Code 52, Mic and zoom alba 1.3mp webcam
benlaw1
Hello, i have an issue with my alba 1.3mp webcam. In device manager there is a yellow triangle with a '!' inside it, announcing an error of code 52. I have fixxed this problem before, however i cannot remember fully how.. All i know is it consisted of using 'Regedit' and deleting several entries.. I am running Windows 7 ultimate edition.
Thanks.
bassfisher6522
I tend to stay away from messing with the registry except as a last resort. That being said, have you tried uninstalling and reinstalling it? Also checking for any malware, spyware or adware lurking on your system.
benlaw1
I found a temp solution, pressing f8 and disable the function of only allowing digitally signed drivers on start up
>>bassfisher6522
I have a completely reinstalled pc, no wares lurking in my pc, installed with websites drivers also.. Thank you for you assistance.
bassfisher6522
Glad to here you have a temp solution to it....keep a look out and post back if anything esle should arise.
