Windows 7 CPU run with no fan
Krypto
Fantastic Member
Location
Ohio
OK now I know what your thinking but do you think I would be ok running a CPU without the fan to flash my bios so I can put in a newer proccessor all I am doing is turning computer on bring up bios flash it then turn it off and put new proccesor in. Thanks In Advance
OK now i know what your thinking but do you think I would be ok running a cpu without the fan to flash my bios so i can put in a newer proccessor all i am oing is turning computer on bring up bios flash it then turn it off and put new proccesor in
no , consider the possibilities of a failed flash eeep :eek:
Top Bottom
