- Thread Author
- #1
- Running windows 7 home premium
- latest windows 7 updates
This problem has persisted for a week or two now, not sure why but my laptop started to have many problems.
some extra information;
- when my wireless signal for the wireless keyboard goes out (randomly), the usb port (usb extension) stops working for that port, however if you take it out and replug, still doesn't work.
only way to "fix" this is by force restarting by turning it off with the power button (i can't even shutdown because it hangs there anyways).
anyways the main problem really is th shutdown/restarts.
this has never happened to be before, had my new laptop for about 4 months, and within 1-2 weeks from now, this problem started to happen.
i'm not sure what it could be, whether its new windows update, or new applications i installed (well, i don't really install many new apps, and i have roughly the same things i did when i first got my laptop).
its literally impossible to shutdown it successfuly (well i never decide to wait ages, but if the laptop doesn't shut down in a few mins, something has to be wrong) - same applies to the restart, both doesn't work unless i force it with the power button.
however, if i boot up the laptop (not logging in), i am able to shut it down as i assume no services are started up yet.
according to my event log from performance view, there are alot of warnings, some crticals and such - then again this has only happened recently, so this is pretty frustrating to me.
heres an example below;
this is just 1 of them, and theres alot.
some of the applications i use are trivial (like trillian, skype, steam, etc) and i've had all these programs before and it was fine, able to shut down and so on.
again, this has only happened recently.
i've did a factory reset (hoping it would fix the problem) but nothing as happened interms of fixing so.. i'm pretty much out of idea's, have done everything according to my searches by disabling various things, nothing good so far yet.
any help is appreciated and willing to follow every step in order to fix this problem.
thanks
- liqt
Windows has shutdown:
Shutdown Duration : 19478ms
IsDegradation : false
Incident Time (UTC) : 2011-07-05T16:35:07.937364300Z
thanks
- liqt
