Death Stranding 2 PC Arrives March 19 2026 with Cross Vendor Upscalers and Pico
Death Stranding 2 arrives on PC with a clear roadmap for performance and features: a March 19, 2026 launch, four hardware presets that target 1080p, 1440p and 4K at set frame targets, full support for the latest vendor upscalers plus an in‑engine option called Pico, ultrawide and portable presets, and a mandatory 150 GB SSD install. The headline: the port from Nixxes and Kojima Productions is deliberately accessible on the lower end while offering modern frame‑generation and upscaling tools for high‑end rigs — but there are important caveats and a few oddities you’ll want to know before you pre‑purchase.
A dark beach scene with a handheld console and a glowing display of resolutions and a 150GB SSD sign.Background / Overview​
Death Stranding 2: On the Beach launched first on PlayStation 5 and will come to Windows on March 19, 2026, with Nixxes Software responsible for the PC port. The port promises more than just a straight build — Nixxes has added PC‑specific options like uncapped framerates, a Portable preset for handheld PCs, ultrawide film and gameplay support, and compatibility with multiple upscaling and frame‑generation technologies.
Kojima’s sequel is built on the Decima engine, which already powers visually ambitious titles on both consoles and PC. That engine pedigree explains why the port targets a wide performance spectrum: from modest hardware able to produce 1080p/30 with compromises, up to flagship silicon capable of 4K/60 with the “Very High” preset. The official hardware guidance also pairs each preset with explicit GPU and CPU examples, plus a single RAM and storage baseline: 16 GB of system RAM and a 150 GB SSD are listed for all tiers.
What the official PC system requirements say​
The porting team published four configuration targets presented as presets — Minimum (Low), Medium, High (Recommended) and Very High — mapped to typical resolutions and average performance goals. These are the profiles Nixxes/Kojima recommend for different playstyles and hardware classes.
Official performance targets and hardware examples (summary):
  • Minimum (Low) — average target: 1080p @ 30 FPS
  • GPU: NVIDIA GeForce GTX 1660 or AMD Radeon RX 5500 XT (8 GB)
  • CPU: Intel Core i3‑10100 or AMD Ryzen 3 3100
  • RAM: 16 GB
  • Storage: 150 GB SSD
  • Medium (Medium) — average target: 1080p @ 60 FPS
  • GPU: NVIDIA GeForce RTX 3060 (12 GB) or AMD Radeon RX 6600
  • CPU: Intel Core i5‑11400 or AMD Ryzen 5 5600
  • RAM: 16 GB
  • High (Recommended) — average target: 1440p @ 60 FPS
  • GPU: NVIDIA GeForce RTX 3070 or AMD Radeon RX 6800
  • CPU: Intel Core i7‑11700 or AMD Ryzen 7 5700X
  • RAM: 16 GB
  • Very High — average target: 4K @ 60 FPS
  • GPU: NVIDIA GeForce RTX 4080 or AMD Radeon listing from the publisher (see note)
  • RAM: 16 GB
These official presets also note support for multiple upscaling/frame‑generation techs (NVIDIA DLSS 4, AMD FSR 4, Intel XeSS 2) and an engine-native upscaler known as Pico (Progressive Image Compositor), the latter developed by Guerrilla for the Decima engine and appearing on PC for the first time with this port.
Plain language: what these numbers mean for you​
  • If you have an entry‑level GPU from the GTX 16/early RX 5000 era, you can expect playable performance at modest settings (1080p/30) but will likely rely on the game’s upscalers or dynamic resolution to move the needle.
  • Mainstream 30–60 fps experiences at 1080p/1440p should be achievable on midrange RTX 3060 / RX 6600 / RTX 3070 / RX 6800 hardware, especially if you enable upscalers or frame generation.
  • The Very High target for native 4K/60 is aimed at flagship cards; the publisher’s example includes an NVIDIA RTX 4080 and a corresponding high‑end AMD part listed in the official table (this naming is discussed below).
Upscalers, Frame Generation, and Pico — what’s actually in the box​
One of the most consequential aspects of the PC announcement is the multi‑vendor support for both upscaling and frame generation. The port launches with:
  • NVIDIA DLSS 4 (with frame generation options)
  • AMD FSR 4 (upscaling + frame generation on supported modes)
  • Intel XeSS 2 (reconstruction upscaling with frame generation where available)
  • Pico, Guerrilla’s Progressive Image Compositor, available on PC for the first time
Why that matters: frame generation (often marketed as FrameGen / FrameBoost etc.) produces interpolated frames between rendered frames to increase effective frame rate. When paired with an advanced upscaler, you can target higher refresh rates or better image quality with a lighter GPU load than rendering everything natively. Because Death Stranding 2 offers all three major vendor technologies plus Pico, the port avoids locking players to a single vendor stack — you can choose the combination that best suits your GPU and visual preferences.
Pico — an in‑engine wildcard​
Pico is the Decima engine’s own upscaler, developed by Guerrilla. It’s described as a Progressive Image Compositor and has been used in console builds; the PC port brings Pico as a cross‑GPU option. This is notable because:
  • Pico is engine‑tuned; that can yield excellent image fidelity at certain resolution budgets.
  • It’s vendor‑agnostic and can be used on older cards that lack hardware tensor/XMX resources.
  • Nixxes has stated it can be combined with vendor frame‑generation tech, offering interesting cross‑vendor combos (for example, Pico as the renderer + DLSS/FSR frame generation).
Treat Pico as an extra tool in the toolbox rather than a direct DLSS/FSR replacement — real comparisons from technical outlets will determine where it sits in the quality/performance hierarchy.
Ultrawide, cutscenes, and the Portable preset​
The PC launch pays particular attention to display and use cases beyond the standard desktop:
  • Ultrawide support: Cutscenes are authored for 21:9, and gameplay extends to 32:9. Players on 16:9 monitors can also emulate widescreen aspect ratios through settings.
  • Portable preset: The team added a dedicated Portable preset aimed at handheld Windows devices (for example, Steam Deck and ASUS ROG Ally). Expect lower texture and effect budgets plus tuned frame targets to keep thermals and power consumption sane.
  • Controller features: Full mouse & keyboard support plus DualSense integration are included; as with other ports, advanced haptics or adaptive trigger behaviours may require a wired connection.
These additions reflect modern PC port expectations: ultrawide fidelity and handheld friendliness are no longer fringe features, and Nixxes has signalled explicit support for both.
Storage, memory, and OS: the non‑GPU bottlenecks​
Across all presets the PC guidance lists 16 GB of RAM and a 150 GB SSD as the baseline. Several practical points follow:
  • 150 GB SSD requirement is significant. That size suggests high‑resolution texture sets, additional shader/mesh data for PC, or simply a conservative allocation for streaming buffers and caches. If you’re tight on space, plan for a 250–500 GB free block rather than trying to squeeze the install onto a crowded drive.
  • 16 GB RAM minimum is reasonable for a modern AAA title, but players who multitask (streaming, web browsers, voice apps) or mod the game will want to consider 32 GB for headroom.
  • OS: Windows 10/11 (Version 1909 or newer) is listed as compatible. Ensure you’re on a supported and updated OS to take advantage of driver toolchains and optional platform features.
Storage performance matters: a fast NVMe SSD will minimize texture streaming stutters and loading hiccups, and is recommended over older SATA drives wherever possible.
Performance expectations and recommended strategies​
The official presets provide a useful baseline, but real‑world performance depends on multiple variables: driver maturity, whether you run with frame generation, upscaler choice, background apps, and whether you target native or upscaled resolutions.
Practical tuning advice:
  • Start with the preset that most closely matches your hardware, then:
  • If you’re under target, enable a quality upscaler (DLSS 4 / FSR 4 / XeSS 2) and set frame generation to a conservative multiplier.
  • If you want ultimate image fidelity, run the High/Very High preset with native rendering and accept lower frame targets or try Pico plus native AA.
  • Use dynamic resolution scaling where available to maintain framerate stability in dense scenes.
  • Keep GPU drivers and Windows updates current at launch — vendors often ship game‑specific optimizations in their first post‑launch drivers.
  • If you play ultrawide or super‑ultrawide, test FOV and HUD scaling — some games require HUD adjustments to avoid UI clipping.
Because the port ships with multiple upscalers, expect an initial wave of comparative testing from independent technical teams. Those reviews will clarify recommended paths per GPU class.
The AMD naming oddity and verification note​
The official publisher table lists an AMD GPU for the Very High tier using a name that does not match AMD’s current public naming conventions. This appears in the vendor table as an unusual model string; multiple outlets replicated the same listing because it was present in the original publisher materials. Two important points:
  • The publisher’s table is the primary source of truth for the presets; if it lists a specific AMD part name, that is the official guidance at the time of publication.
  • However, that AMD name is inconsistent with AMD’s existing product families and may be a typographical or editorial error. Several reputable outlets echoed the same string verbatim, but third‑party reporting cannot resolve whether the label is a mistake or a placeholder for an upcoming/untagged AMD SKU.
Recommendation: treat the AMD entry for the Very High tier with caution. If you’re planning a new GPU purchase to target 4K/60 with maximum fidelity, use the NVIDIA RTX 4080 example as a clearer reference point, or target an AMD RX 7900‑class card until AMD’s naming is clarified. Expect the publisher or AMD to issue clarification ahead of or shortly after launch.
Ray tracing — absent (for now) and what that implies​
Notably, neither the publisher guidance nor the main PlayStation blog entry lists ray tracing features for the PC build. Several reporting outlets and community posts flagged that there will be no ray‑tracing options at launch for Death Stranding 2 on PC. If your expectation was path‑traced global illumination or RT reflections, the announced feature set focuses on high‑quality rasterization plus modern upscalers and frame generation instead.
Implications:
  • The absence of ray tracing reduces the incremental GPU requirements for equivalent visual quality, which helps explain the relatively modest GPU baselines for 1440p/60.
  • It also means the PC team prioritized consistent cross‑vendor performance and multiplatform parity over adding RT features that might only benefit one vendor’s highest‑end hardware.
This doesn’t preclude the addition of ray tracing via a future update, but there is no official launch promise for RT effects.
Compatibility cases: ultrawide, handhelds, and non‑standard rigs​
  • Ultrawide owners will appreciate that cutscenes were authored with 21:9 in mind and gameplay supports up to 32:9; this is a rare and welcome fidelity commitment. Expect fewer pillarboxed cutscenes and better native support for wider displays.
  • Handheld PC players should find the Portable preset a good starting point; however, battery life and thermals are still the limiting factors on small devices. Test and tweak local settings for sustained performance rather than burst benchmarks.
  • Older hardware (e.g., GTX 10/16 series) can still run the game at 1080p/30 on Low — but remember that feature parity for upscalers varies by card, so use Pico or vendor-independent modes when hardware lacks DLSS/XeSS acceleration.
What PC players should do now (a simple checklist)​
  • Verify free disk space: reserve at least 200 GB if your drive also hosts Windows and other titles.
  • Update GPU drivers the week of launch — vendors often release game‑specific optimizations.
  • If you use ultrawide or a handheld device, plan time to fine‑tune UI scaling and thermal limits.
  • Consider 32 GB RAM only if you stream or run heavy background tasks; otherwise 16 GB meets the official baseline.
  • If you’re buying or upgrading a GPU specifically for this game, aim for hardware on the High/Very High examples to meet 1440p/4K goals reliably; if you need to choose one vendor now, prefer cards with strong frame‑generation and upscaler support for the best experience.
Risks, unknowns, and what to watch after launch​
  • Driver maturity and availability of vendor features. Frame generation modes and premium upscaler options often ship in driver updates or require specific vendor SDK levels. Expect vendor driver updates and possible post‑launch patches from Nixxes to polish combinations like DLSS 4 + Pico frame gen.
  • Potential typos in official materials. As noted, certain vendor nomenclature in the official table looks inconsistent; verify with updated publisher communications before making hardware purchase decisions based solely on a named AMD SKU from the initial table.
  • Modding and texture packs. PC installs frequently grow when modders add optional high‑res textures; a 150 GB baseline may balloon if the community introduces unofficial packs. Block off storage headroom accordingly.
  • Performance variance in open world sections. Decima engine titles are streaming‑heavy; texture streaming and level streaming can make storage and memory performance as important as raw GPU power. NVMe is recommended.
Why this matters for the PC scene​
Death Stranding 2’s PC port is an example of contemporary AAA PC publishing where the goal is broad compatibility and modern quality features without forcing players into a single vendor ecosystem. By shipping with DLSS 4, FSR 4, XeSS 2, the Pico in‑engine upscaler, and frame generation across technologies, the port embraces the trend of hybrid approaches: render at a lower internal resolution, reconstruct or interpolate frames, and output smooth, high‑fidelity experiences even on midrange hardware.
For the PC community that values choice, that is welcome. It also puts pressure on technical outlets and creators to deliver head‑to‑head comparisons at launch: how does Pico compare to vendor upscalers at various res and quality levels? Which combinations offer the best image for the lowest system cost? Those answers will define whether this port is merely competent or technically remarkable.
Nixxes and Kojima Productions are bringing Death Stranding 2 to PC with a pragmatic, modern approach: a clear set of presets for 1080p, 1440p and 4K targets, cross‑vendor support for upscaling and frame generation, ultrawide and handheld presets, and a substantial 150 GB SSD install. The technical sheet is designed to make the game playable on older midrange hardware while unlocking excellent experiences on high‑end rigs through DLSS 4 and frame generation. That said, a few unresolved details—most notably an inconsistent AMD SKU in the publisher table and the absence of ray tracing — deserve attention and clarification before you buy hardware specifically for the Very High target.
If you care about visual fidelity and performance trade‑offs, wait for the first technical comparisons and driver updates at launch day. If you want to play at a comfortable 1080p or 1440p without investing in cutting‑edge hardware, the official presets suggest you’ll be able to do that — especially if you use the port’s wide upscaler and frame‑generation options. See you on the beach.
Source: KitGuru Death Stranding 2 PC system requirements revealed for 1080p, 1440p and 4K - KitGuru
