Windows 7 closing laptop = BSOD! HELP
davearb
HI, doing my head in! If someone could take a look at the minidump file attached it would be greatly appreciated.
Thanks, davearb
Hi Dave and welcome to W7 Forums!
Also, could you please just post the problem in one section of the forums (you have a copy here: Link Removed).
To get the most help from us regarding BSODs, please use these instructions: Link Removed to give a full report, as the minidumps don't always give the answer.
Analysis:
Debug session time: Sun Nov 18 12:32:31.448 2012 (UTC + 11:00)
Loading Dump File [C:\Users\MZ\SysnativeBSODs\111812-8486-01.dmp]
Built by: 7601.17944.amd64fre.win7sp1_gdr.120830-0333
System Uptime: 0 days 0:33:22.308
BugCheck F4, {3, fffffa8008f83b30, fffffa8008f83e10, fffff80002fd7460}
Probably caused by : wininit.exe
Bugcheck code 000000f4
Arguments:
Arg1: 0000000000000003, Process
Arg2: fffffa8008f83b30...
Analysis:
Arguments:
Arg2: fffffa8008f83b30, Terminating object
Arg3: fffffa8008f83e10, Process image file name
Arg4: fffff80002fd7460, Explanatory message (ascii)
PROCESS_NAME:  wininit.exe
BUGCHECK_STR:  0xF4_C0000005
FAILURE_BUCKET_ID:  X64_0xF4_C0000005_IMAGE_wininit.exe
Debug session time: Sun Nov 18 12:36:24.643 2012 (UTC + 11:00)
Loading Dump File [C:\Users\MZ\SysnativeBSODs\111812-4212-01.dmp]
System Uptime: 0 days 0:01:23.876
BugCheck F4, {3, fffffa8008fb4b30, fffffa8008fb4e10, fffff80002f94460}
Arguments:
Arg2: fffffa8008fb4b30, Terminating object
Arg3: fffffa8008fb4e10, Process image file name
Arg4: fffff80002f94460, Explanatory message (ascii)
The two dmps point to wininit.exe (Windows Initialization), which is Windows Start-Up Application.
You also have two drivers that could cause BSODs:
nusb3xhc.sys Thu Sep 30 14:00:03 2010 (4CA40B43)
NEC Electronics USB 3.0 Host Controller Driver (previous BSOD issues with 2010 version)
nusb3hub.sys Thu Sep 30 14:00:03 2010 (4CA40B43)
please update them accordingly.
For wininit.exe: When your computer boots, repeatedly press F8 until a screen shows up asking you what startup method you wish to use. Select "Safe Mode" and then press ENTER. If wininit.exe is the actual problem, you should be able to boot up in to Safe Mode without a problem (most likely you will be able to do so).
Restart your computer and boot it up normally (I'm assuming you can do this - if you can't just continue in Safe Mode).
Then Go to the Windows Icon in your Taskbar, and in the "Search" box, type "Run".
In the "Run" box, type "msconfig" (no quotations).
In System Configuration, select the Startup tab, and then click "Disable All". Then click "Apply", and restart.
Hopefully it won't have any issues after that - if you can restart the computer normally without issues after disabling all the items, then we know it's an issue with one of the startup drivers.
ALTERNITAVELY
on System Configuration, in the "General Tab", select "Diagnostic startup" and reboot the computer.
Link RemovedHi GeneralHiningII, thanks so much for your response. I did as you said below and seem to have the same problems. Have attached my latst minidump file. If you have time would you mind reviewing and see if there is anything else to consider?
Thanks
davearb
Thanks, davearb
