CVE-2025-13042: V8 Heap Corruption Fixed in Chrome 142 and Edge
A recently assigned vulnerability, CVE-2025-13042, is a high-severity flaw in Chromium’s V8 JavaScript engine described as an “inappropriate implementation” that can lead to heap corruption when a user loads specially crafted HTML; it was fixed upstream in the Chrome 142 branch, and Microsoft has recorded the CVE in its Security Update Guide to show Microsoft Edge (Chromium-based) customers whether their Edge builds have ingested the Chromium fix and are therefore no longer vulnerable.
Glowing V8 chip with CVE-2025 label and Chrome/Edge logos.Background / Overview​
Chromium is an open-source browser engine composed of multiple subsystems — Blink, V8, ANGLE, WebRTC, and others — that is embedded in Google Chrome and consumed by many downstream browsers and runtimes, including Microsoft Edge (Chromium-based) and WebView2. When Chromium developers identify and patch a vulnerability, the patch lands upstream (Chromium/Chrome) first; downstream vendors must then ingest that change, test it, and publish their own vendor-specific builds. Microsoft’s Security Update Guide (SUG) is the canonical place Microsoft uses to record CVEs that affect products it ships and to indicate the downstream status for Microsoft Edge. In practice, listing CVE-2025-13042 in the SUG tells administrators and users which Edge builds contain the ingestion of the Chromium fix and can be treated as remediated. Chromium’s terse public label “inappropriate implementation” typically signals a logic, validation, or integration error rather than a simple memory-corruption descriptor; however, in engines like V8, logic or validation mistakes can still result in memory-safety outcomes such as heap corruption, especially when combined with JIT optimizations and complex internal representations. Because V8 executes untrusted JavaScript and WebAssembly delivered by webpages, such bugs are reachable remotely and have historically been weaponized into reliable exploit chains. The practical upshot: vendors treat V8 issues with high urgency.
What CVE-2025-13042 actually is​
Technical summary (public-facing)​
  • Vulnerability ID: CVE-2025-13042
  • Component: V8 JavaScript engine (Chromium)
  • Impact summary: Inappropriate implementation in V8 could allow a remote attacker to trigger heap corruption via a crafted HTML page. The Chromium project rates the vulnerability severity as High.
Upstream remediation​
Chromium/Chrome upstream remediation for this issue landed in the Chrome 142 stable family — the publicly reported upstream threshold identifies Chrome versions prior to 142.0.7444.166 as vulnerable, with later 142.x builds including the fix. Independent vulnerabilities trackers and distribution packaging advisories reflect this upstream fixed boundary.
CVSS and operational severity​
Public trackers list a CVSS v3.1 base score of 8.8 (High) for this CVE, with an attack vector of Network, attack complexity Low, and user interaction required (for instance, loading a malicious page). That numeric score aligns with the high priority vendors place on V8 issues because they can be triggered remotely by unprivileged content. Note that CVSS scores and severity interpretations are useful for prioritization but are only one part of operational risk assessment.
Why Microsoft lists Chromium CVEs in the Security Update Guide​
Shared upstream code, distinct downstream responsibility​
Microsoft Edge is a downstream consumer of Chromium OSS. When a vulnerability is found in Chromium (for example, in V8), Google/Chromium creates the CVE and ships upstream fixes in Chrome releases. Microsoft must then ingest the upstream fixes, perform vendor-specific integration and validation, and ship an Edge release that includes the upstream correction. The Security Update Guide exists to record this downstream ingestion status: it tells administrators whether a given Microsoft product build is still vulnerable or has been remediated by Microsoft’s downstream release. In short, the SUG entry for CVE-2025-13042 is an operational signal for Edge customers — not an admission Microsoft introduced the bug.
Why this matters to enterprises​
Enterprises and compliance teams need an authoritative vendor statement describing which shipped builds are fixed. A Chrome upstream update does not instantly make all Chromium-based browsers safe. The SUG is Microsoft’s canonical record that correlates a CVE with Microsoft-shipped builds and provides the downstream remediation boundary administrators must use for patch verification and reporting workflows. This clears up ambiguity during the “ingestion lag” between an upstream fix and downstream releases.
How to verify whether your browser is vulnerable — step-by-step​
The single most reliable method is to read your browser’s full version string (including the underlying Chromium revision where available) and compare it against the patched build numbers published by Google/Chromium and Microsoft’s Security Update Guide or Edge release notes. Below are clear, platform-appropriate steps.
Microsoft Edge (desktop: Windows, macOS, Linux)​
  • Open Microsoft Edge.
  • Click the three-dot menu in the top-right corner → Help and feedback → About Microsoft Edge.
  • Or enter edge://settings/help in the address bar and press Enter. The About page shows the full Edge version string and will automatically check for updates; if an update is available it downloads and prompts you to restart.
  • For the underlying Chromium revision and extra diagnostic detail, enter edge://version in the address bar. Copy the version string exactly and compare it to the Edge build listed in Microsoft’s SUG entry for CVE-2025-13042.
Google Chrome (desktop)​
  • Open Chrome.
  • Menu → Help → About Google Chrome (or type chrome://settings/help). Chrome will display the exact build string and perform an update check.
  • For internal metadata, use chrome://version. Compare the build number to the upstream remediation threshold (Chrome 142.0.7444.166 or later for this CVE).
Mobile (Edge / Chrome on Android and iOS)​
  • Open the app → Settings → About (or check App Info in the OS). Mobile builds may not always expose the underlying Chromium revision. Use the App Store / Play Store to ensure you have the latest published app version; consult vendor release notices for mapping between mobile app versions and upstream Chromium revisions.
Embedded Chromium runtimes (Electron, WebView2, CEF)​
  • Many applications bundle Chromium and do not auto-update with the system browser. Check the application's Help → About or vendor release notes for the embedded Chromium revision. For WebView2, inspect the runtime version on the host (WebView2 has its own runtime versioning). Treat embedded runtimes as distinct patch targets in inventory and vulnerability management.
Fleet verification (enterprise)​
  • Use your endpoint management system (SCCM, Intune, WSUS, other EDR telemetry) to inventory Edge/Chrome versions across the fleet. Pull the About/version strings and compare them to the patched build numbers in Microsoft’s SUG or Chrome release notes. Automate this where possible to avoid manual errors.
Mapping version numbers: practical guidance​
Understanding how version strings map to a vulnerability is essential:
  • A Chrome/Chromium version string looks like: major.minor.build.patch (e.g., 142.0.7444.166). When a tracker states “Chrome prior to 142.0.7444.166,” that means any Chrome/Chromium build with a lower build/patch value is considered vulnerable upstream. Microsoft Edge will show its own version string (for example, Edge 142.x.yyy) but you should check the SUG entry or Edge release notes to see which Edge build explicitly lists the ingestion of the Chromium fix. Exact numeric equality is not always required: the SUG may state “Edge fixed in build X,” and if your Edge reported version is equal to or later than X, it’s considered remediated.
Exploitation status and caveats​
Public advisories commonly withhold low-level exploit details until a majority of users have installed patches to reduce the risk of rapid weaponization. Absence of a public proof-of-concept is not proof there is no private exploit. For CVE-2025-13042, public trackers indicate high severity and the upstream fix is in Chrome 142.x; as usual, treat the exploit status as provisional until trusted security researchers or vendors publish confirmed exploitation details. Prior V8 bugs have been weaponized in the wild, which is why V8 fixes receive expedited attention.
Flagged claim: any statement that the vulnerability is being actively exploited should be treated cautiously unless confirmed by multiple independent reports from vendor advisories, government agencies, or coordinated disclosure notices. If exploit reports do emerge, they will typically be published by Chromium, Google’s Chrome Releases, Microsoft, or national CERTs.
Operational recommendations — what to do now​
  • Immediate action for individual users: Update your browser now via the About page (Edge: edge://settings/help; Chrome: chrome://settings/help) and relaunch to complete the install. If your version is older than the patched threshold, update and restart.
  • Enterprise patching checklist:
  • Inventory all Chromium-based runtimes (Edge, Chrome, WebView2, Electron/CEF apps).
  • Use centralized telemetry to collect exact version strings from endpoints.
  • Compare reported versions to the patched build published in Microsoft’s SUG and Chrome release notes.
  • Prioritize patching of high-exposure endpoints (public-facing, privileged users, servers doing document rendering).
  • Apply compensating controls where immediate patching is difficult: restrict web access on high-risk clients, increase browser sandbox hardening policies, block untrusted document previews, and escalate monitoring for browser crashes or anomalous behavior.
  • For ISVs and app vendors embedding Chromium:
  • Review your build pipeline and vendor dependency manifest. If you ship a bundled Chromium or Electron runtime, coordinate with your vendor or update your bundled runtime. End-users of your application should be advised to update to a release that includes the patched runtime.
Risk analysis and critical perspective​
Strengths of the current disclosure and response model​
  • The upstream-downstream model provides transparency: Chromium assigns CVEs and publishes fixes; downstream vendors (Microsoft, Linux distros, application vendors) must signpost ingestion status. The Security Update Guide fills a real operational need for enterprise customers that depend on vendor-specific remediation records. This reduces ambiguity about which builds are safe.
  • The responsible disclosure approach — withholding deep exploitation details until patches reach a wide audience — reduces the chance of rapid, easy weaponization while allowing admins time to patch. For V8 issues, which are high-value exploitation targets, that restraint is typically prudent.
Risks, blind spots, and potential weaknesses​
  • Ingestion lag: There is a non-zero window between Chrome upstream fixes and downstream vendor releases. Enterprises must not assume an immediate parity between Chrome and Edge; the SUG entry is the authoritative record for Edge-specific status. Ingestion lag creates an operational risk window that attackers can exploit.
  • Embedded Chromium runtimes: Electron apps, custom CEF integrations, and WebView2 runtimes can remain on older Chromium versions for long periods. These runtimes are frequently overlooked in vulnerability inventories, producing blind spots. Treat bundled runtimes as separate patch targets.
  • Mobile and OEM variations: Mobile and OEM-packaged Chromiums may not show upstream Chromium revisions explicitly, complicating mapping and verification. Use vendor release notes and app-store update metadata to correlate app versions with upstream patches.
  • False sense of security from version numbers: Version comparison errors are common. When exact compliance or audit evidence is required, confirm the Edge build number Microsoft lists in SUG, or cross-check with Edge release notes and the edge://version output on a sample endpoint. Small build-number discrepancies (packaging metadata differences) can create confusion for compliance teams.
Quick reference: Commands and pages to check now​
  • Microsoft Edge About → edge://settings/help → shows full Edge version and triggers update check.
  • Microsoft Edge internal page → edge://version → shows underlying Chromium revision and command-line details.
  • Google Chrome About → chrome://settings/help → shows Chrome version and triggers update check. chrome://version → internal build metadata.
  • For WebView2: query system runtime version via vendor tooling or check installed runtimes list on the host.
Conclusion and final recommendations​
CVE-2025-13042 is a significant V8 vulnerability that was fixed upstream in the Chrome 142 family and documented in Microsoft’s Security Update Guide to indicate Edge’s downstream remediation status. The presence of the CVE in Microsoft’s SUG is a notification and verification mechanism: it tells Edge customers whether the Edge builds they run have ingested the Chromium fix and are no longer vulnerable. The fastest way to know your exposure is to check your browser’s About page or internal version pages (edge://version or chrome://version) and compare the reported version string with the patched build number supplied in the Chromium/Chrome release notes and Microsoft’s SUG. Enterprises should inventory all Chromium-based engines, prioritize patching of high-risk hosts, and treat embedded runtimes as separate remediation tasks. If immediate upgrades are infeasible, apply compensating controls and increase monitoring until the patch window closes.
For administrators and security teams, record the exact version strings from affected hosts, document the comparison against the SUG or Chrome release threshold (142.0.7444.166), and treat that record as the authoritative evidence for compliance reporting and remediation closure. Vigilance and speed remain the best defenses against browser engine vulnerabilities.
