Welcome!
By registering with us, you'll be able to discuss, share and private message with other members of our community.
SignUp Now!
CORSAIR iCUE
Windows Forum Admin
CORSAIR iCUE software connects all your CORSAIR iCUE compatible products together in a single interface, giving you complete control over your entire setup.
Synchronized lighting across all your iCUE compatible devices brings your system to life, while powerful macro control accelerates your game. Combined with dynamic fan control and precise system, temperature and voltage monitoring, iCUE offers intelligent control with unlimited possibilities.
Download the latest version here:
Corsair has updated iCUE to Link Removed .
No patch notes yet unfortunately.
CORSAIR iCUE v3.10.125
iCUE
3.10.125 | 12/05/2018
Patch Notes for iCUE v3.10.125
  • Hardware Playback for Lighting Effects are now possible for Lighting Node Pro and Commander Pro for all supported RGB Fans, Lighting Strips, and Hydro X products. To access this feature, go to Lighting Channel 1/2 and below Lightings Library, you will see "Hardware Lighting." Selecting any effect will play over all strips and fans (and there is only a limit of one effect) for that specific channel. Hardware Lighting only works when iCUE is no longer running (lock screen, quit iCUE, system startup, etc.). Please note that LL fans are now capable of Hardware Lighting as a new feature
  • Left Click on all iCUE supported mice is now possible with the following prerequisite:
    A separate button on the mouse must first be assigned a Left Click. Once this occurs, Left Click will be enabled to be mappable to any other Action
  • Resolved an issue with firmware not displaying properly with RGB Platinum coolers
  • Opacity has been removed for Static Lighting Effect on Platinum Coolers
  • Resolved an issue with LL RGB series fans remaining at 100% speed when triggered by Vengeance RGB PRO temperature settings
  • Improved startup time for iCUE on Lenovo Y730 laptops
  • Resolved an issue with Lighting Link and HARPOON RGB
  • Corsair One blue has been added to the custom palette for Static Color
  • Resolved an issue with firmware notifications appearing even though the product is on the latest version
  • Resolved an issue with Hardware Profiles and custom lighting for K95 Platinum
  • Resolved an issue with graph indicators appearing off the charts in Graphing Tab
  • Resolved an issue with an empty Performance Tab when selecting another device
  • Resolved an issue that may cause iCUE to crash if too many delays are deleted simultaneously
  • Resolved an issue with iCUE icon flashing in the Windows Taskbar
  • Added an indicator when a DIMM module has been rotated for Vengeance RGB PRO
  • Resolved an issue with search not working properly with specific special characters
  • Pong has been resolved to work properly when fans are setup appropriately (sails right side up)
  • Resolved the issue of an old banner appearing
  • Resolved other various minor issues and bugs
I'm not sure if this is due to the update but, after setting up everything to get my new SSD working the iCUE software is refusing to work properly. I keep receiving a notification on the software saying the macros isn't working properly and that I should repair the installation which I have tried several times but it doesn't work. I set up the keybindings and profile but it doesn't respond in-game. Is there a fix for this?
EDIT: Nevermind. After installing a missing driver for my motherboard it seems to have fixed it.
Corsair has updated iCUE to v3.11.114
Patch Notes for iCUE v3.11.114
  • iCUE v3.11 will now support the following products being announced at CES 2019:
    Harpoon RGB Wireless
    CORSAIR ONE (2019 Models)
    Dominator Platinum RGB DDR4 Memory
    H100i RGB Platinum SE
    Ironclaw RGB
  • Resolved a security issue with Corsair Service (Thanks to everyone who reported this issue to us, especially Joe Doran, Emma McCall, and Brady Donovan)
  • Resolved an issue with Notifications and temperature thresholds not reverting from new changes
  • Resolved an issue with tooltips not appearing on all devices in Space and Dashboard
  • Improved how Notifications are displayed when they are active/inactive
  • Resolved an issue with Hydro Series PRO Coolers and specific lighting effects not saving properly to the device
  • Hydro Series Platinum Coolers now share lighting effects and lighting libraries (users sharing profiles between devices will no longer require the exact device to see the configured lighting effects)
  • Resolved an issue with Hardware Lighting - Arc Lighting Effect with Hydro Series Platinum Coolers
  • Resolved a rare issue with Mic Volume and Sidetone values not matching between iCUE Space and device settings
  • Resolved a rare issue with Dashboard and System Information not properly displaying
  • Resolved an issue with VOID PRO Wireless headsets triggering auto-shutdown despite audio being played
  • Glaive DPI brightness intensity can now be adjusted
  • Resolved an issue that allowed Lighting Effect - Temperature values to be equal to one another
  • Resolved an issue with K66 Keyboards and the right Win key
  • Resolved an issue with OSD with certain Corsair gaming mice
Update: There is a known issue with a certain VIA chipset and wireless products that may result in a crash when waking from sleep. The VIA 3.0 chipset in question is using driver version: 10.0.17134.1. We recommend, if possible, to switch your wireless dongle to a different USB port that isn't using this specific chipset to avoid any potential issues with device performance and iCUE.
Patch Notes for iCUE v3.12.118
  • To assist with profiles being shared across different types of devices like Commander Pro, Lighting Node Pro, and Platinum Coolers (with their respective choices of RGB fans and strips), we now will match profile parameters during import with the device that the profile originally contained. For example, if you have a Lighting Node PRO and you have LL fans (x6) in channel 1, a Commander PRO user who has LL fans but in channel 2 will now be able to properly mimic your setup despite the contrast in lighting channel setup.
  • Resolved an issue text overlap with certain languages
  • Resolved an issue with RGB series fans and single color keyboards
  • Resolved an issue with DPI and Dark Core when waking from sleep
  • Lighting Library has now been added for CORSAIR ONE/PRO 2019
  • Hydro Series PRO Coolers now share common lighting and lighting library (i.e., users with H100i PRO can share their lighting effects with H150i PRO)
  • Expanded SDK Support
  • Resolved an issue with Harpoon RGB Wireless DPI colors
  • H100i PLATINUM RGB SE image has been updated to reflect the white color
  • Resolved an issue with Notifications and RGB DRAM Lighting effects
Patch Notes for iCUE v3.13.94
  • Resolved an issue with RGB DRAM detection and configuration with newer AMD platforms and Intel X299
  • Resolved an with HX850i working properly when connected to a Commander PRO
  • Resolved an issue with Corsair Service working properly on AMD Platforms
  • Resolved an issue with horizontal scrolling missing from Space and Home Screen
  • Platinum Series RGB Coolers now have Rain available as a Hardware Lighting Effect
  • Resolved an issue with iCUE window not snapping properly
Patch Notes for iCUE v3.14.104
  • Resolved a minor issue with incorrect playback for Audio Visualizer with Dominator Platinum RGB
  • Resolved an issue with pinning and unpinning information with DRAM to the dashboard from the Timings Tab
  • Dashboard now has a revert to defaults option in Settings
  • Resolved an issue with Hardware Playback not playing properly on startup with Hydro Series Coolers
  • Hydro Series Platinum Coolers now support None for fans in Lighting Setup
  • Resolved an issue with OSD not displaying on software startup
  • Renamed "Backward" to Back" for Mice Buttons for consistency with terminology
  • All warning notifications for iCUE are now removed from iCUE System Tray icon
  • Implemented an enhancement for K83 to disable the R button. This will require a new firmware update (v3.19)
  • Surface Calibration and Hardware Profile tabs are now shown for all wireless devices (but you will still need a physical cable attached to enable these features)
  • Resolved an issue with HS60 improperly showing Lighting Effects
  • Resolved various other minor issues
Patch Notes for iCUE v3.15.101
  • Implemented a software workaround to resolve an issue related to USB timeouts on Hydro Series Platinum Coolers on certain platforms with other applications
  • Resolved an issue with profile lighting data not properly importing to Commander PRO
  • Resolved an issue with Hydro Series H100i Platinum displaying an incorrect integer in the device name
  • iCUE Sensor Logs will now show up to 0.00 for temperature. For thermistors that are incapable of this increase in value, the hundredth value will always be 0 (i.e., 47.5 C will now be 47.50 C).
  • Lighting Profiles for Vengeance RGB PRO and Dominator Platinum RGB are now compatible with each other
  • Resolved an issue with Hydro Series H100i Platinum SE not sharing profile lighting data with other Platinum Series Coolers
  • Updated OpenSSL Library
  • Resolved an issue with K66 Winlock LED not lighting up properly
  • Resolved an issue with Ironclaw Wireless and Sniper Toggle
    Resolved an issue with GLAIVE RGB PRO’s name in Device and Printers
Known Issues:
Lighting Effects - Gradient - Played from Key is currently bugged and will play across all grouped keys. We will resolve this in the next release.
Patch Notes for iCUE v3.16.56
  • Resolved an issue with Vengeance RGB LEDs not turning off properly when disabled
  • Resolved an minor issue with 1000D Lighting Channels displaying improperly
  • Resolved an issue with Vengeance RGB PRO box checkbox not displaying properly
  • Obsidian 1000D's Commander Pro now supports HydroX Lighting
  • Sleep Mode as an adjustable feature has been added to K63 Wireless in Settings
  • K63 Wireless default for LED Shutoff has been changed to 10 from 15 mins
  • Resolved an issue with Play on Pressed Key not triggering lighting properly
  • Resolved an issue with CORSAIR ONE and Lighting Library Effects
  • Resolved an issue with Type Lighting Key and Ripple not displaying properly when switched
  • Resolved other various minor bugs and issues
Known Issues:
  • Some users will experience custom fan curve data loss upon restart. We have identified the source of the issue but will need additional time to resolve. This will be complete by iCUE v3.17
  • Certain profiles may cause iCUE to crash during the import process. This is under investigation.
Patch Notes for iCUE v3.17.94
  • Resolved an issue with Lighting Effects – Arc disappearing from iCUE profiles
  • Resolved a rare issue with Commander PRO incorrectly displaying widgets with no information
  • Resolved an issue with Profile Lighting Storage not properly applying to Lighting Node PRO and Commander PRO properly when importing profiles
  • Resolved an issue with checkboxes and Vengeance RGB PRO Lighting Effects
  • Resolved an issue with System Information and Logs not properly displaying AMD Chipset information. Please note newer chipsets not supported by CPUID can be missing and will be added later when the SDK is updated
  • Resolved an issue with Performance - Custom Fan Curves being deleted after system shutdown
  • Resolved an issue where waking Ironclaw Wireless from sleep may not register the device properly in iCUE
  • Resolved an issue with K83 Wireless Navigation Control text being improperly offset during iCUE window maximization
  • CORSAIR ONE (2019) now supports Hardware Lighting Effects – this can be found under the Lighting Effects tab
  • MacOS Version Only: Removed all audio devices from iCUE temporarily while we implement a new audio driver that will be compatible with macOS Mojave in a later update
  • Resolved various other minor bugs and issues
Known Issues:
iCUE v3.21.88 Patch Notes:
  • Resolved an issue where FW updates cannot be downloaded on X570 systems
  • Resolved an issue with iCUE Service exhibiting leakage of file descriptors
  • Resolved UI issues with the graph for custom lighting effects
  • Improved how Pong is displayed for LL fans – users will now be able to select independent paddle direction
  • Resolved a rare issue with Sniper DPI toggle causing iCUE to crash
  • Resolved an issue with Virtuoso (White) not disabling the LED when microphone is active option is checked
  • Resolved an issue with Viewing only Selected Effects disabling lighting effects when layers are re-ordered
  • Resolved a graphical issue with K83 Wireless and notifications related to Media Mode and Gaming Mode
  • Resolved a graphical display with Dark Core/SE and Glaive PRO related to check box colors under DPI
  • Resolved an issue with mic sidetone not properly enabled when mic is muted in iCUE Dashboard and Space
  • Resolved a rare issue with iCUE not installing on a system with non-English localization
  • Resolved a rare issue where Corsair drivers would not install due to a hang during installation
  • Resolved an issue with iCUE freezing if user continuously switches between USB and Wireless modes
  • Resolved an issue with Vengeance RGB PRO and Dominator Platinum RGB displaying effects improperly when rotated
  • Bass Boost curve has been improved for Virtuoso/SE
Corsair has updated iCUE toLink Removed
iCUE v3.22.74 Patch Notes:
  • iCUE now supports QL RGB Series Fans, our newest edition to our family of RGB fans
  • Resolved an issue with Hydro Series Platinum Coolers not properly showing the number of fans connected
  • Resolved a rare issue with iCUE crashing while idle on certain systems
  • Lighting Node CORE will now support 6 QL Fans by default on a clean install of iCUE
  • Resolved an issue with HARPOON RGB Wireless becoming unpaired after a firmware update
  • Resolved an issue with Virtuoso/SE headsets not using the new bass boost curve when importing older profiles
  • Resolved an issue with Surface Calibration and Slipstream Wireless mice
  • Resolved an issue with French translation related to K83 Wireless Keyboards
  • Resolved an issue with polling rate on K83 Wireless Keyboards
iCUE v3.24.52 Patch Notes:
  • Added support for K95 RGB PLATINUM XT and ICUE H100i/H115i/H150i PRO XT Liquid CPU Coolers
  • iCUE now supports Elgato Stream Deck G-Key Integration with K95 RGB PLATINUM/XT keyboards. To use this feature, please ensure you have SDK Enabled in settings and using the latest version of Stream Deck (v4.5): Download and Support | elgato.com
    This allows G1-G6 keys to be assignable through Elgato’s Stream Deck software and works simultaneously with any Actions assigned in iCUE. For more information, please see our tutorial here:
  • Resolved an issue with iCUE macOS not launching the calculator as an Action
  • Resolved an issue with K66 showing lighting when it is not actually supported
  • Resolved an issue that caused Actions in the Action Library to play over ESC and F-Keys
  • Resolved an issue with Virtuoso headsets improperly displaying battery status when charging cable is rapidly plugged and unplugged with a USB cable
  • Resolved an issue firmware progress counter in iCUE space being incorrectly displayed
  • Resolved an issue with performance curve objects being incorrectly displayed
Corsair has updated iCUE to v3.25.60
iCUE v3.25.60 Patch Notes:
  • iCUE now supports Windows Spatial Sound so users can enable their own audio surround sound solutions. Please note that if Spatial Sound is enabled, iCUE EQ and Surround Sound options are disabled. For more information related to spatial sound, please visit this link: https://docs.microsoft.com/en-us/win.../spatial-sound.
  • Resolved an issue with security related to our service and drivers
  • Audio Visualizer from LS100 is now available for all RGB Fans and Strips. This is a new lighting pattern that will match the volume frequency in Windows
  • Resolved an issue with iCUE not detecting devices on B450 Chipsets
  • Profiles with Lighting Effects are now cross compatible between Platinum Series and PRO XT Hydro Coolers
Recently updated to v3,26.95 although as of yet no patch notes:
Corsair has updated iCUE to v3.27.68
iCUE v3.27.68 Patch Notes:
  • iCUE now supports fan rotation and fan reordering for all Commander PRO and Lighting Node type of devices. Users can rotate clockwise or counter-clockwise their fans and change the RGB hub order for each fan.
    To do this correctly, in lighting setup, match the fans in the user interface to match what is physically shown on your fan. Each fan has a LED color coded that lights up physically to serve as an indicator. This color reflects the order the fan is in and the current orientation.
    Example:
    If your first fan lights up here during lighting setup:
    attachment.php
    Then click on the rotation arrows and match the fan in the software interface to that specific fan:
    attachment.php
    This will notify the software to adjust for the mounting you did with the fan.
  • Hardware Playback for Keyboards and Mice have been dramatically overhauled in order to simplify the process. Hardware Profiles have been removed from iCUE. Instead, all peripherals that support onboard profiles will now list three different tabs:
    attachment.php
    a.) Hardware Actions (will be renamed Onboard Actions in v3.28)
    b.) Hardware Lighting (will be renamed Onboard Lighting in v3.28)
    c.) Onboard Profiles
    You will now be able to select what Actions and Lighting will work when you quit iCUE after you save the profile to the device. When saving the profile, please note that only Hardware Actions and Hardware Lighting layers will be saved to the device. Profiles on the device will automatically be uploaded to iCUE when the device is connected (if profiles are missing from the list).
  • Limited Software Mode is now supported on PRO XT Hydro Coolers. This option can be found in Settings. When Limited Software Mode is enabled, iCUE stops real time control of the device and all features that are modifiable will only consist of what the hardware can support (i.e., Hardware Lighting only, sensor defaults to Coolant only, etc.). The purpose of this feature is to address the need of users who want their cooler to operate in standalone mode with limited software interaction.
  • Implemented a new feature where users will be notified through Windows Notifications that a new major firmware update is available for your device.
  • Resolved an issue with iCUE not installing on macOS 10.13 (High Sierra). Please note that we will only continue to support 10.13 until 10.16 is released.
  • Resolved an issue with Play On Pressed Key for Custom Lighting Effects on Keyboards and Mice.
  • Resolved an issue with iCUE not starting up properly after the option is enabled.
  • Resolved an issue between Virtuoso/SE headsets and Lighting Link Type Lighting effect.
  • Improved the battery icon for wireless devices in Windows 10 with Light Mode.
  • Resolved an issue with K95 XT Keyboards and profile switch not working properly on press.
  • Resolved a rare issue with profiles disappearing in iCUE.
  • CPUID SDK has been updated to include new hardware information.
  • Resolved an issue with DIMM Setup not being saved properly in iCUE.
  • Resolved an issue with iCUE crashing when system resumes itself from Sleep Mode.
  • Resolved other various bugs and issues.
Corsair has updated iCUE to v3.28.70
iCUE v3.28.70 Patch Notes:
  • A notification has been added to K55 for Elgato Stream Deck G-Key integration
  • Resolved an issue with Video Lighting and LS100 during high CPU usage
  • Resolved an issue between certain games and LS100’s Video Lighting
  • Resolved some minor translation bugs
  • Renamed Hardware Lighting Effects to Hardware Lighting
  • Removed Start/Stop in Hardware Lighting effects for Mice since they are not supported
  • Resolved an issue with LS100 detecting Monitor 2 and Monitor 3 as one screen
  • Resolved an issuer with Audio Lighting not retaining changes to alternate color palette
  • Resolved an issue with switching tabs between Lighting Effects and Performance
  • Resolved an issue with Virtuoso Dongle blinking red even during normal operation
  • Resolved an issue with Static Lighting not saving to legacy RGB devices
See if SDK is checked in the settings menu. If it is, uncheck it.
If the issue continues try reinstalling the old version and see if all is ok.
CORSAIR iCUE v3.28.75
WINDOWS
3.28.75 | 05/20/2020
