Copying Files to USB Drive or CD/DVD
Discussion in 'Windows 7 Help and Support' started by ajojoel, Jul 30, 2010.
  1. ajojoel
    ajojoel New Member
    Jul 30, 2010
    6
    0
    Whenever I attempt to copy a picture or music file to my USB drive or to a CD/DVD, I receive the following message for example: "the file IMG_1303 has properties that can't be copied to the new location. Do you wish to continue?"
    How can I remedy this problem?
  2. zvit
    zvit Honorable Member
    Nov 3, 2009
    2,455
    84
    When you copy files from a NTFS file system to a FAT or other non-NTFS file system, there may be properties contained in the file stream that can not be
    copied because the non-NTFS does not support these alternate streams (perhaps not an accurate description, but close enough).
    If the device you are copying to was formatted as NTFS, then you would not see the message about properties not being able to be copied.
    It should be okay to lose the extra properties and still have the files work just fine.
    CommonTater and (deleted member) like this.
  3. Saltgrass
    Saltgrass Excellent Member
    Oct 16, 2009
    15,157
    393
    Any chance it is related to Digital Rights Management?
  4. ajojoel
    ajojoel New Member
    Jul 30, 2010
    6
    0
    Saltgrass Said:
    When you copy files from a NTFS file system to a FAT or other non-NTFS file system, there may be properties contained in the file stream that can not be copied because the non-NTFS does not support these alternate streams (perhaps not an accurate description, but close enough).
    QUESTION: How can I tell if the file I am copying is NTFS or FAT? And, how can I tell if the device I am copying to (generally a CD/DVD/USB) is using NTFS or FAT?
    Appreciate your help - Joel
  5. zvit
    Nov 3, 2009
    2,455
    84
    It's not the file that's NTFS or FAT, it's the way the drive was configured. FAT (File Allocation Table) and NTFS (New Technology File System) are file systems. A certain way that the drive reads the files. So all you have to know is what File System your source and destination drives are. If you go to "My Computer" and select a drive, on the bottom you will see "File System" and it will tell you what it is.
    Like mentioned, it doesn't matter. You can copy files from one system to another - either way.
Share This Page
Loading...
