zvit
Honorable Member
Hey guys! I have had this problem for a few days now and I can't restore my computer for various reasons and I also hadn't had lots of time to research the issue so I'm using workarounds for now but if anyone might know a solution, I'd be glad to hear! (Wow, what a long sentence!)
I use Adobe Encore to create image files from projects (.iso files). Then I use any burning program to burn the images to disks. (Nero, Ashampoo, imgburn etc.) What has been happening lately is that no burning program will burn image files to blu ray anymore. (dvd's ones burn fine). I can play the image files fine on any media player though (so the image file is ok). So in the meantime, I am just burning the blu ray's right from Encore instead of creating an image file. (Encore burns them fine so there is no problem with the burner.)
p.s. None of the burners give any error messages. Imgburn just gets stuck right off the start as it says "preparing image..." (but it apparently writes something to the disk because it ruins the disk). All other burners just make the drive to spin the disk for about a minute and then stop. The burner software is then just stuck before it starts burning.
Any ideas?
It seems like you're facing an issue with burning Blu-ray image files to disks using burning programs like Nero, Ashampoo, and ImgBurn. Since DVD image burning works fine and playing the image files on media players is also successful, the problem seems specific to Blu-ray burning. Here are a few troubleshooting steps and suggestions to potentially resolve this issue: 1. Check Software Settings: - Ensure that the settings in the burning software are correct for Blu-ray burning. Sometimes, settings like burn speed or disk type can affect the burning process. Try different settings to see if it makes a difference. 2. Update Firmware and Drivers: - Make sure that your optical drive has the latest firmware installed. Outdated...
It seems like you're facing an issue with burning Blu-ray image files to disks using burning programs like Nero, Ashampoo, and ImgBurn. Since DVD image burning works fine and playing the image files on media players is also successful, the problem seems specific to Blu-ray burning. Here are a few troubleshooting steps and suggestions to potentially resolve this issue: 1. Check Software Settings: - Ensure that the settings in the burning software are correct for Blu-ray burning. Sometimes, settings like burn speed or disk type can affect the burning process. Try different settings to see if it makes a difference. 2. Update Firmware and Drivers: - Make sure that your optical drive has the latest firmware installed. Outdated firmware can cause compatibility issues with newer disks or formats like Blu-ray. Also, update the drivers for your optical drive from the manufacturer's website. 3. Try Different Burning Software: - If the issue persists with Nero, Ashampoo, and ImgBurn, try using a different burning software to see if the problem is software-specific. You can try software like CDBurnerXP, BurnAware, or any recommended Blu-ray burning software. 4. Check Disk and Image Integrity: - Ensure that the Blu-ray disks you are using are in good condition and compatible with your burner. Try using a different brand of Blu-ray disks. Also, verify the integrity of the Blu-ray image files to rule out any corruption issues. 5. Run a Disc Cleaning: - Dust or dirt on the optical drive lens can sometimes cause burning issues. Consider running a disc cleaning process to clean the drive lens and see if it improves the burning process. 6. Try a Different Computer: - If possible, try burning the Blu-ray image files on a different computer with a different optical drive to see if the issue is related to the computer or the drive itself. 7. Check System Resources: - Ensure that your system has enough resources (CPU, RAM) available during the burning process. Running multiple applications or having low system resources can sometimes lead to burning failures. By following these steps, you may be able to diagnose and resolve the issue you're experiencing with burning Blu-ray image files. If the problem persists, it may be helpful to provide more details about your system configuration and the specific burning software versions you are using for further assistance.
