Chromium’s CVE-2025-12437 — a reported use‑after‑free in the PageInfo component — appears in Microsoft’s Security Update Guide because Microsoft Edge (Chromium‑based) consumes upstream Chromium code; Microsoft records the Chromium CVE in the guide to tell Edge customers the exact point at which Microsoft has ingested and shipped the upstream fix and therefore when Edge is no longer vulnerable.
Exploit CVE-2025-12437 triggers downstream ingestion of browser version data (edge://version, chrome://version).Background / Overview​
Chromium is an upstream, open‑source browser engine that supplies Blink, V8, Mojo, ANGLE and other core components used by Google Chrome and numerous downstream browsers and runtimes (Microsoft Edge, Brave, Opera, Electron apps, etc.. When a security flaw is discovered in Chromium and assigned a CVE, Google (and the Chromium project) publish an upstream fix in Chromium/Chrome. Downstream vendors then must ingest that upstream change, run their own builds and tests, and ship their vendor‑specific package. Microsoft uses the Microsoft Security Update Guide (SUG) to document those upstream CVEs when the vulnerability affects Edge and to declare when the downstream Edge build has the ingestion and is therefore no longer vulnerable.
This operational chain — upstream discovery → Chromium/Chrome patch → downstream ingestion → vendor release — explains two common administrator questions:
  • Why a Chrome/Chromium CVE shows up in Microsoft’s catalog: because Edge includes that OSS and Microsoft needs to tell Edge customers when their product is remediated.
  • How to confirm you’re protected: check your browser’s version string, then map that version to the fixed Chromium/Chrome build listed in Chrome release notes or to the Edge build/ingestion documented in Microsoft’s SUG.
What CVE-2025-12437 Means (technical context)​
Use‑after‑free explained, at a glance​
A use‑after‑free (CWE‑416) occurs when code dereferences a pointer after the memory it points to has been freed. In complex, asynchronous browser components this can lead to heap corruption, data disclosure, or — when combined with other primitives — remote code execution. Use‑after‑free bugs in UI or navigation‑adjacent components are especially concerning because they can often be reached from web content or inter‑process interactions. While public advisories sometimes withhold exploit specifics to reduce the window for weaponization, the presence of a UAF of this class should be treated as high‑priority until endpoints are patched.
PageInfo: why it matters​
PageInfo is the UI that surfaces site security and permission information (the padlock, site permissions, connection metadata) and it interacts with origin/state information. A memory‑safety issue in PageInfo could be triggered by crafted navigation or page content and may expose the renderer or UI process to memory corruption. The specific exploitation path and feasibility are time‑sensitive and often not fully disclosed initially; therefore the operational assumption should be that an unpatched browser is an exposure. Where exact exploit details are missing, treat the claim as provisionally high‑risk and remediate promptly.
Why Microsoft Documents Chromium CVEs in the Security Update Guide​
Microsoft’s Security Update Guide serves as the downstream vendor’s authoritative record for vulnerabilities that affect Microsoft‑shipped products. When Chromium assigns a CVE, Microsoft will list that CVE in SUG if the underlying code is consumed by an affected Microsoft product (most notably Microsoft Edge and WebView2). That listing does not mean Microsoft authored the bug; it signals to administrators:
  • The CVE originates upstream in Chromium/Chrome.
  • Microsoft has tracked the issue and will ingest the fix into Edge builds on a controlled cadence.
  • The SUG entry is the authoritative place to check whether Microsoft has shipped the ingestion in a given Edge channel/build.
This approach creates transparency for enterprise patching and ensures organizations do not assume immediate parity with Chrome the moment Google publishes a patch. There is typically a short ingestion/test window between Chrome shipping a fix and Edge shipping the patched build; SUG tells you when Microsoft has completed that downstream step.
How to See Your Browser Version (step‑by‑step)​
Verifying the browser version on a device is the single fastest way to determine whether an endpoint includes the upstream Chromium fix. The About/version pages also trigger an update check and are the primary device‑level confirmation.
Microsoft Edge (desktop — Windows, macOS)​
  • Open Microsoft Edge.
  • Click the three‑dot menu (Settings and more) at the top‑right.
  • Select Help and feedback → About Microsoft Edge.
  • The About page displays the full version string and will automatically check for updates; if an update is available it begins downloading and prompts you to restart to complete installation.
  • Alternate: in the address bar type edge://version to see the full product and underlying Chromium revision.
Google Chrome (desktop)​
  • Open Google Chrome.
  • Click the three‑dot menu → Help → About Google Chrome.
  • Chrome shows the exact version and will check for updates; you can also visit chrome://version for build details.
Mobile (Edge / Chrome on Android or iOS)​
  • Open the app → menu → Settings → About (or check the app store page). Mobile stores show the installed version and the latest available. The update flow on mobile goes through Play Store / App Store; use the store listing to determine whether an update is published to your channel.
How to Use the Version to Confirm the Fix​
  • From the browser’s About page, copy the full version string.
  • Check the upstream Chromium/Chrome release notes (Chrome Releases) to find the Chrome build that lists CVE‑2025‑12437 as fixed. Chrome release notes typically list CVE IDs and the fixed Chrome builds.
  • Check Microsoft’s Security Update Guide (SUG) entry for CVE‑2025‑12437 and Microsoft Edge release notes to find the Edge build (and channel) where Microsoft recorded ingestion of the Chromium fix. The SUG entry is Microsoft’s downstream confirmation and will indicate the Edge build number that removes the vulnerability.
  • If your installed Edge/Chrome version is equal to or later than the fixed build listed by the vendor, the browser is considered remediated for that CVE. If not, update and restart the browser.
Important operational note: Do not assume Edge is patched at the same moment Chrome is. Chrome may push a stable fix earlier; Microsoft must still ingest and test the upstream change before shipping a patched Edge release. Use SUG/Edge release notes to confirm the ingestion.
Enterprise Verification and Inventory (practical guidance)​
Enterprises must verify remediation across fleets rather than relying on a single device check. Recommended steps:
  • Inventory first: use your endpoint management tool (Intune, SCCM/MECM, Jamf, or third‑party patch managers) to query installed browsers and versions across your environment.
  • Prioritize: flag internet‑facing devices, kiosks, admin/privileged workstations and any systems that run embedded Chromium binaries (Electron apps, packaged kiosks) because those often do not auto‑update.
  • Map versions: compare inventory results to the Chrome fixed build and to the Edge SUG / release note ingestion build for CVE‑2025‑12437.
  • Remediate: push the patched Edge/Chrome builds using your standard deployment pipeline; accelerate rings for high‑risk groups.
If you need a quick, machine‑readable check on a Windows workstation, most administrators collect the application version metadata centrally via management tooling. For ad‑hoc checks, the browser’s About page or edge://version/chrome://version remain the fastest device‑level confirmations.
Short‑term Mitigations If You Can’t Update Immediately​
While updates are the best fix, apply compensating controls to reduce exposure:
  • Enable Enhanced Security Mode / strict site isolation features to limit the impact of renderer compromises.
  • Use web filtering / proxy allowlists to restrict access to untrusted sites for privileged users.
  • For highly sensitive roles, provide a separate hardened image or temporarily restrict browsing to a known safe set of sites.
  • Monitor EDR/telemetry for browser crashes, unusual renderer restarts, child process creation from msedge/chrome processes and anomalous network connections originating from browser processes. These are common early indicators of exploitation attempts.
Detection and Logging Recommendations​
  • Ensure browser and system telemetry are forwarded to your SIEM/EDR: renderer crashes, sandbox exits, frequent process restarts, and anomalous child process creation from browser binaries are notable signals.
  • Tune rules to capture suspicious file writes, unexpected remote shells spawned from browser‑owned processes, and unusual parent/child process relationships.
  • Keep vulnerability scanners updated (Qualys, Tenable, Nessus rules) so they flag installations below the patched Chrome/Edge baseline. Several security advisories and scanning rules map to Chrome/Chromium minimum patched builds; use those as part of your verification.
Critical Analysis — Strengths, Limitations, and Risks​
Strengths of Microsoft’s SUG approach​
  • Authoritative downstream confirmation: SUG provides the practical statement enterprises need: the Edge build numbers and channels that contain the ingestion. This is crucial for compliance and managed update workflows.
  • Centralized communication: Instead of tracking multiple upstream advisories, administrators can consult SUG as a single pane of truth for Microsoft products.
Limitations and operational risks​
  • Ingestion lag: There is inevitably a short window between Chrome shipping a fix and Edge shipping the ingested fix. During that window, Chrome users may be patched while Edge users remain exposed. Organizations should not assume parity with Chrome.
  • Embedded Chromium blind spots: Applications that bundle a specific Chromium revision (Electron apps, kiosks, custom images) often do not auto‑update with Chrome/Edge and remain vulnerable until rebuilt or repackaged. Inventory these separately.
  • Terse technical disclosures: Browser vendors frequently withhold exploit details until a majority of users are patched. That responsible‑disclosure approach reduces weaponization risk but increases the burden on defenders to act without full exploit telemetry. Treat “no public exploit yet” as provisional.
Risk posture summary for CVE‑2025‑12437​
  • Home users: moderate to high risk if running unpatched browsers in the vulnerable build range. Update immediately via the browser About page.
  • Managed enterprise fleets: high operational risk if updates are delayed by staged rollouts or frozen images. Prioritize internet‑facing systems, admin consoles and embedded Chromium instances.
Practical, Actionable Checklist (copy‑ready)​
  • Open Microsoft Edge → Settings and more → Help and feedback → About Microsoft Edge (edge://settings/help). Copy the full version string.
  • Check the Microsoft Security Update Guide (SUG) entry for CVE‑2025‑12437 to confirm the Edge build that contains the Chromium ingestion. Treat the SUG entry as the authoritative downstream confirmation.
  • If using Chrome, open chrome://settings/help or chrome://version to confirm the Chrome build listed against Chrome release notes for the CVE.
  • If your installed build is older than the fixed build(s) listed by the vendor, update and restart the browser immediately.
  • For enterprises: inventory installed browsers across the fleet, identify embedded Chromium runtimes, and accelerate deployment to high‑risk rings. Use compensating controls while rollout proceeds.
Flags, Caveats and What Can’t Be Verified Here​
  • Exact Edge build numbers that correspond to Chromium’s patch for CVE‑2025‑12437 are time‑sensitive. The Microsoft Security Update Guide entry and Edge release notes are the authoritative sources for the precise ingestion mapping; those pages should be checked live to confirm the current fixed Edge version. Any claim of a specific Edge build here would be provisional unless confirmed against the SUG entry at the time of reading.
  • Detailed exploit mechanics (trigger sequences, proof‑of‑concepts) are often withheld by vendors early in the disclosure timeline. If exploit details are absent from public advisories, that is usually an intentional risk‑mitigation measure and not evidence the bug is non‑exploitable. Treat withheld technical detail as a reason to prioritize patching rather than to wait.
Final Recommendations​
  • Prioritize updates: use the browser About pages to update individual devices, and push the patched Edge builds via your management systems for fleets. Confirm the fixed Edge build via Microsoft’s Security Update Guide before declaring remediation complete.
  • Inventory and patch embedded Chromium instances separately; these are commonly overlooked and can remain vulnerable long after desktop browsers are updated.
  • Apply compensating controls and tighten monitoring until your fleet reports the patched versions. Enhance EDR detection for browser crash patterns and anomalous child process activity.
In short: the appearance of CVE‑2025‑12437 in Microsoft’s Security Update Guide is a downstream notification that Edge consumes Chromium code — the SUG entry tells you when Microsoft has shipped the ingestion that removes the vulnerability. The fastest way to confirm whether your device is protected is to open Microsoft Edge → About (edge://settings/help) or Chrome → About (chrome://settings/help), copy the version, and compare it to the vendor’s reported fixed build; if in doubt, update now and consult SUG / Edge release notes for final confirmation.
