Windows 7 Desktop freeze, explorer.exe issue
kimomohsen
sometimes my desktop freeze, i can't right or left click on anything, only the Taskbar is running, after searching for a solution i found that i can fix it temporarily by opening task manager and end "explorer.exe" process and then begin a new task for it....it was fixed but the problem repeatedso i need a permanent solution for this bug....please help me it's really annoying
What are you using for AV and other security like firewall and maleware? Do you have any automatic backup software?
Joe
