After some tweaking, I finally managed to install Windows 7
My next problem is that I cant find my SATA drivers.
I think this might be the problem:
Compatibility issue between Promise FastTrak 378 (tm) Controller and Windows
Which is the message I got when I am trying to add the hardware. (Mobo: Asus K8V Deluxe).
Is it a way to work around this problem, or do I have to go back using WinXP to get to use my SATA harddrives?
Problem solved when I used the XP drivers.
