Windows 7 D-link help please DWA-142
Darenberry
Hello im in need of some help. I have windows7 ultamite 64bit.
And all my drivers were installed by windows which is really nice but the most important driver wont install. I have a D-link DWA-142 wireless addapter. When i try to install the drivers i get an error msg saying "fail to install Wireless driver. Setup will exit".
Now i know iv been told it's not compatable with windows 7 BUT i have read forums where people claim to have gotten it to work "they just wont respond" and d-link says it it wont work with vista and i had it working.
Any advice or tips would be really appreciated. I dont have 150 to buy a new one.
Thanks for your time.
Daren berry
[email protected]
And all my drivers were installed by windows which is really nice but the most important driver wont install. I have a D-link DWA-142 wireless addapter. When i try to install the drivers i get an error msg saying \"fail to install Wireless driver. Setup will exit\".
Now i know iv been told it's not compatable with windows 7 BUT i have read forums where people claim to have gotten it to work \"they just wont respond\" and d-link says it it wont work with vista and i had it working.
Daren berry
[email protected]
See this post, the guy evidently found a driver for a netgear card with the same chipset as the d-link and it worked for him. Figure it might be worth a try. http://forums.dlink.com/index.php?topic=9211.0
Solved
I had this same problem Two Win7 computers had no problem (one 32 bit and 1 64 bit AND a laptop that had no problems with it) But a third 64bit computer Utterly refused to use the DWA-142.
My solution.... Plugged it into a working computer and pulled up the driver details through the Device Manager. This info told me what SYS file in System32/Drivers directory it was using. I then copied that file to a thumb drive and copied it into the driver directory on the non-working computer.
Plugged in the DWA-142 and...SOLVED. Driver installed and ready to use!
