Critical ICS Vulnerabilities in Delta Electronics and Keysight Products
Critical ICS Vulnerabilities: Delta Electronics & Keysight Exposures​
In recent advisories issued by the Cybersecurity and Infrastructure Security Agency (CISA), critical vulnerabilities have been identified in two widely used industrial control system (ICS) platforms. The affected products—Delta Electronics’ CNCSoft-G2 and Keysight’s Ixia Vision Product Family—now face significant scrutiny from organizations that depend on secure, reliable control systems. While these vulnerabilities may not directly target Windows operating systems, they serve as a stark reminder that no aspect of an organization’s digital ecosystem is immune from cyber threats.
Delta Electronics CNCSoft-G2: Heap-Based Buffer Overflow​
Overview​
Delta Electronics has come under scrutiny following the discovery of a heap-based buffer overflow vulnerability in its CNCSoft-G2 human-machine interface (HMI). The vulnerability, now designated as CVE-2025-22881, affects versions V2.1.0.10 and prior. With a calculated CVSS v4 base score of 8.5, the issue presents a high risk for exploitation under certain conditions.
Technical Details​
  • Issue: The root problem lies in inadequate validation of user-supplied data during the copy process. This lack of proper boundary checks allows the creation of a fixed-length heap-based buffer overflow.
  • Impact: Exploiting this vulnerability could lead to remote code execution—a particularly dangerous consequence that can enable attackers to run malicious code within the context of the current process.
  • Attack Complexity: Although successful exploitation requires tricking a user into visiting a compromised webpage or opening a malicious file, the low level of attack complexity makes this vulnerability especially noteworthy.
Mitigation Strategies​
Delta Electronics recommends an immediate update to CNCSoft-G2 version V2.1.0.20 or later. Additionally, the following best practices are advised:
  • Exercise Caution with Untrusted Links: Instruct users to refrain from clicking on suspicious or unsolicited links.
  • Network Segmentation: Avoid exposing crucial control systems to the Internet and isolate them behind robust firewalls.
  • Secure Remote Access: When remote access is indispensable, rely on secure methods such as virtual private networks (VPNs).
These measures are part of a broader cybersecurity strategy aimed at reducing the potential attack surface and safeguarding ICS environments.
Summary: The Delta Electronics advisory underscores the dangers posed by buffer overflow vulnerabilities in ICS environments and highlights the necessity for both immediate patching and longer-term security best practices.
Keysight Ixia Vision: Multifaceted Vulnerabilities in Focus​
Overview​
Keysight’s Ixia Vision Product Family, widely deployed within the Information Technology sector, is now facing multiple vulnerabilities. These include path traversal issues and problems related to improper restriction of XML external entity references, collectively opening doors to remote code execution and related attacks. One of the most critical vulnerabilities in this case has been assigned CVE-2025-24494, with a CVSS v4 base score of 8.6.
Technical Details​
The advisory details several vulnerabilities with varying risk profiles:
  • Path Traversal Vulnerability:
  • Exploitation: Can lead to remote code execution using an administrative account. In conjunction with the file ‘Upload’ functionality, attackers might execute arbitrary scripts or binaries.
  • Affected Version: The problem affects the Ixia Vision Product Family version 6.3.13.2.
  • Remediation: An update to version 6.7.0 has been released with a subsequent update (version 6.8.0) addressing additional issues such as arbitrary file download and deletion.
  • XML External Entity (XXE) Injection:
  • Exploitation: This vulnerability allows for the arbitrary download of files by injecting external entity references maliciously.
  • Risk Compounding: While individually some of these vulnerabilities are rated at a lower score (CVSS v3.1 base scores around 4.9), when exploited in tandem they have the potential to facilitate more severe attacks.
  • Combined Impact: The integrated threat landscape includes scenarios where attackers may crash the device, execute code remotely, or trigger catastrophic buffer overflows, thereby compromising the ICS environment.
Mitigation and Recommendations​
Keysight urges users to upgrade to the latest software version immediately. Highlights of their mitigation strategy include:
  • Software Updates: Avoid using older versions of the Ixia Vision software that are known to be vulnerable.
  • Network Hardening: Limit exposure by placing critical control system devices behind firewalls and in segregated network segments.
  • Enhanced Remote Access Security: Use secure remote access methods, bearing in mind that even VPNs should be kept current and monitored for vulnerabilities.
  • Awareness Against Social Engineering: Along with technical measures, educating staff to recognize and avoid phishing attempts or other social engineering attacks is essential.
Summary: The advisory for Keysight’s Ixia Vision illuminates the dangers of multi-vector attacks on critical ICS components and emphasizes the need for rigorous patch management, proactive defense strategies, and mindful network design to ensure ongoing system integrity.
Expert Analysis: Broader Implications for Industrial and IT Environments​
A Wake-Up Call for ICS Security​
Both CISA advisories reveal a sobering reality: even specialized industrial platforms are susceptible to vulnerabilities that could have far-reaching consequences. For IT professionals—especially those managing networks that include both traditional Windows environments and ICS assets—the following points are crucial:
  • Interconnectivity Risks: As operational technology (OT) and information technology (IT) continue to converge, a vulnerability in one area can quickly cascade into another. A compromised ICS can serve as a pivot point for broader network intrusions.
  • Defense-in-Depth: These incidents underscore the need for layered security measures. It’s not enough to have just antivirus software or firewalls; organizations must deploy multi-tiered defenses (including strict access controls, continuous monitoring, and regular audits) across all systems.
  • Patch Management: Timely updates based on vendor advisories are non-negotiable. The risks associated with delayed patching are heightened by the fact that many attackers actively scour networks for these known weaknesses.
  • Risk Assessment and Impact Analysis: Organizations must routinely reassess their cybersecurity posture, especially for systems critical to infrastructure. Periodically reviewing potential attack vectors and remaining informed of the latest threats can be the difference between a secure environment and a significant breach.
Real-World Implications​
Consider an industrial facility that integrates Windows-based control centers with ICS devices. Should a vulnerability such as the ones in CNCSoft-G2 or Ixia Vision be exploited, the ramifications could be severe—from operational disruptions to potential safety incidents. The lesson here is clear: it is imperative for enterprises to undertake comprehensive risk management strategies that encompass every facet of their technology stack.
Summary: Integrating robust defense mechanisms and staying vigilant to emerging vulnerabilities will ensure that both operational and business networks remain secure against the evolving tactics of cyber adversaries.
Mitigation and Proactive Cybersecurity Strategies for Today​
Best Practices for Improving ICS Cybersecurity​
  • Timely Software Updates: Ensure that all devices and software are upgraded to the latest secure versions. Regular patching is crucial.
  • Network Segmentation: Isolate ICS devices from the broader enterprise network when possible. Use firewalls and separate network zones to minimize exposure.
  • Secured Remote Access: Enforce the use of robust VPNs and secure remote desktop protocols. Verify that remote access methods are kept current and are properly monitored.
  • User Awareness Training: Educate users to avoid unsolicited emails, untrusted links, and attachment openings that could lead to social engineering attacks.
  • Defense-in-Depth Architecture: Combine multiple security layers—from endpoint protection to rigorous access controls across your network—to ensure that no single vulnerability can be easily exploited.
A Call for Vigilance​
The recent CISA advisories serve as a timely reminder that the cybersecurity threat landscape is evolving rapidly. For organizations that manage Windows environments as well as critical ICS systems, embracing a proactive and multi-layered defense strategy is essential. Vigilance, combined with adherence to cybersecurity best practices, can significantly mitigate the risks posed by these vulnerabilities.
Final Thought: In a world where technological convergence is the norm, security is only as robust as its weakest link. By staying informed and acting swiftly on vendor and CISA recommendations, IT professionals can keep their networks—and the critical systems they support—secure from evolving threats.
Stay tuned to WindowsForum.com for further updates and expert analysis on cybersecurity issues impacting critical infrastructures and Windows environments alike.
Sources:
