Windows 7 Dbpoweramp triggers BSOD
gijoewoz
I am in desperate need of help! I have a month old Toshiba Portege that worked fine for only a couple of days. It is running on Windows 7 Home Premium 64bit.
I can trigger a BSOD by clicking the Eject button in dbpoweramp, or by setting it to automatically eject after completion. This happens every time without fail. I also have intermittent issues by manually pushing the eject button on the drive, usually it works, sometimes it doesn't open. It never crashes though.
I have taken the computer back to Best Buy and at first they said it was "infected" 4 days later it was "fixed." As soon as I brought it home I realized that the issue was not resolved at all. I took it back and they did a "clean install" but the exact problem has persisted.
I have attached some files that should help. I ran the verifier.exe and clicked "eject" to cause the BSOD but my computer did not recover normally this time. It hung for many minutes on the black start screen with the windows logo until i pulled the battery. Then it booted up just fine. However, I can't seem to be able to move the new .dmp file to a new folder and zip it up.
I have been dealing with this for over 3 weeks now and nothing is getting fixed. I hope someone can help me quickly. If I need to try something specific or include more info please let me know.
Link RemovedLink Removed
[langtitle=nl]Re: Dbpoweramp triggers BSOD[/langtitle]
[lang=nl]Hoi,
Ik had hetzelfde probleem. Erg vervelend idd. Na wat Googlen kwam ik op de volgende pagina: BSOD when Ejecting CDs - dbpoweramp
Met de volgende tekst:
"The problem is Intel RST 10.1.1008 and SATA optical drive. Rolling back to the previous version, 9.6.1014, eliminates BSOD. This computer has a SATA optical drive, on my older laptop with 32bit Win XP, IDE optical and SATA hdd, there is no conflict with RST 10.1. Also there is no conflict when using a Plextor USB drive.
My conclusion (of course I only have 2 computers to test) is the BSOD occurs with the following combination:
Intel Rapid Storage Technology Driver ver 10.1.1008
SATA optical drive
communication method:SCSI...
[lang=nl]Hoi,
SATA optical drive
communication method:SCSI passthrough
actions causing BSOD:
Option checked Prevent auto-run on all CD drives
Option checked eject after rip
click Eject icon
If I'm correct, there will be many more people having problems, as new computers come out with SATA, instead of IDE, optical drives."
Ik heb idd het probleem verholpen door de Intel RST 10.1.1008 driver te vervangen door een oudere. Hoop dat dit helpt.[/lang]
Re: [langtitle=nl]Re: Dbpoweramp triggers BSOD[/langtitle]
minidump
0: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 0000000000000000, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000008, value 0 = read operation, 1 = write operation
Arg4: 0000000000000000, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80003117100
 0000000000000000
CURRENT_IRQL:  2
FAULTING_IP:
+62672faf015bd99c
00000000`00000000 ??              ???
PROCESS_NAME:  System
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0xD1
TRAP_FRAME:  fffff80000b9c740 -- (.trap 0xfffff80000b9c740)
rax=fffff80000b9c800 rbx=0000000000000000 rcx=fffffa8004df2b58
rdx=fffff80000b9c8d8 rsi=0000000000000000 rdi=0000000000000000
rip=0000000000000000 rsp=fffff80000b9c8d0 rbp=0000000000000000
 r8=fffff80000b9c8d0  r9=0000000000000000 r10=0000000000000000
r11=0000000056040600 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei ng nz na pe nc
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff80002ee72a9 to fffff80002ee7d00
FAILED_INSTRUCTION_ADDRESS:
+62672faf015bd99c
STACK_TEXT:
fffff800`00b9c5f8 fffff800`02ee72a9 : 00000000`0000000a 00000000`00000000 00000000`00000002 00000000`00000008 : nt!KeBugCheckEx
fffff800`00b9c600 fffff800`02ee5f20 : 00000000`00000000 fffffa80`09d5d320 fffffa80`0718c760 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff800`00b9c740 00000000`00000000 : 00000000`00000200 00000000`56040600 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x260
STACK_COMMAND:  kb
FOLLOWUP_IP:
nt!KiPageFault+260
fffff800`02ee5f20 440f20c0        mov     rax,cr8
SYMBOL_STACK_INDEX:  2
SYMBOL_NAME:  nt!KiPageFault+260
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4d9fdd5b
FAILURE_BUCKET_ID:  X64_0xD1_CODE_AV_NULL_IP_nt!KiPageFault+260
Followup: MachineOwner
drivers
fffff800`00bc7000 fffff800`00bd1000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff800`02e1f000 fffff800`02e68000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff800`02e68000 fffff800`03451000   nt       ntkrnlmp.exe Sat Apr 09 05:15:23 2011 (4D9FDD5B)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`00c7c000 fffff880`00ccb000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`00ccb000 fffff880`00cdf000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`00cdf000 fffff880`00d3d000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00d3d000 fffff880`00dfd000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`00e00000 fffff880`00e15000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00e15000 fffff880`00e2f000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`00e2f000 fffff880`00e36000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00e36000 fffff880`00e46000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`00e46000 fffff880`00e5a000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`00e67000 fffff880`00f0b000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f0b000 fffff880`00f1a000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00f1a000 fffff880`00f71000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`00f71000 fffff880`00f7a000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00f7a000 fffff880`00f84000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`00f84000 fffff880`00fb7000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00fb7000 fffff880`00fc4000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`00fc4000 fffff880`00fd9000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00fd9000 fffff880`00fe2000   compbatt compbatt.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00fe2000 fffff880`00fee000   BATTC    BATTC.SYS    Tue Jul 14 00:31:01 2009 (4A5BC3B5)
fffff880`01000000 fffff880`0102a000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`0102a000 fffff880`01035000   msahci   msahci.sys   Sat Nov 20 10:33:58 2010 (4CE7A416)
fffff880`01035000 fffff880`01040000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`01040000 fffff880`0108c000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`01095000 fffff880`011e9000   iaStor   iaStor.sys   Sat Nov 06 07:44:52 2010 (4CD50774)
fffff880`011e9000 fffff880`011f2000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`01222000 fffff880`013c5000   Ntfs     Ntfs.sys     Sat Nov 20 09:20:57 2010 (4CE792F9)
fffff880`01432000 fffff880`01490000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`01490000 fffff880`014ab000   ksecdd   ksecdd.sys   Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`014ab000 fffff880`0151d000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`0151d000 fffff880`0152e000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`0152e000 fffff880`01538000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`01538000 fffff880`015ce000   klif     klif.sys     Fri Oct 01 08:28:56 2010 (4CA58DB8)
fffff880`0160b000 fffff880`016fe000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`016fe000 fffff880`0175e000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`0175e000 fffff880`01789000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`01789000 fffff880`017af000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`01800000 fffff880`01816000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`01816000 fffff880`01a1a000   tcpip    tcpip.sys    Sat Nov 20 09:25:52 2010 (4CE79420)
fffff880`01a1a000 fffff880`01a64000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff880`01a64000 fffff880`01ab0000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`01ab0000 fffff880`01ab4e00   TVALZ    TVALZ.SYS    Tue Jul 14 03:18:54 2009 (4A5BEB0E)
fffff880`01ab5000 fffff880`01b2f000   tos_sps64 tos_sps64.sys Wed Jun 24 06:31:09 2009 (4A41BA1D)
fffff880`01b2f000 fffff880`01b30f80   Thpevm   Thpevm.SYS   Mon Jun 29 09:15:37 2009 (4A487829)
fffff880`01b31000 fffff880`01b3d000   thpdrv   thpdrv.sys   Mon Jun 29 03:02:56 2009 (4A4820D0)
fffff880`01b3d000 fffff880`01b45000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`01b45000 fffff880`01b7f000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`01b7f000 fffff880`01b91000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`01b91000 fffff880`01b9c000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`01b9c000 fffff880`01bad000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`01bad000 fffff880`01bcf000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`01bcf000 fffff880`01bdc000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`01bdc000 fffff880`01bed000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`01c00000 fffff880`01c3a000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01c3a000 fffff880`01c50000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01c50000 fffff880`01c80000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`01c8e000 fffff880`023ed000   kl1      kl1.sys      Wed Jun 09 14:34:19 2010 (4C0F985B)
fffff880`023ed000 fffff880`023f6000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`023f6000 fffff880`023ff000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`03600000 fffff880`03610000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`03610000 fffff880`03619000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`03619000 fffff880`03620000   kl2      kl2.sys      Wed Jun 09 14:24:47 2010 (4C0F961F)
fffff880`03620000 fffff880`03774000   dump_iaStor dump_iaStor.sys Sat Nov 06 07:44:52 2010 (4CD50774)
fffff880`03788000 fffff880`037b2000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`037b2000 fffff880`037bb000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`037bb000 fffff880`037c2000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`037c2000 fffff880`037d0000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`037d0000 fffff880`037f5000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`037f5000 fffff880`037fe000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`04200000 fffff880`0424d000   mrxsmb10 mrxsmb10.sys Wed Feb 23 04:55:12 2011 (4D649330)
fffff880`0424d000 fffff880`04271000   mrxsmb20 mrxsmb20.sys Wed Feb 23 04:55:12 2011 (4D649330)
fffff880`04271000 fffff880`0427b000   vwifimp  vwifimp.sys  Tue Jul 14 01:07:28 2009 (4A5BCC40)
fffff880`0428d000 fffff880`04356000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`04356000 fffff880`04374000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff880`04374000 fffff880`0438c000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`0438c000 fffff880`043b9000   mrxsmb   mrxsmb.sys   Wed Feb 23 04:56:22 2011 (4D649376)
fffff880`04800000 fffff880`04851000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`04851000 fffff880`0485d000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff880`0485d000 fffff880`04868000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`04868000 fffff880`04877000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`04877000 fffff880`04895000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`0489b000 fffff880`04924000   afd      afd.sys      Sat Nov 20 09:23:27 2010 (4CE7938F)
fffff880`04924000 fffff880`04969000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`04969000 fffff880`04972000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`04972000 fffff880`04998000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`04998000 fffff880`049ae000   vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`049ae000 fffff880`049b7000   klim6    klim6.sys    Thu Apr 22 16:07:24 2010 (4BD0662C)
fffff880`049b7000 fffff880`049c6000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`049c6000 fffff880`049e1000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`049e1000 fffff880`049f5000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff880`04a00000 fffff880`04a46000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`04a46000 fffff880`04a57000   HECIx64  HECIx64.sys  Wed Oct 20 00:33:43 2010 (4CBE2AD7)
fffff880`04a57000 fffff880`04aad000   e1c62x64 e1c62x64.sys Thu May 05 01:19:01 2011 (4DC1ECF5)
fffff880`04aad000 fffff880`04abe000   usbehci  usbehci.sys  Sat Nov 20 10:43:54 2010 (4CE7A66A)
fffff880`04ad9000 fffff880`04bcd000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`04e00000 fffff880`04e37000   bpenum   bpenum.sys   Sun May 16 15:28:26 2010 (4BF0010A)
fffff880`04e5c000 fffff880`04eb2000   USBPORT  USBPORT.SYS  Sat Nov 20 10:44:00 2010 (4CE7A670)
fffff880`04eb2000 fffff880`04ed6000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`04ed6000 fffff880`04ef4000   risdxc64 risdxc64.sys Fri Apr 22 10:03:44 2011 (4DB14470)
fffff880`04ef4000 fffff880`04f23000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`04f23000 fffff880`04f3e000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`04f3e000 fffff880`04f5f000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`04f5f000 fffff880`04f79000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`04f79000 fffff880`04fbc000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`04fbc000 fffff880`04fcc000   WDKMD    WDKMD.sys    Thu Dec 23 10:28:18 2010 (4D132442)
fffff880`05000000 fffff880`05098000   srv      srv.sys      Wed Feb 23 04:56:21 2011 (4D649375)
fffff880`0509b000 fffff880`05141000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`05141000 fffff880`0514c000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`0514c000 fffff880`0517d000   srvnet   srvnet.sys   Wed Feb 23 04:55:44 2011 (4D649350)
fffff880`0517d000 fffff880`0518f000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`0518f000 fffff880`051f9000   srv2     srv2.sys     Wed Feb 23 04:56:00 2011 (4D649360)
fffff880`0522e000 fffff880`05ddfce0   igdkmd64 igdkmd64.sys Tue Apr 05 04:10:07 2011 (4D9A880F)
fffff880`06000000 fffff880`0601e000   i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0602b000 fffff880`067ad000   NETwNs64 NETwNs64.sys Wed Jul 14 12:42:54 2010 (4C3DA2BE)
fffff880`067ad000 fffff880`067ba000   vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`067ba000 fffff880`067eb000   nusb3xhc nusb3xhc.sys Fri Nov 19 01:34:25 2010 (4CE5D421)
fffff880`067eb000 fffff880`067ecf00   USBD     USBD.SYS     Tue Jul 14 01:06:23 2009 (4A5BCBFF)
fffff880`067ed000 fffff880`067fc000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`06a00000 fffff880`06a12000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`06a13000 fffff880`06b70000   SynTP    SynTP.sys    Fri Dec 17 02:20:50 2010 (4D0AC902)
fffff880`06b70000 fffff880`06b7a000   klmouflt klmouflt.sys Mon Nov 02 16:26:06 2009 (4AEF081E)
fffff880`06b7a000 fffff880`06b89000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`06b89000 fffff880`06b93000   tdcmdpst tdcmdpst.sys Thu Jul 30 09:39:35 2009 (4A715C47)
fffff880`06b93000 fffff880`06b9a000   TVALZFL  TVALZFL.sys  Fri Jun 19 11:05:44 2009 (4A3B62F8)
fffff880`06b9a000 fffff880`06b9e500   CmBatt   CmBatt.sys   Tue Jul 14 00:31:03 2009 (4A5BC3B7)
fffff880`06b9f000 fffff880`06baf000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`06baf000 fffff880`06bc5000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`06bc5000 fffff880`06be9000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`06be9000 fffff880`06bf5000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`06bf5000 fffff880`06bf6480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`07000000 fffff880`07053000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`07053000 fffff880`07066000   ndisuio  ndisuio.sys  Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`07066000 fffff880`0707e000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`070e1000 fffff880`0713b000   usbhub   usbhub.sys   Sat Nov 20 10:44:30 2010 (4CE7A68E)
fffff880`0713b000 fffff880`07154000   nusb3hub nusb3hub.sys Fri Nov 19 01:34:24 2010 (4CE5D420)
fffff880`07154000 fffff880`07169000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`07169000 fffff880`0719b000   bpmp     bpmp.sys     Sun May 16 15:28:36 2010 (4BF00114)
fffff880`0719b000 fffff880`071b8000   cdfs     cdfs.sys     Tue Jul 14 00:19:46 2009 (4A5BC112)
fffff880`071b8000 fffff880`071c6000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`071c6000 fffff880`071d9000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`071d9000 fffff880`071ee000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`08400000 fffff880`0841d000   usbccgp  usbccgp.sys  Sat Nov 20 10:44:03 2010 (4CE7A673)
fffff880`0841d000 fffff880`0844a280   usbvideo usbvideo.sys Sat Nov 20 10:44:34 2010 (4CE7A692)
fffff880`0844b000 fffff880`08451e80   pgeffect pgeffect.sys Mon Jun 22 10:00:11 2009 (4A3F481B)
fffff880`08452000 fffff880`0846c000   bpusb    bpusb.sys    Sun May 16 15:28:29 2010 (4BF0010D)
fffff880`0846c000 fffff880`0848f000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`08496000 fffff880`08721c00   RTKVHD64 RTKVHD64.sys Fri Dec 10 10:09:09 2010 (4D01FC45)
fffff880`08722000 fffff880`0875f000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`0875f000 fffff880`08781000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`08781000 fffff880`08786200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`08787000 fffff880`087da000   IntcDAud IntcDAud.sys Fri Oct 15 09:28:17 2010 (4CB810A1)
fffff880`087da000 fffff880`087e6000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`0b502000 fffff880`0b510000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff960`00010000 fffff960`00322000   win32k   win32k.sys   unavailable (00000000)
fffff960`00590000 fffff960`0059a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff960`00790000 fffff960`007b7000   cdd      cdd.dll      unavailable (00000000)
Unloaded modules:
fffff880`0b491000 fffff880`0b502000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`087e6000 fffff880`087f4000   monitor.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01c80000 fffff880`01c8e000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`03621000 fffff880`03775000   dump_iaStor.
    Checksum:  00000000
    ImageSize:  00154000
fffff880`03775000 fffff880`03788000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
