Windows 7 can't open the right click option on desktop or anywhere else Error msg appear ?
Ben Diab
Hi guys
few days ago i faced a problem on ma system n i thought it's gna go away by the time but more that week nothing was changed
whenever i try to use the Mouse right click options on the desktop or any other folder... this Message appears :
Link Removed due to 404 Error
Can any one help me on this please ?!
it says : the specified Module could not be found: C:\program files\common files\Adobe\Adobe Version cue CS4\Client\4.0.0\Version Cue.dll
thats it !
If you run explorer.exe as administrator does it happen?
Is the Version Cue.dll file at the specified location?
Do you have any Adobe destinations in the Send to button?
Are you running any spyware or firewalls that might block local access by the file?
Maybe an Adobe forum would know. Have you done any updates for CS4?
Top Bottom
