Constant BSOD, help need ><"
[SOLVED]Constant BSOD, help need ><"
I've only just recently built my computer, i installed all the latest drivers(excluding msi motherboard, just used the cd for that), but i seem to get BSOD on alot of programs/functions, some including:
-When Previewing screensaver
-Playing chess
-When getting computer rating.
Computer specs:
i5 2400 3.1ghz
gigabyte HD 6850 1gb
MSI P67-GD55-B3
Windows 7 64bit home premium
Problem signature:
OS Version: 6.1.7600.2.0.0.768.3
Locale ID: 2057
Additional information about the problem:
BCCode: 116
BCP1: FFFFFA8003E234E0
BCP2: FFFFF88003EC5F94
BCP3: 0000000000000000
BCP4: 0000000000000002
OS Version: 6_1_7600
Service Pack: 0_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\040211-19765-01.dmp
C:\Users\Samuel\AppData\Local\Temp\WER-29515-0.sysdata.xml
Read our privacy statement online:
Windows 7 Privacy Statement - Microsoft Windows
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Boot to safe mode and disable the videocard in Control Panel > Device Manager.
If it gives you 116 and doesn't let you boot normally, that's likely the card bit the dust.
Things to try before replacing the videocard:
BugCheck 116, {fffffa8003e234e0, fffff88003ec5f94, 0, 2}
*** WARNING: Unable to verify timestamp for atikmpag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmpag.sys
Probably caused by : atikmpag.sys ( atikmpag+6f94 )
1. No overclocking, reset bios settings (load setup/optimized/fail-safe defaults)
2. Re-install the video driver, try different versions,
http://www.guru3d.com/category/driversweeper/
3. Update Creative Audio Driver,
MBfilt64.sys Thu Jul 30 23:40:32 2009
4. Update IOGEAR GWU623
arusb_win7x.sys Thu Nov 26 03:55:17 2009
BCCode 116 ---> videocard fault.
CRASH DUMPS
Loading Dump File [F:\DMP\040211-19765-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0xfffff800`02a08000 PsLoadedModuleList = 0xfffff800`02c45e50
Debug session time: Sat Apr  2 07:21:02.681 2011 (UTC - 4:00)
System Uptime: 0 days 0:04:12.992
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Followup: MachineOwner
3: kd> !analyze -v
VIDEO_TDR_FAILURE (116)
Attempt to reset the display driver and recover from timeout failed.
Arguments:
Arg1: fffffa8003e234e0, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff88003ec5f94, The pointer into responsible device driver module (e.g. owner tag).
Arg3: 0000000000000000, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 0000000000000002, Optional internal context dependent data.
Debugging Details:
FAULTING_IP:
atikmpag+6f94
fffff880`03ec5f94 4883ec28        sub     rsp,28h
DEFAULT_BUCKET_ID:  GRAPHICS_DRIVER_TDR_FAULT
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x116
PROCESS_NAME:  System
CURRENT_IRQL:  0
STACK_TEXT:
fffff880`05be4988 fffff880`03f66cbc : 00000000`00000116 fffffa80`03e234e0 fffff880`03ec5f94 00000000`00000000 : nt!KeBugCheckEx
fffff880`05be4990 fffff880`03f669c6 : fffff880`03ec5f94 fffffa80`03e234e0 fffffa80`05ec4010 fffffa80`0622e410 : dxgkrnl!TdrBugcheckOnTimeout+0xec
fffff880`05be49d0 fffff880`03e0ff07 : fffffa80`03e234e0 00000000`00000000 fffffa80`05ec4010 fffffa80`0622e410 : dxgkrnl!TdrIsRecoveryRequired+0x1a2
fffff880`05be4a00 fffff880`03e39b75 : 00000000`ffffffff 00000000`00003c03 00000000`00000000 00000000`00000002 : dxgmms1!VidSchiReportHwHang+0x40b
fffff880`05be4ae0 fffff880`03e382bb : 00000000`00000102 00000000`00000000 00000000`00003c03 00000000`00000000 : dxgmms1!VidSchiCheckHwProgress+0x71
fffff880`05be4b10 fffff880`03e0b2c6 : ffffffff`ff676980 fffffa80`0622e410 00000000`00000000 00000000`00000000 : dxgmms1!VidSchiWaitForSchedulerEvents+0x1fb
fffff880`05be4bb0 fffff880`03e37e7a : 00000000`00000000 fffffa80`05ec4010 00000000`00000080 fffffa80`0622e410 : dxgmms1!VidSchiScheduleCommandToRun+0x1da
fffff880`05be4cc0 fffff800`02d1d166 : 00000000`fffffc32 fffffa80`07a04b60 fffffa80`03cb9040 fffffa80`07a04b60 : dxgmms1!VidSchiWorkerThread+0xba
fffff880`05be4d00 fffff800`02a58486 : fffff880`02f64180 fffffa80`07a04b60 fffff880`02f6efc0 fffff880`01267534 : nt!PspSystemThreadStartup+0x5a
fffff880`05be4d40 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND:  .bugcheck ; kb
FOLLOWUP_IP:
atikmpag+6f94
SYMBOL_NAME:  atikmpag+6f94
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: atikmpag
IMAGE_NAME:  atikmpag.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4ca29309
FAILURE_BUCKET_ID:  X64_0x116_IMAGE_atikmpag.sys
DRIVERS
fffff880`00f1b000 fffff880`00f72000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02c78000 fffff880`02d02000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`0415a000 fffff880`04170000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`00c4d000 fffff880`00c58000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`0649d000 fffff880`065a7000   arusb_win7x arusb_win7x.sys Thu Nov 26 03:55:17 2009 (4B0E4275)
fffff880`00c1a000 fffff880`00c23000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00c23000 fffff880`00c4d000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`0436d000 fffff880`0438d000   AtihdW76 AtihdW76.sys Mon Aug 16 06:41:02 2010 (4C6915BE)
fffff880`04824000 fffff880`04ffa000   atikmdag atikmdag.sys Tue Sep 28 21:41:26 2010 (4CA29946)
fffff880`03ebf000 fffff880`03f0a000   atikmpag atikmpag.sys Tue Sep 28 21:14:49 2010 (4CA29309)
fffff880`0191e000 fffff880`01925000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`02de7000 fffff880`02df8000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`02b62000 fffff880`02b80000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00790000 fffff960`007b7000   cdd      cdd.dll      unavailable (00000000)
fffff880`018eb000 fffff880`01915000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00d2d000 fffff880`00ded000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01885000 fffff880`018b5000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00ccf000 fffff880`00d2d000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`010f4000 fffff880`01167000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`0414a000 fffff880`0415a000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`05eef000 fffff880`05efd000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`019ca000 fffff880`019e8000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`02c68000 fffff880`02c77000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`0186f000 fffff880`01885000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`043ca000 fffff880`043ec000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`05f09000 fffff880`05f12000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`05efd000 fffff880`05f09000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`05f12000 fffff880`05f25000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`065a7000 fffff880`065b3000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`03f0a000 fffff880`03ffe000   dxgkrnl  dxgkrnl.sys  Mon Jul 13 19:38:56 2009 (4A5BC590)
fffff880`03e00000 fffff880`03e46000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`01082000 fffff880`01096000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`01036000 fffff880`01082000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`0122b000 fffff880`01235000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`01835000 fffff880`0186f000   fvevol   fvevol.sys   Mon Jul 13 19:22:15 2009 (4A5BC1A7)
fffff880`01400000 fffff880`0144a000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`02fe5000 fffff800`0302e000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`04800000 fffff880`04824000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`03e46000 fffff880`03e57000   HECIx64  HECIx64.sys  Tue Oct 19 19:33:43 2010 (4CBE2AD7)
fffff880`065ce000 fffff880`065e7000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`065e7000 fffff880`065ef080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`065c0000 fffff880`065ce000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`02a9a000 fffff880`02b62000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`0146e000 fffff880`01477000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`040f2000 fffff880`04110000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`04134000 fffff880`0414a000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`04110000 fffff880`0411f000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff800`00bad000 fffff800`00bb7000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`04290000 fffff880`042d3000   ks       ks.sys       Mon Jul 13 20:00:31 2009 (4A5BCA9F)
fffff880`01200000 fffff880`0121a000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`015d0000 fffff880`015fb000   ksecpkg  ksecpkg.sys  Mon Jul 13 19:50:34 2009 (4A5BC84A)
fffff880`043ec000 fffff880`043f1200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`06452000 fffff880`06467000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0640e000 fffff880`06431000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`05ee1000 fffff880`05eef000   MBfilt64 MBfilt64.sys Thu Jul 30 23:40:32 2009 (4A7267B0)
fffff880`00c77000 fffff880`00cbb000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`06400000 fffff880`0640e000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`0403b000 fffff880`0404a000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`065f0000 fffff880`065fd000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00c00000 fffff880`00c1a000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02b80000 fffff880`02b98000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`02b98000 fffff880`02bc4000   mrxsmb   mrxsmb.sys   Mon Jul 13 19:23:59 2009 (4A5BC20F)
fffff880`02a00000 fffff880`02a4d000   mrxsmb10 mrxsmb10.sys Mon Jul 13 19:24:08 2009 (4A5BC218)
fffff880`02a4d000 fffff880`02a70000   mrxsmb20 mrxsmb20.sys Mon Jul 13 19:24:05 2009 (4A5BC215)
fffff880`01983000 fffff880`0198e000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f7b000 fffff880`00f85000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01096000 fffff880`010f4000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`02c5d000 fffff880`02c68000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`0145c000 fffff880`0146e000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0147e000 fffff880`01570000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04194000 fffff880`041a0000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`06467000 fffff880`0647a000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`041a0000 fffff880`041cf000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`04358000 fffff880`0436d000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02d8c000 fffff880`02d9b000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02d02000 fffff880`02d47000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01570000 fffff880`015d0000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`0198e000 fffff880`0199f000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02c51000 fffff880`02c5d000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02a08000 fffff800`02fe5000   nt       ntkrnlmp.exe Mon Jul 13 19:40:48 2009 (4A5BC600)
fffff880`01259000 fffff880`013fc000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`01915000 fffff880`0191e000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`0433f000 fffff880`04358000   nusb3hub nusb3hub.sys Thu Sep 30 00:00:03 2010 (4CA40B43)
fffff880`01000000 fffff880`01030000   nusb3xhc nusb3xhc.sys Thu Sep 30 00:00:03 2010 (4CA40B43)
fffff880`05f25000 fffff880`05f78000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`02d50000 fffff880`02d76000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00fc5000 fffff880`00fda000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f85000 fffff880`00fb8000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00e5c000 fffff880`00e63000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00fef000 fffff880`00fff000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0121a000 fffff880`0122b000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`060fb000 fffff880`061a1000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`0438d000 fffff880`043ca000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00cbb000 fffff880`00ccf000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`04170000 fffff880`04194000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`041cf000 fffff880`041ea000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`04000000 fffff880`04021000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`04021000 fffff880`0403b000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`02c00000 fffff880`02c51000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`01968000 fffff880`01971000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01971000 fffff880`0197a000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0197a000 fffff880`01983000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`011b3000 fffff880`011ed000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`0647a000 fffff880`06492000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0408c000 fffff880`040f2000   Rt64win7 Rt64win7.sys Thu Nov 11 01:35:36 2010 (4CDB8EB8)
fffff880`05c77000 fffff880`05ee0800   RTKVHD64 RTKVHD64.sys Tue Nov 02 07:25:59 2010 (4CCFF547)
fffff880`061a1000 fffff880`061ac000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`0411f000 fffff880`0412b000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`02d9b000 fffff880`02db8000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`01452000 fffff880`0145c000   speedfan speedfan.sys Sat Dec 18 06:03:51 2010 (4D0C9517)
fffff880`0144a000 fffff880`01452000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`06f6c000 fffff880`06fdd000   spsys    spsys.sys    Mon May 11 13:20:58 2009 (4A085E7A)
fffff880`06ed4000 fffff880`06f6c000   srv      srv.sys      Mon Jul 13 19:25:11 2009 (4A5BC257)
fffff880`06000000 fffff880`06069000   srv2     srv2.sys     Mon Jul 13 19:25:02 2009 (4A5BC24E)
fffff880`061ac000 fffff880`061d9000   srvnet   srvnet.sys   Mon Jul 13 19:24:58 2009 (4A5BC24A)
fffff880`0404a000 fffff880`0404b480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01601000 fffff880`017fe000   tcpip    tcpip.sys    Mon Jul 13 19:25:34 2009 (4A5BC26E)
fffff880`061d9000 fffff880`061eb000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`019bd000 fffff880`019ca000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`0199f000 fffff880`019bd000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02dd3000 fffff880`02de7000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00470000 fffff960`0047a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`01800000 fffff880`01826000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`042d3000 fffff880`042e5000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`04ffa000 fffff880`04ffbf00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`03e57000 fffff880`03e68000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`042e5000 fffff880`0433f000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`03e68000 fffff880`03ebe000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`00fb8000 fffff880`00fc5000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01925000 fffff880`01933000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01933000 fffff880`01958000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00fda000 fffff880`00fef000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00e00000 fffff880`00e5c000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01167000 fffff880`011b3000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`065b3000 fffff880`065c0000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`02d76000 fffff880`02d8c000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`02db8000 fffff880`02dd3000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`01958000 fffff880`01968000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e68000 fffff880`00f0c000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f0c000 fffff880`00f1b000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02d47000 fffff880`02d50000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00060000 fffff960`0036f000   win32k   win32k.sys   unavailable (00000000)
fffff880`0412b000 fffff880`04134000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f72000 fffff880`00f7b000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`06431000 fffff880`06452000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`018b5000 fffff880`018c3000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`018c3000 fffff880`018cf000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`018cf000 fffff880`018d8000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`018d8000 fffff880`018eb000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Ok so i reinstalled my video card drivers and i found out that i used the wrong version, now that i installed it its running nicely without bsods =3:):):)
many thanks man.
You're welcome.
