Windows 7 Desktop does not save theme/ KVM
kevin from Chi-town
Has anyone else had this happen. You set a particular theme and it disappears on reboot. Then...downloaded themes from MS disappear.
Also, I'm running this test pc next to 2 pcs running XP pro. All of these are hooked up to a KVM. Every other time I boot on the win 7 pc, theres no response from the Logitech wireless keyboard and mouse.
Anybody else?
I wish I was drinking, then there would be an excuse!
It sounds like you're experiencing a couple of issues with your Windows 7 setup. Let's address each problem you mentioned:
Issue 1: Theme Disappearance on Reboot​
When a theme you set keeps disappearing on reboot, it could be due to a few reasons:
  • Corrupted User Profile: Your user profile might be corrupted, causing settings not to save correctly.
  • Third-Party Software Conflict: Some third-party software might be interfering with the theme settings.
  • Permissions Issue: There could be permission problems preventing the theme from saving changes.
Issue 2: Downloaded Themes Disappearing​
If themes downloaded from Microsoft vanish, it might be because:
  • Corruption: The downloaded...
  • Corruption: The downloaded themes might be corrupt.
  • Storage Issue: Themes might not be saving correctly due to storage problems.
Issue 3: Logitech Wireless Keyboard and Mouse Issue​
The intermittent response from your Logitech wireless keyboard and mouse on boot could be caused by:
  • Driver or Software Issue: The drivers for the keyboard and mouse might need updating or reinstallation.
  • Interference: Wireless interference could be disrupting the connection.
  • Battery: Check if the batteries in the keyboard and mouse are functioning well.
Suggestions to Troubleshoot:​
  1. User Profile Check: Create a new user profile and see if the issues still occur.
  2. Software Check: Disable third-party software temporarily and check if the problems persist.
  3. Driver Update: Ensure your Logitech keyboard and mouse have the latest drivers installed.
  4. Battery Replacement: If the devices are battery-operated, replace the batteries to rule out power issues.
    Community Input:​
    While I couldn't find specific threads related to your exact issues, you might find helpful insights and solutions from the Windows community. Feel free to ask for assistance on the Windows Forum or other tech support platforms for more tailored advice. It's essential to address these issues to enhance your user experience and avoid frustrations. Let me know if you need further assistance or guidance on any specific troubleshooting steps!
