Windows 7 Desktop slower than Laptop
rns3011
Anyone know why my Desktop computer which has much better hardware would run Windows7 slower than my Laptop?
Desktop is:
3ghz dual core
Asus P5K motherboard
4GB RAM
250GB Western Digital 7200 RPM SATA 3.0
8800 GT
Laptop is:
Dell 1520
2ghz dual core
2GB RAM
150GB Western Digital 7200 RPM SATA 3.0
m8600GT
The main issue is that the entire OS just seems slow and sluggish on my desktop, while the laptop is just screaming right along.
Starting up is quick and smooth on the laptop, and it takes forever for my desktop to start up. Even shutting down is slow. Just doesn't make sense.
The only thing I could really think of is that perhaps the standard drivers are playing better with my Laptop than in my Desktop. Anyone have any similar situation or know why my Desktop is so much slower?
dm00ney1
Things to consider,
Age of the equipment, which is older, which is newer
Type of install (where both same type, new or upgrade)
Drivers definetely a possibility. would upgrade to check.
also you have 4g of ram in the desktop, but what kind/speed and such.
More info would be useful in Troubleshooting
rns3011
Desktop is newer and better hardware all around. Both installs of Win7 are from the same exact DVD. Build 7000 to be exact.
Here's my DXDIAG from my Laptop.
System Information
Time of this report: 2/21/2009, 00:05:03
Machine name: LAPTOPWIN7
Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7000) (7000.winmain_win7beta.081212-1400)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: Inspiron 1520
BIOS: Phoenix ROM BIOS PLUS Version 1.10 A09
Processor: Intel(R) Core(TM)2 Duo CPU T7300 @ 2.00GHz (2 CPUs), ~2.0GHz
Memory: 2046MB RAM
Page File: 1466MB used, 2925MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7000.0000 32bit Unicode
Display Devices
Card name: NVIDIA GeForce 8600M GT (Prerelease - WDDM 1.1)
Manufacturer: NVIDIA
Chip type: GeForce 8600M GT
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0407&SUBSYS_01F11028&REV_A1
Display Memory: 1012 MB
Dedicated Memory: 245 MB
Shared Memory: 767 MB
Current Mode: 1680 x 1050 (32 bit) (60Hz)
Monitor: Generic PnP Monitor
Native Mode: 1680 x 1050 (60.000Hz)
Driver Name: nvd3dum.dll,nvwgf2um.dll
Driver Version: 7.15.0011.7923 (English)
DDI Version: 10
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 11/20/2008 21:25:00, 6004736 bytes
I could post all of it, but I doubt it would be too much more helpful. I'll post my Desktop in a few as soon as I get it up and running again.
I just finished re-installing Windows7 again.
I made two slight changes this time:
1. I turned off AHCI and set my SATA configuration to IDE in the BIOS
2. I used my Vista CD to delete, create, and format a new Partition for the Windows7 to be installed on.
So far the Desktop seems to be running up to what I expected it to run at.
