fffff880`04053000 fffff880`040a4000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`040a4000 fffff880`040b0000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff880`040b0000 fffff880`040bb000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`040bb000 fffff880`040ca000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`040ca000 fffff880`040e8000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`040e8000 fffff880`040f9000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`040f9000 fffff880`0411f000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`0411f000 fffff880`04179000   usbhub   usbhub.sys   Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`04179000 fffff880`041cc000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`041cc000 fffff880`041e4000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`04200000 fffff880`04222000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`04222000 fffff880`0422f000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`0422f000 fffff880`042b8000   afd      afd.sys      Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`042b8000 fffff880`042c1000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`042c1000 fffff880`042e7000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`042e7000 fffff880`044ef000   dump_iaStor dump_iaStor.sys Thu Dec 17 18:41:59 2009 (4B2A7B77)
fffff880`0450c000 fffff880`04536000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`04536000 fffff880`04567000   MpFilter MpFilter.sys Wed Apr 06 21:07:29 2011 (4D9CC801)
fffff880`04567000 fffff880`04570000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`04570000 fffff880`04577000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`04577000 fffff880`04585000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`04585000 fffff880`045aa000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`045aa000 fffff880`045ba000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`045ba000 fffff880`045c3000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`045c3000 fffff880`045cc000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`045cc000 fffff880`045d5000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`045d5000 fffff880`045e0000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`045e0000 fffff880`045f1000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`045f1000 fffff880`04600000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`04600000 fffff880`04616000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`0461f000 fffff880`04713000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`04713000 fffff880`04759000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`04759000 fffff880`047af000   USBPORT  USBPORT.SYS  Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`047af000 fffff880`047d1000   ETD      ETD.sys      Thu Oct 15 10:23:18 2009 (4AD6EA06)
fffff880`047d1000 fffff880`047e0000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`047e0000 fffff880`047e9000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`047e9000 fffff880`047f1000   ATK64AMD ATK64AMD.sys Wed May 13 02:04:54 2009 (4A0A1CB6)
fffff880`047f1000 fffff880`047fd000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`04c00000 fffff880`04c2f000   nusb3xhc nusb3xhc.sys Mon Oct 26 14:19:48 2009 (4AE5B004)
fffff880`04c2f000 fffff880`04c30f00   USBD     USBD.SYS     Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`04c31000 fffff880`04c44000   L1C62x64 L1C62x64.sys Fri Sep 04 06:39:09 2009 (4AA0A7FD)
fffff880`04c44000 fffff880`04c62000   i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`04c64000 fffff880`04de1000   athrx    athrx.sys    Mon Oct 05 17:33:57 2009 (4ACA1FF5)
fffff880`04de1000 fffff880`04dee000   vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`04dee000 fffff880`04dfd000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`04dfd000 fffff880`04dfe480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`05800000 fffff880`05824000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`05825000 fffff880`063cd5c0   igdkmd64 igdkmd64.sys Sun Apr 10 19:50:59 2011 (4DA1FC13)
fffff880`063ce000 fffff880`063df000   HECIx64  HECIx64.sys  Thu Sep 17 20:54:16 2009 (4AB293E8)
fffff880`063df000 fffff880`063f0000   usbehci  usbehci.sys  Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`063f0000 fffff880`063f8000   kbfiltr  kbfiltr.sys  Mon Jul 20 10:21:42 2009 (4A643726)
fffff880`063f8000 fffff880`063fc500   CmBatt   CmBatt.sys   Tue Jul 14 00:31:03 2009 (4A5BC3B7)
fffff880`06600000 fffff880`06623000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`06623000 fffff880`06644000   WudfPf   WudfPf.sys   Sat Nov 20 10:42:44 2010 (4CE7A624)
fffff880`06644000 fffff880`06659000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`06659000 fffff880`06661000   ASMMAP64 ASMMAP64.sys Thu Jul 02 10:13:26 2009 (4A4C7A36)
fffff880`0666a000 fffff880`06887000   RTKVHD64 RTKVHD64.sys Thu Dec 10 09:38:13 2009 (4B20C185)
fffff880`06887000 fffff880`068c4000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`068c4000 fffff880`068e6000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`068e6000 fffff880`068eb200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`068ec000 fffff880`0693f000   IntcDAud IntcDAud.sys Fri Oct 15 09:28:17 2010 (4CB810A1)
fffff880`0693f000 fffff880`0694d000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`0694d000 fffff880`06960000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`06960000 fffff880`0696c000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`069d9000 fffff880`069e7000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`069e7000 fffff880`069fa000   ndisuio  ndisuio.sys  Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`08a00000 fffff880`08a24000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`08a85000 fffff880`08b4e000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`08b4e000 fffff880`08b6c000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff880`08b6c000 fffff880`08b84000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`08b84000 fffff880`08bb1000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`08bb1000 fffff880`08bff000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`0a018000 fffff880`0a0be000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`0a0be000 fffff880`0a0c9000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`0a0c9000 fffff880`0a0fa000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`0a0fa000 fffff880`0a10c000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`0a10c000 fffff880`0a175000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`0a45b000 fffff880`0a4f3000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`0a524000 fffff880`0a534000   MpNWMon  MpNWMon.sys  Wed Apr 06 21:07:23 2011 (4D9CC7FB)
fffff880`0a534000 fffff880`0a54c000   NisDrvWFP NisDrvWFP.sys Wed Apr 06 21:08:53 2011 (4D9CC855)
fffff880`0a5bd000 fffff880`0a5c8000   asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`0a5c8000 fffff880`0a5e5000   usbccgp  usbccgp.sys  Fri Mar 25 03:29:14 2011 (4D8C0C0A)
fffff880`0a5e5000 fffff880`0a5f5d00   STREAM   STREAM.SYS   Tue Jul 14 01:06:18 2009 (4A5BCBFA)
fffff880`0a5f6000 fffff880`0a5fea80   sncduvc  sncduvc.SYS  Mon Dec 29 09:14:26 2008 (495894F2)
fffff880`0f200000 fffff880`0f21b000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`0f21b000 fffff880`0f23c000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`0f23c000 fffff880`0f256000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`0f256000 fffff880`0f299000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`0f299000 fffff880`0f2ab000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`0f2ab000 fffff880`0f2c2000   nusb3hub nusb3hub.sys Mon Oct 26 14:19:44 2009 (4AE5B000)
fffff880`0f2c2000 fffff880`0f2d7000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`0f2d7000 fffff880`0f2e1000   vwifimp  vwifimp.sys  Tue Jul 14 01:07:28 2009 (4A5BCC40)
fffff880`0f2eb000 fffff880`0ff4f000   nvlddmkm nvlddmkm.sys Wed Aug 03 10:08:32 2011 (4E391010)
fffff880`0ff4f000 fffff880`0ff54000   nvBridge nvBridge.kmd Sat May 21 04:58:23 2011 (4DD7385F)
fffff880`0ff54000 fffff880`0ff7ad00   Impcd    Impcd.sys    Fri Feb 26 23:32:11 2010 (4B8859FB)
fffff880`0ff7b000 fffff880`0ff8b000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`0ff8b000 fffff880`0ffa1000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`0ffa1000 fffff880`0ffc5000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`0ffc5000 fffff880`0fff4000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff960`00020000 fffff960`00333000   win32k   win32k.sys   Sat Jun 11 04:06:57 2011 (4DF2DBD1)
fffff960`004b0000 fffff960`004ba000   TSDDD    TSDDD.dll    Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff960`00740000 fffff960`00767000   cdd      cdd.dll      Sat Nov 20 12:55:34 2010 (4CE7C546)
fffff960`00820000 fffff960`00881000   ATMFD    ATMFD.DLL    Sat Feb 19 09:00:32 2011 (4D5F86B0)
Unloaded modules:
fffff880`0c41e000 fffff880`0c626000   hiber_iaStor
    Checksum:  00000000
    ImageSize:  00208000
fffff880`0c626000 fffff880`0c639000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`0696c000 fffff880`06989000   usbccgp.sys
    Checksum:  00000000
    ImageSize:  0001D000
fffff880`0a5a1000 fffff880`0a5b2000   STREAM.SYS
    Checksum:  00000000
    ImageSize:  00011000
fffff880`0a5b2000 fffff880`0a5bb000   sncduvc.SYS
    Checksum:  00000000
    ImageSize:  00009000
fffff880`02200000 fffff880`023b8000   snp2uvc.sys
    Checksum:  00000000
    ImageSize:  001B8000
fffff880`0a5e4000 fffff880`0a5fa000   LHidFilt.Sys
    Checksum:  00000000
    ImageSize:  00016000
fffff880`0a573000 fffff880`0a587000   LMouFilt.Sys
    Checksum:  00000000
    ImageSize:  00014000
fffff880`0a55a000 fffff880`0a573000   HIDCLASS.SYS
    Checksum:  00000000
    ImageSize:  00019000
fffff880`0a54c000 fffff880`0a55a000   hidusb.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0a44d000 fffff880`0a45a000   mouhid.sys
    Checksum:  00000000
    ImageSize:  0000D000
fffff880`0a587000 fffff880`0a598000   STREAM.SYS
    Checksum:  00000000
    ImageSize:  00011000
fffff880`0a598000 fffff880`0a5a1000   sncduvc.SYS
    Checksum:  00000000
    ImageSize:  00009000
    Checksum:  00000000
    ImageSize:  001B8000
fffff880`0a5a3000 fffff880`0a5a5000   MSPCLOCK.sys
    Checksum:  00000000
    ImageSize:  00002000
fffff880`0a5a1000 fffff880`0a5a3000   MSPQM.sys
    Checksum:  00000000
    ImageSize:  00002000
    Checksum:  00000000
    ImageSize:  00011000
    Checksum:  00000000
    ImageSize:  00009000
    Checksum:  00000000
    ImageSize:  001B8000
fffff880`0c2f0000 fffff880`0c4f8000   hiber_iaStor
    Checksum:  00000000
    ImageSize:  00208000
fffff880`0c4f8000 fffff880`0c50b000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`0a4f3000 fffff880`0a524000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`0a443000 fffff880`0a44d000   Dot4Prt.sys
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`0a428000 fffff880`0a443000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  0001B000
fffff880`0a400000 fffff880`0a428000   Dot4.sys
    Checksum:  00000000
    ImageSize:  00028000
fffff880`0a5c8000 fffff880`0a5d4000   usbprint.sys
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0a5a5000 fffff880`0a5b6000   usbscan.sys
    Checksum:  00000000
    ImageSize:  00011000
fffff880`0a5d4000 fffff880`0a5e4000   dot4usb.sys
    Checksum:  00000000
    ImageSize:  00010000
fffff880`0a54c000 fffff880`0a562000   LHidFilt.Sys
    Checksum:  00000000
    ImageSize:  00016000
fffff880`0a56f000 fffff880`0a583000   LMouFilt.Sys
    Checksum:  00000000
    ImageSize:  00014000
fffff880`0a501000 fffff880`0a51a000   HIDCLASS.SYS
    Checksum:  00000000
    ImageSize:  00019000
fffff880`0a4f3000 fffff880`0a501000   hidusb.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0a562000 fffff880`0a56f000   mouhid.sys
    Checksum:  00000000
    ImageSize:  0000D000
fffff880`0c2c3000 fffff880`0c4cb000   hiber_iaStor
    Checksum:  00000000
    ImageSize:  00208000
fffff880`0c4cb000 fffff880`0c4de000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`0a175000 fffff880`0a1e6000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`0a585000 fffff880`0a587000   MSPCLOCK.sys
    Checksum:  00000000
    ImageSize:  00002000
fffff880`0a583000 fffff880`0a585000   MSPQM.sys
    Checksum:  00000000
    ImageSize:  00002000
fffff880`0a41a000 fffff880`0a42b000   STREAM.SYS
    Checksum:  00000000
    ImageSize:  00011000
fffff880`0a42b000 fffff880`0a434000   sncduvc.SYS
    Checksum:  00000000
    ImageSize:  00009000
fffff880`02229000 fffff880`023e1000   snp2uvc.sys
    Checksum:  00000000
    ImageSize:  001B8000
fffff880`0c012000 fffff880`0c21a000   hiber_iaStor
    Checksum:  00000000
    ImageSize:  00208000
fffff880`0c21a000 fffff880`0c22d000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`0c2a2000 fffff880`0c4aa000   hiber_iaStor
    Checksum:  00000000
    ImageSize:  00208000
fffff880`0c4aa000 fffff880`0c4bd000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`0a175000 fffff880`0a1a6000   WUDFRd.sys
    Checksum:  00000000
    ImageSize:  00031000
fffff880`0a44f000 fffff880`0a459000   Dot4Prt.sys
    Checksum:  00000000
    ImageSize:  0000A000
fffff880`0a434000 fffff880`0a44f000   USBSTOR.SYS
    Checksum:  00000000
    ImageSize:  0001B000
fffff880`0a4f3000 fffff880`0a51b000   Dot4.sys
    Checksum:  00000000
    ImageSize:  00028000
fffff880`0a5ed000 fffff880`0a5f9000   usbprint.sys
    Checksum:  00000000
    ImageSize:  0000C000
BUGCHECK FE - Usually caused by a USB DRIVER
BUGCHECK D1 - Usually caused by a DRIVERS
Possible causes - Atheros network adapter driver - athrx.sys
First i would update ALL devices connected VIA the USB ports ( mice keyboard WEBCAM )
update the athrx.sys driver as stated above
Alright, I will see what I can do. Thanks!
