Hi all.
I'm experiencing (minor, but annoying) issues with Windows 7's fonts.
It seems that my Cleartype is half ON at all times, eventhough the option is disabled. My fonts in desktop's shortcuts and "view, edit file help" texts on bars etc are clearly antialiased, smoothened and bolded, as Cleartype would be ON. But the fonts on softwares like mIRC or WWW browser look normal. If i change my DPI or similar, everything goes normal - until i boot the computer, then things go wrong again.
If i enable Cleartype -function, then everything goes the opposite: desktop's fonts etc are slim and as i want them to be, but texts in mirc and www browser etc have cleartype fonts, and being a bit messy (depending on font).
I've also tried to disable the "smoothen font edges" option but it just makes fonts too crappy.
I'm using Nvidia display card if that makes any difference.
Just to make it clear here's few screenshots.
This is how i want them to be:
http://personal.inet.fi/koti/rautis/desktop2.jpg
this is how it ends up after a reboot:
http://personal.inet.fi/koti/rautis/desktop.jpg
As you see, it's not major problem but i hate those cleartype style fonts, since somewhere else they do corrupt the fonts, making them harder to read. And as you can see, the "search programs and files" text on start menu goes also a bit more worse.
Thank you really much =)
