Cybersecurity infographic showing a SharePoint farm vulnerability, privilege escalation, and July 2026 security advisory.
CVE-2026-55052 gives an authenticated attacker a path to elevated privileges on unpatched Microsoft SharePoint Server farms, with Microsoft assigning the flaw a CVSS 3.1 score of 8.8. Fixes arrived with the July 14, 2026 security updates for SharePoint Enterprise Server 2016, SharePoint Server 2019, and SharePoint Server Subscription Edition.
Detailed in Microsoft’s Security Update Guide and recorded by the National Vulnerability Database, the vulnerability stems from missing authorization checks in Microsoft Office SharePoint. An attacker needs an existing low-privilege account, but exploitation can take place remotely, requires no user interaction, and is assessed as having low attack complexity.
Microsoft classifies the report confidence as confirmed, meaning the vendor has validated the vulnerability and its technical basis. That designation should not be confused with evidence of attacks: CISA’s initial assessment lists exploitation as “none,” and CVE-2026-55052 was not identified as an actively exploited zero-day when Microsoft published the advisory.
A SharePoint Account Is the Starting Point, Not the Prize​
The CVSS vector for CVE-2026-55052 is CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H. In practical terms, an attacker must already possess low-level privileges, but can then reach the vulnerable SharePoint component over the network without persuading another user to open a document, click a link, or approve a prompt.
Microsoft describes the weakness as missing authorization, mapped to CWE-862. This class of vulnerability occurs when an application exposes an action or resource without adequately verifying whether the authenticated user is permitted to use it. Authentication establishes who is making the request; authorization is supposed to determine what that identity may do.
That distinction makes compromised SharePoint accounts particularly relevant. Password spraying, stolen session tokens, reused credentials, malicious insiders, and accounts left active after staff or contractors depart could all provide the initial privileges required by the CVSS assessment. CVE-2026-55052 then potentially turns limited access into a much broader compromise.
Microsoft scores confidentiality, integrity, and availability impacts as high. The public advisory does not yet provide a detailed exploitation walkthrough, identify the precise SharePoint endpoint involved, or state exactly which elevated role an attacker obtains. Administrators should therefore avoid assuming that the flaw is restricted to a single site collection or a narrowly scoped permission.
CISA’s Stakeholder-Specific Vulnerability Categorization data assesses the technical impact as “total” while marking the attack as not readily automatable. That suggests exploitation may require target-specific knowledge or an authenticated foothold rather than supporting indiscriminate Internet-wide scanning. It does not make the flaw harmless inside a breached identity environment.
Three Supported SharePoint Branches Need July’s Fix​
Microsoft lists three affected on-premises SharePoint product lines. The corrected versions establish straightforward patch-verification targets:
  • SharePoint Enterprise Server 2016 installations must reach build 16.0.5561.1001 or later through the July update identified as KB5002891.
  • SharePoint Server 2019 installations must reach build 16.0.10417.20175 or later through KB5002883.
  • SharePoint Server Subscription Edition installations must reach build 16.0.19725.20434 or later through KB5002882.
The vulnerability record does not list SharePoint Online as affected. Microsoft controls deployment for the hosted service, while customers remain responsible for patching and completing the upgrade process on their own SharePoint Server farms.
Installing a SharePoint package is only part of that process. Farm administrators must deploy the applicable binaries to every SharePoint server and run the SharePoint Products Configuration Wizard or PSConfig as required to complete the upgrade. A farm in which some nodes have the July binaries while others remain on older builds should not be treated as fully remediated.
The July packages also address numerous other SharePoint and Office vulnerabilities, including remote-code-execution, information-disclosure, spoofing, and security-feature-bypass issues. CVE-2026-55052 is therefore one reason to deploy the cumulative update, not the only one.
For SharePoint Server Subscription Edition, KB5002882 reports package build 16.0.19725.20434 and replaces KB5002873. Microsoft says the update is available through Microsoft Update, the Microsoft Update Catalog, and the Download Center.
Workflow Dependencies Complicate the Maintenance Window​
The July SharePoint updates carry operational instructions that administrators should incorporate into testing rather than treating these packages as routine Windows cumulative updates. Microsoft warns Subscription Edition customers using SharePoint Workflow Manager to install KB5002799 on the farm before applying KB5002882.
Farms still using the Classic version of Workflow Manager must enable Microsoft’s documented server debug flag and reset IIS to continue using it. SharePoint Server 2016 environments running SharePoint 2013-style workflows have a similar prerequisite involving the August 2025 SharePoint Workflow Manager update.
KB5002882 also contains a nonsecurity repair for SharePoint 2010 workflows that stopped initiating after installation of the June 2026 update. That fix may remove one barrier for organizations that delayed the previous cumulative update because of workflow failures, but it also reinforces the need to test legacy workflow paths after patching.
Microsoft documents another post-PSConfig action for Subscription Edition. Administrators are instructed to set DisableActorTokenAudienceValidation to true because a defense-in-depth validation feature under development may cause a regression. Microsoft says existing actor-token validation checks remain in place, but the setting deserves explicit tracking so it does not disappear into an undocumented maintenance script.
These dependencies do not justify leaving CVE-2026-55052 exposed. They do mean that SharePoint teams should coordinate the rollout with application owners, workflow administrators, identity teams, and backup operators instead of relying on a generic server-patching ring.
Confirmed Does Not Mean Exploited​
The report-confidence language supplied with the vulnerability can be easy to misread. A “confirmed” rating means Microsoft accepts that the flaw exists and that the available technical information is credible. It does not indicate that Microsoft or CISA has observed malicious use.
As of July 15, the National Vulnerability Database was still enriching the entry and had not produced an independent NVD score. Its record carries Microsoft’s 8.8 rating, identifies CWE-862, and notes that CISA’s exploitation status is “none.” Those details may change if researchers publish proof-of-concept code or incident responders connect the flaw to real intrusions.
The lack of known exploitation offers administrators a patching window, not a reason to wait. SharePoint is commonly connected to Active Directory, document repositories, search services, workflow systems, and line-of-business applications. A privilege boundary failure in that position can amplify an account compromise even when an attacker cannot begin anonymously.
Internet-facing farms deserve the shortest practical deployment timetable, followed by internal farms reachable from user, contractor, VPN, or partner networks. Administrators should also review recent role changes, unexpected site-collection administrator assignments, suspicious permission modifications, new accounts, and unusual authenticated requests around the patch window.
CVE-2026-55052 currently requires a low-privilege foothold and is not known to be under active attack. The concrete deadline for SharePoint operators is nevertheless already here: complete the July 14 updates across every farm node, finish PSConfig, verify the fixed build number, and confirm that legacy workflows still function before considering the vulnerability closed.
  1. CVE-2026-55052 Microsoft SharePoint Elevation of Privilege Vulnerability MSRC 2026-07-14T07:00:00-07:00
