jimc52
Hi. I have 5 hard disks on my computer (four SATA internal + one external). I was able to get disk management in W7 to work one time. It reported one of my hard disks incorrectly, telling me I have a 2 Teribyte drive when I do not have it. I attempted a reformat (NTFS, default). Anyway, after doing this, I decided to reboot, hoping that W7 would re-detect this and then correct the actual value of the disk (a 500 Gig HD). Since rebooting (I have done it several times), when I start Computer Management console and click on Disk Management, windows says at the bottom of the console "connecting to Virtual Disk Service..." but it never connects. It just remains in limbo. I checked system services and all the dependencies and they are all enabled, so its not a matter of some system service being disabled.
Has anyone else had this problem of not being able to use Disk Management to see the drives? Has anyone had an incorrectly reported hard disk volume? How did you solve this problem? What can I do to get W7 Disk Management to work again?
Thanks
Thanks
