Disable UAC for Specific Applicatons (shortcut), Not enitre System
jco
Honorable Member
I'm running Windows 7 Ultimate, 64 bit:
Is there a way to change the UAC settings or disable it for a particular shortcut (application) on my computer? I don't want to change all UAC controls for my system because I still want the added security, however, on applications that I know are installed on my computer, there should be a way. Then I won't be nagged each time.
Thanks
Thanks
I've seen event scheduler hacks that claim to do this but I wouldn't really trust them.
The safest answer is "No, they don't let you do that".
And for what it's worth... I would give my eye teeth for a "while list" in the UAC.
Trouble
Noob Whisperer
After some research, I found this article which seems like it may get you where you want.
The process is a little convoluted, but you may want to give it a go. By the way the pictures in the article may appear broken, but if you click on them they'll open or even right click and choose open in new window or tab
Run a Program with Administrative Privileges without UAC Prompts — MAXIMUMpcguides – Windows Vista tips, tricks, help, and how-to guides
hope it helps
jco
Honorable Member
Yes I saw the Scheduler hack too and did not want to go that route. You're right about the "UAC Acceptance List". That would be great. Lets give that idea to Microsoft. Maybe they will fix it in 3-4 years.
Thanks
jco
Honorable Member
I downloaded and gave it a try. It did not work. I will play with it more in the next few days with other programs and see if it works at all. Thanks
jco
Honorable Member
#8
That works great and was easy to do.
Thanks very much.
#9
You are welcome. : )
Joe S
#10
IMHO, UAC can be safely disabled (Never Notify) if you have good anti-virus software, spyware protection and firewall installed.
I agree especially on a single user machine.
Joe
#11
Joe
May I say "X 2" ?
I run a really tight ship, so to speak, and I surely don't need no OS asking me "are you sure" every five minutes.
I just run a little script to "Disable UAC", and that does it.
By the way, for anyone using AVG 9.0 Pro, the new AVG Anti Virus 2011 is now available for download.
I just got it yesterday. I love it!
Spybot Search & Destroy has a new version out.
Cheers Mates!
Old Timer
