Windows 7 Could do with some expert advice.
Wayward
View attachment 020311-22729-01.zip
Hi Guys/Gals
First and foremost, I must say....great forum!
Was hoping someone could release me from the hell I've been experiencing lately with random BSOD's?...they're driving me nuts!!!!
I've attached the .dmp file for your consideration.
Many, many thanks in advance!
Kind regards all.
http://windows7forums.com/blue-scre...mportant-every-thread-starter-please-see.html
Update these drivers for sure:
ASUS ATK0110 ACPI Utility
ASACPI.sys Sun Mar 27 22:30:36 2005
ZBoard Keyboard by Ideazon Corporation
Alpham164.sys Mon Jul 23 03:57:03 2007
Marvell Yukon Ethernet Controller
yk62x64.sys Mon Feb 23 10:02:27 2009
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\020311-22729-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02e58000 PsLoadedModuleList = 0xfffff800`03095e50
Debug session time: Thu Feb  3 17:19:19.023 2011 (UTC - 5:00)
System Uptime: 2 days 5:25:39.022
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 1E, {ffffffffc0000005, fffff80002ed564a, 0, ffffffffffffffff}
Probably caused by : ntkrnlmp.exe ( nt!KiDispatchException+1b9 )
Followup: MachineOwner
1: kd> !analyze -v
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff80002ed564a, The address that the exception occurred at
Arg4: ffffffffffffffff, Parameter 1 of the exception
Debugging Details:
FAULTING_IP:
nt!KeUpdateRunTime+ea
fffff800`02ed564a c3              ret
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  ffffffffffffffff
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800031000e0
 ffffffffffffffff
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
BUGCHECK_STR:  0x1E_c0000005
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
CURRENT_IRQL:  d
EXCEPTION_RECORD:  fffff88002f1b8b8 -- (.exr 0xfffff88002f1b8b8)
ExceptionAddress: fffff80002ed564a (nt!KeUpdateRunTime+0x00000000000000ea)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
TRAP_FRAME:  fffff88002f1b960 -- (.trap 0xfffff88002f1b960)
rax=1918965b3b08e200 rbx=0000000000000000 rcx=0000000000000011
rdx=000000000000f423 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002ed564a rsp=fffff88002f1baf8 rbp=fffff88002f1bb80
 r8=0000000000012292  r9=0000000000000000 r10=0000000000000e85
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei ng nz na po nc
nt!KeUpdateRunTime+0xea:
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80002f02a39 to fffff80002ec8740
STACK_TEXT:
fffff880`02f1b0e8 fffff800`02f02a39 : 00000000`0000001e ffffffff`c0000005 fffff800`02ed564a 00000000`00000000 : nt!KeBugCheckEx
fffff880`02f1b0f0 fffff800`02ec7d82 : fffff880`02f1b8b8 fffff880`009ec180 fffff880`02f1b960 fffff880`009ec180 : nt!KiDispatchException+0x1b9
fffff880`02f1b780 fffff800`02ec668a : fffff800`02ed4b25 00001f80`00000df8 fffff780`00000320 fffff880`02f1bb00 : nt!KiExceptionDispatch+0xc2
fffff880`02f1b960 fffff800`02ed564a : 1918965b`3b08e200 00000000`00000000 fffff880`02f1bb80 fffff880`009ec180 : nt!KiGeneralProtectionFault+0x10a
fffff880`02f1baf8 1918965b`3b08e200 : 00000000`00000000 fffff880`02f1bb80 fffff880`009ec180 00000000`00000001 : nt!KeUpdateRunTime+0xea
fffff880`02f1bb00 00000000`00000000 : fffff880`02f1bb80 fffff880`009ec180 00000000`00000001 00000000`00000001 : 0x1918965b`3b08e200
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`02f02a39 cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt!KiDispatchException+1b9
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4c1c44a9
FAILURE_BUCKET_ID:  X64_0x1E_c0000005_nt!KiDispatchException+1b9
Drivers:
fffff880`02c00000 fffff880`02c3e000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00f94000 fffff880`00feb000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`02c89000 fffff880`02d13000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`0407c000 fffff880`04092000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`053ee000 fffff880`053faf00   Alpham164 Alpham164.sys Mon Jul 23 03:57:03 2007 (46A45F4F)
fffff880`05200000 fffff880`05205500   Alpham264 Alpham264.sys Tue Mar 20 05:51:03 2007 (45FFAE87)
fffff880`00dde000 fffff880`00de9000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`0fe1a000 fffff880`0fe22000   ASACPI   ASACPI.sys   Sun Mar 27 22:30:36 2005 (42476C4C)
fffff880`00dab000 fffff880`00db4000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00db4000 fffff880`00dde000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`019cd000 fffff880`019d4000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`04135000 fffff880`04146000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`06000000 fffff880`0601e000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff880`0538e000 fffff880`0539e000   BthEnum  BthEnum.sys  Mon Jul 13 20:06:52 2009 (4A5BCC1C)
fffff880`0539e000 fffff880`053be000   bthpan   bthpan.sys   Mon Jul 13 20:07:00 2009 (4A5BCC24)
fffff880`052d6000 fffff880`05362000   bthport  bthport.sys  Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`052be000 fffff880`052d6000   BTHUSB   BTHUSB.sys   Mon Jul 13 20:06:52 2009 (4A5BCC1C)
fffff960`007c0000 fffff960`007e7000   cdd      cdd.dll      unavailable (00000000)
fffff880`01969000 fffff880`01993000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00cd1000 fffff880`00d91000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01903000 fffff880`01933000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c73000 fffff880`00cd1000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01112000 fffff880`01185000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`0406c000 fffff880`0407c000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`0195e000 fffff880`01967000   cpuz134_x64 cpuz134_x64.sys Fri Jul 09 07:16:58 2010 (4C37052A)
fffff880`018a3000 fffff880`018b1000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`04094000 fffff880`04117000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
fffff880`04117000 fffff880`04135000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`02de8000 fffff880`02df7000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`018ed000 fffff880`01903000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`04400000 fffff880`04422000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`02df7000 fffff880`02e00000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`01933000 fffff880`0193f000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`0193f000 fffff880`01952000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`01952000 fffff880`0195e000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`10a84000 fffff880`10b78000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`10b78000 fffff880`10bbe000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`0750c000 fffff880`07542000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`0fe0d000 fffff880`0fe1a000   fdc      fdc.sys      Mon Jul 13 20:00:54 2009 (4A5BCAB6)
fffff880`010a0000 fffff880`010b4000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`04539000 fffff880`04544000   flpydisk flpydisk.sys Mon Jul 13 20:00:54 2009 (4A5BCAB6)
fffff880`01054000 fffff880`010a0000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`013e2000 fffff880`013ec000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`018b3000 fffff880`018ed000   fvevol   fvevol.sys   Mon Jul 13 19:22:15 2009 (4A5BC1A7)
fffff880`01400000 fffff880`0144a000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff880`0fe00000 fffff880`0fe0d000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`02e0f000 fffff800`02e58000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`10bdc000 fffff880`10c00000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`04559000 fffff880`045b5000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`053cc000 fffff880`053e5000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`053e5000 fffff880`053ed080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`053be000 fffff880`053cc000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`06126000 fffff880`061ee000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`01474000 fffff880`0147d000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`0416c000 fffff880`04182000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`0446a000 fffff880`04479000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`05213000 fffff880`05221000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00ba3000 fffff800`00bad000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`0448a000 fffff880`044cd000   ks       ks.sys       Mon Jul 13 20:00:31 2009 (4A5BCA9F)
fffff880`013b7000 fffff880`013d1000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`015cf000 fffff880`015fa000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`045f2000 fffff880`045f7200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`060f9000 fffff880`0610e000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0522f000 fffff880`05252000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c1b000 fffff880`00c5f000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`05221000 fffff880`0522f000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`04479000 fffff880`04488000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`05206000 fffff880`05213000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00d91000 fffff880`00dab000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`01993000 fffff880`019c4000   MpFilter MpFilter.sys Tue Sep 14 20:19:28 2010 (4C901110)
fffff880`061ee000 fffff880`061fe000   MpNWMon  MpNWMon.sys  Tue Sep 14 20:19:30 2010 (4C901112)
fffff880`0601e000 fffff880`06036000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`06036000 fffff880`06063000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`06063000 fffff880`060b1000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`060b1000 fffff880`060d4000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`01850000 fffff880`0185b000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00ff4000 fffff880`00ffe000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`010b4000 fffff880`01112000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`02ddd000 fffff880`02de8000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01462000 fffff880`01474000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0147d000 fffff880`0156f000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`01897000 fffff880`018a3000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`011d1000 fffff880`01200000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`04544000 fffff880`04559000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`02d42000 fffff880`02d51000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02c44000 fffff880`02c89000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`0156f000 fffff880`015cf000   NETIO    NETIO.SYS    Thu Apr 08 22:43:59 2010 (4BBE946F)
fffff880`07542000 fffff880`07557000   NisDrvWFP NisDrvWFP.sys Tue Sep 14 20:20:25 2010 (4C901149)
fffff880`0185b000 fffff880`0186c000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`02dd1000 fffff880`02ddd000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02e58000 fffff800`03434000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`01214000 fffff880`013b7000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`019c4000 fffff880`019cd000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`10a82000 fffff880`10a83180   nvBridge nvBridge.kmd Fri Jan 07 20:57:22 2011 (4D27C482)
fffff880`0fe27000 fffff880`10a81d00   nvlddmkm nvlddmkm.sys Fri Jan 07 21:07:22 2011 (4D27C6DA)
fffff880`02d1c000 fffff880`02d42000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00e40000 fffff880`00e55000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00e00000 fffff880`00e33000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00ec6000 fffff880`00ecd000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00ecd000 fffff880`00edd000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`013d1000 fffff880`013e2000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`072a1000 fffff880`07347000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`045b5000 fffff880`045f2000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c5f000 fffff880`00c73000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`041d8000 fffff880`041fc000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`019e2000 fffff880`019fd000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`04424000 fffff880`04445000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`04445000 fffff880`0445f000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`02d80000 fffff880`02dd1000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`0445f000 fffff880`0446a000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`01835000 fffff880`0183e000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`0183e000 fffff880`01847000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`01847000 fffff880`01850000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01000000 fffff880`0103a000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`05362000 fffff880`0538e000   rfcomm   rfcomm.sys   Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`0610e000 fffff880`06126000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`07347000 fffff880`07352000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`0145a000 fffff880`01462000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`07476000 fffff880`0750c000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`07391000 fffff880`073f8000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`07352000 fffff880`0737f000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`04488000 fffff880`04489480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01601000 fffff880`017fe000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`0737f000 fffff880`07391000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`0188a000 fffff880`01897000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`0186c000 fffff880`0188a000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`02d6c000 fffff880`02d80000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00580000 fffff960`0058a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`04146000 fffff880`0416c000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`044cd000 fffff880`044df000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`052a3000 fffff880`052bdc00   usbaudio usbaudio.sys Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`05258000 fffff880`05275000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`045f8000 fffff880`045f9f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`10bcb000 fffff880`10bdc000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`044df000 fffff880`04539000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04182000 fffff880`041d8000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`00c00000 fffff880`00c1b000   USBSTOR  USBSTOR.SYS  Mon Jul 13 20:06:34 2009 (4A5BCC0A)
fffff880`10bbe000 fffff880`10bcb000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`05275000 fffff880`052a2100   usbvideo usbvideo.sys Mon Jul 13 20:07:00 2009 (4A5BCC24)
fffff880`00e33000 fffff880`00e40000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`019d4000 fffff880`019e2000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01800000 fffff880`01825000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`0144a000 fffff880`0145a000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
fffff880`00e55000 fffff880`00e6a000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00e6a000 fffff880`00ec6000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01185000 fffff880`011d1000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`02d51000 fffff880`02d6c000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`01825000 fffff880`01835000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00ee1000 fffff880`00f85000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f85000 fffff880`00f94000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02d13000 fffff880`02d1c000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00060000 fffff960`00370000   win32k   win32k.sys   unavailable (00000000)
fffff880`04063000 fffff880`0406c000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00feb000 fffff880`00ff4000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`060d8000 fffff880`060f9000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
fffff880`07557000 fffff880`07588000   WUDFRd   WUDFRd.sys   Mon Jul 13 20:06:06 2009 (4A5BCBEE)
fffff880`04000000 fffff880`04063000   yk62x64  yk62x64.sys  Mon Feb 23 10:02:27 2009 (49A2BA83)
Unloaded modules:
fffff880`075b7000 fffff880`075c3000   hiber_atapor
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`075c3000 fffff880`075cc000   hiber_atapi.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`075cc000 fffff880`075df000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`075b5000 fffff880`075b7000   MSPCLOCK.sys
    Checksum:  00000000
    ImageSize:  00002000
fffff880`075b3000 fffff880`075b5000   MSPQM.sys
    Checksum:  00000000
    ImageSize:  00002000
fffff880`075b0000 fffff880`075b3000   MSKSSRV.sys
    Checksum:  00000000
    ImageSize:  00003000
fffff880`07588000 fffff880`07594000   hiber_atapor
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`07594000 fffff880`0759d000   hiber_atapi.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`0759d000 fffff880`075b0000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`07400000 fffff880`07471000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
    Checksum:  00000000
    ImageSize:  0000C000
    Checksum:  00000000
    ImageSize:  00009000
    Checksum:  00000000
    ImageSize:  00013000
fffff880`07200000 fffff880`07271000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`01933000 fffff880`01941000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01941000 fffff880`0194d000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0194d000 fffff880`01956000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`01956000 fffff880`01969000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Crash Dumps:
Machine Name:
1: kd> !analyze -v
Arguments:
Debugging Details:
FAULTING_IP:
 ffffffffffffffff
CURRENT_IRQL:  d
NumberParameters: 2
STACK_TEXT:
STACK_COMMAND:  kb
FOLLOWUP_IP:
MODULE_NAME: nt
Drivers:
Unloaded modules:
    Checksum:  00000000
    ImageSize:  0000C000
    Checksum:  00000000
    ImageSize:  00009000
    Checksum:  00000000
    ImageSize:  00013000
    Checksum:  00000000
    ImageSize:  00002000
    Checksum:  00000000
    ImageSize:  00002000
    Checksum:  00000000
    ImageSize:  00003000
    Checksum:  00000000
    ImageSize:  0000C000
    Checksum:  00000000
    ImageSize:  00009000
    Checksum:  00000000
    ImageSize:  00013000
    Checksum:  00000000
    ImageSize:  00071000
    Checksum:  00000000
    ImageSize:  0000C000
    Checksum:  00000000
    ImageSize:  00009000
    Checksum:  00000000
    ImageSize:  00013000
    Checksum:  00000000
    ImageSize:  00071000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0000C000
    Checksum:  00000000
    ImageSize:  00009000
    Checksum:  00000000
    ImageSize:  00013000
Many, many thanks for your help Cybercore.
I updated all items listed but still get the BSOD's...any other ideas?
I cant explain how much your help is appreciated!!
Regards
  • 020311-22729-01.zip
No you haven't:
ASUSTeK Computer Inc.-Support-
ASUS support > Downloads for your motherboard > ATK0110 ACPI Utility.
SteelSeries – Home
Marvell: Support
Crash Dumps:
Machine Name:
1: kd> !analyze -v
Arguments:
Debugging Details:
FAULTING_IP:
 ffffffffffffffff
CURRENT_IRQL:  d
NumberParameters: 2
STACK_TEXT:
STACK_COMMAND:  kb
FOLLOWUP_IP:
MODULE_NAME: nt
Drivers:
Unloaded modules:
    Checksum:  00000000
    ImageSize:  0000C000
    Checksum:  00000000
    ImageSize:  00009000
    Checksum:  00000000
    ImageSize:  00013000
    Checksum:  00000000
    ImageSize:  00002000
    Checksum:  00000000
    ImageSize:  00002000
    Checksum:  00000000
    ImageSize:  00003000
    Checksum:  00000000
    ImageSize:  0000C000
    Checksum:  00000000
    ImageSize:  00009000
    Checksum:  00000000
    ImageSize:  00013000
    Checksum:  00000000
    ImageSize:  00071000
    Checksum:  00000000
    ImageSize:  0000C000
    Checksum:  00000000
    ImageSize:  00009000
    Checksum:  00000000
    ImageSize:  00013000
    Checksum:  00000000
    ImageSize:  00071000
    Checksum:  00000000
    ImageSize:  0000E000
    Checksum:  00000000
    ImageSize:  0000C000
    Checksum:  00000000
    ImageSize:  00009000
    Checksum:  00000000
    ImageSize:  00013000
Top Bottom
