Daily BSOD and freezing
theduddler
So I built a system for my friend, it's similar to mine and hooked up the same way and mine is working fine.
here is his rig info:
GIGABYTE GA-870A-UD3
AMD Athlon II X4 640
CORSAIR CMPSU-550VX 550W
XFX HD-583X-ZAFV Radeon HD 5830 1GB
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
He keeps getting this the BSOD he keeps getting
and sometimes gets one with the header PAGE FAULT IN NONPAGED AREA or DATA BUS ERROR
Upon that, sometimes his computer will freeze at the Gigabyte screen, or it will freeze on the Loading Windows screen or it won't even show anything on the screen at all.
If he pulls out the videocard and puts in an old one, it works sometimes...
Also, when he plays games it's fine, but as soon as he exits the game, he will blue screen
any possible reasons this could be happening?
zigzag3143
Honorable Member
Microsoft MVP
Hi and welcome
We need the dmp file created when the crash occurred.
If you wish to have others assist you with your computer's BSOD symptoms, upload the contents of your "\Windows\Minidump" folder. The procedure:
* Copy the contents of \Windows\Minidump to another (temporary) location somewhere on your machine.
* Zip up the copy.
* Start your own thread (or add it to this one) in the appropriate section of the forum and attach the ZIP archive to your post using the "paperclip" (file attachments) button.
* Briefly describe the problem history and circumstances in the same post. Somebody will attend to your query as soon as possible.
Ken J
cybercore
here are the dumps
100210-29936-01.dmp (9.10.2010)
BugCheck A, {ce5915cbc, 2, 0, fffff80002e98e13}
Probably caused by : ntkrnlmp.exe ( nt!KiProcessExpiredTimerList+103 )
Uninstall AVG and replace it with MSE:
AVG Worldwide - Download tools
Link Removed due to 404 Error
Update:
gdrv.sys Fri Mar 13 05:22:29 2009
GIGABYTE Tools
Support & Downloads - GIGABYTE
GIGABYTE Download Center
sptd.sys Sun Oct 11 23:55:14 2009
Daemon/Alcohol/Duplex Secure
DuplexSecure
DuplexSecure - FAQ
AtiPcie.sys Tue May 05 18:00:22 2009
ATI PCIE Driver for ATI PCIE chipset
Global Provider of Innovative Graphics, Processors and Media Solutions | AMD
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [F:\a\Minidump\D M P\100210-29936-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02e1d000 PsLoadedModuleList = 0xfffff800`0305ae50
Debug session time: Sat Oct  2 22:33:21.203 2010 (GMT-5)
System Uptime: 0 days 4:24:20.966
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Followup: MachineOwner
3: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 0000000ce5915cbc, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
Arg4: fffff80002e98e13, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800030c50e0
 0000000ce5915cbc
CURRENT_IRQL:  2
FAULTING_IP:
fffff800`02e98e13 0fb6432b        movzx   eax,byte ptr [rbx+2Bh]
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xA
PROCESS_NAME:  System
TRAP_FRAME:  fffff88002ffb450 -- (.trap 0xfffff88002ffb450)
rax=0000000000000009 rbx=0000000000000000 rcx=fffffa80068999d0
rdx=0000000000000102 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002e98e13 rsp=fffff88002ffb5e0 rbp=fffffa8006ba23c0
 r8=fffff88002fd5301  r9=0000000000000002 r10=0000000000000092
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl nz na po cy
nt!KiProcessExpiredTimerList+0x103:
fffff800`02e98e13 0fb6432b        movzx   eax,byte ptr [rbx+2Bh] ds:00000000`0000002b=??
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80002e8cca9 to fffff80002e8d740
STACK_TEXT:
fffff880`02ffb308 fffff800`02e8cca9 : 00000000`0000000a 0000000c`e5915cbc 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`02ffb310 fffff800`02e8b920 : 00000000`00000004 0000000c`e5915c91 fffffa80`04845e98 00000000`0018347c : nt!KiBugCheckDispatch+0x69
fffff880`02ffb450 fffff800`02e98e13 : fffffa80`068999f0 fffffa80`03fb5210 fffffa80`03fb5210 00000000`00000102 : nt!KiPageFault+0x260
fffff880`02ffb5e0 fffff800`02e994be : 00000024`eddf768a fffff880`02ffbc58 00000000`000f8392 fffff880`02fd67c8 : nt!KiProcessExpiredTimerList+0x103
fffff880`02ffbc30 fffff800`02e98cb7 : 0000000a`de7be2c1 0000000a`000f8392 0000000a`de7be22b 00000000`00000092 : nt!KiTimerExpiration+0x1be
fffff880`02ffbcd0 fffff800`02e95eea : fffff880`02fd3180 fffff880`02fddfc0 00000000`00000000 fffffa80`046de0a0 : nt!KiRetireDpcList+0x277
fffff880`02ffbd80 00000000`00000000 : fffff880`02ffc000 fffff880`02ff6000 fffff880`02ffbd40 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  nt!KiProcessExpiredTimerList+103
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4c1c44a9
FAILURE_BUCKET_ID:  X64_0xA_nt!KiProcessExpiredTimerList+103
fffff800`00bc0000 fffff800`00bca000   kdcom    kdcom.dll    Tue Jul 14 04:31:07 2009 (4A5BDFDB)
fffff800`02e1d000 fffff800`033f9000   nt       ntkrnlmp.exe Sat Jun 19 07:16:41 2010 (4C1C44A9)
fffff800`033f9000 fffff800`03442000   hal      hal.dll      Tue Jul 14 04:27:36 2009 (4A5BDF08)
fffff880`00c00000 fffff880`00c10000   watchdog watchdog.sys Tue Jul 14 02:37:35 2009 (4A5BC53F)
fffff880`00c10000 fffff880`00c19000   rdpencdd rdpencdd.sys Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`00c1e000 fffff880`00c2b000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Tue Jul 14 04:29:09 2009 (4A5BDF65)
fffff880`00c2b000 fffff880`00c3f000   PSHED    PSHED.dll    Tue Jul 14 04:32:23 2009 (4A5BE027)
fffff880`00c3f000 fffff880`00c9d000   CLFS     CLFS.SYS     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00c9d000 fffff880`00d5d000   CI       CI.dll       Tue Jul 14 04:32:13 2009 (4A5BE01D)
fffff880`00d5d000 fffff880`00da9000   fltmgr   fltmgr.sys   Tue Jul 14 02:19:59 2009 (4A5BC11F)
fffff880`00da9000 fffff880`00dd3000   cdrom    cdrom.sys    Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00dd3000 fffff880`00df8000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 02:38:51 2009 (4A5BC58B)
fffff880`00e00000 fffff880`00e5c000   volmgrx  volmgrx.sys  unavailable (00000000)
fffff880`00e5c000 fffff880`00e7c000   jraid    jraid.sys    Wed Jan 27 10:58:17 2010 (4B600029)
fffff880`00e7c000 fffff880`00e96000   mountmgr mountmgr.sys Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00e96000 fffff880`00e9f000   atapi    atapi.sys    Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`00e9f000 fffff880`00ec9000   ataport  ataport.SYS  Tue Jul 14 02:19:52 2009 (4A5BC118)
fffff880`00ec9000 fffff880`00ed4000   amdxata  amdxata.sys  Tue May 19 20:56:59 2009 (4A12F2EB)
fffff880`00ed4000 fffff880`00edd000   RDPCDD   RDPCDD.sys   Tue Jul 14 03:16:34 2009 (4A5BCE62)
fffff880`00ede000 fffff880`00f82000   Wdf01000 Wdf01000.sys Tue Jul 14 02:22:07 2009 (4A5BC19F)
fffff880`00f82000 fffff880`00f91000   WDFLDR   WDFLDR.SYS   Tue Jul 14 02:19:54 2009 (4A5BC11A)
fffff880`00f91000 fffff880`00fc4000   pci      pci.sys      Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`00fc4000 fffff880`00fd9000   volmgr   volmgr.sys   Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`00fd9000 fffff880`00fed000   fileinfo fileinfo.sys Tue Jul 14 02:34:25 2009 (4A5BC481)
fffff880`00fed000 fffff880`00ffb000   vga      vga.sys      Tue Jul 14 02:38:47 2009 (4A5BC587)
fffff880`01000000 fffff880`01057000   ACPI     ACPI.sys     Tue Jul 14 02:19:34 2009 (4A5BC106)
fffff880`01057000 fffff880`01061000   msisadrv msisadrv.sys Tue Jul 14 02:19:26 2009 (4A5BC0FE)
fffff880`01061000 fffff880`0106e000   vdrvroot vdrvroot.sys Tue Jul 14 03:01:31 2009 (4A5BCADB)
fffff880`0106e000 fffff880`0107e000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`01082000 fffff880`011a8000   sptd     sptd.sys     Sun Oct 11 23:55:14 2009 (4AD24632)
fffff880`011a8000 fffff880`011b1000   WMILIB   WMILIB.SYS   Tue Jul 14 02:19:51 2009 (4A5BC117)
fffff880`011b1000 fffff880`011e0000   SCSIPORT SCSIPORT.SYS Tue Jul 14 03:01:04 2009 (4A5BCAC0)
fffff880`011e0000 fffff880`011f5000   partmgr  partmgr.sys  Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`011f5000 fffff880`011fc000   pciide   pciide.sys   Tue Jul 14 02:19:49 2009 (4A5BC115)
fffff880`01200000 fffff880`01230000   CLASSPNP CLASSPNP.SYS Tue Jul 14 02:19:58 2009 (4A5BC11E)
fffff880`0123a000 fffff880`013dd000   Ntfs     Ntfs.sys     Tue Jul 14 02:20:47 2009 (4A5BC14F)
fffff880`013f0000 fffff880`013f9000   Null     Null.SYS     Tue Jul 14 02:19:37 2009 (4A5BC109)
fffff880`013f9000 fffff880`01400000   Beep     Beep.SYS     Tue Jul 14 03:00:13 2009 (4A5BCA8D)
fffff880`01400000 fffff880`0143a000   fvevol   fvevol.sys   Sat Sep 26 05:34:26 2009 (4ABD7DB2)
fffff880`0143a000 fffff880`01450000   disk     disk.sys     Tue Jul 14 02:19:57 2009 (4A5BC11D)
fffff880`01450000 fffff880`01458000   AtiPcie  AtiPcie.sys  Tue May 05 18:00:22 2009 (4A005486)
fffff880`01465000 fffff880`014c3000   msrpc    msrpc.sys    Tue Jul 14 02:21:32 2009 (4A5BC17C)
fffff880`014c3000 fffff880`014dd000   ksecdd   ksecdd.sys   Tue Jul 14 02:20:54 2009 (4A5BC156)
fffff880`014dd000 fffff880`01550000   cng      cng.sys      Tue Jul 14 02:49:40 2009 (4A5BC814)
fffff880`01550000 fffff880`01561000   pcw      pcw.sys      Tue Jul 14 02:19:27 2009 (4A5BC0FF)
fffff880`01561000 fffff880`0156b000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 02:19:45 2009 (4A5BC111)
fffff880`0156b000 fffff880`015b7000   volsnap  volsnap.sys  Tue Jul 14 02:20:08 2009 (4A5BC128)
fffff880`015b7000 fffff880`015f1000   rdyboost rdyboost.sys Tue Jul 14 02:34:34 2009 (4A5BC48A)
fffff880`01600000 fffff880`0162b000   ksecpkg  ksecpkg.sys  Fri Dec 11 08:03:32 2009 (4B21E0B4)
fffff880`0162b000 fffff880`01675000   fwpkclnt fwpkclnt.sys Tue Jul 14 02:21:08 2009 (4A5BC164)
fffff880`01675000 fffff880`01685000   vmstorfl vmstorfl.sys Tue Jul 14 02:42:54 2009 (4A5BC67E)
fffff880`01687000 fffff880`01779000   ndis     ndis.sys     Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`01779000 fffff880`017d9000   NETIO    NETIO.SYS    Tue Jul 14 02:21:46 2009 (4A5BC18A)
fffff880`017d9000 fffff880`017e1000   spldr    spldr.sys    Mon May 11 19:56:27 2009 (4A0858BB)
fffff880`017e1000 fffff880`017f3000   mup      mup.sys      Tue Jul 14 02:23:45 2009 (4A5BC201)
fffff880`017f3000 fffff880`017fc000   hwpolicy hwpolicy.sys Tue Jul 14 02:19:22 2009 (4A5BC0FA)
fffff880`01803000 fffff880`01a00000   tcpip    tcpip.sys    Mon Jun 14 06:39:04 2010 (4C15A458)
fffff880`02c00000 fffff880`02c26000   pacer    pacer.sys    Tue Jul 14 03:09:41 2009 (4A5BCCC5)
fffff880`02c26000 fffff880`02c35000   netbios  netbios.sys  Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`02c35000 fffff880`02c52000   serial   serial.sys   Tue Jul 14 03:00:40 2009 (4A5BCAA8)
fffff880`02c52000 fffff880`02c6d000   wanarp   wanarp.sys   Tue Jul 14 03:10:21 2009 (4A5BCCED)
fffff880`02c6d000 fffff880`02c81000   termdd   termdd.sys   Tue Jul 14 03:16:36 2009 (4A5BCE64)
fffff880`02c87000 fffff880`02c90000   rdprefmp rdprefmp.sys Tue Jul 14 03:16:35 2009 (4A5BCE63)
fffff880`02c90000 fffff880`02c9b000   Msfs     Msfs.SYS     Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`02c9b000 fffff880`02cac000   Npfs     Npfs.SYS     Tue Jul 14 02:19:48 2009 (4A5BC114)
fffff880`02cac000 fffff880`02cca000   tdx      tdx.sys      Tue Jul 14 02:21:15 2009 (4A5BC16B)
fffff880`02cca000 fffff880`02cd7000   TDI      TDI.SYS      Tue Jul 14 02:21:18 2009 (4A5BC16E)
fffff880`02cd7000 fffff880`02d28000   avgtdia  avgtdia.sys  Fri Jun 04 00:09:57 2010 (4C081A25)
fffff880`02d28000 fffff880`02d6d000   netbt    netbt.sys    Tue Jul 14 02:21:28 2009 (4A5BC178)
fffff880`02d6d000 fffff880`02df7000   afd      afd.sys      Tue Jul 14 02:21:40 2009 (4A5BC184)
fffff880`02df7000 fffff880`02e00000   wfplwf   wfplwf.sys   Tue Jul 14 03:09:26 2009 (4A5BCCB6)
fffff880`03e00000 fffff880`03e47000   avgldx64 avgldx64.sys Fri Jun 04 00:06:48 2010 (4C081968)
fffff880`03e47000 fffff880`03e4f000   AppleCharger AppleCharger.sys Tue Apr 06 11:21:27 2010 (4BBAEF07)
fffff880`03e4f000 fffff880`03e75000   tunnel   tunnel.sys   Tue Jul 14 03:09:37 2009 (4A5BCCC1)
fffff880`03e75000 fffff880`03e8a000   amdppm   amdppm.sys   Tue Jul 14 02:19:25 2009 (4A5BC0FD)
fffff880`03e8a000 fffff880`03e93000   wmiacpi  wmiacpi.sys  Tue Jul 14 02:31:02 2009 (4A5BC3B6)
fffff880`03eb3000 fffff880`03f04000   rdbss    rdbss.sys    Tue Jul 14 02:24:09 2009 (4A5BC219)
fffff880`03f04000 fffff880`03f10000   nsiproxy nsiproxy.sys Tue Jul 14 02:21:02 2009 (4A5BC15E)
fffff880`03f10000 fffff880`03f1b000   mssmbios mssmbios.sys Tue Jul 14 02:31:10 2009 (4A5BC3BE)
fffff880`03f1b000 fffff880`03f2a000   discache discache.sys Tue Jul 14 02:37:18 2009 (4A5BC52E)
fffff880`03f2a000 fffff880`03fad000   csc      csc.sys      Tue Jul 14 02:24:26 2009 (4A5BC22A)
fffff880`03fad000 fffff880`03fcb000   dfsc     dfsc.sys     Tue Jul 14 02:23:44 2009 (4A5BC200)
fffff880`03fcb000 fffff880`03fdc000   blbdrive blbdrive.sys Tue Jul 14 02:35:59 2009 (4A5BC4DF)
fffff880`03fdc000 fffff880`03fe3080   avgmfx64 avgmfx64.sys Mon Apr 26 00:06:15 2010 (4BD4AEC7)
fffff880`04000000 fffff880`04045000   arox7igy arox7igy.SYS Wed Jul 15 00:12:55 2009 (4A5CF4D7)
fffff880`04045000 fffff880`04055000   CompositeBus CompositeBus.sys Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`04055000 fffff880`0406b000   AgileVpn AgileVpn.sys Tue Jul 14 03:10:24 2009 (4A5BCCF0)
fffff880`0406b000 fffff880`0408f000   rasl2tp  rasl2tp.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`0408f000 fffff880`0409b000   ndistapi ndistapi.sys Tue Jul 14 03:10:00 2009 (4A5BCCD8)
fffff880`0409b000 fffff880`040ca000   ndiswan  ndiswan.sys  Tue Jul 14 03:10:11 2009 (4A5BCCE3)
fffff880`040d5000 fffff880`0411f000   atikmpag atikmpag.sys Thu Aug 26 04:20:56 2010 (4C75C178)
fffff880`0411f000 fffff880`04175000   USBPORT  USBPORT.SYS  Tue Jul 14 03:06:31 2009 (4A5BCC07)
fffff880`04175000 fffff880`041cc000   Rt64win7 Rt64win7.sys Thu Mar 04 15:42:52 2010 (4B8FB8DC)
fffff880`041cc000 fffff880`041e7000   raspppoe raspppoe.sys Tue Jul 14 03:10:17 2009 (4A5BCCE9)
fffff880`04200000 fffff880`04230000   nusb3xhc nusb3xhc.sys Fri Nov 20 12:16:01 2009 (4B066C61)
fffff880`04230000 fffff880`04231f00   USBD     USBD.SYS     Tue Jul 14 03:06:23 2009 (4A5BCBFF)
fffff880`04232000 fffff880`0423f000   usbfilter usbfilter.sys Tue Dec 22 10:26:22 2009 (4B3082AE)
fffff880`0423f000 fffff880`0424c000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 15:17:04 2009 (4A1151C0)
fffff880`0424c000 fffff880`04257000   usbohci  usbohci.sys  Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`04257000 fffff880`04268000   usbehci  usbehci.sys  Tue Jul 14 03:06:30 2009 (4A5BCC06)
fffff880`04268000 fffff880`04274000   serenum  serenum.sys  Tue Jul 14 03:00:33 2009 (4A5BCAA1)
fffff880`04274000 fffff880`04291000   parport  parport.sys  Tue Jul 14 03:00:40 2009 (4A5BCAA8)
fffff880`0429a000 fffff880`0438e000   dxgkrnl  dxgkrnl.sys  Fri Oct 02 04:00:14 2009 (4AC5509E)
fffff880`0438e000 fffff880`043d4000   dxgmms1  dxgmms1.sys  Tue Jul 14 02:38:32 2009 (4A5BC578)
fffff880`043d4000 fffff880`043f8000   HDAudBus HDAudBus.sys Tue Jul 14 03:06:13 2009 (4A5BCBF5)
fffff880`04800000 fffff880`0483e000   1394ohci 1394ohci.sys Tue Jul 14 03:07:12 2009 (4A5BCC30)
fffff880`04840000 fffff880`04ffb000   atikmdag atikmdag.sys Thu Aug 26 04:47:22 2010 (4C75C7AA)
fffff880`05200000 fffff880`05222000   drmk     drmk.sys     Tue Jul 14 04:01:25 2009 (4A5BD8E5)
fffff880`05222000 fffff880`05227200   ksthunk  ksthunk.sys  Tue Jul 14 03:00:19 2009 (4A5BCA93)
fffff880`0523d000 fffff880`0525e000   raspptp  raspptp.sys  Tue Jul 14 03:10:18 2009 (4A5BCCEA)
fffff880`0525e000 fffff880`05278000   rassstp  rassstp.sys  Tue Jul 14 03:10:25 2009 (4A5BCCF1)
fffff880`05278000 fffff880`05283000   rdpbus   rdpbus.sys   Tue Jul 14 03:17:46 2009 (4A5BCEAA)
fffff880`05283000 fffff880`05292000   kbdclass kbdclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`05292000 fffff880`052a1000   mouclass mouclass.sys Tue Jul 14 02:19:50 2009 (4A5BC116)
fffff880`052a1000 fffff880`052a2480   swenum   swenum.sys   Tue Jul 14 03:00:18 2009 (4A5BCA92)
fffff880`052a3000 fffff880`052e6000   ks       ks.sys       Thu Mar 04 06:32:25 2010 (4B8F37D9)
fffff880`052e6000 fffff880`052f8000   umbus    umbus.sys    Tue Jul 14 03:06:56 2009 (4A5BCC20)
fffff880`052f8000 fffff880`0530f000   nusb3hub nusb3hub.sys Fri Nov 20 12:15:57 2009 (4B066C5D)
fffff880`0530f000 fffff880`05369000   usbhub   usbhub.sys   Tue Jul 14 03:07:09 2009 (4A5BCC2D)
fffff880`05369000 fffff880`0537e000   NDProxy  NDProxy.SYS  Tue Jul 14 03:10:05 2009 (4A5BCCDD)
fffff880`0537e000 fffff880`053b4d80   RtHDMIVX RtHDMIVX.sys Wed Jan 27 05:04:58 2010 (4B5FAD5A)
fffff880`053b5000 fffff880`053f2000   portcls  portcls.sys  Tue Jul 14 03:06:27 2009 (4A5BCC03)
fffff880`0685c000 fffff880`06aaf700   RTKVHD64 RTKVHD64.sys Wed Jul 28 13:01:36 2010 (4C500000)
fffff880`06ab0000 fffff880`06acb000   USBSTOR  USBSTOR.SYS  Tue Jul 14 03:06:34 2009 (4A5BCC0A)
fffff880`06acb000 fffff880`06ae8000   usbccgp  usbccgp.sys  Tue Jul 14 03:06:45 2009 (4A5BCC15)
fffff880`06ae8000 fffff880`06af6000   hidusb   hidusb.sys   Tue Jul 14 03:06:22 2009 (4A5BCBFE)
fffff880`06af6000 fffff880`06b0f000   HIDCLASS HIDCLASS.SYS Tue Jul 14 03:06:21 2009 (4A5BCBFD)
fffff880`06b0f000 fffff880`06b17080   HIDPARSE HIDPARSE.SYS Tue Jul 14 03:06:17 2009 (4A5BCBF9)
fffff880`06b18000 fffff880`06b25000   mouhid   mouhid.sys   Tue Jul 14 03:00:20 2009 (4A5BCA94)
fffff880`06b25000 fffff880`06b33000   kbdhid   kbdhid.sys   Tue Jul 14 03:00:20 2009 (4A5BCA94)
fffff880`06b33000 fffff880`06b3f000   Dxapi    Dxapi.sys    Tue Jul 14 02:38:28 2009 (4A5BC574)
fffff880`06b3f000 fffff880`06b4d000   crashdmp crashdmp.sys Tue Jul 14 03:01:01 2009 (4A5BCABD)
fffff880`06b4d000 fffff880`06b59000   dump_dumpata dump_dumpata.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`06b59000 fffff880`06b62000   dump_atapi dump_atapi.sys Tue Jul 14 02:19:47 2009 (4A5BC113)
fffff880`06b62000 fffff880`06b75000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 02:21:51 2009 (4A5BC18F)
fffff880`06b75000 fffff880`06b83000   monitor  monitor.sys  Tue Jul 14 02:38:52 2009 (4A5BC58C)
fffff880`06b83000 fffff880`06ba6000   luafv    luafv.sys    Tue Jul 14 02:26:13 2009 (4A5BC295)
fffff880`06ba6000 fffff880`06bc7000   WudfPf   WudfPf.sys   Tue Jul 14 03:05:37 2009 (4A5BCBD1)
fffff880`06bc7000 fffff880`06bdc000   lltdio   lltdio.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`06bdc000 fffff880`06bf4000   rspndr   rspndr.sys   Tue Jul 14 03:08:50 2009 (4A5BCC92)
fffff880`06e32000 fffff880`06efa000   HTTP     HTTP.sys     Tue Jul 14 02:22:16 2009 (4A5BC1A8)
fffff880`06efa000 fffff880`06f18000   bowser   bowser.sys   Tue Jul 14 02:23:50 2009 (4A5BC206)
fffff880`06f18000 fffff880`06f30000   mpsdrv   mpsdrv.sys   Tue Jul 14 03:08:25 2009 (4A5BCC79)
fffff880`06f30000 fffff880`06f5d000   mrxsmb   mrxsmb.sys   Sat Feb 27 09:52:19 2010 (4B88CF33)
fffff880`06f5d000 fffff880`06fab000   mrxsmb10 mrxsmb10.sys Sat Feb 27 09:52:28 2010 (4B88CF3C)
fffff880`06fab000 fffff880`06fce000   mrxsmb20 mrxsmb20.sys Sat Feb 27 09:52:26 2010 (4B88CF3A)
fffff880`07c00000 fffff880`07c68000   srv2     srv2.sys     Tue Jun 22 06:20:47 2010 (4C202C0F)
fffff880`07ceb000 fffff880`07d91000   peauth   peauth.sys   Tue Jul 14 04:01:19 2009 (4A5BD8DF)
fffff880`07d91000 fffff880`07d9c000   secdrv   secdrv.SYS   Wed Sep 13 16:18:38 2006 (4508052E)
fffff880`07d9c000 fffff880`07dc9000   srvnet   srvnet.sys   Tue Jun 22 06:20:32 2010 (4C202C00)
fffff880`07dc9000 fffff880`07ddb000   tcpipreg tcpipreg.sys Tue Jul 14 03:09:49 2009 (4A5BCCCD)
fffff880`08000000 fffff880`08071000   spsys    spsys.sys    Mon May 11 20:20:58 2009 (4A085E7A)
fffff880`080f9000 fffff880`0818f000   srv      srv.sys      Tue Jun 22 06:21:11 2010 (4C202C27)
fffff880`0818f000 fffff880`08198000   gdrv     gdrv.sys     Fri Mar 13 05:22:29 2009 (49B9D175)
fffff960`00060000 fffff960`0036f000   win32k   win32k.sys   unavailable (00000000)
fffff960`00480000 fffff960`0048a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff960`006f0000 fffff960`00717000   cdd      cdd.dll      unavailable (00000000)
Unloaded modules:
fffff880`015f1000 fffff880`015ff000   crashdmp.sys
    Checksum:  00000000
fffff880`01458000 fffff880`01464000   dump_ataport
    Checksum:  00000000
fffff880`01230000 fffff880`01239000   dump_atapi.s
    Checksum:  00000000
fffff880`013dd000 fffff880`013f0000   dump_dumpfve
    Checksum:  00000000
