connection problem
silver-s
hi,
i've just installed win 7 build 7000' all was fine until i had to connet to the internet.
in the access type it says local only.
i flushed dns several times and it has an ip addrass and all...
whay i cant connet to the internet ?
driver seems fine,
oh one last thing when i run diagnostics it says : " the configured DNS server in incorrect or do not exist"
help ??:confused:
stuigi
Was this an upgrade from a working pc or a new install. Have you made sure that you typed the dns fields properly. I know this sounds simplistic, but I was guilty of doing that
