Gekiganger
This is my 1st time here so, hello nice to meet you all.
I have a corega wireless adapter that is plugged into my pc as an access point for my PSP and DS but I keep getting the problem of "DHCP is not enabled for wireless networking" and it says the wireless adapter doesn't have a valid IP address.
In services the DHCP is set to started.
here are the results of the ipconfig/all
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Jerome>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Jerome-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : zaq.ne.jp
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : CG-WLUSBNM
Physical Address. . . . . . . . . : 00-0A-79-F6-E7-EA
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
IPv6 Address. . . . . . . . . . . : 2002:3a55:2531:13:d4d3:5dc1:3f8a:d25c(Pre
ferred)
Site-local IPv6 Address . . . . . : fec0::13:d4d3:5dc1:3f8a:d25c%2(Preferred)
Temporary IPv6 Address. . . . . . : 2002:3a55:2531:13:2d72:7d3:e006:d551(Pref
erred)
Link-local IPv6 Address . . . . . : fe80::d4d3:5dc1:3f8a:d25c%19(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.100.1(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . :
DHCPv6 IAID . . . . . . . . . . . : 318769785
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-14-50-03-EE-00-21-85-18-A9-BF
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%2
fec0:0:0:ffff::2%2
fec0:0:0:ffff::3%2
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : zaq.ne.jp
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 00-21-85-18-A9-BF
DHCP Enabled. . . . . . . . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::20c7:8c5d:9658:c6b3%12(Preferred)
IPv4 Address. . . . . . . . . . . : 58.85.37.49(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.254.0
Lease Obtained. . . . . . . . . . : 2010年11月12日 23:53:27
Lease Expires . . . . . . . . . . : 2010年11月13日 11:02:03
Default Gateway . . . . . . . . . : 58.85.36.1
DHCP Server . . . . . . . . . . . : 220.152.39.84
DHCPv6 IAID . . . . . . . . . . . : 201335173
DNS Servers . . . . . . . . . . . : 122.197.254.7
122.197.254.10
Tunnel adapter isatap.zaq.ne.jp:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter Local Area Connection* 12:
Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:7f:2ca4:c5aa:dace(Prefer
red)
Link-local IPv6 Address . . . . . : fe80::7f:2ca4:c5aa:dace%11(Preferred)
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.{F1285EDB-14E6-4A7A-B6B2-9012F945E121}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter 6TO4 Adapter:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #2
IPv6 Address. . . . . . . . . . . : 2002:3a55:2531::3a55:2531(Preferred)
Default Gateway . . . . . . . . . : 2002:c058:6301::c058:6301
122.197.254.10
I've also set the Internet Protocol to Obtain an IP address automatically and Obtain DNS server address automatically but this still doesn't solve the problem.
I also set up the connection as an Ad-Hoc network and enable Internet Connection Sharing...but still no joy.....
What does the psp support?
What kind of security does it have? Is it encrypted?
Yes, your wireless Access Point hotspot is encrypted with WPA2-Personal (AES) encryption. Your security is as strong as the Password that you select. The Ad Hoc mode hotspots are protected with WEP encryption.
How do I turn off encryption?
Encryption is required with Connectify, we take your safety and security seriously. Also, Microsoft only built WPA2 encryption into Windows 7 for use in Access Points, so device support for other encryptions is simply not available.
SOURCE: Connectify - Turn your Windows 7 laptop into a Wi-Fi Hotspot - Frequently Asked Questions
Take a look at this article and see if it will help you do what you're looking to do. You may be able to employ Wireless Hosted Networking, either natively with Windows 7 or by using Connectify (link at the bottom of this article). Keep us posted.
Link Removed - Invalid URL
when I use Connectify, my psp says that the security type is not supported
and in the cmd prompt I get this message
C:\Windows\system32>netsh wlan start hostednetwork
The hosted network couldn't be started.
The group or resource is not in the correct state to perform the requested opera
tion.
