Constant BSOD issues
Hello everyone, I am keep receiving BSOD (6-10 per day) and for months I am unable to figure out why. Every few minutes, I receive "irql_not_less_or_equal" caused by "ntoskrnl.exe". I downloaded Bluescreenviewer and tried to find anything, but no luck so far. I have attached all the recent BSOD Minidump files in hope of someone being able to help me. It happens randomly, sometimes when I'm in iTunes, when copying files or just sitting on the desktop. Therefore I am unable to link it to the specific area (Graphics, ram, disc, etc...)
Specs:
Intel Core 2 Quad (2.83GHz) LGA775
Patriot Memory 9-9-9-24 PC3-8500 1333EL
2x OCZ Agility SSD in Raid 0
Intel Extreme motherboard
AMD Radeon 5870 1GB Graphics Card (Oct. 22 video drivers)
I'd appreciate any help, as my computer is pretty much useless because it won't stay on for longer than 1 hour without causing a BSOD.
Thanks in advance!
usasma
Fantastic Member
For a complete analysis, please provide this info: http://windows7forums.com/blue-screen-death-bsod/38837-how-ask-help-bsod-problem.html
e1y60x64.sys Mon Aug 18 17:45:05 2008 (48A9ED61)
Intel(R) 82567LM Gigabit Network Connection
http://www.carrona.org/drivers/driver.php?id=e1y60x64.sys
If this doesn't fix the BSOD's, please try these 2 things (I'm uncertain if this is hardware or software):
- run these free hardware diagnostics: Hardware Diagnostics
- run Driver Verifier according to these directions: Driver Verifier Settings
Analysis:
The following is for informational purposes only.
[FONT=lucida console]**************************Sat Nov 10 00:28:55.150 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111012-8268-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].17944.amd64fre.win7sp1_gdr.120830-0333
System Uptime:[B]0 days 0:21:05.056[/B]
BugCheck Code: [B]BugCheck A, {fffffa7fffffffd0, 2, 1, fffff80001ce087c}[/B]
Probably caused by :[B]memory_corruption ( nt!MiInsertPageInFreeOrZeroedList+54c )[/B]
BugCheck Info: [B]IRQL_NOT_LESS_OR_EQUAL (a)[/B]
Arguments:
Arg1: fffffa7fffffffd0, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
Arg4: fffff80001ce087c, address which referenced memory
BUGCHECK_STR:  0xA
PROCESS_NAME: [B]MsMpEng.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0xA_nt!MiInsertPageInFreeOrZeroedList+54c[/B]
CPUID:        "Intel(R) Core(TM)2 Quad CPU    Q9550  @ 2.83GHz"
MaxSpeed:     2830
CurrentSpeed: [B]2830[/B]
  BIOS Version                  SGP4510H.86A.0125.2010.0121.1927
  BIOS Release Date             01/21/2010
  Manufacturer
  Product Name
**************************Sat Nov 10 00:06:52.901 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\111012-8658-01.dmp]
System Uptime:[B]0 days 3:13:29.416[/B]
BugCheck Code: [B]BugCheck A, {fffffa7fffffffd0, 2, 1, fffff80001ce687c}[/B]
Arguments:
Arg4: fffff80001ce687c, address which referenced memory
BUGCHECK_STR:  0xA
MaxSpeed:     2830
  Manufacturer
  Product Name
**************************Fri Nov  9 20:52:23.502 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\110912-10717-01.dmp]
System Uptime:[B]0 days 1:34:19.408[/B]
BugCheck Code: [B]BugCheck 4A, {7fefe02baea, 2, 0, fffff8800bb186e0}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiSystemServiceExit+245 )[/B]
BugCheck Info: [B]IRQL_GT_ZERO_AT_SYSTEM_SERVICE (4a)[/B]
Arguments:
Arg1: 000007fefe02baea, Address of system function (system call routine)
Arg2: 0000000000000002, Current IRQL
Arg3: 0000000000000000, 0
Arg4: fffff8800bb186e0, 0
PROCESS_NAME: [B]explorer.exe[/B]
BUGCHECK_STR:  RAISED_IRQL_FAULT
FAILURE_BUCKET_ID: [B]X64_RAISED_IRQL_FAULT_explorer.exe_nt!KiSystemServiceExit+245[/B]
MaxSpeed:     2830
  Manufacturer
  Product Name
**************************Fri Nov  9 19:16:08.134 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\110912-10467-01.dmp]
System Uptime:[B]0 days 4:18:12.039[/B]
BugCheck Code: [B]BugCheck 1000007E, {ffffffffc0000005, fffff80001ca7861, fffff880009a9998, fffff880009a91f0}[/B]
Probably caused by :[B]memory_corruption ( nt!MmZeroPageThread+3c4 )[/B]
BugCheck Info: [B]SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)[/B]
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff80001ca7861, The address that the exception occurred at
Arg3: fffff880009a9998, Exception Record Address
Arg4: fffff880009a91f0, Context Record Address
PROCESS_NAME: [B]System[/B]
BUGCHECK_STR:  0x7E
FAILURE_BUCKET_ID: [B]X64_0x7E_nt!MmZeroPageThread+3c4[/B]
MaxSpeed:     2830
  Manufacturer
  Product Name
**************************Thu Nov  8 17:25:32.010 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\110912-13244-01.dmp]
System Uptime:[B]0 days 0:36:08.915[/B]
BugCheck Code: [B]BugCheck A, {fffffa7fffffffd0, 2, 1, fffff80001c9287c}[/B]
Arguments:
Arg4: fffff80001c9287c, address which referenced memory
BUGCHECK_STR:  0xA
MaxSpeed:     2830
  Manufacturer
  Product Name
**************************Wed Nov  7 23:03:56.554 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\110712-8502-01.dmp]
System Uptime:[B]0 days 0:30:31.070[/B]
BugCheck Code: [B]BugCheck 24, {1904fb, fffff8800a7f0fd8, fffff8800a7f0830, fffff80001afbb9e}[/B]
Probably caused by :[B]memory_corruption ( nt!MiRemoveAnyPage+13e )[/B]
BugCheck Info: [B]NTFS_FILE_SYSTEM (24)[/B]
Arguments:
Arg1: 00000000001904fb
Arg2: fffff8800a7f0fd8
Arg3: fffff8800a7f0830
Arg4: fffff80001afbb9e
DEFAULT_BUCKET_ID:  NULL_DEREFERENCE
PROCESS_NAME: [B]iTunes.exe[/B]
BUGCHECK_STR:  0x24
FAILURE_BUCKET_ID: [B]X64_0x24_nt!MiRemoveAnyPage+13e[/B]
MaxSpeed:     2830
  Manufacturer
  Product Name
**************************Wed Nov  7 19:51:08.511 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\110712-7924-01.dmp]
System Uptime:[B]0 days 0:17:29.027[/B]
BugCheck Code: [B]BugCheck A, {fffffa7fffffffd0, 2, 1, fffff80001aed87c}[/B]
Arguments:
Arg4: fffff80001aed87c, address which referenced memory
BUGCHECK_STR:  0xA
PROCESS_NAME: [B]svchost.exe[/B]
MaxSpeed:     2830
  Manufacturer
  Product Name
**************************Sat Oct 27 13:44:15.110 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\102712-7004-01.dmp]
System Uptime:[B]0 days 3:19:01.016[/B]
BugCheck Code: [B]BugCheck A, {fffffa7fffffffd0, 2, 1, fffff80001a9787c}[/B]
Arguments:
Arg4: fffff80001a9787c, address which referenced memory
BUGCHECK_STR:  0xA
PROCESS_NAME: [B]chrome.exe[/B]
MaxSpeed:     2830
  Manufacturer
  Product Name
[/FONT]
3rd Party Drivers:
[COLOR=RED][B]e1y60x64.sys                Mon Aug 18 17:45:05 2008 (48A9ED61)[/B][/COLOR]
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
iaStor.sys                  Wed Mar  3 21:51:31 2010 (4B8F2033)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
iaStorV.sys                 Thu Jun 10 20:46:19 2010 (4C11875B)
stwrt64.sys                 Sun Oct 23 22:57:05 2011 (4EA4D401)
AtihdW76.sys                Fri May 11 04:25:40 2012 (4FACCD04)
MpFilter.sys                Thu Aug 23 19:03:14 2012 (5036B6B2)
atikmpag.sys                Thu Sep 27 21:12:52 2012 (5064F994)
atikmdag.sys                Thu Sep 27 22:14:57 2012 (50650821)
usbaapl64.sys               Fri Jun 22 02:01:11 2012 (4FE40A27)
GEARAspiWDM.sys             Thu May  3 15:56:17 2012 (4FA2E2E1)
[/FONT]
http://www.carrona.org/drivers/driver.php?id=intelppm.sys
http://www.carrona.org/drivers/driver.php?id=iaStor.sys
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=iaStorV.sys
http://www.carrona.org/drivers/driver.php?id=stwrt64.sys
http://www.carrona.org/drivers/driver.php?id=AtihdW76.sys
http://www.carrona.org/drivers/driver.php?id=MpFilter.sys
http://www.carrona.org/drivers/driver.php?id=atikmpag.sys
http://www.carrona.org/drivers/driver.php?id=atikmdag.sys
http://www.carrona.org/drivers/driver.php?id=usbaapl64.sys
http://www.carrona.org/drivers/driver.php?id=GEARAspiWDM.sys
