I want to change the volume label of my partition (wrongly named 500Gb_I to 500Gb_F, which is the real partion on my 2 hard disks.But Win7 shows ACCESS DENIED
P.S. I use Total Commander for ALL explorer type functions. Its a million times better than Windows Explorer. I also use it to rename partitions etc...
Sorry. Cannot help. I dont use total commander as windows explorer does all I require. In my customised view (Show drive letters) I would not need the choice of name you are using -it shows the drive letter.
I renamed mine no problem using WE. U might stoop to WE and try it, then u would know if it is a TC problem. Also, it shouldn't matter, but if u are not logged on as admin u might try right clicking and selecting RUN AS ADMINISTRATOR
