Constant BSOD/crash
Hello all!
I have experienced crashes with the BSOD that made me believe it had something to do with a driver that was corrupt, malfunctioning, etc. I would receive the IRQL_NOT_LESS_OR_EQUAL and/or DRIVER_IRQL_NOT_LESS_OR_EQUAL. I notice this was happening around the beginning of last month when one or two things happened-- a new Windows Update occurred and possibly wasn't installed completely/correctly, and I had begun to play a new game on Facebook. I am thinking that playing that game calls up on one of the drivers that may be horrifically disfigured/corrupt as even when I would play the game in HP's QuickWeb, it would periodically crash as well.
This caused me to consider strongly of doing clean restore as Windows 7 would not load at all (normally). I tried doing the Verifier check and it also would crash up on restart, making me believe one of my drivers is bad.
It began to get progressively bad to the point where every restart caused a crash-- couldn't get into windows at all; Startup Repair would not work and previous restore points would not be useful.
Any assistance you could give me would be greatly appreciated. memory.PNG View attachment Minidump.zip spd.PNG
Yes, the memory is set right (ddr400 6-6-6-24 1.8v).
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
IRQL_NOT_LESS_OR_EQUAL (a)
This is usually caused by drivers using improper addresses.
1. Uninstall Symantec and then replace it with MSE:
Download and run the Norton Removal Tool to uninstall your Norton product | Norton Support
https://www.microsoft.com/security_essentials/
2. Uninstall Daemon Tools and then remove its driver with the use of this tool:
DuplexSecure - FAQ
3. Update old drivers, as many of them listed below as you can find :
HP Support & Drivers
adpu320.sys Tue Feb 27 19:04:15 2007
Adaptec Ultra320 SCSI Driver
arc.sys Thu May 24 17:27:55 2007
Adaptec RAID Controller
Apfiltr.sys Tue May 12 05:38:59 2009
Touchpad
elxstor.sys Tue Feb 03 17:52:11 2009
Emulex LightPulse Storport Miniport
enecir.sys Wed May 20 02:08:57 2009
ENE CIR Driver for eHome
HpSAMD.sys Mon May 18 19:43:49 2009
Smart Array SAS/SATA Controller Media Driver
HpqKbFiltr.sys Wed Apr 29 09:48:30 2009
HP Quick Launch Buttons
jmcr.sys Thu Jul 09 08:45:19 2009
JMicron JMB38X Flash Media Controller
ql2300.sys Thu Jan 22 18:05:06 2009
QLogic Fibre Channel Stor Miniport Driver
Rt64win7.sys Fri May 22 10:52:30 2009
Realtek 8136/8168/8169 NDIS 6.20 PCI/PCIe
vsmraid.sys Fri Jan 30 20:18:57 2009
VIA RAID driver
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\122810-55739-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (2 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02c5e000 PsLoadedModuleList = 0xfffff800`02e9be50
Debug session time: Tue Dec 28 21:50:00.633 2010 (UTC - 5:00)
System Uptime: 0 days 0:26:17.397
Loading Kernel Symbols
...........................Unable to load image Unknown_Module_00000000`00000000, Win32 error 0n2
*** WARNING: Unable to verify timestamp for Unknown_Module_00000000`00000000
Unable to add module at 00000000`00000000
Loading User Symbols
Missing image name, possible paged-out or corrupt data.
Loading unloaded module list
...Missing image name, possible paged-out or corrupt data.
....Missing image name, possible paged-out or corrupt data.
BugCheck A, {0, 2, 1, fffff80002cd9e20}
Probably caused by : ntkrnlmp.exe ( nt!KiProcessExpiredTimerList+110 )
Followup: MachineOwner
0: kd> !analyze -v
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 0000000000000000, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
Arg4: fffff80002cd9e20, address which referenced memory
Debugging Details:
OVERLAPPED_MODULE: Address regions for 'ndis' and 'Unknown_Module_fffff880`020d1490' overlap
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff80002f060e0
 0000000000000000
CURRENT_IRQL:  0
FAULTING_IP:
fffff800`02cd9e20 f00fba2f07      lock bts dword ptr [rdi],7
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xA
PROCESS_NAME:  System
LAST_CONTROL_TRANSFER:  from fffff80002cdc24a to fffff880049c87f2
STACK_TEXT:
fffff800`04a08c98 fffff800`02cdc24a : 00000000`00223019 fffffa80`0564a218 fffff800`02e56c40 00000000`00000001 : 0xfffff880`049c87f2
fffff800`04a08ca0 fffff800`02cd6ebc : fffff800`02e48e80 fffff800`00000000 00000000`00000000 fffff880`0520f480 : nt!PoIdle+0x53a
fffff800`04a08d80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x2c
STACK_COMMAND:  .bugcheck ; kb
FOLLOWUP_IP:
SYMBOL_NAME:  nt!KiProcessExpiredTimerList+110
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4c1c44a9
FAILURE_BUCKET_ID:  X64_0xA_nt!KiProcessExpiredTimerList+110
Loading Dump File [F:\a\Minidump\D M P\DMP\122810-46503-01.dmp]
Mini Kernel Dump does not have process information
Machine Name:
Kernel base = 0xfffff800`02c11000 PsLoadedModuleList = 0xfffff800`02e4ee50
Debug session time: Tue Dec 28 18:55:18.519 2010 (UTC - 5:00)
System Uptime: 0 days 0:12:17.610
BugCheck D1, {0, 2, 8, 0}
Probably caused by : ntkrnlmp.exe ( nt!KiPageFault+260 )
0: kd> !analyze -v
If kernel debugger is available get stack backtrace.
Arguments:
Arg3: 0000000000000008, value 0 = read operation, 1 = write operation
Arg4: 0000000000000000, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002eb90e0
 0000000000000000
CURRENT_IRQL:  2
FAULTING_IP:
+3332333431616164
00000000`00000000 ??              ???
BUGCHECK_STR:  0xD1
TRAP_FRAME:  fffff80000ba2600 -- (.trap 0xfffff80000ba2600)
rax=0000000000000000 rbx=0000000000000000 rcx=fffffa8003dbd300
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=0000000000000000 rsp=fffff80000ba2798 rbp=0000000000000001
 r8=00000000ae3106c1  r9=0000000001cba6ea r10=0000000000000000
r11=fffff80002dfbe80 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl zr na po nc
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80002c80ca9 to fffff80002c81740
FAILED_INSTRUCTION_ADDRESS:
+3332333431616164
STACK_TEXT:
fffff800`00ba24b8 fffff800`02c80ca9 : 00000000`0000000a 00000000`00000000 00000000`00000002 00000000`00000008 : nt!KeBugCheckEx
fffff800`00ba24c0 fffff800`02c7f920 : 00000000`00000000 fffff800`00ba2848 fffff800`02dfbe80 fffff800`00ba2e88 : nt!KiBugCheckDispatch+0x69
fffff800`00ba2600 00000000`00000000 : fffff800`02c8d29e fffff800`00000000 00000000`00000000 00000000`40b41288 : nt!KiPageFault+0x260
STACK_COMMAND:  kb
FOLLOWUP_IP:
nt!KiPageFault+260
fffff800`02c7f920 440f20c0        mov     rax,cr8
SYMBOL_STACK_INDEX:  2
SYMBOL_NAME:  nt!KiPageFault+260
MODULE_NAME: nt
FAILURE_BUCKET_ID:  X64_0xD1_CODE_AV_NULL_IP_nt!KiPageFault+260
Loading Dump File [F:\a\Minidump\D M P\DMP\122910-35427-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02c5a000 PsLoadedModuleList = 0xfffff800`02e97e50
Debug session time: Wed Dec 29 10:15:11.145 2010 (UTC - 5:00)
System Uptime: 0 days 0:02:30.314
BugCheck D1, {ffc, 2, 0, fffff88001e2cb85}
Unable to load image \SystemRoot\System32\DRIVERS\fvevol.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for fvevol.sys
*** ERROR: Module load completed but symbols could not be loaded for fvevol.sys
Unable to load image \SystemRoot\System32\Drivers\sptd.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for sptd.sys
*** ERROR: Module load completed but symbols could not be loaded for sptd.sys
Probably caused by : fvevol.sys ( fvevol+2cb85 )
1: kd> !analyze -v
Arguments:
Arg1: 0000000000000ffc, memory referenced
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff88001e2cb85, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002f020e0
 0000000000000ffc
CURRENT_IRQL:  2
FAULTING_IP:
fvevol+2cb85
fffff880`01e2cb85 8b040a          mov     eax,dword ptr [rdx+rcx]
BUGCHECK_STR:  0xD1
TRAP_FRAME:  fffff8800391b4d0 -- (.trap 0xfffff8800391b4d0)
rax=0000000000031440 rbx=0000000000000000 rcx=000000fffffa9000
rdx=ffffff0000057ffc rsi=0000000000000000 rdi=0000000000000000
rip=fffff88001e2cb85 rsp=fffff8800391b660 rbp=0000000000000000
 r8=0000000000001000  r9=000000000000000e r10=0000000000401902
r11=000000fffffa8004 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl nz na po nc
fvevol+0x2cb85:
fffff880`01e2cb85 8b040a          mov     eax,dword ptr [rdx+rcx] ds:3022:00000000`00000ffc=????????
LAST_CONTROL_TRANSFER:  from fffff80002cc9ca9 to fffff80002cca740
STACK_TEXT:
fffff880`0391b388 fffff800`02cc9ca9 : 00000000`0000000a 00000000`00000ffc 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`0391b390 fffff800`02cc8920 : 00000000`00401902 fffffa80`03839e9b 00000000`00000050 00000000`1433743f : nt!KiBugCheckDispatch+0x69
fffff880`0391b4d0 fffff880`01e2cb85 : fffff880`01e01043 fffff800`02cccd26 fffffa80`03839e0b fffffa80`04465940 : nt!KiPageFault+0x260
fffff880`0391b660 fffff880`01e01043 : fffff800`02cccd26 fffffa80`03839e0b fffffa80`04465940 fffffa80`03839bd0 : fvevol+0x2cb85
fffff880`0391b668 fffff800`02cccd26 : fffffa80`03839e0b fffffa80`04465940 fffffa80`03839bd0 fffffa80`03839bd0 : fvevol+0x1043
fffff880`0391b670 fffff880`00c018ee : 00000000`00000001 000000da`00000001 fffff880`0391bbf0 00000000`00000000 : nt!IopfCompleteRequest+0x3a6
fffff880`0391b750 fffff800`02cccd26 : 00000000`00000000 fffff880`058f91cf fffffa80`05531040 fffff800`02e59880 : CLASSPNP!TransferPktComplete+0x1ce
fffff880`0391b7d0 fffff880`0138341a : fffffa80`043ad1a0 00000000`00000001 fffffa80`03823b80 00000000`00000000 : nt!IopfCompleteRequest+0x3a6
fffff880`0391b8b0 fffff880`01383242 : fffffa80`03823b80 fffff880`00000001 00000000`d6094380 00000000`d6094380 : ataport!IdeCompleteScsiIrp+0x62
fffff880`0391b8e0 fffff880`0137de32 : 00000000`00000002 00000000`00000000 00000000`00000001 fffff880`058fe49e : ataport!IdeCommonCrbCompletion+0x5a
fffff880`0391b910 fffff880`013867ed : fffffa80`043ad1a0 fffffa80`03823b80 00000000`00000000 fffff880`0391baa8 : ataport!IdeTranslateCompletedRequest+0x236
fffff880`0391ba40 fffff880`013860ec : fffffa80`043ad1a0 00000000`00000000 fffffa80`043ad1a0 00000000`00000000 : ataport!IdeProcessCompletedRequests+0x4d5
fffff880`0391bb70 fffff880`011164ce : fffffa80`033da000 fffff880`0391bc58 fffffa80`043ad050 fffffa80`033da750 : ataport!IdePortCompletionDpc+0x1a8
fffff880`0391bc30 fffffa80`033da000 : fffff880`0391bc58 fffffa80`043ad050 fffffa80`033da750 fffff880`009e8180 : sptd+0x424ce
fffff880`0391bc38 fffff880`0391bc58 : fffffa80`043ad050 fffffa80`033da750 fffff880`009e8180 00000000`00000000 : 0xfffffa80`033da000
fffff880`0391bc40 fffffa80`043ad050 : fffffa80`033da750 fffff880`009e8180 00000000`00000000 fffff880`009ecec0 : 0xfffff880`0391bc58
fffff880`0391bc48 fffffa80`033da750 : fffff880`009e8180 00000000`00000000 fffff880`009ecec0 00000000`00000022 : 0xfffffa80`043ad050
fffff880`0391bc50 fffff880`009e8180 : 00000000`00000000 fffff880`009ecec0 00000000`00000022 00000000`00000000 : 0xfffffa80`033da750
fffff880`0391bc58 00000000`00000000 : fffff880`009ecec0 00000000`00000022 00000000`00000000 00000000`00000000 : 0xfffff880`009e8180
STACK_COMMAND:  kb
FOLLOWUP_IP:
fvevol+2cb85
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  fvevol+2cb85
MODULE_NAME: fvevol
IMAGE_NAME:  fvevol.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4abd7db2
FAILURE_BUCKET_ID:  X64_0xD1_fvevol+2cb85
1: kd> !analyze -v
Arguments:
Debugging Details:
READ_ADDRESS:  0000000000000ffc
CURRENT_IRQL:  2
FAULTING_IP:
fvevol+2cb85
BUGCHECK_STR:  0xD1
fvevol+0x2cb85:
STACK_TEXT:
STACK_COMMAND:  kb
FOLLOWUP_IP:
fvevol+2cb85
MODULE_NAME: fvevol
Drivers:
fffff880`047a3000 fffff880`047b0000   Accelerometer Accelerometer.sys Fri Jul 16 11:02:38 2010 (4C40748E)
fffff880`01038000 fffff880`0108f000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`014ba000 fffff880`01535000   adp94xx  adp94xx.sys  Fri Dec 05 18:54:42 2008 (4939BF42)
fffff880`01535000 fffff880`0158b000   adpahci  adpahci.sys  Tue May 01 13:30:09 2007 (46377921)
fffff880`0158b000 fffff880`015ba000   adpu320  adpu320.sys  Tue Feb 27 19:04:15 2007 (45E4C6FF)
fffff880`0373a000 fffff880`037c4000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04643000 fffff880`04659000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`010cd000 fffff880`010d4000   aliide   aliide.sys   Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00e74000 fffff880`00e7b000   amdide   amdide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`049ea000 fffff880`049ff000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`015ba000 fffff880`015d8000   amdsata  amdsata.sys  Tue May 19 13:53:21 2009 (4A12F211)
fffff880`01200000 fffff880`01247000   amdsbs   amdsbs.sys   Fri Mar 20 14:36:03 2009 (49C3E213)
fffff880`015d8000 fffff880`015e3000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`04865000 fffff880`048a4000   Apfiltr  Apfiltr.sys  Tue May 12 05:38:59 2009 (4A0943B3)
fffff880`015e3000 fffff880`015fc000   arc      arc.sys      Thu May 24 17:27:55 2007 (4656035B)
fffff880`01400000 fffff880`0141b000   arcsas   arcsas.sys   Wed Jan 14 14:27:37 2009 (496E3CA9)
fffff880`01371000 fffff880`0137a000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0137a000 fffff880`013a4000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`04a53000 fffff880`04bc2000   athrx    athrx.sys    Mon Sep 21 22:47:11 2009 (4AB83AAF)
fffff880`04d85000 fffff880`04da6000   AtiHdmi  AtiHdmi.sys  Fri Jul 24 02:33:11 2009 (4A6955A7)
fffff880`052df000 fffff880`058f6000   atikmdag atikmdag.sys Wed Aug 05 00:14:11 2009 (4A790713)
fffff880`01db5000 fffff880`01dbd000   AtiPcie  AtiPcie.sys  Tue May 05 11:00:22 2009 (4A005486)
fffff960`00960000 fffff960`009c1000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`0475e000 fffff880`047a3000   av9owlik av9owlik.SYS Tue Jul 14 17:12:55 2009 (4A5CF4D7)
fffff880`00fcd000 fffff880`00fd9000   BATTC    BATTC.SYS    Mon Jul 13 19:31:01 2009 (4A5BC3B5)
fffff880`01c00000 fffff880`01c07000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`048d7000 fffff880`049c4000   BHDrvx64 BHDrvx64.sys Mon Nov 15 18:11:35 2010 (4CE1BE27)
fffff880`0474d000 fffff880`0475e000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`03ee0000 fffff880`03efe000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff880`046b1000 fffff880`0474d000   ccHPx64  ccHPx64.sys  Fri Feb 05 16:05:45 2010 (4B6C8829)
fffff960`00740000 fffff960`00767000   cdd      cdd.dll      unavailable (00000000)
fffff880`01a4f000 fffff880`01a79000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00cdd000 fffff880`00d9d000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`04cf2000 fffff880`04d04000   circlass circlass.sys Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`00c00000 fffff880`00c30000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c7f000 fffff880`00cdd000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`04bf8000 fffff880`04bfc500   CmBatt   CmBatt.sys   Mon Jul 13 19:31:03 2009 (4A5BC3B7)
fffff880`00e7b000 fffff880`00e83000   cmdide   cmdide.sys   Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01ecb000 fffff880`01f3e000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`010c4000 fffff880`010cd000   compbatt compbatt.sys Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`047b0000 fffff880`047c0000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`047ef000 fffff880`047fd000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`045bb000 fffff880`045d9000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`045ac000 fffff880`045bb000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01e3a000 fffff880`01e50000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`04c00000 fffff880`04c22000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`046a4000 fffff880`046b0000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`01dbd000 fffff880`01dd0000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`044a3000 fffff880`044ae000   dump_msahci dump_msahci.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`0449b000 fffff880`044a3000   dvmio    dvmio.sys    Fri Sep 25 13:50:24 2009 (4ABD02E0)
fffff880`01dd0000 fffff880`01ddc000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`058f6000 fffff880`059ea000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`05200000 fffff880`05246000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`04400000 fffff880`04476000   eeCtrl64 eeCtrl64.sys Fri May 21 17:44:45 2010 (4BF6FECD)
fffff880`016f3000 fffff880`0177a000   elxstor  elxstor.sys  Tue Feb 03 17:52:11 2009 (4988CA9B)
fffff880`048b3000 fffff880`048d0000   enecir   enecir.sys   Wed May 20 02:08:57 2009 (4A139E79)
fffff880`087cf000 fffff880`087ef000   ENG64    ENG64.SYS    Mon Dec 13 20:47:30 2010 (4D06CCB2)
fffff880`04476000 fffff880`0449b000   EraserUtilRebootDrv EraserUtilRebootDrv.sys Fri May 21 17:44:45 2010 (4BF6FECD)
fffff880`08615000 fffff880`087cf000   EX64     EX64.SYS     Mon Dec 13 20:55:48 2010 (4D06CEA4)
fffff880`04bc2000 fffff880`04bf8000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`01a00000 fffff880`01a14000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`01b41000 fffff880`01b8d000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01f4f000 fffff880`01f59000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01e00000 fffff880`01e3a000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`0208b000 fffff880`020d5000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`04a46000 fffff880`04a53000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`02c11000 fffff800`02c5a000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`05246000 fffff880`0526a000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`04cb2000 fffff880`04ccb000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`04ca1000 fffff880`04cb2000   hidir    hidir.sys    Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`04ccb000 fffff880`04cd3080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`037ee000 fffff880`037fc000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`01ff1000 fffff880`01ffb000   hpdskflt hpdskflt.sys Fri Jul 16 11:02:38 2010 (4C40748E)
fffff880`059ea000 fffff880`059f6000   HpqKbFiltr HpqKbFiltr.sys Wed Apr 29 09:48:30 2009 (49F85AAE)
fffff880`014a3000 fffff880`014ba000   HpSAMD   HpSAMD.sys   Mon May 18 19:43:49 2009 (4A11F2B5)
fffff880`03e0e000 fffff880`03ed6000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`020e5000 fffff880`020ee000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`052b9000 fffff880`052d7000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01253000 fffff880`01371000   iaStorV  iaStorV.sys  Wed Apr 08 12:57:17 2009 (49DCD76D)
fffff880`04531000 fffff880`045ac000   IDSvia64 IDSvia64.sys Fri Nov 05 17:13:11 2010 (4CD47367)
fffff880`0177a000 fffff880`0178b000   iirsp    iirsp.sys    Tue Dec 13 16:47:54 2005 (439F418A)
fffff880`00e5c000 fffff880`00e64000   intelide intelide.sys Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`00c30000 fffff880`00c57000   Ironx64  Ironx64.SYS  Tue Apr 27 20:48:23 2010 (4BD785D7)
fffff880`010a6000 fffff880`010af000   isapnp   isapnp.sys   Mon Jul 13 19:31:08 2009 (4A5BC3BC)
fffff880`0526a000 fffff880`05291000   jmcr     jmcr.sys     Thu Jul 09 08:45:19 2009 (4A55E65F)
fffff880`04856000 fffff880`04865000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`04de3000 fffff880`04df1000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00b9b000 fffff800`00ba5000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`04600000 fffff880`04643000   ks       ks.sys       Mon Jul 13 20:00:31 2009 (4A5BCA9F)
fffff880`01eb1000 fffff880`01ecb000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`02060000 fffff880`0208b000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`048d0000 fffff880`048d5200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`06acc000 fffff880`06ae1000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0178b000 fffff880`017aa000   lsi_fc   lsi_fc.sys   Tue Dec 09 17:46:09 2008 (493EF531)
fffff880`013a4000 fffff880`013c1000   lsi_sas  lsi_sas.sys  Mon May 18 20:20:23 2009 (4A11FB47)
fffff880`017aa000 fffff880`017bd000   lsi_sas2 lsi_sas2.sys Mon May 18 20:31:48 2009 (4A11FDF4)
fffff880`017bd000 fffff880`017dc000   lsi_scsi lsi_scsi.sys Thu Apr 16 18:13:50 2009 (49E7AD9E)
fffff880`06a88000 fffff880`06aab000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c5e000 fffff880`00c6b000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`017dc000 fffff880`017e8000   megasas  megasas.sys  Mon May 18 21:09:46 2009 (4A1206DA)
fffff880`01600000 fffff880`016a4000   MegaSR   MegaSR.sys   Mon May 18 21:25:54 2009 (4A120AA2)
fffff880`06a7a000 fffff880`06a88000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`048a4000 fffff880`048b3000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`04df1000 fffff880`04dfe000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00e83000 fffff880`00e9d000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00fa3000 fffff880`00fcd000   mpio     mpio.sys     Mon Jul 13 20:01:27 2009 (4A5BCAD7)
fffff880`03efe000 fffff880`03f16000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`03f16000 fffff880`03f43000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`03f43000 fffff880`03f91000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`03f91000 fffff880`03fb4000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`01498000 fffff880`014a3000   msahci   msahci.sys   Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`00d9d000 fffff880`00dc3000   msdsm    msdsm.sys    Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01800000 fffff880`0180b000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0108f000 fffff880`01099000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01e53000 fffff880`01eb1000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`04526000 fffff880`04531000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01fdf000 fffff880`01ff1000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`020ee000 fffff880`021e0000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`0467d000 fffff880`04689000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`06b34000 fffff880`06b47000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`047c0000 fffff880`047ef000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`04d70000 fffff880`04d85000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`037c4000 fffff880`037d3000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`03600000 fffff880`03645000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`02000000 fffff880`02060000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`016a4000 fffff880`016b4000   nfrd960  nfrd960.sys  Tue Jun 06 17:11:48 2006 (4485EF94)
fffff880`016df000 fffff880`016f0000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0451a000 fffff880`04526000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02c5a000 fffff800`03236000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`01c12000 fffff880`01db5000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`01df5000 fffff880`01dfe000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`00dc3000 fffff880`00dec000   nvraid   nvraid.sys   Wed May 20 02:39:40 2009 (4A13A5AC)
fffff880`016b4000 fffff880`016df000   nvstor   nvstor.sys   Wed May 20 02:45:37 2009 (4A13A711)
fffff880`06ae1000 fffff880`06b34000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`0364e000 fffff880`03674000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`010af000 fffff880`010c4000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f70000 fffff880`00fa3000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00e9d000 fffff880`00ea4000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00e64000 fffff880`00e74000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01f3e000 fffff880`01f4f000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`078a0000 fffff880`07946000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`04da6000 fffff880`04de3000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c6b000 fffff880`00c7f000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`01815000 fffff880`019b9000   ql2300   ql2300.sys   Thu Jan 22 18:05:06 2009 (4978FBA2)
fffff880`01a88000 fffff880`01ae7000   ql40xx   ql40xx.sys   Mon May 18 21:18:11 2009 (4A1208D3)
fffff880`04659000 fffff880`0467d000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`04689000 fffff880`046a4000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`045d9000 fffff880`045fa000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`04cd6000 fffff880`04cf0000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`044c9000 fffff880`0451a000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`01c07000 fffff880`01c10000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`019ee000 fffff880`019f7000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`019f7000 fffff880`01a00000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01fa5000 fffff880`01fdf000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`06b47000 fffff880`06b5f000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`04a0d000 fffff880`04a46000   Rt64win7 Rt64win7.sys Fri May 22 10:52:30 2009 (4A16BC2E)
fffff880`021e0000 fffff880`021fd000   sbp2port sbp2port.sys Mon Jul 13 19:19:53 2009 (4A5BC119)
fffff880`044af000 fffff880`044c9000   SCDEmu   SCDEmu.SYS   Mon Apr 12 04:52:25 2010 (4BC2DF49)
fffff880`01009000 fffff880`01038000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
fffff880`07946000 fffff880`07951000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`052d7000 fffff880`052df000   serscan  serscan.sys  Mon Jul 13 20:35:32 2009 (4A5BD2D4)
fffff880`01ae7000 fffff880`01af5000   SiSRaid2 SiSRaid2.sys Wed Sep 24 14:28:20 2008 (48DA86C4)
fffff880`01af5000 fffff880`01b0d000   sisraid4 sisraid4.sys Wed Oct 01 17:56:04 2008 (48E3F1F4)
fffff880`020dd000 fffff880`020e5000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`010d4000 fffff880`011fa000   sptd     sptd.sys     Sun Oct 11 16:55:14 2009 (4AD24632)
fffff880`06b5f000 fffff880`06be5000   SRTSP64  SRTSP64.SYS  Wed Feb 24 18:59:29 2010 (4B85BD61)
fffff880`013df000 fffff880`013f3000   SRTSPX64 SRTSPX64.SYS Wed Feb 24 18:59:48 2010 (4B85BD74)
fffff880`07800000 fffff880`07896000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`07990000 fffff880`079f7000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`07951000 fffff880`0797e000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`01b0d000 fffff880`01b17000   stexstor stexstor.sys Tue Feb 17 18:03:36 2009 (499B4248)
fffff880`01436000 fffff880`01498000   storport storport.sys Mon Jul 13 20:01:18 2009 (4A5BCACE)
fffff880`04c22000 fffff880`04ca1000   stwrt64  stwrt64.sys  Wed Mar 24 00:01:24 2010 (4BA98E94)
fffff880`04cf0000 fffff880`04cf1480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01b8d000 fffff880`01bfb000   SYMDS64  SYMDS64.SYS  Mon Aug 17 19:35:30 2009 (4A89E942)
fffff880`01a14000 fffff880`01a4f000   SYMEFA64 SYMEFA64.SYS Wed Apr 21 17:47:39 2010 (4BCF727B)
fffff880`03704000 fffff880`0373a000   SYMEVENT64x86 SYMEVENT64x86.SYS Thu Aug 13 18:28:21 2009 (4A849385)
fffff880`0368e000 fffff880`03704000   SYMTDIV  SYMTDIV.SYS  Tue May 04 00:38:27 2010 (4BDFA4C3)
fffff880`02202000 fffff880`023ff000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`0797e000 fffff880`07990000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`017e8000 fffff880`017f5000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`013c1000 fffff880`013df000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`0141b000 fffff880`0142f000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`005c0000 fffff960`005ca000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`049c4000 fffff880`049ea000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`04d04000 fffff880`04d16000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`06a2f000 fffff880`06a4c000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`04dfe000 fffff880`04dfff00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`052a8000 fffff880`052b9000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`0529c000 fffff880`052a8000   usbfilter usbfilter.sys Fri Apr 03 07:39:51 2009 (49D5F587)
fffff880`04d16000 fffff880`04d70000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`05291000 fffff880`0529c000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`04800000 fffff880`04856000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`06a4c000 fffff880`06a79100   usbvideo usbvideo.sys Mon Jul 13 20:07:00 2009 (4A5BCC24)
fffff880`01099000 fffff880`010a6000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01a79000 fffff880`01a87000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`00ea4000 fffff880`00eac000   viaide   viaide.sys   Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`019b9000 fffff880`019de000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00fd9000 fffff880`00fee000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00e00000 fffff880`00e5c000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01f59000 fffff880`01fa5000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`01b17000 fffff880`01b41000   vsmraid  vsmraid.sys  Fri Jan 30 20:18:57 2009 (4983A701)
fffff880`04a00000 fffff880`04a0d000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`03674000 fffff880`0368a000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`03ed6000 fffff880`03ee0000   vwifimp  vwifimp.sys  Mon Jul 13 20:07:28 2009 (4A5BCC40)
fffff880`037d3000 fffff880`037ee000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`019de000 fffff880`019ee000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`020d5000 fffff880`020dd000   wd       wd.sys       Mon Jul 13 19:19:55 2009 (4A5BC11B)
fffff880`00ebd000 fffff880`00f61000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f61000 fffff880`00f70000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`03645000 fffff880`0364e000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00080000 fffff960`00390000   win32k   win32k.sys   unavailable (00000000)
fffff880`059f6000 fffff880`059ff000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`01000000 fffff880`01009000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`06aab000 fffff880`06acc000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`01dbd000 fffff880`01dcb000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01dcb000 fffff880`01dd7000   dump_pciidex
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01dd7000 fffff880`01de2000   dump_msahci.
    Checksum:  00000000
    ImageSize:  0000B000
fffff880`01de2000 fffff880`01df5000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`037d3000 fffff880`037f0000   serial.sys
    Checksum:  00000000
    ImageSize:  0001D000
hello!
thank you so much for helping me with this. Unfortunately, this caused immediate problems when I restarted the computer. It went into the indows recovery error screen, where it asks me to do startup repair or start windows normally. Either option causes it to go to a boot manager screen which says that the boot manager failed to start, etc. with the 0xc000000f error. I am not sure what to do now. When I access the Recovery Options, neither the startup repair or the system restore work. The comp either freezes or crashes again. I was doing some research and think it might have something to do with my bcdoutput file-- I have several boot loader entries that i think is causing some issues ? Could some take a look at it for me please?
Hi!
thank you-- i just attempted this, and the same error occurred.
thoughts?
ETA: It really bothers me that no matter what I try, I cannot seem to run the recovery disc from my ROM Drive. The only way I have access is to press F11 to attempt to get into recovery mode. Otherwise, it sends me into a continuous loop of the windows error recovery and both options lead to the windows boot manager screen which calls for the disc.
Hi!
thoughts?
If it bsod-ed during the repair, this likely points to a hardware problem. Start troubleshooting by running memtest 10 passes overnight:
Memtest86+ - Advanced Memory Diagnostic Tool
Then check your hard drive:
HD Diagnostic
Might be the power supply too Power Supply Test - How Do I Test the Power Supply in My Computer? - PSU Test
