Windows 7 Counter Strike 1.6 bug problem... HELP PLZ!
Kosmith
I have this problem that every 6\7 seconds my game gets stuck for like 1 second,
and when I play serious games this problem becomes very serious.
I have tried to change video resolution and renderer, but nothing changes.
If I open a New Game just by myself I have no problems.
This means that nor video and computer technical problems are involved in this particular problem..
I have Windows 7 Home Premium. I have a strong computer and graphic-card.
If anybody has any idea for a factor to this problem, please help!
Thank you for everybody! :o
It sounds like you are experiencing periodic freezes in your game, even though you have a powerful computer and graphics card. Since you mentioned that this issue occurs every 6-7 seconds and only happens when playing serious games, it could be related to background processes interfering with your gaming experience. Here are some steps you can take to try and resolve this issue: 1. Update Graphics Card Drivers: Ensure that your graphics card drivers are up to date. Outdated drivers can cause performance issues in games. 2. Close Background Applications: Close any unnecessary background applications running on your computer. These programs can consume system resources and cause interruptions in gameplay. 3. Check for...
It sounds like you are experiencing periodic freezes in your game, even though you have a powerful computer and graphics card. Since you mentioned that this issue occurs every 6-7 seconds and only happens when playing serious games, it could be related to background processes interfering with your gaming experience. Here are some steps you can take to try and resolve this issue: 1. Update Graphics Card Drivers: Ensure that your graphics card drivers are up to date. Outdated drivers can cause performance issues in games. 2. Close Background Applications: Close any unnecessary background applications running on your computer. These programs can consume system resources and cause interruptions in gameplay. 3. Check for Running Processes: Use Task Manager to monitor running processes during gameplay. Look for any programs consuming high CPU or memory usage that could be causing the freezes. 4. Disable Windows Updates During Gameplay: Windows Updates can sometimes run in the background and affect game performance. You can schedule updates to avoid interruptions during gaming sessions. 5. Adjust Power Settings: Make sure your power settings are optimized for performance rather than power saving. Set your power plan to High Performance to ensure your system is running at its best for gaming. 6. Check for Malware: Run a full system scan for malware and viruses. Malware can impact system performance and cause issues during gameplay. 7. Monitor System Temperatures: Use monitoring software to check the temperatures of your CPU and GPU. Overheating components can lead to performance issues. Ensure that your system is adequately cooled. 8. Verify Game Files: If you are experiencing issues with a specific game, verify the game files through the game launcher to check for any corrupted or missing files. 9. Adjust In-Game Settings: Try lowering the in-game graphics settings to see if the issue persists. Sometimes, high settings can overload the system and cause freezes. 10. Check for Windows Updates: Ensure that your Windows 7 operating system is up to date with the latest updates and patches. These updates can address performance issues and bugs. By following these steps, you may be able to identify and resolve the intermittent freezes you are experiencing in your games. If the issue persists, feel free to provide more details for further assistance.
