Microsoft has recorded an Elevation of Privilege vulnerability in Visual Studio tracked as CVE‑2025‑55240, a high‑severity bug that allows an authorized local user to gain greater privileges on an affected machine — a classic privilege escalation vector that demands immediate attention from developers, build‑server operators, and enterprise IT teams.
Visual Studio is one of the most widely used integrated development environments (IDE) on Windows. A flaw that lets a local, low‑privilege account trick the IDE or its components into performing actions with elevated privileges is a serious problem because it can turn a compromised developer workstation or an abused build agent into a full‑blown foothold inside a network.
Public vulnerability trackers and vendor summaries list CVE‑2025‑55240 as an improper access control issue (CWE‑284) with a CVSS v3.1 base score of 7.3 (High) and a vector indicating a local attack path that can require user interaction. The published vector and scoring indicate high confidentiality, integrity, and availability impacts if successfully exploited.
Microsoft’s Security Update Guide is the canonical entry point for the vendor advisory and patch references; public aggregators reference the MSRC entry for this CVE. Administrators should treat the MSRC advisory as the authoritative source for which Visual Studio versions and exact builds are affected and which KBs or installer updates remediate the issue.
Caution: Some trackers can mislabel related CVEs or conflate multiple fixes released on the same update day. Always verify the exact Visual Studio version and the KB/installer revision against Microsoft’s Update Guide before deploying to production. If the MSRC product table for CVE‑2025‑55240 is incomplete or client‑rendered, administrators must use the Update Catalog or Visual Studio’s own update channel as confirmation.
Administrators must treat this as a high‑priority patching item for developer endpoints and CI/CD infrastructure. At the same time, avoid relying solely on third‑party trackers: always validate the exact affected Visual Studio versions and KB identifiers against Microsoft’s Update Guide before deploying updates at scale. If the vendor advisory omits precise build data or is client‑rendered, use the Microsoft Update Catalog and Visual Studio’s official update mechanism to ensure you install the correct revision.
Unverifiable claims flagged:
If you manage developer fleets or CI infrastructure, prioritize this update in your next maintenance window and validate deployments against the Microsoft Update Guide entries for CVE‑2025‑55240. For environments where immediate patching is challenging, implement access restrictions and monitoring to limit the window of opportunity for an attacker.
Background
Visual Studio is one of the most widely used integrated development environments (IDE) on Windows. A flaw that lets a local, low‑privilege account trick the IDE or its components into performing actions with elevated privileges is a serious problem because it can turn a compromised developer workstation or an abused build agent into a full‑blown foothold inside a network.Public vulnerability trackers and vendor summaries list CVE‑2025‑55240 as an improper access control issue (CWE‑284) with a CVSS v3.1 base score of 7.3 (High) and a vector indicating a local attack path that can require user interaction. The published vector and scoring indicate high confidentiality, integrity, and availability impacts if successfully exploited.
What the CVE actually says (concise, verifiable facts)
- The vulnerability is described as improper access control in Visual Studio that allows an authorized local attacker to elevate privileges locally.
- Public trackers list a CVSS 3.1 score of 7.3 and a vector consistent with a local attack requiring low privileges and likely some user interaction; exploitation results in high confidentiality/integrity/availability impact.
- The CVE record was first published to public trackers on October 14, 2025.
- Vendor guidance (MSRC) has been referenced by multiple trackers; the recommended remediation is to apply the vendor updates listed in the Microsoft Update/KB entries that correspond to affected Visual Studio releases.
Why this matters: risk profile and attack surface
Developer workstations and build infrastructure
Visual Studio runs on developer desktops and laptops and is often integrated into CI/CD pipelines and shared build servers. A local privilege escalation in the IDE or its related processes is particularly dangerous for these reasons:- Developer machines often run with privileged tokens for debugging, signing, or deployment tasks; an elevated Visual Studio process can abuse these tokens.
- Build agents and shared CI runners frequently run automated jobs that perform privileged actions (signing, publishing artifacts). If a local account on a build agent can escalate via Visual Studio components, an attacker could tamper with build artifacts or implant supply‑chain backdoors.
- Developers commonly open projects and third‑party templates from public sources; user interaction as a step in the attack chain means social engineering remains a viable enabler.
Typical exploit primitives
Public writeups for Visual Studio privilege escalations (other CVEs in the ecosystem) show common attack primitives that give a realistic picture of how CVE‑2025‑55240 could be abused:- Malicious project files or build scripts that execute during project load or build events.
- Unchecked file‑system operations where privileged processes follow attacker‑controlled paths or symbolic links.
- Misuse of extension loading, search path handling, or launcher behavior to load attacker‑controlled binaries into a privileged process context.
Technical analysis — what the scoring and CWE mean
CWE‑284: Improper Access Control
CWE‑284 describes scenarios where a program fails to enforce correct permissions before performing privileged actions. In a Visual Studio context this can show up as:- The IDE or helper processes performing file writes or executing programs without verifying the caller’s rights.
- Components trusting a relative path or environment variable that a lower‑privileged user can manipulate.
- Failure to confine actions that should be restricted to administrator accounts or to processes that have been explicitly elevated.
CVSS vector readout (what each part signals)
Public aggregators list the vector as something akin to AV:L/AC:L/PR:L/UI:R/S:U/C:H/I:H/A:H. Interpreting that:- AV:L — Attack Vector: Local — attacker requires local access (not remote).
- AC:L — Attack Complexity: Low — the conditions to exploit are not complex.
- PR:L — Privileges Required: Low — attacker needs only a low‑privilege account on the host.
- UI:R — User Interaction: Required — exploitation likely needs the user to take an action (open a file, load a project).
- C:H/I:H/A:H — High impacts across confidentiality, integrity and availability.
Affected products and patch status (what we can verify)
Multiple public trackers and advisory summaries indicate the flaw affects Visual Studio and that Microsoft has published updates to remediate the issue. Third‑party aggregators state that patches are available for common supported Visual Studio releases, including Visual Studio 2017, 2019 and 2022, though exact build numbers and KB packages must be confirmed against the Microsoft Update Guide. Administrators should not substitute an aggregator’s list for the vendor’s product/KB table.Caution: Some trackers can mislabel related CVEs or conflate multiple fixes released on the same update day. Always verify the exact Visual Studio version and the KB/installer revision against Microsoft’s Update Guide before deploying to production. If the MSRC product table for CVE‑2025‑55240 is incomplete or client‑rendered, administrators must use the Update Catalog or Visual Studio’s own update channel as confirmation.
Practical remediation — prioritized, actionable steps
The following is a hardened, operational checklist to remediate CVE‑2025‑55240 across small teams and large enterprises.- Inventory and identify at‑risk hosts and images.
- Enumerate developer workstations, laptops, and build servers running any Visual Studio editions.
- For containerized build images, inspect base images for Visual Studio components or .NET runtimes that may include the vulnerable codepath.
- Confirm Microsoft bulletins and match KBs.
- Use the Microsoft Security Update Guide and the Update Catalog to find the exact KB or Visual Studio installer revision that addresses CVE‑2025‑55240.
- For enterprise deployments, record the KB identifiers you will deploy via WSUS or SCCM.
- Apply vendor updates.
- Patch developer machines using Visual Studio’s update channel or Microsoft’s offline installers for air‑gapped environments.
- For build agents, schedule staged rollouts: pilot → validation → broad deployment.
- Tighten local access until patches are installed.
- Restrict who can log in or run jobs on build agents; apply the principle of least privilege.
- Block untrusted accounts from interactive logins on developer workstations where possible.
- Harden CI/CD and build environments.
- Require multi‑factor authentication for access to build triggers and artifact repositories.
- Ensure build agents run with minimal privileges; avoid running agent software as SYSTEM when not required.
- Monitor and detect likely indicators.
- Watch for unusual elevations of devenv.exe or build processes, unexpected file writes to privileged locations, or unrecognized external connections created by IDE processes.
- Establish EDR hunts for processes invoking privilege‑related APIs or loading unsigned binaries into Visual Studio process space.
- For suspected compromise — incident response.
- Isolate affected hosts, collect volatile artifacts (process lists, network sessions, loaded module lists).
- Preserve build logs and code signing events; rotate signing keys if there is any suspicion of artifact tampering.
- Rebuild compromised build agents from known‑good images and reissue any compromised credentials.
Detection and forensic guidance
Because this is a local privilege escalation with user interaction, defenders should focus on telemetry that evidences elevated operations originating after a user action:- Process lineage: track parent/child relationships where a user‑level process spawns a process that performs privileged actions.
- File system activity: unexpected writes to system directories, installers, or signing keys.
- Network activity: elevated processes making outbound connections shortly after a project load or build.
- Security event logs: UAC/consent dialogs, elevation approvals, and process integrity level changes.
Threat modeling: who gains most by exploiting this?
Attackers who benefit most from CVE‑2025‑55240 fall into two categories:- Attackers seeking to pivot within a breached organization. A local escalator on a developer machine or build host can provide the necessary privilege to access source code, keys, or other high‑value artifacts.
- Supply‑chain adversaries who aim to compromise software builds. By escalating privileges on a build agent, an attacker could inject malicious code into signed artifacts that later distribute to downstream consumers.
Strengths and weaknesses of the vendor response
Notable strengths
- Microsoft has published an advisory and (per trackers) provided updates to remediate the issue; that means an official path to resolution exists for administrators to act on. Public aggregators reference MSRC entries, and vendor updates appear to have been released contemporaneously with the CVE publication.
- The CVSS vector and the CWE classification are published, enabling defenders to prioritize and construct pragmatic mitigations across their estate.
Potential risks and limitations
- Vendor advisories sometimes intentionally withhold deep exploit details to reduce the chance of active exploitation prior to mass patching; while that is defensible, it leaves defenders to make conservative assumptions about exploitability and scope based on the high‑level data. Flag this as a reason to patch promptly rather than wait for a PoC.
- Aggregators occasionally conflate related CVEs or attribute fixes incorrectly across different Visual Studio branches. Relying solely on a third‑party aggregator for patch targeting is risky — verify against Microsoft’s Update Guide and the Visual Studio release notes.
What enterprise teams should do now — an operational checklist
- Short‑term (first 72 hours)
- Identify high‑value developer workstations and build hosts; apply available Visual Studio updates there first.
- Block interactive logons to build agents and remove unnecessary local accounts.
- Push EDR detections to catch suspicious elevation events.
- Medium‑term (1–2 weeks)
- Complete a staged update across fleet using WSUS/SCCM or equivalent; verify KB installation and reboot where required.
- Rebuild any suspicious CI agents from known‑good images; rotate credentials used in build signing/secrets stores if compromise is suspected.
- Long‑term
- Harden development workflows: restrict who can modify build definitions, introduce code review gates, and sign all build artifacts with keys stored in hardware security modules (HSMs) or vaults.
- Train developers on the risk of opening untrusted project files and unverified templates; enforce least‑privilege practices on developer workstations.
Final assessment and cautionary notes
CVE‑2025‑55240 is a high‑impact, local elevation of privilege affecting Visual Studio with a realistic attack surface in development and build environments. The public scoring and CWE classification make the risk clear: an attacker with local access and a way to cause user interaction can escalate to higher privileges and potentially manipulate code, builds, or signing operations.Administrators must treat this as a high‑priority patching item for developer endpoints and CI/CD infrastructure. At the same time, avoid relying solely on third‑party trackers: always validate the exact affected Visual Studio versions and KB identifiers against Microsoft’s Update Guide before deploying updates at scale. If the vendor advisory omits precise build data or is client‑rendered, use the Microsoft Update Catalog and Visual Studio’s official update mechanism to ensure you install the correct revision.
- Some public feeds list specific affected Visual Studio releases and patch availability; however, when exact build numbers are missing from the MSRC table or when aggregators disagree, treat those release lists as provisional until confirmed directly from Microsoft. Exercise caution before assuming coverage for non‑listed branches.
Closing takeaway
For developers and Windows administrators, the practical takeaway is straightforward: inventory, verify, patch, and monitor. Visual Studio is a trusted component in modern development workflows; a local privilege escalation like CVE‑2025‑55240 turns that trust into an attack vector unless mitigated. Apply the vendor updates listed by Microsoft, harden access to developer and CI assets, and reinforce detection around elevated IDE activity to reduce the risk of follow‑on compromise.If you manage developer fleets or CI infrastructure, prioritize this update in your next maintenance window and validate deployments against the Microsoft Update Guide entries for CVE‑2025‑55240. For environments where immediate patching is challenging, implement access restrictions and monitoring to limit the window of opportunity for an attacker.
