- Thread Author
- #1
Hello,
I hope this is the right place to post this.
I have a laptop with Windows 7, and I take my internet from an outlet in the wall connected to the University Accomodation Network; I assume that's a switch.
The cable is too short and I want to go wireless, so I need to ask this BEFORE I buy any hardware.
I'm willing to buy an ADSL modem which functions as a wireless router and acess point. I think they all do, right?
Okay, my question is, can this hardware recieve internet from a LAN port and direct it to my Laptop via WiFi?
I ask this because, as far as I know, these modems recieve internet data from a specific ADSL port, filter it through their own internal system as if they are a computer (router), and then share it through LAN and WiFi to connected devices, but what about recieving that from a LAN port? Will I still be able to enter the router's system and set things up for security, or will it just work as an open access point in this case?
If possible, does Windows 7 require any particular settings for that?
I'm sorry it's obvious I'm confused, and I had to post my question like this becuase I obviously don't know what keyword to search for in order to get the specific answer I want. The most common search results deal with routers and ADSL modems.
I hope you guys can help. Thank you.
Best regards,
~KR
Best regards,
~KR
