Windows 7 Defender Settings
prkundan
Member
At times my computer runs slow. I even get message that memory is insufficient. When I copy a file from another computer on the n/w the copying becomes very slow. If I run anti-virus scan it displays no virus found. If I close a Word file and try to delete it I get a message File is open, but I see no open file on the screen. I doubt that some one deliberately inducing background processes to occupy my memory and make the whole system slow. I do not know how to defend from this attack. Please guide me as to as to how I should I set Windows defender so that no other comp on the n/w interferes with my comp & I also come to know which comp is interfering with my comp.
Although I wouldn't recommend running Windows defender as your sole protection. Malware isn't always the reason for a slow computer.
  • A dirty fan or heat sink can cause the CPU to throttle
  • Too many processes running a system
  • Cheaper hardware obviously will make for a slower computer
  • Failing hard drive
I'd start by providing your system specs and the running process information.
The latter can be dumped from powershell with the following command Get-Process | Export-Clixml -Path $env:USERPROFILE\Desktop\process.xml
