A man sits at a laptop with three monitors displaying Windows Copilot and Office Copilot interfaces.
Microsoft’s Copilot can stop delivering insights for a handful of very ordinary reasons — flaky connectivity, stale tokens, a corrupt local cache or a client that needs repair — and understanding the difference between a device-level hiccup and a tenant- or control‑plane outage changes whether you spend three minutes or three hours chasing symptoms. The tips in this guide walk through the quick fixes every user should try first, then move into power‑user and IT runbooks, diagnostics you can run as an admin, and a pragmatic risk assessment you can use to decide whether to rely on Copilot for mission‑critical workflows.
Background / Overview​
Copilot is not a single app; it is a family of AI experiences that run across multiple surfaces — Windows Copilot, the standalone Copilot app, Copilot inside Microsoft 365 apps (Word, Excel, Teams), and web access at the Copilot portal. That multi‑surface design is a strength because one surface often remains usable when another is degraded, but it also creates a long dependency chain that makes troubleshooting non‑trivial. Authentication (Azure AD / Entra), license checks, CDN/edge routing, and the model serving back ends all have to be healthy for Copilot insights to appear reliably. Early triage should therefore aim to separate local client issues from identity/licensing and global service problems.
Why this matters now: recent operational noise and short incidents have shown that Copilot can be interrupted by a control‑plane change, a surge that outpaces autoscaling, or token/conditional‑access regressions. Those events typically resolve quickly, but for teams that have embedded Copilot into daily workflows the productivity impact — and the support burden — can be high. Treating Copilot as infrastructure and having a simple runbook reduces wasted time when it fails.
Quick fixes that resolve most “Copilot insights stopped working” reports​
Start with the easy stuff. The majority of Copilot failure reports come down to connectivity, cached credentials, or a client that needs a restart. These four actions are the fastest triage steps and fix most cases in minutes.
1. Verify your internet connection (2 minutes)​
  • Check the Wi‑Fi / network icon and confirm you have a working route to the internet.
  • If you suspect packet loss or DNS problems, try a phone hotspot to rule out corporate proxy or DNS filtering.
  • If the connection is flaky, reboot your router and then your device before proceeding. This eliminates many transient edge/network path issues.
2. Reboot Copilot and your PC (2–5 minutes)​
  • Close the Copilot app or the Copilot pane and re‑open it. If you’re in a browser, close the tab and open a new private/incognito window.
  • If the problem persists, reboot the whole device. A fresh OS session clears stale sockets, transient token states and many local service problems.
3. Try a different device or account (5–10 minutes)​
  • Sign out of Copilot and Office, then sign in with the account you know has Copilot entitlement. Shared Family plans and tenant assignments can hide features from secondary accounts.
  • If possible, test the same account on another device (a laptop, phone, or another PC). If the other device works, the issue is local to the original device. If both fail, the problem is likely tenant or service scoped.
4. Repair the Copilot app or reset the client (10–20 minutes)​
  • On Windows: Settings > Apps > Installed apps > find Copilot > Advanced options > Repair. If Repair fails, choose Reset (warning: Reset will clear local app data).
  • For Office-integrated Copilot issues, use Quick Repair via Settings > Apps > Installed apps > Office > Modify, or reinstall the Copilot/Office client if necessary. Reinstalling often fixes corruption introduced by updates or partial installs.
If these steps restore service, you’re done. If not, move on to deeper checks below.
Intermediate troubleshooting (for advanced users)​
When the quick steps fail, the next focus areas are identity and session state, browser artifacts, network path issues, and local app data that may be corrupt.
Clear tokens, cookies and cached data​
  • Sign out of all Microsoft accounts in your browser(s) and Office apps. Close the browsers.
  • Clear browsing data (cookies and cached images/files) or test in an incognito window. Browser extensions (ad blockers, privacy tools) frequently block scripts or cookies Copilot relies on. Re‑enable extensions one at a time to find the offender.
Delete local Copilot caches (advanced)​
  • If Copilot still fails, some local caches can be corrupt. Make sure you are signed out of your Microsoft identity across browsers and Office. Then run Win+R and open: %localappdata%\Microsoft
  • Delete the “Identity Cache” and “OneAuth” folders, then restart the device. This forces token refresh and can resolve lingering silent‑auth failures. Be careful: only delete the folders specified, and ensure you have credentials to sign back in.
Check per‑app and privacy toggles in Office​
  • In Office apps: File > Account > Update Options > Update Now to get the latest client. Then check File > Options > Copilot (or File > Account > Account Privacy > Manage Settings) and ensure Enable Copilot and connected experiences are allowed. If the Copilot tab is missing, your Office build is likely out of date.
Test multiple Copilot surfaces​
  • Try copilot.microsoft.com (web), the Windows Copilot app, Teams/Office integrated Copilot and the mobile Copilot app. If one surface works and another doesn’t, the problem is surface‑specific (client vs. server routing). Use this to narrow the fault domain.
Network and edge causes that look like “Copilot is down”​
Not all outages are global. Many look global from a single vantage point because of edge/CDN or ISP path problems.
  • Edge / CDN failures (Cloudflare, Azure Front Door) can block healthy back ends and produce 5xx errors. These problems often show as sudden spikes in user reports from one region.
  • Corporate proxies, firewall rules, and DNS policies can block Copilot endpoints or specific cookies/tokens, creating persistent failures for managed devices. Testing via a phone hotspot helps isolate this.
If you suspect an edge/CDN path or ISP block:
  • Try a phone hotspot.
  • Use a different browser or the standalone Copilot app to exclude browser‑specific blocking.
  • Gather timestamps and HTTP error codes to pass to your ISP or Microsoft support. These artifacts accelerate diagnosis.
Admin / enterprise runbook: what IT should do next​
Enterprises need a compact escalation flow that distinguishes tenant service incidents from device issues. Below is a prioritized checklist you can put into a runbook.
  • Confirm entitlement: verify the user’s Copilot license and service plan in the Microsoft 365 admin center. Licensing gaps are surprisingly common.
  • Check Service Health and Message Center in the Microsoft 365 admin center for tenant‑scoped incidents (look for incident IDs like those Microsoft publishes). If Microsoft has posted an incident, follow the posted guidance and incident ID.
  • Collect evidence: timestamps (with timezone), screenshots, HTTP error codes, Azure AD sign‑in logs, and conditional access events. These logs are essential for Microsoft support.
  • Test cross‑surface: verify whether Copilot works from copilot.microsoft.com, Teams desktop, and Word/Excel desktop to isolate the failure domain.
  • If a subset of users are impacted, inspect conditional access policies and tenant routing; misapplied rules often produce selective failures.
  • If the issue is widespread and no tenant incident is posted, open a Microsoft support ticket with the collected artifacts and reference any local evidence you have.
Practical admin tips:
  • Keep a short internal status channel that isn’t tenant dependent (external Slack or email list) so you can coordinate even if the tenant messaging is affected.
  • Maintain a fallback: local templates, macros or manual summarization processes that teams can switch to when Copilot is degraded. This materially reduces operational risk.
Security, privacy and governance considerations​
Copilot’s convenience comes with trade‑offs. When you enable connected experiences, document analysis or connectors, content is processed in Microsoft’s cloud unless explicitly running on a Copilot+ local model. That has three immediate implications:
  • Data movement: Enabling file read or third‑party connectors increases the range of content that leaves the endpoint. In regulated environments, coordinate with compliance/Purview team before enabling connectors for wide user bases.
  • Memory and connectors: Persistent memory features and connectors expand the assistant’s context — useful for productivity, riskier for long‑term data retention and auditability. Review connector scopes periodically and revoke unused authorizations.
  • Hallucinations and verification: Copilot can produce plausible but incorrect answers. Always require human verification for high‑stakes outputs and keep an audit trail of Copilot‑driven actions.
Administrators should:
  • Pilot Copilot features with a small user cohort.
  • Turn off model personalization or training on sensitive tenants where required.
  • Use Purview/DLP controls to limit what Copilot can access.
Advanced fixes and when to delete local data​
If app repair and reset fail, deleting specific local data stores can clear stuck authentication states. Only proceed when you understand the consequences.
  • Sign out of Microsoft accounts in browsers and Office.
  • Run Win+R and open: %localappdata%\Microsoft
  • Delete “Identity Cache” and “OneAuth” folders. Reboot and sign in again. This forces full token reissuance. Use this step if you see endless sign‑in redirects or 401/403 loops that persist after cache clearing. This technique is effective but must be done carefully to avoid losing other cached app settings.
Flag unverifiable claims: if you read a forum post claiming a specific incident ID or a precise quota/credit number for Copilot usage, treat it cautiously until you verify it in the Microsoft 365 admin center or an official Microsoft notice. Pricing, quotas and plan features have changed frequently in recent product updates.
A short diagnostic checklist you can print and follow (condensed)​
  • Check internet connection and try a hotspot.
  • Reboot Copilot app and the device.
  • Sign out/in on the device and in the browser; clear cookies and cache.
  • Repair or Reset the Copilot app; use Quick Repair for Office if needed.
  • Try a different device/account to scope the problem.
  • Admins: check tenant Service Health, run Copilot Service Plan Diagnostic, collect Azure AD logs.
Critical analysis — strengths, weaknesses and operational risk​
Copilot’s strengths are clear: it reduces context switching, automates repetitive tasks, and brings multi‑modal features (text, voice, vision) into workflows. For many users, Copilot’s value proposition — fast summarization, automated table extraction, and on‑demand drafting — is real and measurable. The multi‑surface strategy is also a resilience benefit: if one surface is broken, another can fill in.
However, the weaknesses are structural:
  • Concentration risk: dependency on identity (Azure AD), the control plane and edge providers concentrates failure modes. Small control‑plane regressions or edge incidents can cascade.
  • Fragmented availability: feature presence depends on region, client build and license plan. Users often report missing Copilot UI due to version mismatch or entitlement gaps.
  • Privacy and audit: cloud processing and connector scopes expand data flows and make governance more complex. Enterprises must explicitly decide where and how Copilot is allowed to operate.
Practical risk posture: Treat Copilot as a productivity enhancement, not a hard requirement for critical automation unless you’ve built robust fallbacks and SLAs with Microsoft for enterprise deployments. For small teams or individuals, the convenience trade‑off may be acceptable; for regulated or high‑uptime operations, plan fallbacks and instrument usage carefully.
When to escalate to Microsoft support​
Escalate when:
  • You’ve verified licensing and the correct account but Copilot still fails after updates and cache clearing.
  • Multiple users across different devices/networks are impacted in the same tenant.
  • You can provide reproducible evidence (timestamps, HTTP codes, Azure AD logs, screenshots) that demonstrates the failure pattern. These artifacts cut investigation time dramatically.
Include the Copilot Service Plan Diagnostic output and tenant ID when opening a case; Microsoft frequently requests those items early in an investigation.
Final takeaways and recommended next steps​
  • Always start with connectivity, sign‑out/sign‑in, and a simple reboot. Those three steps fix most Copilot insight failures.
  • If quick fixes fail, escalate methodically: clear browser tokens, try another surface, repair or reset the app, and only then remove local identity caches.
  • For IT teams: treat Copilot as part of your operational stack. Maintain a lightweight runbook that covers tenant health checks, evidence collection, and fallback workflows. This prevents minor outages from becoming major business disruptions.
  • Consider governance: enable connected experiences and connectors only when you’ve validated compliance controls and are comfortable with cloud processing of your content.
Copilot is a powerful assistant, but like any cloud‑first feature it depends on many moving parts. A disciplined, layered troubleshooting approach — quick local fixes first, then identity and network isolation, then admin diagnostics — will get you back to stable insights faster and with fewer support tickets.
  1. Insights From Copilot Have Stopped Working Guiding Tech
