- Thread Author
- #1
I have a learning center with 12 systems that I need to make identical.
There also needs to be an easy plan to update OS & software to keep things identical.
I need some opinions and direction to figure out best way to do this.
Choices: Windows AIK - sysprep and imagex process using a winpe disk
acronis or other image SW.
Processes: incremental updates or total reimaging
One issue is activating software like Photoshop. Total reimage would require reactivation with each update.
I am technical but have never done this before.
thx for ur help
thx for ur help
My preference is to use Ghost Solution Suite ... specifically the ghost32.exe (or ghost64.exe) running from a Win7PE_SE iso that booted off a USB key. If you want an all in one do everything for you solution Ghost Solution Suite or Acronis get mentioned allot. Several years ago a company I worked for was using Altiris Deployment Solution which looked to be the best for imaging thousands of desktops ... but wuold still be cool for only 12.
Similar threads
- Replies
- 1
- Views
- 679
- Article
- Replies
- 0
- Views
- 48
- Replies
- 0
- Views
- 901
- Replies
- 8
- Views
- 4K
