livinlife
hey i got the 4500 and rebooted with the windows 7, so usually i upgraded from service pack 1 xp, basically i have the drivers disk which i install chipset,audio,and video but none of them work on windows 7. i just wanna go to the internet on it but u cant i was in device manager theres a ! on eternet controller and audio so how can i get drivers for this asap!:confused:
If you check here: Link Removed - Invalid URL
You'll see that no drivers for anything but xp is given....
I think your machine might be a little old for 7 unfortunately... How old is it exactly?
its about a 2001-2002 diminesion 4500 i mean there has to be a way just to get on the internet and audio everything is working clean and good
If you can find any vista drivers then you may get it to work...
