livix07
Honorable Member
BugCheck C8, {20002, fffff801e3a01010, ffffd78e10437460, 0}
*** WARNING: Unable to verify timestamp for ndisrfl.sys
*** ERROR: Module load completed but symbols could not be loaded for ndisrfl.sys
Probably caused by : ndisrfl.sys ( ndisrfl+5619 )
Followup:     MachineOwner
try updating the above driver mentioned in the probable cause:
ndisrfl.sys: Intel Technology Access Filter Driver
Why does WinDBG give a different output on my computer:
*** WARNING: Unable to verify timestamp for ndis.sys
*** ERROR: Module load completed but symbols could not be loaded for ndis.sys
Probably caused by : ndis.sys ( ndis+5a76d )
If you're using the MS symbol server it appears there is an issue on the sym serv. You may need to manually download and install the symbols.
SYMSRV: UNC: d:\symbols\ndis.pdb\4DF9FE7F2D73B4E46FD12A45015B834A1\ndis.pdb - path not found
SYMSRV: UNC: d:\symbols\ndis.pdb\4DF9FE7F2D73B4E46FD12A45015B834A1\ndis.pd_ - path not found
SYMSRV: UNC: d:\symbols\ndis.pdb\4DF9FE7F2D73B4E46FD12A45015B834A1\file.ptr - path not found
SYMSRV: HTTPGET: /download/symbols/ndis.pdb/4DF9FE7F2D73B4E46FD12A45015B834A1/ndis.pdb
SYMSRV: HttpQueryInfo: 801901f8 - HTTP_STATUS_GATEWAY_TIMEOUT
SYMSRV: RESULT: 0x801901F8
Perhaps you need to download debugger symbols, not sure.
It debugged for me, had to use 32 bit debugger however.
2: kd> !analyze -v
IRQL_UNEXPECTED_VALUE (c8)
The processor's IRQL is not what it should be at this time.  This is
usually caused by a lower level routine changing IRQL for some period
and not restoring IRQL at the end of that period (eg acquires spinlock
but doesn't release it).
        if UniqueValue is 0 or 1
            2 = APC->KernelRoutine
            3 = APC
            4 = APC->NormalRoutine
Arguments:
Arg1: 0000000000020002, (Current IRQL << 16) | (Expected IRQL << 8) | UniqueValue
Arg2: fffff801e3a01010
Arg3: ffffd78e10437460
Arg4: 0000000000000000
Debugging Details:
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BUILD_VERSION_STRING:  10.0.17134.165 (WinBuild.160101.0800)
SYSTEM_MANUFACTURER:  MSI
SYSTEM_PRODUCT_NAME:  MS-7977
SYSTEM_SKU:  Default string
SYSTEM_VERSION:  1.0
BIOS_VENDOR:  American Megatrends Inc.
BIOS_VERSION:  1.90
BIOS_DATE:  05/11/2016
BASEBOARD_MANUFACTURER:  MSI
BASEBOARD_PRODUCT:  Z170A GAMING M5 (MS-7977)
BASEBOARD_VERSION:  1.0
DUMP_TYPE:  2
DUMP_FILE_ATTRIBUTES: 0x8
  Kernel Generated Triage Dump
BUGCHECK_P1: 20002
BUGCHECK_P2: fffff801e3a01010
BUGCHECK_P3: ffffd78e10437460
BUGCHECK_P4: 0
CPU_COUNT: 8
CPU_MHZ: d50
CPU_VENDOR:  GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 5e
CPU_STEPPING: 3
CPU_MICROCODE: 6,5e,3,0 (F,M,S,R)  SIG: BE'00000000 (cache) BE'00000000 (init)
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  WIN8_DRIVER_FAULT
BUGCHECK_STR:  0xC8
PROCESS_NAME:  IntelTechnolog
CURRENT_IRQL:  2
ANALYSIS_SESSION_HOST:  NEMESIS
ANALYSIS_SESSION_TIME:  07-20-2018 13:37:22.0066
ANALYSIS_VERSION: 10.0.16299.15 x86fre
LAST_CONTROL_TRANSFER:  from fffff80314e727dd to fffff80314e3a430
STACK_TEXT:
ffffd78e`10437358 fffff803`14e727dd : 00000000`000000c8 00000000`00020002 fffff801`e3a01010 ffffd78e`10437460 : nt!KeBugCheckEx
ffffd78e`10437360 fffff803`14cfa0cd : fffff801`e3a01010 ffffd78e`10437460 ffff800a`f7656520 00000000`00000000 : nt!KeExpandKernelStackAndCalloutInternal+0x1786fd
ffffd78e`104373c0 fffff801`e3a5a76d : 1a000004`1480c867 00000000`00000000 00000000`00000000 fffffd3f`feb59d40 : nt!KeExpandKernelStackAndCalloutEx+0x1d
ffffd78e`10437400 fffff801`e3a2b18e : 00000000`00000000 ffff800a`f7656520 00000000`00000001 00000000`00000000 : ndis!NdisIsStatusIndicationCloneable+0x124d
ffffd78e`104374d0 fffff801`e3a086df : ffff800a`9c98ec60 ffff800a`f7656520 ffffd78e`00000000 ffff800a`00000001 : ndis!NdisGetDeviceReservedExtension+0x5e8e
ffffd78e`104375a0 fffff801`e5395619 : ffff800a`9d1c9010 ffff800a`b10c05d0 ffff800a`f6b84580 ffff800a`9bc58960 : ndis!NdisFIndicateReceiveNetBufferLists+0x3f
ffffd78e`104375e0 ffff800a`9d1c9010 : ffff800a`b10c05d0 ffff800a`f6b84580 ffff800a`9bc58960 00000000`00000000 : ndisrfl+0x5619
ffffd78e`104375e8 ffff800a`b10c05d0 : ffff800a`f6b84580 ffff800a`9bc58960 00000000`00000000 ffff800a`f6b84580 : 0xffff800a`9d1c9010
ffffd78e`104375f0 ffff800a`f6b84580 : ffff800a`9bc58960 00000000`00000000 ffff800a`f6b84580 00000000`00000000 : 0xffff800a`b10c05d0
ffffd78e`104375f8 ffff800a`9bc58960 : 00000000`00000000 ffff800a`f6b84580 00000000`00000000 fffff801`e539294b : 0xffff800a`f6b84580
ffffd78e`10437600 00000000`00000000 : ffff800a`f6b84580 00000000`00000000 fffff801`e539294b ffff800a`9bc58960 : 0xffff800a`9bc58960
THREAD_SHA1_HASH_MOD_FUNC:  055b6a724acca365988e2c6b6da8d347e6922266
THREAD_SHA1_HASH_MOD_FUNC_OFFSET:  073351a6e89caf3a7eba71708aa60cecfb34c31a
THREAD_SHA1_HASH_MOD:  d36b1a7cfe3c60986ddd0d0efe2780c076af4dfd
FOLLOWUP_IP:
ndisrfl+5619
fffff801`e5395619 ??              ???
SYMBOL_STACK_INDEX:  6
SYMBOL_NAME:  ndisrfl+5619
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: ndisrfl
IMAGE_NAME:  ndisrfl.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  559eaa0f
STACK_COMMAND:  .thread ; .cxr ; kb
BUCKET_ID_FUNC_OFFSET:  5619
FAILURE_BUCKET_ID:  0xC8_ndisrfl!unknown_function
PRIMARY_PROBLEM_CLASS:  0xC8_ndisrfl!unknown_function
TARGET_TIME:  2018-07-20T06:35:06.000Z
OSBUILD:  17134
OSSERVICEPACK:  165
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK:  784
PRODUCT_TYPE:  1
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
OSEDITION:  Windows 10 WinNt TerminalServer SingleUserTS Personal
OS_LOCALE:
USER_LCID:  0
OSBUILD_TIMESTAMP:  2018-07-06 02:57:56
BUILDDATESTAMP_STR:  160101.0800
BUILDLAB_STR:  WinBuild
BUILDOSVER_STR:  10.0.17134.165
ANALYSIS_SESSION_ELAPSED_TIME:  540
ANALYSIS_SOURCE:  KM
FAILURE_ID_HASH_STRING:  km:0xc8_ndisrfl!unknown_function
FAILURE_ID_HASH:  {20302235-0de7-f870-5df6-1f3817b4dc0e}
This isn't really the best place to discuss your debugger as it's someone else's thread. Best thing to do is open a new thread or visit sysnative.com and read a few of the guides they have on debugging.
I posted it here because it is related to his problem. It is his .dmp file. Anyway you can remove my post.
I always grab mine manually.
I then keep the Symbol file folder backed up (this now runs to the tune of 25GB or so).
