Windows 7 Custom Icons For Shortcuts?
Discussion in 'Desktop Customization' started by bkelley, Feb 18, 2010.
  1. bkelley
    bkelley New Member
    May 25, 2009
    24
    0
    How can I use custom images (.PNGs or whatever) for shortcut icons?
  2. bkelley
    bkelley New Member
    May 25, 2009
    24
    0
    So, as long as they are .ico types they'll work?
  3. bkelley
    bkelley New Member
    May 25, 2009
    24
    0
    #4 bkelley, Feb 18, 2010
  4. bkelley
    bkelley New Member
    May 25, 2009
    24
    0
    Yeah, that's what it was at, but it was even smaller when I added it to the shortcut.
    What I'm trying to do is use icons from an icon pack so they are uniform in my taskbar. I got them to change after converting the files to .ICO, but for programs that don't use the pinned icons for combining windows, it makes a new icon with the default icon. If that makes any sense.
  5. fjgold
    fjgold New Member
    Jan 11, 2009
    1,111
    60
    Try Gnu Image Manipulation Program or GIMP for Windows.
    It's free open source software.
    GIMP - for Windows
    When you open a .png in Gimp you have the option in the toolbar at top of main window to scale the .png.
    image>scale image.
    After scaling image to size you want choose file>save as and and use the "select file type (by extension)" option (expand the +)
    and select Microsoft Windows Icon to change from .png to .ico.
    I use Gimp all the time, mainly for this purpose, works great.
    I have thousands of icons I've picked up over time, many of them originally in .png form, lots of them recovered from linux distros (Linux uses .png's almost exclusively for icons).
    GIMP does a great job of manipulating them.
    I keep them in a folder in the root of my C:\ partition that I've named "Win 7 icons".
    This way all my custom shortcut icons are in one place.
  6. cybercore
    cybercore New Member
    Jul 7, 2009
    15,822
    321
Share This Page
Loading...
