Windows 7 Can anyone help about my BSOD?
Hi shyrene‎ and Welcome to The Forum.
STOP 0x0000000A: IRQL_NOT_LESS_OR_EQUAL
Usual causes:
Kernel mode driver, System Service, BIOS, Windows, Virus scanner, Backup tool, compatibility
Your latest dump file lists ntkrpamp.exe as the probable cause. This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes often indicate hardware issues.
As a Priority:
Avira is known to be a cause of BSOD's on some Win 7 systems.
Uninstall Avira and download BSOD friendly Link Removed due to 404 Error as its replacement. Make sure Windows firewall is enabled!
Make sure your system is fully updated, including SP1.
Outdated Drivers. Update:
adfs.SYS Thu Aug 14 15:57:15 2008 This is the driver for Adobe Drive. Although I've never seen this cause a problem, I personally have never found a use for the Adobe Drive. Even when I've had Photoshop, an Illustrator trial and an Acrobat trial on my machine. I'd get rid of Adobe Drive, unless, of course, you've found the use for it and use it!
ISODrive.sys Tue Feb 10 09:22:07 2009 ISO CD-ROM Device Driver - ISODrive EZB Systems
RimSerial.sys Mon Nov 24 17:02:13 2008 Link Removed - Invalid URL(probably associated with a Blackberry)
Drivers with Updates:
GEARAspiWDM.sys Mon May 18 13:17:04 2009 Gear Software CD-ROM Class Filter Driver v4.015.1 (Feb 2010). Also comes as part of iTunes
nvlddmkm.sys Fri Jul 30 00:28:09 2010 nVidia Graphics Drivers.
Rt86win7.sys Thu Nov 05 14:14:57 2009 Realtek PCIe GBE Family Controller v7.046
RTKVHDA.sys Fri Mar 12 21:45:28 2010 Realtek HD Audio R2.64
seehcri.sys Wed Jan 09 08:41:37 2008 SonyEricsson Device 0016 (likely a phone)
Bugcheck Analysis:
BugCheck A, {40064, 2, 0, 832eb1cc}
Probably caused by : ntkrpamp.exe ( nt!ExpScanGeneralLookasideList+22 )
Followup: MachineOwner
0: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 00040064, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000000, bitfield :
Arg4: 832eb1cc, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from 833b4718
Unable to read MiSystemVaType memory at 83394160
 00040064
CURRENT_IRQL:  2
FAULTING_IP:
832eb1cc 8b51e0          mov     edx,dword ptr [ecx-20h]
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xA
PROCESS_NAME:  System
TRAP_FRAME:  8d74bbfc -- (.trap 0xffffffff8d74bbfc)
ErrCode = 00000000
eax=00000000 ebx=00000004 ecx=00040084 edx=00000000 esi=94fbff80 edi=0000087f
eip=832eb1cc esp=8d74bc70 ebp=8d74bc80 iopl=0         nv up ei pl nz na po cy
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010203
nt!ExpScanGeneralLookasideList+0x22:
832eb1cc 8b51e0          mov     edx,dword ptr [ecx-20h] ds:0023:00040064=????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from 832eb1cc to 832927eb
STACK_TEXT:
8d74bbfc 832eb1cc badb0d00 00000000 8d74bc1c nt!KiTrap0E+0x2cf
8d74bc80 832d51e5 83386680 83386678 00000000 nt!ExpScanGeneralLookasideList+0x22
8d74bd50 8345a66d 00000000 a2bc5661 00000000 nt!KeBalanceSetManager+0x195
8d74bd90 8330c0d9 832d5050 00000000 00000000 nt!PspSystemThreadStartup+0x9e
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x19
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt!ExpScanGeneralLookasideList+22
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrpamp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc007
FAILURE_BUCKET_ID:  0xA_nt!ExpScanGeneralLookasideList+22
Drivers:
 bba25000 bbb6f400   1394hub  1394hub.sys  Mon Aug 15 07:07:53 2011 (4E48B7B9)
8b497000 8b4df000   ACPI     ACPI.sys     Tue Jul 14 00:11:11 2009 (4A5BBF0F)
9957c000 9958ce80   adfs     adfs.SYS     Thu Aug 14 15:57:15 2008 (48A447CB)
90633000 9068d000   afd      afd.sys      Tue Jul 14 00:12:34 2009 (4A5BBF62)
909b7000 909c9000   AgileVpn AgileVpn.sys Tue Jul 14 00:55:00 2009 (4A5BC954)
8b5e8000 8b5f1000   amdxata  amdxata.sys  Tue May 19 18:57:35 2009 (4A12F30F)
8b5bc000 8b5c5000   atapi    atapi.sys    Tue Jul 14 00:11:15 2009 (4A5BBF13)
8b5c5000 8b5e8000   ataport  ataport.SYS  Tue Jul 14 00:11:18 2009 (4A5BBF16)
99a00000 99a4d000   ATMFD    ATMFD.DLL    unavailable (00000000)
987d2000 987e9000   avgntflt avgntflt.sys Fri May 27 15:33:11 2011 (4DDFB627)
908c8000 908ef000   avipbb   avipbb.sys   Wed Apr 13 13:28:13 2011 (4DA596DD)
8b9f5000 8b9fc000   Beep     Beep.SYS     Tue Jul 14 00:45:00 2009 (4A5BC6FC)
908ba000 908c8000   blbdrive blbdrive.sys Tue Jul 14 00:23:04 2009 (4A5BC1D8)
8b2a1000 8b2a9000   BOOTVID  BOOTVID.dll  Tue Jul 14 02:04:34 2009 (4A5BD9A2)
994c0000 994d9000   bowser   bowser.sys   Tue Jul 14 00:14:21 2009 (4A5BBFCD)
99de0000 99dfe000   cdd      cdd.dll      unavailable (00000000)
8b9cf000 8b9ee000   cdrom    cdrom.sys    Tue Jul 14 00:11:24 2009 (4A5BBF1C)
8b2eb000 8b396000   CI       CI.dll       Tue Jul 14 02:09:28 2009 (4A5BDAC8)
8b983000 8b9a8000   CLASSPNP CLASSPNP.SYS Tue Jul 14 00:11:20 2009 (4A5BBF18)
8b2a9000 8b2eb000   CLFS     CLFS.SYS     Tue Jul 14 00:11:10 2009 (4A5BBF0E)
8b78d000 8b7ea000   cng      cng.sys      Tue Jul 14 00:32:55 2009 (4A5BC427)
90995000 909a2000   CompositeBus CompositeBus.sys Tue Jul 14 00:45:26 2009 (4A5BC716)
98729000 98736000   crashdmp crashdmp.sys Tue Jul 14 00:45:50 2009 (4A5BC72E)
9083e000 908a2000   csc      csc.sys      Tue Jul 14 00:15:08 2009 (4A5BBFFC)
908a2000 908ba000   dfsc     dfsc.sys     Tue Jul 14 00:14:16 2009 (4A5BBFC8)
907d1000 907dd000   discache discache.sys Tue Jul 14 00:24:04 2009 (4A5BC214)
8bbed000 8bbfe000   disk     disk.sys     Tue Jul 14 00:11:28 2009 (4A5BBF20)
97987000 979a0000   drmk     drmk.sys     Tue Jul 14 01:36:05 2009 (4A5BD2F5)
98741000 9874a000   dump_atapi dump_atapi.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
98736000 98741000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:11:16 2009 (4A5BBF14)
9874a000 9875b000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:12:47 2009 (4A5BBF6F)
9871f000 98729000   Dxapi    Dxapi.sys    Tue Jul 14 00:25:25 2009 (4A5BC265)
92493000 9254a000   dxgkrnl  dxgkrnl.sys  Tue Jul 14 00:26:15 2009 (4A5BC297)
9254a000 92583000   dxgmms1  dxgmms1.sys  Tue Jul 14 00:25:25 2009 (4A5BC265)
bbb70000 bbbe8980   EagleXNt EagleXNt.sys Mon Apr 25 01:33:42 2011 (4DB4C166)
8b400000 8b411000   fileinfo fileinfo.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
8b396000 8b3ca000   fltmgr   fltmgr.sys   Tue Jul 14 00:11:13 2009 (4A5BBF11)
8b600000 8b609000   Fs_Rec   Fs_Rec.sys   unavailable (00000000)
8b951000 8b983000   fvevol   fvevol.sys   Tue Jul 14 00:13:01 2009 (4A5BBF7D)
8bb54000 8bb85000   fwpkclnt fwpkclnt.sys Tue Jul 14 00:12:03 2009 (4A5BBF43)
91a0d000 91a12280   GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:16:53 2009 (4A1151B5)
83215000 8324c000   hal      halmacpi.dll Tue Jul 14 00:11:03 2009 (4A5BBF07)
90922000 90941000   HDAudBus HDAudBus.sys Tue Jul 14 00:50:55 2009 (4A5BC85F)
97908000 97958000   HdAudio  HdAudio.sys  Tue Jul 14 00:51:46 2009 (4A5BC892)
9943b000 994c0000   HTTP     HTTP.sys     Tue Jul 14 00:12:53 2009 (4A5BBF75)
8bbe5000 8bbed000   hwpolicy hwpolicy.sys Tue Jul 14 00:11:01 2009 (4A5BBF05)
9097d000 90995000   i8042prt i8042prt.sys Tue Jul 14 00:11:23 2009 (4A5BBF1B)
9958d000 995a5000   idmwfp   idmwfp.sys   Mon Mar 28 18:36:01 2011 (4D90C701)
8b591000 8b598000   intelide intelide.sys Tue Jul 14 00:11:19 2009 (4A5BBF17)
90910000 90922000   intelppm intelppm.sys Tue Jul 14 00:11:03 2009 (4A5BBF07)
907ba000 907d1000   ISODrive ISODrive.sys Tue Feb 10 09:22:07 2009 (4991473F)
91a00000 91a0d000   kbdclass kbdclass.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
80bcf000 80bd7000   kdcom    kdcom.dll    Tue Jul 14 02:08:58 2009 (4A5BDAAA)
97871000 978a5000   ks       ks.sys       Tue Jul 14 00:45:13 2009 (4A5BC709)
8b77a000 8b78d000   ksecdd   ksecdd.sys   Tue Jul 14 00:11:56 2009 (4A5BBF3C)
8b8ff000 8b924000   ksecpkg  ksecpkg.sys  Tue Jul 14 00:34:00 2009 (4A5BC468)
9841a000 9842a000   lltdio   lltdio.sys   Tue Jul 14 00:53:18 2009 (4A5BC8EE)
987b7000 987d2000   luafv    luafv.sys    Tue Jul 14 00:15:44 2009 (4A5BC020)
8b218000 8b290000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 02:06:41 2009 (4A5BDA21)
909aa000 909b7000   modem    modem.sys    Tue Jul 14 00:55:24 2009 (4A5BC96C)
987ac000 987b7000   monitor  monitor.sys  Tue Jul 14 00:25:58 2009 (4A5BC286)
925f2000 925ff000   mouclass mouclass.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
8b5a6000 8b5bc000   mountmgr mountmgr.sys Tue Jul 14 00:11:27 2009 (4A5BBF1F)
994d9000 994eb000   mpsdrv   mpsdrv.sys   Tue Jul 14 00:52:52 2009 (4A5BC8D4)
994eb000 9950e000   mrxsmb   mrxsmb.sys   Tue Jul 14 00:14:24 2009 (4A5BBFD0)
9950e000 99549000   mrxsmb10 mrxsmb10.sys Tue Jul 14 00:14:34 2009 (4A5BBFDA)
99549000 99564000   mrxsmb20 mrxsmb20.sys Tue Jul 14 00:14:29 2009 (4A5BBFD5)
8b3eb000 8b3f6000   Msfs     Msfs.SYS     Tue Jul 14 00:11:26 2009 (4A5BBF1E)
8b4e8000 8b4f0000   msisadrv msisadrv.sys Tue Jul 14 00:11:09 2009 (4A5BBF0D)
8b74f000 8b77a000   msrpc    msrpc.sys    unavailable (00000000)
907b0000 907ba000   mssmbios mssmbios.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
8bbd5000 8bbe5000   mup      mup.sys      Tue Jul 14 00:14:14 2009 (4A5BBFC6)
8b80a000 8b8c1000   ndis     ndis.sys     Tue Jul 14 00:12:24 2009 (4A5BBF58)
909e1000 909ec000   ndistapi ndistapi.sys Tue Jul 14 00:54:24 2009 (4A5BC930)
90800000 90822000   ndiswan  ndiswan.sys  Tue Jul 14 00:54:34 2009 (4A5BC93A)
978f7000 97908000   NDProxy  NDProxy.SYS  Tue Jul 14 00:54:27 2009 (4A5BC933)
906e5000 906f3000   netbios  netbios.sys  Tue Jul 14 00:53:54 2009 (4A5BC912)
9068d000 906bf000   netbt    netbt.sys    Tue Jul 14 00:12:18 2009 (4A5BBF52)
8b8c1000 8b8ff000   NETIO    NETIO.SYS    Tue Jul 14 00:12:35 2009 (4A5BBF63)
8b200000 8b20e000   Npfs     Npfs.SYS     Tue Jul 14 00:11:31 2009 (4A5BBF23)
907a6000 907b0000   nsiproxy nsiproxy.sys Tue Jul 14 00:12:08 2009 (4A5BBF48)
8324c000 8365c000   nt       ntkrpamp.exe Tue Jul 14 00:15:19 2009 (4A5BC007)
8b620000 8b74f000   Ntfs     Ntfs.sys     Tue Jul 14 00:12:05 2009 (4A5BBF45)
8b9ee000 8b9f5000   Null     Null.SYS     unavailable (00000000)
92491000 92492040   nvBridge nvBridge.kmd Fri Jul 30 00:23:19 2010 (4C520D67)
91a13000 92490e40   nvlddmkm nvlddmkm.sys Fri Jul 30 00:28:09 2010 (4C520E89)
906c6000 906e5000   pacer    pacer.sys    Tue Jul 14 00:53:58 2009 (4A5BC916)
8b525000 8b536000   partmgr  partmgr.sys  Tue Jul 14 00:11:35 2009 (4A5BBF27)
8b4f0000 8b51a000   pci      pci.sys      Tue Jul 14 00:11:16 2009 (4A5BBF14)
8b598000 8b5a6000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:11:15 2009 (4A5BBF13)
8b7ea000 8b7f8000   pcw      pcw.sys      Tue Jul 14 00:11:10 2009 (4A5BBF0E)
9fa0b000 9faa2000   peauth   peauth.sys   Tue Jul 14 01:35:44 2009 (4A5BD2E0)
97958000 97987000   portcls  portcls.sys  Tue Jul 14 00:51:00 2009 (4A5BC864)
8b290000 8b2a1000   PSHED    PSHED.dll    Tue Jul 14 02:09:36 2009 (4A5BDAD0)
909c9000 909e1000   rasl2tp  rasl2tp.sys  Tue Jul 14 00:54:33 2009 (4A5BC939)
90822000 9083a000   raspppoe raspppoe.sys Tue Jul 14 00:54:53 2009 (4A5BC94D)
907dd000 907f4000   raspptp  raspptp.sys  Tue Jul 14 00:54:47 2009 (4A5BC947)
97827000 9783e000   rassstp  rassstp.sys  Tue Jul 14 00:54:57 2009 (4A5BC951)
90765000 907a6000   rdbss    rdbss.sys    Tue Jul 14 00:14:26 2009 (4A5BBFD2)
9785f000 97869000   rdpbus   rdpbus.sys   Tue Jul 14 01:02:40 2009 (4A5BCB20)
8b800000 8b808000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:01:40 2009 (4A5BCAE4)
9fb7a000 9fb9f000   rdpdr    rdpdr.sys    Tue Jul 14 01:02:56 2009 (4A5BCB30)
8b615000 8b61d000   rdpencdd rdpencdd.sys Tue Jul 14 01:01:39 2009 (4A5BCAE3)
8b7f8000 8b800000   rdprefmp rdprefmp.sys Tue Jul 14 01:01:41 2009 (4A5BCAE5)
9fbb6000 9fbe7000   RDPWD    RDPWD.SYS    Tue Jul 14 01:01:50 2009 (4A5BCAEE)
8b924000 8b951000   rdyboost rdyboost.sys Tue Jul 14 00:22:02 2009 (4A5BC19A)
97858000 9785ea00   RimSerial RimSerial.sys Mon Nov 24 17:02:13 2008 (492ADE15)
909a2000 909aa000   RootMdm  RootMdm.sys  Tue Jul 14 00:55:21 2009 (4A5BC969)
987e9000 987fc000   rspndr   rspndr.sys   Tue Jul 14 00:53:20 2009 (4A5BC8F0)
90941000 9097d000   Rt86win7 Rt86win7.sys Thu Nov 05 14:14:57 2009 (4AF2DDE1)
9843b000 9871ec80   RTKVHDA  RTKVHDA.sys  Fri Mar 12 21:45:28 2010 (4B9AB5F8)
9faa2000 9faac000   secdrv   secdrv.SYS   Wed Sep 13 14:18:32 2006 (45080528)
97869000 9786ef00   seehcri  seehcri.sys  Wed Jan 09 08:41:37 2008 (478488C1)
925e8000 925f2000   serenum  serenum.sys  Tue Jul 14 00:45:27 2009 (4A5BC717)
906f3000 9070d000   serial   serial.sys   Tue Jul 14 00:45:33 2009 (4A5BC71D)
8bbcd000 8bbd5000   spldr    spldr.sys    Mon May 11 17:13:47 2009 (4A084EBB)
9fb29000 9fb7a000   srv      srv.sys      Tue Jul 14 00:15:10 2009 (4A5BBFFE)
9fada000 9fb29000   srv2     srv2.sys     Tue Jul 14 00:14:52 2009 (4A5BBFEC)
9faac000 9facd000   srvnet   srvnet.sys   Tue Jul 14 00:14:45 2009 (4A5BBFE5)
9075f000 90764a00   ssmdrv   ssmdrv.sys   Tue May 05 11:05:18 2009 (4A000F5E)
9786f000 97870380   swenum   swenum.sys   Tue Jul 14 00:45:08 2009 (4A5BC704)
8ba0b000 8bb54000   tcpip    tcpip.sys    Tue Jul 14 00:13:18 2009 (4A5BBF8E)
9facd000 9fada000   tcpipreg tcpipreg.sys Tue Jul 14 00:54:14 2009 (4A5BC926)
90628000 90633000   TDI      TDI.SYS      Tue Jul 14 00:12:12 2009 (4A5BBF4C)
9fb9f000 9fba9000   tdtcp    tdtcp.sys    Tue Jul 14 01:01:37 2009 (4A5BCAE1)
90611000 90628000   tdx      tdx.sys      Tue Jul 14 00:12:10 2009 (4A5BBF4A)
9074f000 9075f000   termdd   termdd.sys   Tue Jul 14 01:01:35 2009 (4A5BCADF)
99db0000 99db9000   TSDDD    TSDDD.dll    unavailable (00000000)
9fba9000 9fbb6000   tssecsrv tssecsrv.sys Tue Jul 14 01:01:50 2009 (4A5BCAEE)
908ef000 90910000   tunnel   tunnel.sys   Tue Jul 14 00:54:03 2009 (4A5BC91B)
978a5000 978b3000   umbus    umbus.sys    Tue Jul 14 00:51:38 2009 (4A5BC88A)
98798000 987abb00   usbaudio usbaudio.sys Tue Jul 14 00:51:23 2009 (4A5BC87B)
9875b000 98772000   usbccgp  usbccgp.sys  Tue Jul 14 00:51:31 2009 (4A5BC883)
98772000 98773700   USBD     USBD.SYS     Tue Jul 14 00:51:05 2009 (4A5BC869)
925d9000 925e8000   usbehci  usbehci.sys  Tue Jul 14 00:51:14 2009 (4A5BC872)
978b3000 978f7000   usbhub   usbhub.sys   Tue Jul 14 00:52:06 2009 (4A5BC8A6)
9258e000 925d9000   USBPORT  USBPORT.SYS  Tue Jul 14 00:51:13 2009 (4A5BC871)
92583000 9258e000   usbuhci  usbuhci.sys  Tue Jul 14 00:51:10 2009 (4A5BC86E)
98774000 98797b00   usbvideo usbvideo.sys Tue Jul 14 00:51:51 2009 (4A5BC897)
90729000 9074e9c0   VBoxDrv  VBoxDrv.sys  Mon May 16 18:00:56 2011 (4DD15848)
9783e000 97857180   VBoxNetAdp VBoxNetAdp.sys Mon May 16 18:00:56 2011 (4DD15848)
90720000 90728d80   VBoxUSBMon VBoxUSBMon.sys Mon May 16 18:00:56 2011 (4DD15848)
8b51a000 8b525000   vdrvroot vdrvroot.sys Tue Jul 14 00:46:19 2009 (4A5BC74B)
8b609000 8b615000   vga      vga.sys      Tue Jul 14 00:25:50 2009 (4A5BC27E)
8b3ca000 8b3eb000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:25:49 2009 (4A5BC27D)
8bb85000 8bb8e000   vmstorfl vmstorfl.sys unavailable (00000000)
8b536000 8b546000   volmgr   volmgr.sys   Tue Jul 14 00:11:25 2009 (4A5BBF1D)
8b546000 8b591000   volmgrx  volmgrx.sys  unavailable (00000000)
8bb8e000 8bbcd000   volsnap  volsnap.sys  Tue Jul 14 00:11:34 2009 (4A5BBF26)
9070d000 90720000   wanarp   wanarp.sys   Tue Jul 14 00:55:02 2009 (4A5BC956)
8b5f1000 8b5fe000   watchdog watchdog.sys Tue Jul 14 00:24:10 2009 (4A5BC21A)
8b418000 8b489000   Wdf01000 Wdf01000.sys Tue Jul 14 00:11:36 2009 (4A5BBF28)
8b489000 8b497000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:11:25 2009 (4A5BBF1D)
906bf000 906c6000   wfplwf   wfplwf.sys   Tue Jul 14 00:53:51 2009 (4A5BC90F)
99b50000 99d9a000   win32k   win32k.sys   unavailable (00000000)
8b4df000 8b4e8000   WMILIB   WMILIB.SYS   Tue Jul 14 00:11:22 2009 (4A5BBF1A)
98400000 9841a000   WudfPf   WudfPf.sys   Tue Jul 14 00:50:13 2009 (4A5BC835)
Unloaded modules:
bbb70000 bbbe9000   EagleXNt.sys
    Checksum:  00000000
    ImageSize:  00079000
ace34000 ace9e000   spsys.sys
    Checksum:  00000000
    ImageSize:  0006A000
99564000 9957c000   parport.sys
    Checksum:  00000000
    ImageSize:  00018000
8b9a8000 8b9b5000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000D000
8ba00000 8ba0b000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000B000
8b9b5000 8b9be000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
8b9be000 8b9cf000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00011000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
thanks sir elmer..i already update the drivers..i think its avira cause the BSOD after i update the avira it start the BSOD...
i will replace the avira...thanks again..
