Loading Dump File [C:\Users\PalmDesert\AppData\Local\Temp\SALF04.tmp\052913-20389-01.dmp]
Symbol search path is: SRV*a:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (6 procs) Free x64
Built by: 7601.18113.amd64fre.win7sp1_gdr.130318-1533
Machine Name:
Kernel base = 0xfffff800`02e0c000 PsLoadedModuleList = 0xfffff800`0304f670
Debug session time: Wed May 29 11:49:43.508 2013 (UTC - 4:00)
System Uptime: 0 days 0:44:17.710
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
ERROR: FindPlugIns 8007007b
* Bugcheck Analysis *
BugCheck FE, {5, fffffa8005bac1a0, 10024397, fffffa8006168a68}
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: usbport!_DEVICE_EXTENSION ***
Probably caused by : usbohci.sys ( usbohci!OHCI_PollAsyncEndpoint+99 )
Followup: MachineOwner
5: kd> .reload
5: kd> !analyze -v
BUGCODE_USB_DRIVER (fe)
USB Driver bugcheck, first parameter is USB bugcheck code.
Arguments:
Arg1: 0000000000000005, USBBUGCODE_INVALID_PHYSICAL_ADDRESS The host controller is
using a physical memory address that was not allocated by
the USBport driver.
Arg2: fffffa8005bac1a0, Device extension pointer of the host controller
Arg3: 0000000010024397, PCI Vendor,Product id for the controller
Arg4: fffffa8006168a68, Pointer to Endpoint data structure
Debugging Details:
*** work. ***
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0xFE
PROCESS_NAME: System
CURRENT_IRQL: 2
LAST_CONTROL_TRANSFER: from fffff8800519ff3e to fffff80002e81c00
STACK_TEXT:
fffff880`02eb0ad8 fffff880`0519ff3e : 00000000`000000fe 00000000`00000005 fffffa80`05bac1a0 00000000`10024397 : nt!KeBugCheckEx
fffff880`02eb0ae0 fffff880`04240a45 : 00000000`00145180 fffffa80`06168820 00000000`00000000 fffff880`05a5d000 : USBPORT!USBPORTSVC_MapHwPhysicalToVirtual+0x18a
fffff880`02eb0b20 fffff880`04242737 : fffffa80`06168a68 fffffa80`06168820 00000000`00000000 fffffa80`05bac1a0 : usbohci!OHCI_PollAsyncEndpoint+0x99
fffff880`02eb0b80 fffff880`05173e8b : 00000000`00000002 fffffa80`06168820 fffffa80`05bac1a0 00000000`00000000 : usbohci!OHCI_PollEndpoint+0x3f
fffff880`02eb0bb0 fffff880`051789d1 : 00000000`00000010 00000000`00000004 fffffa80`06168820 fffffa80`05bac050 : USBPORT!MPf_PollEndpoint+0x9b
fffff880`02eb0be0 fffff880`05184077 : fffffa80`05bac1a0 00000000`00000010 fffffa80`0000000e 00000000`00000000 : USBPORT!USBPORT_iSetGlobalEndpointStateTx+0x7c1
fffff880`02eb0c40 fffff880`05174f89 : fffffa80`05bac050 00000000`00000000 fffffa80`05baca02 fffffa80`05baca18 : USBPORT!USBPORT_Core_UsbHcIntDpc_Worker+0x1c3
fffff880`02eb0ca0 fffff800`02e8c2fc : fffff880`02e88180 fffffa80`05baca18 fffffa80`05baca30 00000000`00000000 : USBPORT!USBPORT_Xdpc_Worker+0x1d9
fffff880`02eb0cd0 fffff800`02e7990a : fffff880`02e88180 fffff880`02e93040 00000000`00000000 fffff880`05174db0 : nt!KiRetireDpcList+0x1bc
fffff880`02eb0d80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND: kb
FOLLOWUP_IP:
fffff880`04240a45 8bd3 mov edx,ebx
SYMBOL_STACK_INDEX: 2
SYMBOL_NAME: usbohci!OHCI_PollAsyncEndpoint+99
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: usbohci
IMAGE_NAME: usbohci.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4a5bcc06
FAILURE_BUCKET_ID: X64_0xFE_INVALID_PHYSICAL_ADDR_usbohci!OHCI_PollAsyncEndpoint+99
5: kd> lmvm usbohci
start end module name
fffff880`0423e000 fffff880`04249000 usbohci (pdb symbols) a:\symbols\usbohci.pdb\E503D4CE218541B3BAFF734DA3580FAA1\usbohci.pdb
Loaded symbol image file: usbohci.sys
Mapped memory image file: a:\symbols\usbohci.sys\4A5BCC06b000\usbohci.sys
Image path: \SystemRoot\system32\DRIVERS\usbohci.sys
Image name: usbohci.sys
Timestamp: Mon Jul 13 20:06:30 2009 (4A5BCC06)
CheckSum: 0000E008
ImageSize: 0000B000
File version: 6.1.7600.16385
Product version: 6.1.7600.16385
File flags: 0 (Mask 3F)
File OS: 40004 NT Win32
File type: 2.0 Dll
File date: 00000000.00000000
Translations: 0409.04b0
CompanyName: Microsoft Corporation
ProductName: Microsoft® Windows® Operating System
InternalName: USBOHCI.sys
OriginalFilename: USBOHCI.sys
ProductVersion: 6.1.7600.16385
FileVersion: 6.1.7600.16385 (win7_rtm.090713-1255)
FileDescription: OHCI USB Miniport Driver
LegalCopyright: © Microsoft Corporation. All rights reserved.
5: kd> lmntsm
fffff880`04200000 fffff880`0423e000 1394ohci 1394ohci.sys Sat Nov 20 05:44:56 2010 (4CE7A6A8)
fffff880`00eb6000 fffff880`00f0d000 ACPI ACPI.sys Sat Nov 20 04:19:16 2010 (4CE79294)
fffff880`03b21000 fffff880`03baa000 afd afd.sys Tue Dec 27 22:59:20 2011 (4EFA9418)
fffff880`04600000 fffff880`04616000 AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`04083000 fffff880`04098000 amdppm amdppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`00daf000 fffff880`00dba000 amdxata amdxata.sys Fri Mar 19 12:18:18 2010 (4BA3A3CA)
fffff880`0425a000 fffff880`04262000 ASACPI ASACPI.sys Wed Jul 15 23:31:29 2009 (4A5E9F11)
fffff880`00d7c000 fffff880`00d85000 atapi atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00d85000 fffff880`00daf000 ataport ataport.SYS Sat Nov 20 04:19:15 2010 (4CE79293)
fffff880`0643c000 fffff880`065f4000 athurx athurx.sys Thu Sep 17 13:30:02 2009 (4AB2721A)
fffff960`00920000 fffff960`00981000 ATMFD ATMFD.DLL unavailable (00000000)
fffff880`05431000 fffff880`05451000 avgntflt avgntflt.sys Fri Feb 22 04:33:47 2013 (51273B7B)
fffff880`04039000 fffff880`0405d000 avipbb avipbb.sys Fri Feb 22 04:33:53 2013 (51273B81)
fffff880`0402f000 fffff880`04039000 avkmgr avkmgr.sys Fri Feb 22 04:33:49 2013 (51273B7D)
fffff880`0124c000 fffff880`01253000 Beep Beep.SYS Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`0401e000 fffff880`0402f000 blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`06d2a000 fffff880`06d48000 bowser bowser.sys Tue Feb 22 23:55:04 2011 (4D649328)
fffff960`007c0000 fffff960`007e7000 cdd cdd.dll unavailable (00000000)
fffff880`00ca2000 fffff880`00d62000 CI CI.dll Sat Nov 20 08:12:36 2010 (4CE7C944)
fffff880`011ce000 fffff880`011fe000 CLASSPNP CLASSPNP.SYS Sat Nov 20 04:19:23 2010 (4CE7929B)
fffff880`00c44000 fffff880`00ca2000 CLFS CLFS.SYS Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01000000 fffff880`01072000 cng cng.sys Fri Jun 01 23:25:51 2012 (4FC987BF)
fffff880`051dd000 fffff880`051ed000 CompositeBus CompositeBus.sys Sat Nov 20 05:33:17 2010 (4CE7A3ED)
fffff880`06428000 fffff880`06436000 crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`0417b000 fffff880`041fe000 csc csc.sys Sat Nov 20 04:27:12 2010 (4CE79470)
fffff880`04000000 fffff880`0401e000 dfsc dfsc.sys Sat Nov 20 04:26:31 2010 (4CE79447)
fffff880`0416c000 fffff880`0417b000 discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01236000 fffff880`0124c000 disk disk.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`055a0000 fffff880`055c2000 drmk drmk.sys Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`06217000 fffff880`06220000 dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`065f4000 fffff880`06600000 dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`055e1000 fffff880`055f4000 dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`055f4000 fffff880`05600000 Dxapi Dxapi.sys Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`0426a000 fffff880`0435e000 dxgkrnl dxgkrnl.sys Tue Apr 09 23:28:09 2013 (5164DC49)
fffff880`0435e000 fffff880`043a4000 dxgmms1 dxgmms1.sys Tue Apr 09 23:27:15 2013 (5164DC13)
fffff880`04163000 fffff880`0416c000 EIO64 EIO64.sys Tue Jul 21 22:34:42 2009 (4A667AC2)
fffff880`01122000 fffff880`01136000 fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`010d6000 fffff880`01122000 fltmgr fltmgr.sys Sat Nov 20 04:19:24 2010 (4CE7929C)
fffff880`0122c000 fffff880`01236000 Fs_Rec Fs_Rec.sys Wed Feb 29 22:41:06 2012 (4F4EEFD2)
fffff880`00dba000 fffff880`00df4000 fvevol fvevol.sys Sat Nov 20 04:24:06 2010 (4CE793B6)
fffff880`015a5000 fffff880`015ee000 fwpkclnt fwpkclnt.sys Wed Jan 02 22:06:48 2013 (50E4F5C8)
fffff800`033f2000 fffff800`0343b000 hal hal.dll Sat Nov 20 08:00:25 2010 (4CE7C669)
fffff880`043a4000 fffff880`043c8000 HDAudBus HDAudBus.sys Sat Nov 20 05:43:42 2010 (4CE7A65E)
fffff880`055c8000 fffff880`055e1000 HIDCLASS HIDCLASS.SYS Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`0620e000 fffff880`06216080 HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`06200000 fffff880`0620e000 hidusb hidusb.sys Sat Nov 20 05:43:49 2010 (4CE7A665)
fffff880`06c61000 fffff880`06d2a000 HTTP HTTP.sys Sat Nov 20 04:24:30 2010 (4CE793CE)
fffff880`0141a000 fffff880`01423000 hwpolicy hwpolicy.sys Sat Nov 20 04:18:54 2010 (4CE7927E)
fffff880`07aac000 fffff880`07ab5000 IOMap64 IOMap64.sys Thu Feb 04 20:55:34 2010 (4B6B7A96)
fffff880`040d3000 fffff880`040e2000 kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`0641a000 fffff880`06428000 kbdhid kbdhid.sys Sat Nov 20 05:33:25 2010 (4CE7A3F5)
fffff800`00bb0000 fffff800`00bba000 kdcom kdcom.dll Sat Feb 05 11:52:49 2011 (4D4D8061)
fffff880`0546c000 fffff880`054af000 ks ks.sys Sat Nov 20 05:33:23 2010 (4CE7A3F3)
fffff880`01200000 fffff880`0121b000 ksecdd ksecdd.sys Fri Jun 01 22:50:23 2012 (4FC97F6F)
fffff880`0157b000 fffff880`015a5000 ksecpkg ksecpkg.sys Fri Jun 01 23:27:11 2012 (4FC9880F)
fffff880`055c2000 fffff880`055c7200 ksthunk ksthunk.sys Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`024d1000 fffff880`024e6000 lltdio lltdio.sys Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0540e000 fffff880`05431000 luafv luafv.sys Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c23000 fffff880`00c30000 mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`05400000 fffff880`0540e000 monitor monitor.sys Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`0545b000 fffff880`0546a000 mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`0640d000 fffff880`0641a000 mouhid mouhid.sys Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00d62000 fffff880`00d7c000 mountmgr mountmgr.sys Sat Nov 20 04:19:21 2010 (4CE79299)
fffff880`06d48000 fffff880`06d60000 mpsdrv mpsdrv.sys Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`06d60000 fffff880`06d8d000 mrxsmb mrxsmb.sys Tue Apr 26 22:40:38 2011 (4DB78226)
fffff880`06d8d000 fffff880`06ddb000 mrxsmb10 mrxsmb10.sys Fri Jul 08 22:46:28 2011 (4E17C104)
fffff880`06ddb000 fffff880`06dff000 mrxsmb20 mrxsmb20.sys Tue Apr 26 22:39:37 2011 (4DB781E9)
fffff880`03ad6000 fffff880`03ae1000 Msfs Msfs.SYS Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f16000 fffff880`00f20000 msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01136000 fffff880`01194000 msrpc msrpc.sys Sat Nov 20 04:21:56 2010 (4CE79334)
fffff880`04158000 fffff880`04163000 mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01408000 fffff880`0141a000 mup mup.sys Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01428000 fffff880`0151b000 ndis ndis.sys Sat Nov 20 04:23:30 2010 (4CE79392)
fffff880`0463a000 fffff880`04646000 ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`02539000 fffff880`0254c000 ndisuio ndisuio.sys Sat Nov 20 05:50:08 2010 (4CE7A7E0)
fffff880`04646000 fffff880`04675000 ndiswan ndiswan.sys Sat Nov 20 05:52:32 2010 (4CE7A870)
fffff880`0551b000 fffff880`05530000 NDProxy NDProxy.SYS Sat Nov 20 05:52:20 2010 (4CE7A864)
fffff880`03a3c000 fffff880`03a4b000 netbios netbios.sys Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`03baa000 fffff880`03bef000 netbt netbt.sys Sat Nov 20 04:23:18 2010 (4CE79386)
fffff880`0151b000 fffff880`0157b000 NETIO NETIO.SYS Wed Aug 22 11:11:28 2012 (5034F6A0)
fffff880`03ae1000 fffff880`03af2000 Npfs Npfs.SYS Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0414c000 fffff880`04158000 nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02e0c000 fffff800`033f2000 nt ntkrnlmp.exe Mon Mar 18 23:21:42 2013 (5147D9C6)
fffff880`01253000 fffff880`013f5000 Ntfs Ntfs.sys Fri Apr 12 07:54:36 2013 (5167F5FC)
fffff880`010cc000 fffff880`010d5000 Null Null.SYS Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`05530000 fffff880`05563000 nvhda64v nvhda64v.sys Mon Feb 25 00:27:35 2013 (512AF647)
fffff880`04691000 fffff880`05172000 nvlddmkm nvlddmkm.sys Sun May 12 15:09:45 2013 (518FE8F9)
fffff880`024e6000 fffff880`02539000 nwifi nwifi.sys Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`03a00000 fffff880`03a26000 pacer pacer.sys Sat Nov 20 05:52:18 2010 (4CE7A862)
fffff880`00f60000 fffff880`00f75000 partmgr partmgr.sys Sat Mar 17 01:06:09 2012 (4F641BC1)
fffff880`00f20000 fffff880`00f53000 pci pci.sys Sat Nov 20 04:19:11 2010 (4CE7928F)
fffff880`00fe6000 fffff880`00fed000 pciide pciide.sys Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00fed000 fffff880`00ffd000 PCIIDEX PCIIDEX.SYS Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0121b000 fffff880`0122c000 pcw pcw.sys Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`02400000 fffff880`024a6000 peauth peauth.sys Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`05563000 fffff880`055a0000 portcls portcls.sys Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c30000 fffff880`00c44000 PSHED PSHED.dll Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`04616000 fffff880`0463a000 rasl2tp rasl2tp.sys Sat Nov 20 05:52:34 2010 (4CE7A872)
fffff880`04675000 fffff880`04690000 raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`04098000 fffff880`040b9000 raspptp raspptp.sys Sat Nov 20 05:52:31 2010 (4CE7A86F)
fffff880`040b9000 fffff880`040d3000 rassstp rassstp.sys Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`040fb000 fffff880`0414c000 rdbss rdbss.sys Sat Nov 20 04:27:51 2010 (4CE79497)
fffff880`051ed000 fffff880`051f8000 rdpbus rdpbus.sys Mon Jul 13 20:17:46 2009 (4A5BCEAA)
fffff880`03abb000 fffff880`03ac4000 RDPCDD RDPCDD.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`03ac4000 fffff880`03acd000 rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`03acd000 fffff880`03ad6000 rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01194000 fffff880`011ce000 rdyboost rdyboost.sys Sat Nov 20 04:43:10 2010 (4CE7982E)
fffff880`0254c000 fffff880`02564000 rspndr rspndr.sys Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`043c8000 fffff880`043fa000 Rt64win7 Rt64win7.sys Thu Feb 26 04:04:13 2009 (49A65B0D)
fffff880`06c00000 fffff880`06c0b000 secdrv secdrv.SYS Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`051c8000 fffff880`051d4000 serenum serenum.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`03a4b000 fffff880`03a68000 serial serial.sys Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`01400000 fffff880`01408000 spldr spldr.sys Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`07ab5000 fffff880`07b26000 spsys spsys.sys Mon May 11 13:20:58 2009 (4A085E7A)
fffff880`07a14000 fffff880`07aac000 srv srv.sys Thu Apr 28 23:06:06 2011 (4DBA2B1E)
fffff880`02564000 fffff880`025cd000 srv2 srv2.sys Thu Apr 28 23:05:46 2011 (4DBA2B0A)
fffff880`06c0b000 fffff880`06c3c000 srvnet srvnet.sys Thu Apr 28 23:05:35 2011 (4DBA2AFF)
fffff880`0546a000 fffff880`0546b480 swenum swenum.sys Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01600000 fffff880`01800000 tcpip tcpip.sys Wed Jan 02 22:11:48 2013 (50E4F6F4)
fffff880`06c3c000 fffff880`06c4e000 tcpipreg tcpipreg.sys Sat Nov 20 05:51:48 2010 (4CE7A844)
fffff880`03b14000 fffff880`03b21000 TDI TDI.SYS Sat Nov 20 04:22:06 2010 (4CE7933E)
fffff880`03af2000 fffff880`03b14000 tdx tdx.sys Sat Nov 20 04:21:54 2010 (4CE79332)
fffff880`040e7000 fffff880`040fb000 termdd termdd.sys Sat Nov 20 06:03:40 2010 (4CE7AB0C)
fffff960`004e0000 fffff960`004ea000 TSDDD TSDDD.dll unavailable (00000000)
fffff880`0405d000 fffff880`04083000 tunnel tunnel.sys Sat Nov 20 05:51:50 2010 (4CE7A846)
fffff880`054af000 fffff880`054c1000 umbus umbus.sys Sat Nov 20 05:44:37 2010 (4CE7A695)
fffff880`063dc000 fffff880`063f9000 usbccgp usbccgp.sys Sat Nov 20 05:44:03 2010 (4CE7A673)
fffff880`063f9000 fffff880`063faf00 USBD USBD.SYS Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`04249000 fffff880`0425a000 usbehci usbehci.sys Sat Nov 20 05:43:54 2010 (4CE7A66A)
fffff880`054c1000 fffff880`0551b000 usbhub usbhub.sys Sat Nov 20 05:44:30 2010 (4CE7A68E)
fffff880`0423e000 fffff880`04249000 usbohci usbohci.sys Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`05172000 fffff880`051c8000 USBPORT USBPORT.SYS Sat Nov 20 05:44:00 2010 (4CE7A670)
fffff880`00f53000 fffff880`00f60000 vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`00c13000 fffff880`00c21000 vga vga.sys Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`06225000 fffff880`063dc000 viahduaa viahduaa.sys Sat May 15 06:22:39 2010 (4BEE75EF)
fffff880`03a86000 fffff880`03aab000 VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`015ee000 fffff880`015fe000 vmstorfl vmstorfl.sys Sat Nov 20 04:57:30 2010 (4CE79B8A)
fffff880`00f75000 fffff880`00f8a000 volmgr volmgr.sys Sat Nov 20 04:19:28 2010 (4CE792A0)
fffff880`00f8a000 fffff880`00fe6000 volmgrx volmgrx.sys Sat Nov 20 04:20:43 2010 (4CE792EB)
fffff880`01072000 fffff880`010be000 volsnap volsnap.sys Sat Nov 20 04:20:08 2010 (4CE792C8)
fffff880`06400000 fffff880`0640d000 vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`03a26000 fffff880`03a3c000 vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`03a68000 fffff880`03a83000 wanarp wanarp.sys Sat Nov 20 05:52:36 2010 (4CE7A874)
fffff880`03aab000 fffff880`03abb000 watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e03000 fffff880`00ea7000 Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00ea7000 fffff880`00eb6000 WDFLDR WDFLDR.SYS Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`03bef000 fffff880`03bf8000 wfplwf wfplwf.sys Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00000000 fffff960`00317000 win32k win32k.sys unavailable (00000000)
fffff880`051d4000 fffff880`051dd000 wmiacpi wmiacpi.sys Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f0d000 fffff880`00f16000 WMILIB WMILIB.SYS Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`024b0000 fffff880`024d1000 WudfPf WudfPf.sys Sat Nov 20 05:42:44 2010 (4CE7A624)
Unloaded modules:
fffff880`07b26000 fffff880`07b30000 kerneld.amd6
Checksum: 00000000
ImageSize: 0000A000
fffff880`010be000 fffff880`010cc000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000E000
fffff880`00df4000 fffff880`00e00000 dump_ataport
Checksum: 00000000
ImageSize: 0000C000
fffff880`013f5000 fffff880`013fe000 dump_atapi.s
Checksum: 00000000
ImageSize: 00009000
fffff880`00c00000 fffff880`00c13000 dump_dumpfve
Checksum: 00000000
ImageSize: 00013000
fffff880`03a17000 fffff880`03a41000 cdrom.sys
Checksum: 00000000
ImageSize: 0002A000
