Marko
Windows 7 is great, but it is annoynig whet it does everything for you.
A little problem like this, i have digital camera canon a630 and i want to revover some photos from summer 2009 that are deleted and tried 10 programs for recovery and special ones youst for digital cameras and memory cards but any of these programs cannot recognize my camera as usb memory card, it browses my computer and shows olny hard drive, but when i open my computer it shows digital camera name and inside removable sorage !!
its anoying thing ! please help ??
Thank you
It seems like you are facing an issue with recovering deleted photos from your Canon A630 digital camera on Windows 7. The problem you are experiencing might be related to how Windows 7 is recognizing your camera. Here are a few steps you can try to address the issue: 1. Change USB Connection Mode: Sometimes, digital cameras have different USB connection modes. You can try changing the USB connection mode on your camera. Look for an option on your camera settings that allows you to switch between different USB connection modes like Mass Storage or PTP (Picture Transfer Protocol). 2. Install Camera Driver: Ensure that you have the necessary drivers installed for your Canon A630 digital camera on your Windows 7 PC. Download...
It seems like you are facing an issue with recovering deleted photos from your Canon A630 digital camera on Windows 7. The problem you are experiencing might be related to how Windows 7 is recognizing your camera. Here are a few steps you can try to address the issue: 1. Change USB Connection Mode: Sometimes, digital cameras have different USB connection modes. You can try changing the USB connection mode on your camera. Look for an option on your camera settings that allows you to switch between different USB connection modes like Mass Storage or PTP (Picture Transfer Protocol). 2. Install Camera Driver: Ensure that you have the necessary drivers installed for your Canon A630 digital camera on your Windows 7 PC. Download and install the specific drivers for your camera model from the official Canon website. 3. Use a Card Reader: If the direct connection from the camera to the computer is not working as expected, consider using a card reader. Remove the memory card from your Canon A630 camera and insert it into a card reader connected to your computer. This way, you can access the memory card directly and use data recovery software to recover your deleted photos. 4. Data Recovery Software: Since you mentioned that the recovery programs you tried couldn't recognize your camera as a USB memory card, using a card reader might provide a workaround. Once you can access the memory card through the card reader, try using reputable data recovery software like Recuva, PhotoRec, or Disk Drill to recover your deleted photos. 5. Check Device Manager: Ensure that Windows 7 recognizes your camera properly. You can check the Device Manager to see if your Canon A630 camera is listed correctly under USB devices. If there are any issues indicated in Device Manager, update or reinstall the drivers for the camera. By following these steps, you may be able to recover the photos from your Canon A630 digital camera successfully. If you continue to experience difficulties or need further assistance, feel free to provide more details for additional help.
